root/radiance/ray/src/px/pcond2.c
Revision: 3.17
Committed: Thu Sep 8 22:29:47 2005 UTC (19 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1
Changes since 3.16: +9 -15 lines
Fix for XYZ input
2 static const char RCSid[] = "$Id: pcond2.c,v 3.16 2005/09/08 21:16:44 greg Exp $";
5 * Input and output conditioning routines for pcond.
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "pcond.h"
10 #include "warp3d.h"
11
12
13 RGBPRIMP inprims = stdprims; /* input primaries */
14 COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
15 RGBPRIMP outprims = stdprims; /* output primaries */
16
17 double (*lumf)() = rgblum; /* input luminance function */
18 double inpexp = 1.0; /* input exposure value */
19
20 char *mbcalfile = NULL; /* macbethcal mapping file */
21 char *cwarpfile = NULL; /* color space warping file */
22
23 static struct mbc {
24 COLORMAT cmat;
25 float xa[3][6], ya[3][6];
26 COLOR cmin, cmax;
27 } mbcond; /* macbethcal conditioning struct */
28
29 static WARP3D *cwarp; /* color warping structure */
30
31 static COLOR *scanbuf; /* scanline processing buffer */
32 static int nread; /* number of scanlines processed */
33
34 static void sfscan(COLOR *sl, int len, double sf);
35 static void matscan(COLOR *sl, int len, COLORMAT mat);
36 static void mbscan(COLOR *sl, int len, struct mbc *mb);
37 static void cwscan(COLOR *sl, int len, WARP3D *wp);
38 static void getmbcalfile(char *fn, struct mbc *mb);
39
40
41 extern double
42 rgblum( /* compute (scotopic) luminance of RGB color */
43 COLOR clr,
44 int scotopic
45 )
46 {
47 if (scotopic) /* approximate */
48 return( WHTSEFFICACY * (colval(clr,RED)*.062 +
49 colval(clr,GRN)*.608 + colval(clr,BLU)*.330) );
50 return( WHTEFFICACY * (colval(clr,RED)*inrgb2xyz[1][0] +
51 colval(clr,GRN)*inrgb2xyz[1][1] +
52 colval(clr,BLU)*inrgb2xyz[1][2]) );
53 }
54
55
56 extern double
57 cielum( /* compute (scotopic) luminance of CIE color */
58 COLOR xyz,
59 int scotopic
60 )
61 {
62 if (scotopic) /* approximate */
63 return(colval(xyz,CIEY) *
64 (1.33*(1. + (colval(xyz,CIEY)+colval(xyz,CIEZ))/
65 colval(xyz,CIEX)) - 1.68));
66 return(colval(xyz,CIEY));
67 }
68
69
70 extern COLOR *
71 nextscan(void) /* read and condition next scanline */
72 {
73 if (nread >= numscans(&inpres)) {
74 if (cwarpfile != NULL)
75 free3dw(cwarp);
76 free((void *)scanbuf);
77 return(scanbuf = NULL);
78 }
79 if (what2do&DO_ACUITY)
80 acuscan(scanbuf, nread);
81 else if (freadscan(scanbuf, scanlen(&inpres), infp) < 0) {
82 fprintf(stderr, "%s: %s: scanline read error\n",
83 progname, infn);
84 exit(1);
85 }
86 if (what2do&DO_VEIL) /* add veiling */
87 addveil(scanbuf, nread);
88 if (what2do&DO_COLOR) /* scotopic color loss */
89 scotscan(scanbuf, scanlen(&inpres));
90 if (what2do&DO_LINEAR) /* map luminances */
91 sfscan(scanbuf, scanlen(&inpres), scalef);
92 else
93 mapscan(scanbuf, scanlen(&inpres));
94 if (mbcalfile != NULL) /* device color correction */
95 mbscan(scanbuf, scanlen(&inpres), &mbcond);
96 else if (cwarpfile != NULL) /* device color space warp */
97 cwscan(scanbuf, scanlen(&inpres), cwarp);
98 else if ((lumf == cielum) | (inprims != outprims))
99 matscan(scanbuf, scanlen(&inpres), mbcond.cmat);
100 nread++;
101 return(scanbuf);
102 }
103
104
105 extern COLOR *
106 firstscan(void) /* return first processed scanline */
107 {
108 if (mbcalfile != NULL) /* load macbethcal file */
109 getmbcalfile(mbcalfile, &mbcond);
110 else if (cwarpfile != NULL) {
111 if ((cwarp = load3dw(cwarpfile, NULL)) == NULL)
112 syserror(cwarpfile);
113 } else
114 if (lumf == rgblum)
115 comprgb2rgbWBmat(mbcond.cmat, inprims, outprims);
116 else
117 compxyz2rgbWBmat(mbcond.cmat, outprims);
118 if (what2do&DO_ACUITY)
119 initacuity();
120 scanbuf = (COLOR *)malloc(scanlen(&inpres)*sizeof(COLOR));
121 if (scanbuf == NULL)
122 syserror("malloc");
123 nread = 0;
124 return(nextscan());
125 }
126
127
128 static void
129 sfscan( /* apply scalefactor to scanline */
130 register COLOR *sl,
131 int len,
132 double sf
133 )
134 {
135 while (len--) {
136 scalecolor(sl[0], sf);
137 sl++;
138 }
139 }
140
141
142 static double
143 greypoint( /* compute gamut mapping grey target */
144 COLOR col
145 )
146 {
147 COLOR gryc;
148 int i;
149 /* improves saturated color rendering */
150 copycolor(gryc, col);
151 for (i = 3; i--; )
152 if (gryc[i] > 1)
153 gryc[i] = 1;
154 else if (gryc[i] < 0)
155 gryc[i] = 0;
156 return(bright(gryc));
157 }
158
159
160 static void
161 matscan( /* apply color matrix to scaline */
162 register COLOR *sl,
163 int len,
164 COLORMAT mat
165 )
166 {
167 while (len--) {
168 colortrans(sl[0], mat, sl[0]);
169 clipgamut(sl[0], greypoint(sl[0]), CGAMUT, cblack, cwhite);
170 sl++;
171 }
172 }
173
174
175 static void
176 mbscan( /* apply macbethcal adj. to scaline */
177 COLOR *sl,
178 int len,
179 register struct mbc *mb
180 )
181 {
182 double d;
183 register int i, j;
184
185 while (len--) {
186 colortrans(sl[0], mb->cmat, sl[0]);
187 clipgamut(sl[0], greypoint(sl[0]), CGAMUT, mb->cmin, mb->cmax);
188 for (i = 0; i < 3; i++) {
189 d = colval(sl[0],i);
190 for (j = 0; j < 4 && mb->xa[i][j+1] <= d; j++)
191 ;
192 colval(sl[0],i) = ( (mb->xa[i][j+1] - d)*mb->ya[i][j] +
193 (d - mb->xa[i][j])*mb->ya[i][j+1] ) /
194 (mb->xa[i][j+1] - mb->xa[i][j]);
195 }
196 sl++;
197 }
198 }
199
200
201 static void
202 cwscan( /* apply color space warp to scaline */
203 COLOR *sl,
204 int len,
205 WARP3D *wp
206 )
207 {
208 int rval;
209
210 while (len--) {
211 rval = warp3d(sl[0], sl[0], wp);
212 if (rval & W3ERROR)
213 syserror("warp3d");
214 if (rval & W3BADMAP) {
215 fprintf(stderr, "%s: %s: bad color space map\n",
216 progname, cwarpfile);
217 exit(1);
218 }
219 clipgamut(sl[0], greypoint(sl[0]), CGAMUT, cblack, cwhite);
220 sl++;
221 }
222 }
223
224
225 static void
226 getmbcalfile( /* load macbethcal file */
227 char *fn,
228 register struct mbc *mb
229 )
230 {
231 char buf[128];
232 FILE *fp;
233 int inpflags = 0;
234 register int i;
235
236 if ((fp = fopen(fn, "r")) == NULL)
237 syserror(fn);
238 while (fgets(buf, sizeof(buf), fp) != NULL) {
239 if (!(inpflags & 01) &&
240 sscanf(buf,
241 "rxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
242 &mb->xa[0][0], &mb->xa[0][1],
243 &mb->xa[0][2], &mb->xa[0][3],
244 &mb->xa[0][4], &mb->xa[0][5]
245 ) == 6)
246 inpflags |= 01;
247 else if (!(inpflags & 02) &&
248 sscanf(buf,
249 "rya(i) : select(i,%f,%f,%f,%f,%f,%f)",
250 &mb->ya[0][0], &mb->ya[0][1],
251 &mb->ya[0][2], &mb->ya[0][3],
252 &mb->ya[0][4], &mb->ya[0][5]
253 ) == 6)
254 inpflags |= 02;
255 else if (!(inpflags & 04) &&
256 sscanf(buf,
257 "gxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
258 &mb->xa[1][0], &mb->xa[1][1],
259 &mb->xa[1][2], &mb->xa[1][3],
260 &mb->xa[1][4], &mb->xa[1][5]
261 ) == 6)
262 inpflags |= 04;
263 else if (!(inpflags & 010) &&
264 sscanf(buf,
265 "gya(i) : select(i,%f,%f,%f,%f,%f,%f)",
266 &mb->ya[1][0], &mb->ya[1][1],
267 &mb->ya[1][2], &mb->ya[1][3],
268 &mb->ya[1][4], &mb->ya[1][5]
269 ) == 6)
270 inpflags |= 010;
271 else if (!(inpflags & 020) &&
272 sscanf(buf,
273 "bxa(i) : select(i,%f,%f,%f,%f,%f,%f)",
274 &mb->xa[2][0], &mb->xa[2][1],
275 &mb->xa[2][2], &mb->xa[2][3],
276 &mb->xa[2][4], &mb->xa[2][5]
277 ) == 6)
278 inpflags |= 020;
279 else if (!(inpflags & 040) &&
280 sscanf(buf,
281 "bya(i) : select(i,%f,%f,%f,%f,%f,%f)",
282 &mb->ya[2][0], &mb->ya[2][1],
283 &mb->ya[2][2], &mb->ya[2][3],
284 &mb->ya[2][4], &mb->ya[2][5]
285 ) == 6)
286 inpflags |= 040;
287 else if (!(inpflags & 0100) &&
288 sscanf(buf,
289 "ro = %f*rn + %f*gn + %f*bn",
290 &mb->cmat[0][0], &mb->cmat[0][1],
291 &mb->cmat[0][2]) == 3)
292 inpflags |= 0100;
293 else if (!(inpflags & 0200) &&
294 sscanf(buf,
295 "go = %f*rn + %f*gn + %f*bn",
296 &mb->cmat[1][0], &mb->cmat[1][1],
297 &mb->cmat[1][2]) == 3)
298 inpflags |= 0200;
299 else if (!(inpflags & 0400) &&
300 sscanf(buf,
301 "bo = %f*rn + %f*gn + %f*bn",
302 &mb->cmat[2][0], &mb->cmat[2][1],
303 &mb->cmat[2][2]) == 3)
304 inpflags |= 0400;
305 }
306 if (inpflags != 0777) {
307 fprintf(stderr,
308 "%s: cannot grok macbethcal file \"%s\" (inpflags==0%o)\n",
309 progname, fn, inpflags);
310 exit(1);
311 }
312 fclose(fp);
313 /* compute gamut */
314 for (i = 0; i < 3; i++) {
315 colval(mb->cmin,i) = mb->xa[i][0] -
316 mb->ya[i][0] *
317 (mb->xa[i][1]-mb->xa[i][0]) /
318 (mb->ya[i][1]-mb->ya[i][0]);
319 colval(mb->cmax,i) = mb->xa[i][4] +
320 (1.-mb->ya[i][4]) *
321 (mb->xa[i][5] - mb->xa[i][4]) /
322 (mb->ya[i][5] - mb->ya[i][4]);
323 }
324 }
