root/radiance/ray/src/px/pcond2.c
Fri Aug 21 05:48:28 2015 UTC (8 years, 9 months ago) by greg
CVS Tags: HEAD, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Changes since 3.17: +11 -11 lines
Diff to previous 3.17 , to selected 3.4
Fixed issue with undersampled histogram in phisto
Thu Sep 8 22:29:47 2005 UTC (18 years, 9 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 3.16: +9 -15 lines
Diff to previous 3.16 , to selected 3.4
Fix for XYZ input
Thu Sep 8 21:16:44 2005 UTC (18 years, 9 months ago) by greg
Diff to previous 3.15 , to selected 3.4
Bug fix in last change
Thu Sep 8 19:08:52 2005 UTC (18 years, 9 months ago) by greg
Changes since 3.14: +28 -4 lines
Diff to previous 3.14 , to selected 3.4
Improved rendering of saturated colors
Sun Nov 14 16:57:18 2004 UTC (19 years, 6 months ago) by greg
Changes since 3.13: +3 -6 lines
Diff to previous 3.13 , to selected 3.4
Mon Nov 8 15:50:59 2004 UTC (19 years, 7 months ago) by greg
Changes since 3.12: +6 -3 lines
Diff to previous 3.12 , to selected 3.4
Changes since 3.11: +50 -33 lines
Diff to previous 3.11 , to selected 3.4
Diff to previous 3.10 , to selected 3.4
Changes since 3.9: +5 -7 lines
Diff to previous 3.9 , to selected 3.4
Mon Jan 25 11:51:37 1999 UTC (25 years, 4 months ago) by gwlarson
Changes since 3.8: +3 -3 lines
Diff to previous 3.8 , to selected 3.4
fixed macbeth color mapping reader to match new macbethcal output
Wed Feb 5 16:08:18 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.7: +34 -1 lines
Diff to previous 3.7 , to selected 3.4
changed -m option to read in color warp map (old -m now -d)
Fri Jan 31 15:56:20 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.6: +17 -2 lines
Diff to previous 3.6 , to selected 3.4
added gamut mapping for display devices (doesn't work w/ pcomb)
Thu Jan 30 17:06:27 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.5: +4 -4 lines
Diff to previous 3.5 , to selected 3.4
changed ordering so color trans. before non-lin. corr. for output
Tue Jan 28 16:31:16 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.4: +1 -15 lines
Diff to previous 3.4
removed unnecessary debugging statements
Revision 3.4 - (view) (download) (annotate) - [selected]
Thu Jan 9 13:56:28 1997 UTC (27 years, 5 months ago) by greg
Changes since 3.3: +2 -1 lines
Diff to previous 3.3
Fri Oct 4 18:34:57 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.2: +4 -1 lines
Diff to previous 3.2 , to selected 3.4
minor cleanup
Fri Oct 4 16:10:41 1996 UTC (27 years, 8 months ago) by greg
Changes since 3.1: +15 -3 lines
Diff to previous 3.1 , to selected 3.4
Thu Oct 3 16:52:49 1996 UTC (27 years, 8 months ago) by greg
Diff to selected 3.4
