root/radiance/ray/src/px/pcond3.c
Revision: 3.5
Committed: Thu Jan 9 13:56:30 1997 UTC (28 years, 5 months ago) by greg
Changes since 3.4: +27 -84 lines
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Routines for computing and applying brightness mapping.
9 */
10
11 #include "pcond.h"
12
13
14 #define CVRATIO 0.025 /* fraction of samples allowed > env. */
15
16 #define exp10(x) exp(2.302585093*(x))
17
18 float modhist[HISTRES]; /* modified histogram */
19 double mhistot; /* modified histogram total */
20 float cumf[HISTRES+1]; /* cumulative distribution function */
21
22
23 mkcumf() /* make cumulative distribution function */
24 {
25 register int i;
26 register double sum;
27
28 mhistot = 0.; /* compute modified total */
29 for (i = 0; i < HISTRES; i++)
30 mhistot += modhist[i];
31
32 sum = 0.; /* compute cumulative function */
33 for (i = 0; i < HISTRES; i++) {
34 cumf[i] = sum/mhistot;
35 sum += modhist[i];
36 }
37 cumf[HISTRES] = 1.;
38 }
39
40
41 double
42 cf(b) /* return cumulative function at b */
43 double b;
44 {
45 double x;
46 register int i;
47
48 i = x = HISTRES*(b - bwmin)/(bwmax - bwmin);
49 x -= (double)i;
50 return(cumf[i]*(1.-x) + cumf[i+1]*x);
51 }
52
53
54 double
55 BLw(Lw) /* map world luminance to display brightness */
56 double Lw;
57 {
58 double b;
59
60 if (Lw <= LMIN || (b = Bl(Lw)) <= bwmin+FTINY)
61 return(Bldmin);
62 if (b >= bwmax-FTINY)
63 return(Bldmax);
64 return(Bldmin + cf(b)*(Bldmax-Bldmin));
65 }
66
67
68 double
69 htcontrs(La) /* human threshold contrast sensitivity, dL(La) */
70 double La;
71 {
72 double l10La, l10dL;
73 /* formula taken from Ferwerda et al. [SG96] */
74 if (La < 1.148e-4)
75 return(1.38e-3);
76 l10La = log10(La);
77 if (l10La < -1.44) /* rod response regime */
78 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
79 else if (l10La < -.0184)
80 l10dL = l10La - .395;
81 else if (l10La < 1.9) /* cone response regime */
82 l10dL = pow(.249*l10La + .65, 2.7) - .72;
83 else
84 l10dL = l10La - 1.255;
85
86 return(exp10(l10dL));
87 }
88
89
90 double
91 clampf(Lw) /* derivative clamping function */
92 double Lw;
93 {
94 double bLw, ratio;
95
96 bLw = BLw(Lw); /* apply current brightness map */
97 ratio = what2do&DO_HSENS ? htcontrs(Lb(bLw))/htcontrs(Lw) : Lb(bLw)/Lw;
98 return(ratio/(Lb1(bLw)*(Bldmax-Bldmin)*Bl1(Lw)));
99 }
100
101
102 int
103 shiftdir(bw) /* compute shift direction for histogram */
104 double bw;
105 {
106 if (what2do&DO_HSENS && cf(bw) - (bw - bwmin)/(Bldmax - bwmin))
107 return(1);
108 return(-1);
109 }
110
111
112 int
113 mkbrmap() /* make dynamic range map */
114 {
115 double T, b, s;
116 double ceiling, trimmings;
117 register int i;
118 /* copy initial histogram */
119 bcopy((char *)bwhist, (char *)modhist, sizeof(modhist));
120 s = (bwmax - bwmin)/HISTRES;
121 /* loop until satisfactory */
122 do {
123 mkcumf(); /* sync brightness mapping */
124 if (mhistot <= histot*CVRATIO)
125 return(-1); /* no compression needed! */
126 T = mhistot * (bwmax - bwmin) / HISTRES;
127 trimmings = 0.; /* clip to envelope */
128 for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) {
129 ceiling = T*clampf(Lb(b));
130 if (modhist[i] > ceiling) {
131 trimmings += modhist[i] - ceiling;
132 modhist[i] = ceiling;
133 }
134 }
135 } while (trimmings > histot*CVRATIO);
136
137 return(0); /* we got it */
138 }
139
140
141 scotscan(scan, xres) /* apply scotopic color sensitivity loss */
142 COLOR *scan;
143 int xres;
144 {
145 COLOR ctmp;
146 double incolor, b, Lw;
147 register int i;
148
149 for (i = 0; i < xres; i++) {
150 Lw = plum(scan[i]);
151 if (Lw >= TopMesopic)
152 incolor = 1.;
153 else if (Lw <= BotMesopic)
154 incolor = 0.;
155 else
156 incolor = (Lw - BotMesopic) /
157 (TopMesopic - BotMesopic);
158 if (incolor < 1.-FTINY) {
159 b = (1.-incolor)*slum(scan[i])*inpexp/SWNORM;
160 if (lumf == rgblum) b /= WHTEFFICACY;
161 setcolor(ctmp, b, b, b);
162 if (incolor <= FTINY)
163 setcolor(scan[i], 0., 0., 0.);
164 else
165 scalecolor(scan[i], incolor);
166 addcolor(scan[i], ctmp);
167 }
168 }
169 }
170
171
172 mapscan(scan, xres) /* apply tone mapping operator to scanline */
173 COLOR *scan;
174 int xres;
175 {
176 double mult, Lw, b;
177 register int i;
178
179 for (i = 0; i < xres; i++) {
180 Lw = plum(scan[i]);
181 if (Lw < LMIN) {
182 setcolor(scan[i], 0., 0., 0.);
183 continue;
184 }
185 b = BLw(Lw);
186 mult = (Lb(b) - ldmin)/(ldmax - ldmin) / (Lw*inpexp);
187 if (lumf == rgblum) mult *= WHTEFFICACY;
188 scalecolor(scan[i], mult);
189 }
190 }
191
192
193 putmapping(fp) /* put out mapping function */
194 FILE *fp;
195 {
196 double b, s;
197 register int i;
198 double wlum, sf;
199
200 sf = scalef*inpexp;
201 if (lumf == cielum) sf *= WHTEFFICACY;
202 s = (bwmax - bwmin)/HISTRES;
203 for (i = 0, b = bwmin + .5*s; i < HISTRES; i++, b += s) {
204 wlum = Lb(b);
205 if (what2do&DO_LINEAR)
206 fprintf(fp, "%e %e\n", wlum, sf*wlum);
207 else
208 fprintf(fp, "%e %e\n", wlum, Lb(BLw(wlum)));
209 }
210 }
