root/radiance/ray/src/px/pcond.h
Revision: 3.11
Committed: Mon Jul 14 22:24:00 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 3.10: +11 -3 lines
1 /* RCSid: $Id: pcond.h,v 3.10 2003/02/22 02:07:27 greg Exp $ */
2 /*
3 * Header file for picture file conditioning.
4 */
5 #ifndef _RAD_PCOND_H_
6 #define _RAD_PCOND_H_
7
8 #include "standard.h"
9 #include "color.h"
10 #include "view.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 #ifndef ADJ_VEIL
17 #define ADJ_VEIL 0 /* adjust veil to preserve contrast? */
18 #endif
19
20 #define SWNORM 2.26 /* scotopic/photopic ratio for white */
21 #define WHTSEFFICACY (SWNORM*WHTEFFICACY)
22
23 #define BotMesopic 5.62e-3 /* top of scotopic range */
24 #define TopMesopic 5.62 /* bottom of photopic range */
25
26 #define FOVDIA (1.0*PI/180.0) /* foveal diameter (radians) */
27
28 #define HISTRES 100 /* histogram resolution */
29 #define MAXPREHIST 1024 /* maximum precomputed histogram */
30
31 #define LMIN 1e-7 /* minimum visible world luminance */
32 #define LMAX 1e5 /* maximum visible world luminance */
33
34 #define Bl(Lw) log(Lw) /* brightness function */
35 #define Bl1(Lw) (1.0/(Lw)) /* first derivative of Bl(Lw) */
36 #define Lb(Bw) exp(Bw) /* inverse of brightness function */
37 #define Lb1(Bw) exp(Bw) /* first derivative of Lb(Bw) */
38
39 /* Flags of what to do */
40 #define DO_ACUITY 01
41 #define DO_VEIL 02
42 #define DO_HSENS 04
43 #define DO_COLOR 010
44 #define DO_CWEIGHT 020
45 #define DO_FIXHIST 040
46 #define DO_PREHIST 0100
47 #define DO_LINEAR 0200
48
49 #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR)
50
51 extern int what2do; /* desired adjustments */
52
53 extern double ldmax; /* maximum output luminance */
54 extern double lddyn; /* display dynamic range */
55 extern double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
56
57 extern char *progname; /* global argv[0] */
58
59 extern char *infn; /* input file name */
60 extern FILE *infp; /* input stream */
61 extern double rgblum(), cielum(); /* luminance functions */
62 extern double (*lumf)(); /* input luminance function */
63 extern double inpexp; /* input exposure value */
64
65 #define plum(clr) ((*lumf)(clr,0)/inpexp)
66 #define slum(clr) ((*lumf)(clr,1)/inpexp)
67
68 #define ldmin (ldmax/lddyn)
69
70 extern COLOR *fovimg; /* foveal (1 degree) averaged image */
71 extern int fvxr, fvyr; /* foveal image resolution */
72 extern float *crfimg; /* contrast reduction factors */
73
74 #define fovscan(y) (fovimg+(y)*fvxr)
75 #define crfscan(y) (crfimg+(y)*fvxr)
76
77 extern double fixfrac; /* histogram share due to fixations */
78 extern short (*fixlst)[2]; /* fixation history list */
79 extern int nfixations; /* number of fixation points */
80
81 extern double bwhist[HISTRES]; /* luminance histogram */
82 extern double histot; /* total count of histogram */
83 extern double bwmin, bwmax; /* histogram limits */
84 extern double bwavg; /* mean brightness */
85
86 #define bwhi(B) (int)(HISTRES*((B)-bwmin)/(bwmax-bwmin))
87
88 extern RGBPRIMP inprims; /* input primaries */
89 extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
90
91 extern RGBPRIMP outprims; /* output primaries */
92
93 extern double scalef; /* linear scaling factor */
94
95 extern VIEW ourview; /* picture view */
96 extern double pixaspect; /* pixel aspect ratio */
97 extern RESOLU inpres; /* input picture resolution */
98
99 extern char *mbcalfile; /* macbethcal mapping file */
100 extern char *cwarpfile; /* color warp mapping file */
101
102 extern double hacuity(); /* human acuity func. (cycles/deg.) */
103 extern double htcontrs(); /* human contrast sens. func. */
104 extern double clampf(); /* histogram clamping function */
105 extern double crfactor(); /* contrast reduction factor */
106
107 extern COLOR *firstscan(); /* first processed scanline */
108 extern COLOR *nextscan(); /* next processed scanline */
109
110 #ifdef __cplusplus
111 }
112 #endif
113 #endif /* _RAD_PCOND_H_ */
