--- ray/src/px/pcond3.c 1996/10/03 16:52:50 3.1 +++ ray/src/px/pcond3.c 1997/01/11 10:39:25 3.7 @@ -1,4 +1,4 @@ -/* Copyright (c) 1996 Regents of the University of California */ +/* Copyright (c) 1997 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -11,26 +11,27 @@ static char SCCSid[] = "$SunId$ LBL"; #include "pcond.h" -#define CVRATIO 0.025 /* fraction of pixels allowed > env. */ +#define CVRATIO 0.025 /* fraction of samples allowed > env. */ -#define BotMesopic 5.62e-3 /* top of scotopic range */ -#define TopMesopic 5.62 /* bottom of photopic range */ - #define exp10(x) exp(2.302585093*(x)) -int modhist[HISTRES]; /* modified histogram */ +float modhist[HISTRES]; /* modified histogram */ +double mhistot; /* modified histogram total */ float cumf[HISTRES+1]; /* cumulative distribution function */ mkcumf() /* make cumulative distribution function */ { register int i; - register long sum; + register double sum; - cumf[0] = 0.; - sum = modhist[0]; - for (i = 1; i < HISTRES; i++) { - cumf[i] = (double)sum/histot; + mhistot = 0.; /* compute modified total */ + for (i = 0; i < HISTRES; i++) + mhistot += modhist[i]; + + sum = 0.; /* compute cumulative function */ + for (i = 0; i < HISTRES; i++) { + cumf[i] = sum/mhistot; sum += modhist[i]; } cumf[HISTRES] = 1.; @@ -60,7 +61,7 @@ double Lw; return(Bldmin); if (b >= bwmax-FTINY) return(Bldmax); - return(Bldmin + cf(Bl(Lw))*(Bldmax-Bldmin)); + return(Bldmin + cf(b)*(Bldmax-Bldmin)); } @@ -99,66 +100,31 @@ double Lw; int -shiftdir(bw) /* compute shift direction for histogram */ -double bw; -{ - if (what2do&DO_HSENS && cf(bw) - (bw - bwmin)/(Bldmax - bwmin)) - return(1); - return(-1); -} - - -int mkbrmap() /* make dynamic range map */ { - int hdiffs[HISTRES], above, below; double T, b, s; - int maxd, maxi, sd; + double ceiling, trimmings; register int i; /* copy initial histogram */ - for (i = 0; i < HISTRES; i++) - modhist[i] = bwhist[i]; - T = histot * (bwmax - bwmin) / HISTRES; + bcopy((char *)bwhist, (char *)modhist, sizeof(modhist)); s = (bwmax - bwmin)/HISTRES; /* loop until satisfactory */ - for ( ; ; ) { - mkcumf(); /* sync brightness mapping */ - above = below = 0; /* compute visibility overflow */ + do { + mkcumf(); /* sync brightness mapping */ + if (mhistot <= histot*CVRATIO) + return(-1); /* no compression needed! */ + T = mhistot * (bwmax - bwmin) / HISTRES; + trimmings = 0.; /* clip to envelope */ for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { - hdiffs[i] = modhist[i] - (int)(T*clampf(Lb(b)) + .5); - if (hdiffs[i] > 0) above += hdiffs[i]; - else below -= hdiffs[i]; + ceiling = T*clampf(Lb(b)); + if (modhist[i] > ceiling) { + trimmings += modhist[i] - ceiling; + modhist[i] = ceiling; + } } - if (above <= histot*CVRATIO) - break; /* close enough */ - if (above-below >= 0) - return(-1); /* Houston, we have a problem.... */ - /* original looped here as well (BEGIN_L2) */ - maxd = 0; /* find largest overvis */ - for (i = 0; i < HISTRES; i++) - if (hdiffs[i] > maxd) - maxd = hdiffs[maxi=i]; - /* broke loop here when (maxd == 0) (BREAK_L2) */ - for (sd = shiftdir((maxi+.5)/HISTRES*(bwmax-bwmin)+bwmin); - hdiffs[maxi] == maxd; sd = -sd) - for (i = maxi+sd; i >= 0 & i < HISTRES; i += sd) - if (hdiffs[i] < 0) { - if (hdiffs[i] <= -maxd) { - modhist[i] += maxd; - modhist[maxi] -= maxd; - hdiffs[i] += maxd; - hdiffs[maxi] = 0; - } else { - modhist[maxi] += hdiffs[i]; - modhist[i] -= hdiffs[i]; - hdiffs[maxi] += hdiffs[i]; - hdiffs[i] = 0; - } - break; - } - /* (END_L2) */ - } - return(0); + } while (trimmings > histot*CVRATIO); + + return(0); /* we got it */ } @@ -180,13 +146,13 @@ int xres; incolor = (Lw - BotMesopic) / (TopMesopic - BotMesopic); if (incolor < 1.-FTINY) { + b = (1.-incolor)*slum(scan[i])*inpexp/SWNORM; + if (lumf == rgblum) b /= WHTEFFICACY; + setcolor(ctmp, b, b, b); if (incolor <= FTINY) setcolor(scan[i], 0., 0., 0.); else scalecolor(scan[i], incolor); - b = (1.-incolor)*slum(scan[i])*inpexp/SWNORM; - if (lumf == rgblum) b /= WHTEFFICACY; - setcolor(ctmp, b, b, b); addcolor(scan[i], ctmp); } } @@ -214,37 +180,24 @@ int xres; } -#ifdef DEBUG -doplots() /* generate debugging plots */ +putmapping(fp) /* put out mapping function */ +FILE *fp; { - double T, b, s; - FILE *fp; - char fname[128]; + double b, s; register int i; + double wlum, sf, dlum; - T = histot * (bwmax - bwmin) / HISTRES; + sf = scalef*inpexp; + if (lumf == cielum) sf *= WHTEFFICACY; s = (bwmax - bwmin)/HISTRES; - - sprintf(fname, "%s_hist.plt", infn); - if ((fp = fopen(fname, "w")) == NULL) - syserror(fname); - fputs("include=curve.plt\n", fp); - fputs("title=\"Brightness Frequency Distribution\"\n", fp); - fprintf(fp, "subtitle=%s\n", infn); - fputs("ymin=0\n", fp); - fputs("xlabel=\"Perceptual Brightness B(Lw)\"\n", fp); - fputs("ylabel=\"Frequency Count\"\n", fp); - fputs("Alabel=\"Histogram\"\n", fp); - fputs("Alintype=0\n", fp); - fputs("Blabel=\"Envelope\"\n", fp); - fputs("Bsymsize=0\n", fp); - fputs("Adata=\n", fp); - for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) - fprintf(fp, "\t%f %d\n", b, modhist[i]); - fputs(";\nBdata=\n", fp); - for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) - fprintf(fp, "\t%f %f\n", b, T*clampf(Lb(b))); - fputs(";\n", fp); - fclose(fp); + for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) { + wlum = Lb(b); + if (what2do&DO_LINEAR) { + dlum = sf*wlum; + if (dlum > ldmax) dlum = ldmax; + else if (dlum < ldmin) dlum = ldmin; + fprintf(fp, "%e %e\n", wlum, dlum); + } else + fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum))); + } } -#endif
