--- ray/src/px/pcond2.c 2003/02/22 02:07:27 3.10 +++ ray/src/px/pcond2.c 2004/03/28 20:33:14 3.12 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pcond2.c,v 3.10 2003/02/22 02:07:27 greg Exp $"; +static const char RCSid[] = "$Id: pcond2.c,v 3.12 2004/03/28 20:33:14 schorsch Exp $"; #endif /* * Input and output conditioning routines for pcond. @@ -31,11 +31,18 @@ static WARP3D *cwarp; /* color warping structure */ static COLOR *scanbuf; /* scanline processing buffer */ static int nread; /* number of scanlines processed */ +static void sfscan(COLOR *sl, int len, double sf); +static void matscan(COLOR *sl, int len, COLORMAT mat); +static void mbscan(COLOR *sl, int len, struct mbc *mb); +static void cwscan(COLOR *sl, int len, WARP3D *wp); +static void getmbcalfile(char *fn, struct mbc *mb); -double -rgblum(clr, scotopic) /* compute (scotopic) luminance of RGB color */ -COLOR clr; -int scotopic; + +extern double +rgblum( /* compute (scotopic) luminance of RGB color */ + COLOR clr, + int scotopic +) { if (scotopic) /* approximate */ return( WHTSEFFICACY * (colval(clr,RED)*.062 + @@ -46,10 +53,11 @@ int scotopic; } -double -cielum(xyz, scotopic) /* compute (scotopic) luminance of CIE color */ -COLOR xyz; -int scotopic; +extern double +cielum( /* compute (scotopic) luminance of CIE color */ + COLOR xyz, + int scotopic +) { if (scotopic) /* approximate */ return(colval(xyz,CIEY) * @@ -59,8 +67,8 @@ int scotopic; } -COLOR * -nextscan() /* read and condition next scanline */ +extern COLOR * +nextscan(void) /* read and condition next scanline */ { if (nread >= numscans(&inpres)) { if (cwarpfile != NULL) @@ -87,15 +95,15 @@ nextscan() /* read and condition next scanline */ mbscan(scanbuf, scanlen(&inpres), &mbcond); else if (cwarpfile != NULL) /* device color space warp */ cwscan(scanbuf, scanlen(&inpres), cwarp); - else if (lumf == cielum | inprims != outprims) + else if ((lumf == cielum) | (inprims != outprims)) matscan(scanbuf, scanlen(&inpres), mbcond.cmat); nread++; return(scanbuf); } -COLOR * -firstscan() /* return first processed scanline */ +extern COLOR * +firstscan(void) /* return first processed scanline */ { if (mbcalfile != NULL) /* load macbethcal file */ getmbcalfile(mbcalfile, &mbcond); @@ -117,10 +125,12 @@ firstscan() /* return first processed scanline */ } -sfscan(sl, len, sf) /* apply scalefactor to scanline */ -register COLOR *sl; -int len; -double sf; +static void +sfscan( /* apply scalefactor to scanline */ + register COLOR *sl, + int len, + double sf +) { while (len--) { scalecolor(sl[0], sf); @@ -129,10 +139,12 @@ double sf; } -matscan(sl, len, mat) /* apply color matrix to scaline */ -register COLOR *sl; -int len; -COLORMAT mat; +static void +matscan( /* apply color matrix to scaline */ + register COLOR *sl, + int len, + COLORMAT mat +) { while (len--) { colortrans(sl[0], mat, sl[0]); @@ -142,10 +154,12 @@ COLORMAT mat; } -mbscan(sl, len, mb) /* apply macbethcal adj. to scaline */ -COLOR *sl; -int len; -register struct mbc *mb; +static void +mbscan( /* apply macbethcal adj. to scaline */ + COLOR *sl, + int len, + register struct mbc *mb +) { double d; register int i, j; @@ -166,10 +180,12 @@ register struct mbc *mb; } -cwscan(sl, len, wp) /* apply color space warp to scaline */ -COLOR *sl; -int len; -WARP3D *wp; +static void +cwscan( /* apply color space warp to scaline */ + COLOR *sl, + int len, + WARP3D *wp +) { int rval; @@ -188,11 +204,12 @@ WARP3D *wp; } -getmbcalfile(fn, mb) /* load macbethcal file */ -char *fn; -register struct mbc *mb; +static void +getmbcalfile( /* load macbethcal file */ + char *fn, + register struct mbc *mb +) { - extern char *fgets(); char buf[128]; FILE *fp; int inpflags = 0;
