root/radiance/ray/src/px/pcond2.c
Revision: 3.13
Committed: Mon Nov 8 15:50:59 2004 UTC (19 years, 7 months ago) by greg
Changes since 3.12: +6 -3 lines
2 static const char RCSid[] = "$Id: pcond2.c,v 3.12 2004/03/28 20:33:14 schorsch Exp $";
5 * Input and output conditioning routines for pcond.
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "pcond.h"
10 #include "warp3d.h"
11
12
13 RGBPRIMP inprims = stdprims; /* input primaries */
14 COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
15 RGBPRIMP outprims = stdprims; /* output primaries */
16
17 double (*lumf)() = rgblum; /* input luminance function */
18 double inpexp = 1.0; /* input exposure value */
19
20 char *mbcalfile = NULL; /* macbethcal mapping file */
21 char *cwarpfile = NULL; /* color space warping file */
22
23 static struct mbc {
24 COLORMAT cmat;
25 float xa[3][6], ya[3][6];
26 COLOR cmin, cmax;
27 } mbcond; /* macbethcal conditioning struct */
28
29 static WARP3D *cwarp; /* color warping structure */
30
31 static COLOR *scanbuf; /* scanline processing buffer */
32 static int nread; /* number of scanlines processed */
33
34 static void sfscan(COLOR *sl, int len, double sf);
35 static void matscan(COLOR *sl, int len, COLORMAT mat);
36 static void mbscan(COLOR *sl, int len, struct mbc *mb);
37 static void cwscan(COLOR *sl, int len, WARP3D *wp);
38 static void getmbcalfile(char *fn, struct mbc *mb);
39
40
41 extern double
42 rgblum( /* compute (scotopic) luminance of RGB color */
43 COLOR clr,
44 int scotopic
45 )
46 {
47 if (scotopic) /* approximate */
48 return( WHTSEFFICACY * (colval(clr,RED)*.062 +
49 colval(clr,GRN)*.608 + colval(clr,BLU)*.330) );
50 return( WHTEFFICACY * (colval(clr,RED)*inrgb2xyz[1][0] +
51 colval(clr,GRN)*inrgb2xyz[1][1] +
52 colval(clr,BLU)*inrgb2xyz[1][2]) );
53 }
54
55
56 extern double
57 cielum( /* compute (scotopic) luminance of CIE color */
58 COLOR xyz,
59 int scotopic
60 )
61 {
62 if (scotopic) /* approximate */
63 return(colval(xyz,CIEY) *
64 (1.33*(1. + (colval(xyz,CIEY)+colval(xyz,CIEZ))/
65 colval(xyz,CIEX)) - 1.68));
66 return(colval(xyz,CIEY));
67 }
68
69
70 extern COLOR *
71 nextscan(void) /* read and condition next scanline */
72 {
73 if (nread >= numscans(&inpres)) {
74 if (cwarpfile != NULL)
75 free3dw(cwarp);
76 free((void *)scanbuf);
77 return(scanbuf = NULL);
78 }
79 if (what2do&DO_ACUITY)
80 acuscan(scanbuf, nread);
81 else if (freadscan(scanbuf, scanlen(&inpres), infp) < 0) {
82 fprintf(stderr, "%s: %s: scanline read error\n",
83 progname, infn);
84 exit(1);
85 }
86 if (what2do&DO_VEIL) /* add veiling */
87 addveil(scanbuf, nread);
88 if (what2do&DO_COLOR) /* scotopic color loss */
89 scotscan(scanbuf, scanlen(&inpres));
90 if (what2do&DO_LINEAR) /* map luminances */
91 sfscan(scanbuf, scanlen(&inpres), scalef);
92 else
93 mapscan(scanbuf, scanlen(&inpres));
94 if (mbcalfile != NULL) /* device color correction */
95 mbscan(scanbuf, scanlen(&inpres), &mbcond);
96 else if (cwarpfile != NULL) /* device color space warp */
97 cwscan(scanbuf, scanlen(&inpres), cwarp);
98 else if ((lumf == cielum) | (inprims != outprims))
99 matscan(scanbuf, scanlen(&inpres), mbcond.cmat);
100 nread++;
101 return(scanbuf);
102 }
103
104
105 extern COLOR *
106 firstscan(void) /* return first processed scanline */
107 {
108 if (mbcalfile != NULL) /* load macbethcal file */
109 getmbcalfile(mbcalfile, &mbcond);
110 else if (cwarpfile != NULL) {
111 if ((cwarp = load3dw(cwarpfile, NULL)) == NULL)
112 syserror(cwarpfile);
113 } else
114 if (lumf == rgblum)
115 comprgb2rgbWBmat(mbcond.cmat, inprims, outprims);
116 else
117 compxyz2rgbWBmat(mbcond.cmat, outprims);
118 if (what2do&DO_ACUITY && !initacuity()) {
119 fprintf(stderr, "%s: warning - cannot initialize acuity pass\n",
120 progname);
121 what2do &= ~DO_ACUITY;
122 }
123 scanbuf = (COLOR *)malloc(scanlen(&inpres)*sizeof(COLOR));
124 if (scanbuf == NULL)
125 syserror("malloc");
126 nread = 0;
127 return(nextscan());
128 }
129
130
131 static void
132 sfscan( /* apply scalefactor to scanline */
133 register COLOR *sl,
134 int len,
135 double sf
136 )
137 {
138 while (len--) {
139 scalecolor(sl[0], sf);
140 sl++;
141 }
142 }
143
144
145 static void
146 matscan( /* apply color matrix to scaline */
147 register COLOR *sl,
148 int len,
149 COLORMAT mat
150 )
151 {
152 while (len--) {
153 colortrans(sl[0], mat, sl[0]);
154 clipgamut(sl[0], bright(sl[0]), CGAMUT, cblack, cwhite);
155 sl++;
156 }
157 }
158
159
160 static void
161 mbscan( /* apply macbethcal adj. to scaline */
162 COLOR *sl,
163 int len,
164 register struct mbc *mb
165 )
166 {
167 double d;
168 register int i, j;
169
170 while (len--) {
171 colortrans(sl[0], mb->cmat, sl[0]);
172 clipgamut(sl[0], bright(sl[0]), CGAMUT, mb->cmin, mb->cmax);
173 for (i = 0; i < 3; i++) {
174 d = colval(sl[0],i);
175 for (j = 0; j < 4 && mb->xa[i][j+1] <= d; j++)
176 ;
177 colval(sl[0],i) = ( (mb->xa[i][j+1] - d)*mb->ya[i][j] +
178 (d - mb->xa[i][j])*mb->ya[i][j+1] ) /
179 (mb->xa[i][j+1] - mb->xa[i][j]);
180 }
181 sl++;
182 }
183 }
184
185
186 static void
187 cwscan( /* apply color space warp to scaline */
188 COLOR *sl,
189 int len,
190 WARP3D *wp
191 )
192 {
193 int rval;
194
195 while (len--) {
196 rval = warp3d(sl[0], sl[0], wp);
197 if (rval & W3ERROR)
198 syserror("warp3d");
199 if (rval & W3BADMAP) {
200 fprintf(stderr, "%s: %s: bad color space map\n",
201 progname, cwarpfile);
202 exit(1);
203 }
204 clipgamut(sl[0], bright(sl[0]), CGAMUT, cblack, cwhite);
205 sl++;
206 }
207 }
208
209
210 static void
211 getmbcalfile( /* load macbethcal file */
212 char *fn,
213 register struct mbc *mb
214 )
215 {
216 char buf[128];
217 FILE *fp;
218 int inpflags = 0;
219 register int i;
220
221 if ((fp = fopen(fn, "r")) == NULL)
222 syserror(fn);
223 while (fgets(buf, sizeof(buf), fp) != NULL) {
224 if (!(inpflags & 01) &&
225 sscanf(buf,
226 "rxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
227 &mb->xa[0][0], &mb->xa[0][1],
228 &mb->xa[0][2], &mb->xa[0][3],
229 &mb->xa[0][4], &mb->xa[0][5]
230 ) == 6)
231 inpflags |= 01;
232 else if (!(inpflags & 02) &&
233 sscanf(buf,
234 "rya(i) : select(i,%f,%f,%f,%f,%f,%f)",
235 &mb->ya[0][0], &mb->ya[0][1],
236 &mb->ya[0][2], &mb->ya[0][3],
237 &mb->ya[0][4], &mb->ya[0][5]
238 ) == 6)
239 inpflags |= 02;
240 else if (!(inpflags & 04) &&
241 sscanf(buf,
242 "gxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
243 &mb->xa[1][0], &mb->xa[1][1],
244 &mb->xa[1][2], &mb->xa[1][3],
245 &mb->xa[1][4], &mb->xa[1][5]
246 ) == 6)
247 inpflags |= 04;
248 else if (!(inpflags & 010) &&
249 sscanf(buf,
250 "gya(i) : select(i,%f,%f,%f,%f,%f,%f)",
251 &mb->ya[1][0], &mb->ya[1][1],
252 &mb->ya[1][2], &mb->ya[1][3],
253 &mb->ya[1][4], &mb->ya[1][5]
254 ) == 6)
255 inpflags |= 010;
256 else if (!(inpflags & 020) &&
257 sscanf(buf,
258 "bxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
259 &mb->xa[2][0], &mb->xa[2][1],
260 &mb->xa[2][2], &mb->xa[2][3],
261 &mb->xa[2][4], &mb->xa[2][5]
262 ) == 6)
263 inpflags |= 020;
264 else if (!(inpflags & 040) &&
265 sscanf(buf,
266 "bya(i) : select(i,%f,%f,%f,%f,%f,%f)",
267 &mb->ya[2][0], &mb->ya[2][1],
268 &mb->ya[2][2], &mb->ya[2][3],
269 &mb->ya[2][4], &mb->ya[2][5]
270 ) == 6)
271 inpflags |= 040;
272 else if (!(inpflags & 0100) &&
273 sscanf(buf,
274 "ro = %f*rn + %f*gn + %f*bn",
275 &mb->cmat[0][0], &mb->cmat[0][1],
276 &mb->cmat[0][2]) == 3)
277 inpflags |= 0100;
278 else if (!(inpflags & 0200) &&
279 sscanf(buf,
280 "go = %f*rn + %f*gn + %f*bn",
281 &mb->cmat[1][0], &mb->cmat[1][1],
282 &mb->cmat[1][2]) == 3)
283 inpflags |= 0200;
284 else if (!(inpflags & 0400) &&
285 sscanf(buf,
286 "bo = %f*rn + %f*gn + %f*bn",
287 &mb->cmat[2][0], &mb->cmat[2][1],
288 &mb->cmat[2][2]) == 3)
289 inpflags |= 0400;
290 }
291 if (inpflags != 0777) {
292 fprintf(stderr,
293 "%s: cannot grok macbethcal file \"%s\" (inpflags==0%o)\n",
294 progname, fn, inpflags);
295 exit(1);
296 }
297 fclose(fp);
298 /* compute gamut */
299 for (i = 0; i < 3; i++) {
300 colval(mb->cmin,i) = mb->xa[i][0] -
301 mb->ya[i][0] *
302 (mb->xa[i][1]-mb->xa[i][0]) /
303 (mb->ya[i][1]-mb->ya[i][0]);
304 colval(mb->cmax,i) = mb->xa[i][4] +
305 (1.-mb->ya[i][4]) *
306 (mb->xa[i][5] - mb->xa[i][4]) /
307 (mb->ya[i][5] - mb->ya[i][4]);
308 }
309 }
