root/radiance/ray/src/px/pcond2.c
Thu Sep 8 22:29:47 2005 UTC (19 years, 7 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 3.16: +9 -15 lines
Diff to previous 3.16
Fix for XYZ input
Thu Sep 8 21:16:44 2005 UTC (19 years, 7 months ago) by greg
Diff to previous 3.15
Bug fix in last change
Thu Sep 8 19:08:52 2005 UTC (19 years, 7 months ago) by greg
Changes since 3.14: +28 -4 lines
Diff to previous 3.14
Improved rendering of saturated colors
Sun Nov 14 16:57:18 2004 UTC (20 years, 5 months ago) by greg
Changes since 3.13: +3 -6 lines
Diff to previous 3.13
Mon Nov 8 15:50:59 2004 UTC (20 years, 5 months ago) by greg
Changes since 3.12: +6 -3 lines
Diff to previous 3.12
Sun Mar 28 20:33:14 2004 UTC (21 years ago) by schorsch
Changes since 3.11: +50 -33 lines
Diff to previous 3.11
Sun Jul 27 22:12:03 2003 UTC (21 years, 8 months ago) by schorsch
Diff to previous 3.10
Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.9: +5 -7 lines
Diff to previous 3.9
Mon Jan 25 11:51:37 1999 UTC (26 years, 3 months ago) by gwlarson
Changes since 3.8: +3 -3 lines
Diff to previous 3.8
fixed macbeth color mapping reader to match new macbethcal output
Wed Feb 5 16:08:18 1997 UTC (28 years, 2 months ago) by greg
Changes since 3.7: +34 -1 lines
Diff to previous 3.7
changed -m option to read in color warp map (old -m now -d)
Fri Jan 31 15:56:20 1997 UTC (28 years, 2 months ago) by greg
Changes since 3.6: +17 -2 lines
Diff to previous 3.6
added gamut mapping for display devices (doesn't work w/ pcomb)
Thu Jan 30 17:06:27 1997 UTC (28 years, 2 months ago) by greg
Changes since 3.5: +4 -4 lines
Diff to previous 3.5
changed ordering so color trans. before non-lin. corr. for output
Tue Jan 28 16:31:16 1997 UTC (28 years, 2 months ago) by greg
Changes since 3.4: +1 -15 lines
Diff to previous 3.4
removed unnecessary debugging statements
Thu Jan 9 13:56:28 1997 UTC (28 years, 3 months ago) by greg
Changes since 3.3: +2 -1 lines
Diff to previous 3.3
Fri Oct 4 18:34:57 1996 UTC (28 years, 6 months ago) by greg
Changes since 3.2: +4 -1 lines
Diff to previous 3.2
minor cleanup
Fri Oct 4 16:10:41 1996 UTC (28 years, 6 months ago) by greg
Changes since 3.1: +15 -3 lines
Thu Oct 3 16:52:49 1996 UTC (28 years, 6 months ago) by greg
