root/radiance/ray/src/px/pcond2.c
Revision: 3.12
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 3.11: +50 -33 lines
2 static const char RCSid[] = "$Id: pcond2.c,v 3.11 2003/07/27 22:12:03 schorsch Exp $";
5 * Input and output conditioning routines for pcond.
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "pcond.h"
10 #include "warp3d.h"
11
12
13 RGBPRIMP inprims = stdprims; /* input primaries */
14 COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
15 RGBPRIMP outprims = stdprims; /* output primaries */
16
17 double (*lumf)() = rgblum; /* input luminance function */
18 double inpexp = 1.0; /* input exposure value */
19
20 char *mbcalfile = NULL; /* macbethcal mapping file */
21 char *cwarpfile = NULL; /* color space warping file */
22
23 static struct mbc {
24 COLORMAT cmat;
25 float xa[3][6], ya[3][6];
26 COLOR cmin, cmax;
27 } mbcond; /* macbethcal conditioning struct */
28
29 static WARP3D *cwarp; /* color warping structure */
30
31 static COLOR *scanbuf; /* scanline processing buffer */
32 static int nread; /* number of scanlines processed */
33
34 static void sfscan(COLOR *sl, int len, double sf);
35 static void matscan(COLOR *sl, int len, COLORMAT mat);
36 static void mbscan(COLOR *sl, int len, struct mbc *mb);
37 static void cwscan(COLOR *sl, int len, WARP3D *wp);
38 static void getmbcalfile(char *fn, struct mbc *mb);
39
40
41 extern double
42 rgblum( /* compute (scotopic) luminance of RGB color */
43 COLOR clr,
44 int scotopic
45 )
46 {
47 if (scotopic) /* approximate */
48 return( WHTSEFFICACY * (colval(clr,RED)*.062 +
49 colval(clr,GRN)*.608 + colval(clr,BLU)*.330) );
50 return( WHTEFFICACY * (colval(clr,RED)*inrgb2xyz[1][0] +
51 colval(clr,GRN)*inrgb2xyz[1][1] +
52 colval(clr,BLU)*inrgb2xyz[1][2]) );
53 }
54
55
56 extern double
57 cielum( /* compute (scotopic) luminance of CIE color */
58 COLOR xyz,
59 int scotopic
60 )
61 {
62 if (scotopic) /* approximate */
63 return(colval(xyz,CIEY) *
64 (1.33*(1. + (colval(xyz,CIEY)+colval(xyz,CIEZ))/
65 colval(xyz,CIEX)) - 1.68));
66 return(colval(xyz,CIEY));
67 }
68
69
70 extern COLOR *
71 nextscan(void) /* read and condition next scanline */
72 {
73 if (nread >= numscans(&inpres)) {
74 if (cwarpfile != NULL)
75 free3dw(cwarp);
76 free((void *)scanbuf);
77 return(scanbuf = NULL);
78 }
79 if (what2do&DO_ACUITY)
80 acuscan(scanbuf, nread);
81 else if (freadscan(scanbuf, scanlen(&inpres), infp) < 0) {
82 fprintf(stderr, "%s: %s: scanline read error\n",
83 progname, infn);
84 exit(1);
85 }
86 if (what2do&DO_VEIL) /* add veiling */
87 addveil(scanbuf, nread);
88 if (what2do&DO_COLOR) /* scotopic color loss */
89 scotscan(scanbuf, scanlen(&inpres));
90 if (what2do&DO_LINEAR) /* map luminances */
91 sfscan(scanbuf, scanlen(&inpres), scalef);
92 else
93 mapscan(scanbuf, scanlen(&inpres));
94 if (mbcalfile != NULL) /* device color correction */
95 mbscan(scanbuf, scanlen(&inpres), &mbcond);
96 else if (cwarpfile != NULL) /* device color space warp */
97 cwscan(scanbuf, scanlen(&inpres), cwarp);
98 else if ((lumf == cielum) | (inprims != outprims))
99 matscan(scanbuf, scanlen(&inpres), mbcond.cmat);
100 nread++;
101 return(scanbuf);
102 }
103
104
105 extern COLOR *
106 firstscan(void) /* return first processed scanline */
107 {
108 if (mbcalfile != NULL) /* load macbethcal file */
109 getmbcalfile(mbcalfile, &mbcond);
110 else if (cwarpfile != NULL) {
111 if ((cwarp = load3dw(cwarpfile, NULL)) == NULL)
112 syserror(cwarpfile);
113 } else
114 if (lumf == rgblum)
115 comprgb2rgbWBmat(mbcond.cmat, inprims, outprims);
116 else
117 compxyz2rgbWBmat(mbcond.cmat, outprims);
118 if (what2do&DO_ACUITY)
119 initacuity();
120 scanbuf = (COLOR *)malloc(scanlen(&inpres)*sizeof(COLOR));
121 if (scanbuf == NULL)
122 syserror("malloc");
123 nread = 0;
124 return(nextscan());
125 }
126
127
128 static void
129 sfscan( /* apply scalefactor to scanline */
130 register COLOR *sl,
131 int len,
132 double sf
133 )
134 {
135 while (len--) {
136 scalecolor(sl[0], sf);
137 sl++;
138 }
139 }
140
141
142 static void
143 matscan( /* apply color matrix to scaline */
144 register COLOR *sl,
145 int len,
146 COLORMAT mat
147 )
148 {
149 while (len--) {
150 colortrans(sl[0], mat, sl[0]);
151 clipgamut(sl[0], bright(sl[0]), CGAMUT, cblack, cwhite);
152 sl++;
153 }
154 }
155
156
157 static void
158 mbscan( /* apply macbethcal adj. to scaline */
159 COLOR *sl,
160 int len,
161 register struct mbc *mb
162 )
163 {
164 double d;
165 register int i, j;
166
167 while (len--) {
168 colortrans(sl[0], mb->cmat, sl[0]);
169 clipgamut(sl[0], bright(sl[0]), CGAMUT, mb->cmin, mb->cmax);
170 for (i = 0; i < 3; i++) {
171 d = colval(sl[0],i);
172 for (j = 0; j < 4 && mb->xa[i][j+1] <= d; j++)
173 ;
174 colval(sl[0],i) = ( (mb->xa[i][j+1] - d)*mb->ya[i][j] +
175 (d - mb->xa[i][j])*mb->ya[i][j+1] ) /
176 (mb->xa[i][j+1] - mb->xa[i][j]);
177 }
178 sl++;
179 }
180 }
181
182
183 static void
184 cwscan( /* apply color space warp to scaline */
185 COLOR *sl,
186 int len,
187 WARP3D *wp
188 )
189 {
190 int rval;
191
192 while (len--) {
193 rval = warp3d(sl[0], sl[0], wp);
194 if (rval & W3ERROR)
195 syserror("warp3d");
196 if (rval & W3BADMAP) {
197 fprintf(stderr, "%s: %s: bad color space map\n",
198 progname, cwarpfile);
199 exit(1);
200 }
201 clipgamut(sl[0], bright(sl[0]), CGAMUT, cblack, cwhite);
202 sl++;
203 }
204 }
205
206
207 static void
208 getmbcalfile( /* load macbethcal file */
209 char *fn,
210 register struct mbc *mb
211 )
212 {
213 char buf[128];
214 FILE *fp;
215 int inpflags = 0;
216 register int i;
217
218 if ((fp = fopen(fn, "r")) == NULL)
219 syserror(fn);
220 while (fgets(buf, sizeof(buf), fp) != NULL) {
221 if (!(inpflags & 01) &&
222 sscanf(buf,
223 "rxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
224 &mb->xa[0][0], &mb->xa[0][1],
225 &mb->xa[0][2], &mb->xa[0][3],
226 &mb->xa[0][4], &mb->xa[0][5]
227 ) == 6)
228 inpflags |= 01;
229 else if (!(inpflags & 02) &&
230 sscanf(buf,
231 "rya(i) : select(i,%f,%f,%f,%f,%f,%f)",
232 &mb->ya[0][0], &mb->ya[0][1],
233 &mb->ya[0][2], &mb->ya[0][3],
234 &mb->ya[0][4], &mb->ya[0][5]
235 ) == 6)
236 inpflags |= 02;
237 else if (!(inpflags & 04) &&
238 sscanf(buf,
239 "gxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
240 &mb->xa[1][0], &mb->xa[1][1],
241 &mb->xa[1][2], &mb->xa[1][3],
242 &mb->xa[1][4], &mb->xa[1][5]
243 ) == 6)
244 inpflags |= 04;
245 else if (!(inpflags & 010) &&
246 sscanf(buf,
247 "gya(i) : select(i,%f,%f,%f,%f,%f,%f)",
248 &mb->ya[1][0], &mb->ya[1][1],
249 &mb->ya[1][2], &mb->ya[1][3],
250 &mb->ya[1][4], &mb->ya[1][5]
251 ) == 6)
252 inpflags |= 010;
253 else if (!(inpflags & 020) &&
254 sscanf(buf,
255 "bxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
256 &mb->xa[2][0], &mb->xa[2][1],
257 &mb->xa[2][2], &mb->xa[2][3],
258 &mb->xa[2][4], &mb->xa[2][5]
259 ) == 6)
260 inpflags |= 020;
261 else if (!(inpflags & 040) &&
262 sscanf(buf,
263 "bya(i) : select(i,%f,%f,%f,%f,%f,%f)",
264 &mb->ya[2][0], &mb->ya[2][1],
265 &mb->ya[2][2], &mb->ya[2][3],
266 &mb->ya[2][4], &mb->ya[2][5]
267 ) == 6)
268 inpflags |= 040;
269 else if (!(inpflags & 0100) &&
270 sscanf(buf,
271 "ro = %f*rn + %f*gn + %f*bn",
272 &mb->cmat[0][0], &mb->cmat[0][1],
273 &mb->cmat[0][2]) == 3)
274 inpflags |= 0100;
275 else if (!(inpflags & 0200) &&
276 sscanf(buf,
277 "go = %f*rn + %f*gn + %f*bn",
278 &mb->cmat[1][0], &mb->cmat[1][1],
279 &mb->cmat[1][2]) == 3)
280 inpflags |= 0200;
281 else if (!(inpflags & 0400) &&
282 sscanf(buf,
283 "bo = %f*rn + %f*gn + %f*bn",
284 &mb->cmat[2][0], &mb->cmat[2][1],
285 &mb->cmat[2][2]) == 3)
286 inpflags |= 0400;
287 }
288 if (inpflags != 0777) {
289 fprintf(stderr,
290 "%s: cannot grok macbethcal file \"%s\" (inpflags==0%o)\n",
291 progname, fn, inpflags);
292 exit(1);
293 }
294 fclose(fp);
295 /* compute gamut */
296 for (i = 0; i < 3; i++) {
297 colval(mb->cmin,i) = mb->xa[i][0] -
298 mb->ya[i][0] *
299 (mb->xa[i][1]-mb->xa[i][0]) /
300 (mb->ya[i][1]-mb->ya[i][0]);
301 colval(mb->cmax,i) = mb->xa[i][4] +
302 (1.-mb->ya[i][4]) *
303 (mb->xa[i][5] - mb->xa[i][4]) /
304 (mb->ya[i][5] - mb->ya[i][4]);
305 }
306 }
