root/Development/ray/src/px/pcond.h
Revision: 3.3
Committed: Fri Oct 11 10:46:59 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.2: +3 -0 lines
corrected tests in check2do()
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for picture file conditioning.
7 */
8
9 #include "standard.h"
10
11 #include "color.h"
12
13 #include "view.h"
14
15 #include "resolu.h"
16
17
18 #define SWNORM 2.26 /* scotopic/photopic ratio for white */
19 #define WHTSEFFICACY (SWNORM*WHTEFFICACY)
20
21 #define BotMesopic 5.62e-3 /* top of scotopic range */
22 #define TopMesopic 5.62 /* bottom of photopic range */
23
24 #define FOVDIA (1.0*PI/180.) /* foveal diameter (radians) */
25
26 #define HISTRES 100 /* histogram resolution */
27
28 #define LMIN 1e-4 /* minimum visible world luminance */
29 #define LMAX 1e5 /* maximum visible world luminance */
30
31 #define Bl(Lw) log(Lw) /* brightness function */
32 #define Bl1(Lw) (1.0/(Lw)) /* first derivative of Bl(Lw) */
33 #define Lb(Bw) exp(Bw) /* inverse of brightness function */
34 #define Lb1(Bw) exp(Bw) /* first derivative of Lb(Bw) */
35
36 /* Flags of what to do */
37 #define DO_ACUITY 01
38 #define DO_VEIL 02
39 #define DO_HSENS 04
40 #define DO_COLOR 010
41 #define DO_CWEIGHT 020
42 #define DO_LINEAR 040
43
44 #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR)
45
46 extern int what2do; /* desired adjustments */
47
48 extern double ldmax; /* maximum output luminance */
49 extern double ldmin; /* minimum output luminance */
50 extern double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */
51
52 extern char *progname; /* global argv[0] */
53
54 extern char *infn; /* input file name */
55 extern FILE *infp; /* input stream */
56 extern double rgblum(), cielum(); /* luminance functions */
57 extern double (*lumf)(); /* input luminance function */
58 extern double inpexp; /* input exposure value */
59
60 #define plum(clr) ((*lumf)(clr,0)/inpexp)
61 #define slum(clr) ((*lumf)(clr,1)/inpexp)
62
63 extern COLOR *fovimg; /* foveal (1 degree) averaged image */
64 extern short fvxr, fvyr; /* foveal image resolution */
65
66 #define fovscan(y) (fovimg+(y)*fvxr)
67
68 extern int bwhist[HISTRES]; /* luminance histogram */
69 extern long histot; /* total count of histogram */
70 extern double bwmin, bwmax; /* histogram limits */
71 extern double bwavg; /* mean brightness */
72
73 #define bwhc(B) bwhist[(int)(HISTRES*((B)-bwmin)/(bwmax-bwmin))]
74
75 extern RGBPRIMP inprims; /* input primaries */
76 extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
77
78 extern RGBPRIMP outprims; /* output primaries */
79
80 extern double scalef; /* linear scaling factor */
81
82 extern VIEW ourview; /* picture view */
83 extern double pixaspect; /* pixel aspect ratio */
84 extern RESOLU inpres; /* input picture resolution */
85
86 extern char *mbcalfile; /* macbethcal mapping file */
87
88 extern double hacuity(); /* human acuity func. (cycles/deg.) */
89 extern double htcontrs(); /* human contrast sens. func. */
90
91 extern COLOR *firstscan(); /* first processed scanline */
92 extern COLOR *nextscan(); /* next processed scanline */
