root/radiance/ray/src/px/pcond.h
Sat Jun 7 05:09:46 2025 UTC (2 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.15: +2 -1 lines
Diff to previous 3.15 , to selected 3.11
Thu Nov 30 18:43:05 2017 UTC (7 years, 8 months ago) by greg
CVS Tags: rad5R2, rad5R3, rad5R4
Diff to previous 3.14 , to selected 3.11
Fixed issue with missing veil from very bright sources like the sun
Sun Nov 14 16:57:18 2004 UTC (20 years, 9 months ago) by greg
CVS Tags: rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1
Changes since 3.13: +2 -2 lines
Diff to previous 3.13 , to selected 3.11
Mon Nov 8 15:50:59 2004 UTC (20 years, 9 months ago) by greg
Changes since 3.12: +3 -3 lines
Diff to previous 3.12 , to selected 3.11
Sun Mar 28 20:33:14 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.11: +32 -8 lines
Diff to previous 3.11
Revision 3.11 - (view) (download) (annotate) - [selected]
Mon Jul 14 22:24:00 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 3.10: +11 -3 lines
Diff to previous 3.10
Sat Feb 22 02:07:27 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.9: +11 -8 lines
Diff to previous 3.9 , to selected 3.11
Thu Mar 12 15:47:33 1998 UTC (27 years, 5 months ago) by gwlarson
Changes since 3.8: +3 -1 lines
Diff to previous 3.8 , to selected 3.11
added -I option for precomputed histogram
Mon Feb 9 13:22:26 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 3.7: +3 -3 lines
Diff to previous 3.7 , to selected 3.11
decreased lower threshold for histogram
Wed Mar 19 13:03:11 1997 UTC (28 years, 4 months ago) by greg
Changes since 3.6: +4 -2 lines
Diff to previous 3.6 , to selected 3.11
changed -t option to -u, -d option to -x and -b option to -d
Wed Feb 5 16:08:16 1997 UTC (28 years, 6 months ago) by greg
Diff to previous 3.5 , to selected 3.11
changed -m option to read in color warp map (old -m now -d)
Wed Jan 29 13:22:11 1997 UTC (28 years, 6 months ago) by greg
Changes since 3.4: +7 -2 lines
Diff to previous 3.4 , to selected 3.11
added -i option to take fixation points on standard input
Thu Jan 9 13:56:26 1997 UTC (28 years, 7 months ago) by greg
Changes since 3.3: +3 -3 lines
Diff to previous 3.3 , to selected 3.11
Fri Oct 11 10:46:59 1996 UTC (28 years, 10 months ago) by greg
Changes since 3.2: +3 -0 lines
Diff to previous 3.2 , to selected 3.11
corrected tests in check2do()
Fri Oct 4 18:34:56 1996 UTC (28 years, 10 months ago) by greg
Changes since 3.1: +1 -7 lines
Diff to previous 3.1 , to selected 3.11
minor cleanup
Thu Oct 3 16:52:49 1996 UTC (28 years, 10 months ago) by greg
Diff to selected 3.11
