root/Development/ray/src/px/pcond.h
Revision: 3.1
Committed: Thu Oct 3 16:52:49 1996 UTC (29 years, 1 month ago) by greg
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Header file for picture file conditioning.
7 */
8
9 #include "standard.h"
10
11 #include "color.h"
12
13 #include "view.h"
14
15 #include "resolu.h"
16
17
18 #define SWNORM 2.26 /* scotopic/photopic ratio for white */
19 #define WHTSEFFICACY (SWNORM*WHTEFFICACY)
20
21 #define FOVDIA (1.0*PI/180.) /* foveal diameter (radians) */
22
23 #define HISTRES 100 /* histogram resolution */
24
25 #define LMIN 1e-4 /* minimum visible world luminance */
26 #define LMAX 1e5 /* maximum visible world luminance */
27
28 #define Bl(Lw) log(Lw) /* brightness function */
29 #define Bl1(Lw) (1.0/(Lw)) /* first derivative of Bl(Lw) */
30 #define Lb(Bw) exp(Bw) /* inverse of brightness function */
31 #define Lb1(Bw) exp(Bw) /* first derivative of Lb(Bw) */
32
33 /* Flags of what to do */
34 #define DO_ACUITY 01
35 #define DO_VEIL 02
36 #define DO_HSENS 04
37 #define DO_COLOR 010
38 #define DO_CWEIGHT 020
39 #define DO_LINEAR 040
40
41 #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR)
42
43 extern int what2do; /* desired adjustments */
44
45 extern double ldmax; /* maximum output luminance */
46 extern double ldmin; /* minimum output luminance */
47 extern double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */
48
49 extern char *progname; /* global argv[0] */
50
51 extern char *infn; /* input file name */
52 extern FILE *infp; /* input stream */
53 extern double rgblum(), cielum(); /* luminance functions */
54 extern double (*lumf)(); /* input luminance function */
55 extern double inpexp; /* input exposure value */
56
57 #define plum(clr) ((*lumf)(clr,0)/inpexp)
58 #define slum(clr) ((*lumf)(clr,1)/inpexp)
59
60 extern COLOR *fovimg; /* foveal (1 degree) averaged image */
61 extern short fvxr, fvyr; /* foveal image resolution */
62
63 #define fovscan(y) (fovimg+(y)*fvxr)
64
65 extern int bwhist[HISTRES]; /* luminance histogram */
66 extern long histot; /* total count of histogram */
67 extern double bwmin, bwmax; /* histogram limits */
68 extern double bwavg; /* mean brightness */
69
70 #define lwhc(L) bwhc(Bl(L))
71 #define bwhc(B) bwhist[(int)(HISTRES*((B)-bwmin)/(bwmax-bwmin))]
72
73 extern RGBPRIMP inprims; /* input primaries */
74 extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
75
76 extern RGBPRIMP outprims; /* output primaries */
77
78 extern double scalef; /* linear scaling factor */
79
80 extern VIEW ourview; /* picture view */
81 extern double pixaspect; /* pixel aspect ratio */
82 extern RESOLU inpres; /* input picture resolution */
83
84 extern char *mbcalfile; /* macbethcal mapping file */
85
86 struct mbc { /* data structure for macbethcal conditioning */
87 float xa[3][6], ya[3][6];
88 COLORMAT cmat;
89 };
90
91 extern double hacuity(); /* human acuity func. (cycles/deg.) */
92 extern double htcontrs(); /* human contrast sens. func. */
93
94 extern COLOR *firstscan(); /* first processed scanline */
95 extern COLOR *nextscan(); /* next processed scanline */
