root/radiance/ray/src/px/pcond2.c
Revision: 3.17
Committed: Thu Sep 8 22:29:47 2005 UTC (18 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1
Changes since 3.16: +9 -15 lines
Fix for XYZ input
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.17 static const char RCSid[] = "$Id: pcond2.c,v 3.16 2005/09/08 21:16:44 greg Exp $";
3 greg 3.1 #endif
4     /*
5     * Input and output conditioning routines for pcond.
6 greg 3.10 * Added white-balance adjustment 10/01 (GW).
7 greg 3.1 */
8
9     #include "pcond.h"
10 greg 3.8 #include "warp3d.h"
11 greg 3.1
12
13     RGBPRIMP inprims = stdprims; /* input primaries */
14     COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
15     RGBPRIMP outprims = stdprims; /* output primaries */
16
17     double (*lumf)() = rgblum; /* input luminance function */
18     double inpexp = 1.0; /* input exposure value */
19
20     char *mbcalfile = NULL; /* macbethcal mapping file */
21 greg 3.8 char *cwarpfile = NULL; /* color space warping file */
22 greg 3.1
23 greg 3.3 static struct mbc {
24 greg 3.7 COLORMAT cmat;
25 greg 3.3 float xa[3][6], ya[3][6];
26 greg 3.7 COLOR cmin, cmax;
27 greg 3.3 } mbcond; /* macbethcal conditioning struct */
28 greg 3.1
29 greg 3.8 static WARP3D *cwarp; /* color warping structure */
30
31 greg 3.1 static COLOR *scanbuf; /* scanline processing buffer */
32     static int nread; /* number of scanlines processed */
33
34 schorsch 3.12 static void sfscan(COLOR *sl, int len, double sf);
35     static void matscan(COLOR *sl, int len, COLORMAT mat);
36     static void mbscan(COLOR *sl, int len, struct mbc *mb);
37     static void cwscan(COLOR *sl, int len, WARP3D *wp);
38     static void getmbcalfile(char *fn, struct mbc *mb);
39 greg 3.1
40 schorsch 3.12
41     extern double
42     rgblum( /* compute (scotopic) luminance of RGB color */
43     COLOR clr,
44     int scotopic
45     )
46 greg 3.1 {
47     if (scotopic) /* approximate */
48     return( WHTSEFFICACY * (colval(clr,RED)*.062 +
49     colval(clr,GRN)*.608 + colval(clr,BLU)*.330) );
50     return( WHTEFFICACY * (colval(clr,RED)*inrgb2xyz[1][0] +
51     colval(clr,GRN)*inrgb2xyz[1][1] +
52     colval(clr,BLU)*inrgb2xyz[1][2]) );
53     }
54
55
56 schorsch 3.12 extern double
57     cielum( /* compute (scotopic) luminance of CIE color */
58     COLOR xyz,
59     int scotopic
60     )
61 greg 3.1 {
62     if (scotopic) /* approximate */
63     return(colval(xyz,CIEY) *
64     (1.33*(1. + (colval(xyz,CIEY)+colval(xyz,CIEZ))/
65     colval(xyz,CIEX)) - 1.68));
66     return(colval(xyz,CIEY));
67     }
68
69
70 schorsch 3.12 extern COLOR *
71     nextscan(void) /* read and condition next scanline */
72 greg 3.1 {
73     if (nread >= numscans(&inpres)) {
74 greg 3.8 if (cwarpfile != NULL)
75     free3dw(cwarp);
76 greg 3.10 free((void *)scanbuf);
77 greg 3.4 return(scanbuf = NULL);
78 greg 3.1 }
79 greg 3.2 if (what2do&DO_ACUITY)
80     acuscan(scanbuf, nread);
81     else if (freadscan(scanbuf, scanlen(&inpres), infp) < 0) {
82 greg 3.1 fprintf(stderr, "%s: %s: scanline read error\n",
83     progname, infn);
84     exit(1);
85     }
86     if (what2do&DO_VEIL) /* add veiling */
87 greg 3.2 addveil(scanbuf, nread);
88 greg 3.1 if (what2do&DO_COLOR) /* scotopic color loss */
89     scotscan(scanbuf, scanlen(&inpres));
90     if (what2do&DO_LINEAR) /* map luminances */
91     sfscan(scanbuf, scanlen(&inpres), scalef);
92     else
93     mapscan(scanbuf, scanlen(&inpres));
94     if (mbcalfile != NULL) /* device color correction */
95     mbscan(scanbuf, scanlen(&inpres), &mbcond);
96 greg 3.8 else if (cwarpfile != NULL) /* device color space warp */
97     cwscan(scanbuf, scanlen(&inpres), cwarp);
98 schorsch 3.11 else if ((lumf == cielum) | (inprims != outprims))
99 greg 3.1 matscan(scanbuf, scanlen(&inpres), mbcond.cmat);
100 greg 3.2 nread++;
101 greg 3.1 return(scanbuf);
102     }
103
104
105 schorsch 3.12 extern COLOR *
106     firstscan(void) /* return first processed scanline */
107 greg 3.1 {
108     if (mbcalfile != NULL) /* load macbethcal file */
109     getmbcalfile(mbcalfile, &mbcond);
110 greg 3.8 else if (cwarpfile != NULL) {
111     if ((cwarp = load3dw(cwarpfile, NULL)) == NULL)
112     syserror(cwarpfile);
113     } else
114 greg 3.1 if (lumf == rgblum)
115 greg 3.10 comprgb2rgbWBmat(mbcond.cmat, inprims, outprims);
116 greg 3.1 else
117 greg 3.10 compxyz2rgbWBmat(mbcond.cmat, outprims);
118 greg 3.14 if (what2do&DO_ACUITY)
119     initacuity();
120 greg 3.1 scanbuf = (COLOR *)malloc(scanlen(&inpres)*sizeof(COLOR));
121     if (scanbuf == NULL)
122     syserror("malloc");
123     nread = 0;
124     return(nextscan());
125     }
126
127
128 schorsch 3.12 static void
129     sfscan( /* apply scalefactor to scanline */
130     register COLOR *sl,
131     int len,
132     double sf
133     )
134 greg 3.1 {
135     while (len--) {
136     scalecolor(sl[0], sf);
137     sl++;
138     }
139     }
140
141
142 greg 3.15 static double
143     greypoint( /* compute gamut mapping grey target */
144     COLOR col
145     )
146     {
147     COLOR gryc;
148     int i;
149     /* improves saturated color rendering */
150     copycolor(gryc, col);
151     for (i = 3; i--; )
152 greg 3.17 if (gryc[i] > 1)
153     gryc[i] = 1;
154     else if (gryc[i] < 0)
155     gryc[i] = 0;
156     return(bright(gryc));
157 greg 3.15 }
158
159
160 schorsch 3.12 static void
161     matscan( /* apply color matrix to scaline */
162     register COLOR *sl,
163     int len,
164     COLORMAT mat
165     )
166 greg 3.1 {
167     while (len--) {
168     colortrans(sl[0], mat, sl[0]);
169 greg 3.17 clipgamut(sl[0], greypoint(sl[0]), CGAMUT, cblack, cwhite);
170 greg 3.1 sl++;
171     }
172     }
173
174
175 schorsch 3.12 static void
176     mbscan( /* apply macbethcal adj. to scaline */
177     COLOR *sl,
178     int len,
179     register struct mbc *mb
180     )
181 greg 3.1 {
182     double d;
183     register int i, j;
184
185     while (len--) {
186 greg 3.6 colortrans(sl[0], mb->cmat, sl[0]);
187 greg 3.17 clipgamut(sl[0], greypoint(sl[0]), CGAMUT, mb->cmin, mb->cmax);
188 greg 3.1 for (i = 0; i < 3; i++) {
189     d = colval(sl[0],i);
190     for (j = 0; j < 4 && mb->xa[i][j+1] <= d; j++)
191     ;
192     colval(sl[0],i) = ( (mb->xa[i][j+1] - d)*mb->ya[i][j] +
193     (d - mb->xa[i][j])*mb->ya[i][j+1] ) /
194     (mb->xa[i][j+1] - mb->xa[i][j]);
195     }
196 greg 3.8 sl++;
197     }
198     }
199
200
201 schorsch 3.12 static void
202     cwscan( /* apply color space warp to scaline */
203     COLOR *sl,
204     int len,
205     WARP3D *wp
206     )
207 greg 3.8 {
208     int rval;
209
210     while (len--) {
211     rval = warp3d(sl[0], sl[0], wp);
212     if (rval & W3ERROR)
213     syserror("warp3d");
214     if (rval & W3BADMAP) {
215     fprintf(stderr, "%s: %s: bad color space map\n",
216     progname, cwarpfile);
217     exit(1);
218     }
219 greg 3.17 clipgamut(sl[0], greypoint(sl[0]), CGAMUT, cblack, cwhite);
220 greg 3.1 sl++;
221     }
222     }
223
224
225 schorsch 3.12 static void
226     getmbcalfile( /* load macbethcal file */
227     char *fn,
228     register struct mbc *mb
229     )
230 greg 3.1 {
231     char buf[128];
232     FILE *fp;
233     int inpflags = 0;
234 greg 3.7 register int i;
235 greg 3.1
236     if ((fp = fopen(fn, "r")) == NULL)
237     syserror(fn);
238     while (fgets(buf, sizeof(buf), fp) != NULL) {
239     if (!(inpflags & 01) &&
240     sscanf(buf,
241     "rxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
242     &mb->xa[0][0], &mb->xa[0][1],
243     &mb->xa[0][2], &mb->xa[0][3],
244     &mb->xa[0][4], &mb->xa[0][5]
245     ) == 6)
246     inpflags |= 01;
247     else if (!(inpflags & 02) &&
248     sscanf(buf,
249     "rya(i) : select(i,%f,%f,%f,%f,%f,%f)",
250     &mb->ya[0][0], &mb->ya[0][1],
251     &mb->ya[0][2], &mb->ya[0][3],
252     &mb->ya[0][4], &mb->ya[0][5]
253     ) == 6)
254     inpflags |= 02;
255     else if (!(inpflags & 04) &&
256     sscanf(buf,
257     "gxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
258     &mb->xa[1][0], &mb->xa[1][1],
259     &mb->xa[1][2], &mb->xa[1][3],
260     &mb->xa[1][4], &mb->xa[1][5]
261     ) == 6)
262     inpflags |= 04;
263     else if (!(inpflags & 010) &&
264     sscanf(buf,
265     "gya(i) : select(i,%f,%f,%f,%f,%f,%f)",
266     &mb->ya[1][0], &mb->ya[1][1],
267     &mb->ya[1][2], &mb->ya[1][3],
268     &mb->ya[1][4], &mb->ya[1][5]
269     ) == 6)
270     inpflags |= 010;
271     else if (!(inpflags & 020) &&
272     sscanf(buf,
273     "bxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
274     &mb->xa[2][0], &mb->xa[2][1],
275     &mb->xa[2][2], &mb->xa[2][3],
276     &mb->xa[2][4], &mb->xa[2][5]
277     ) == 6)
278     inpflags |= 020;
279     else if (!(inpflags & 040) &&
280     sscanf(buf,
281     "bya(i) : select(i,%f,%f,%f,%f,%f,%f)",
282     &mb->ya[2][0], &mb->ya[2][1],
283     &mb->ya[2][2], &mb->ya[2][3],
284     &mb->ya[2][4], &mb->ya[2][5]
285     ) == 6)
286     inpflags |= 040;
287     else if (!(inpflags & 0100) &&
288     sscanf(buf,
289 gwlarson 3.9 "ro = %f*rn + %f*gn + %f*bn",
290 greg 3.1 &mb->cmat[0][0], &mb->cmat[0][1],
291     &mb->cmat[0][2]) == 3)
292     inpflags |= 0100;
293     else if (!(inpflags & 0200) &&
294     sscanf(buf,
295 gwlarson 3.9 "go = %f*rn + %f*gn + %f*bn",
296 greg 3.1 &mb->cmat[1][0], &mb->cmat[1][1],
297     &mb->cmat[1][2]) == 3)
298     inpflags |= 0200;
299     else if (!(inpflags & 0400) &&
300     sscanf(buf,
301 gwlarson 3.9 "bo = %f*rn + %f*gn + %f*bn",
302 greg 3.1 &mb->cmat[2][0], &mb->cmat[2][1],
303     &mb->cmat[2][2]) == 3)
304     inpflags |= 0400;
305     }
306     if (inpflags != 0777) {
307     fprintf(stderr,
308     "%s: cannot grok macbethcal file \"%s\" (inpflags==0%o)\n",
309     progname, fn, inpflags);
310     exit(1);
311     }
312     fclose(fp);
313 greg 3.7 /* compute gamut */
314     for (i = 0; i < 3; i++) {
315     colval(mb->cmin,i) = mb->xa[i][0] -
316     mb->ya[i][0] *
317     (mb->xa[i][1]-mb->xa[i][0]) /
318     (mb->ya[i][1]-mb->ya[i][0]);
319     colval(mb->cmax,i) = mb->xa[i][4] +
320     (1.-mb->ya[i][4]) *
321     (mb->xa[i][5] - mb->xa[i][4]) /
322     (mb->ya[i][5] - mb->ya[i][4]);
323     }
324 greg 3.1 }
