| 1 |
/* RCSid: $Id: pcond.h,v 3.13 2004/11/08 15:50:59 greg Exp $ */ |
| 2 |
| 3 |
 * Header file for picture file conditioning. |
| 4 |
| 5 |
#ifndef _RAD_PCOND_H_ |
| 6 |
#define _RAD_PCOND_H_ |
| 7 |
| 8 |
#include "standard.h" |
| 9 |
#include "color.h" |
| 10 |
#include "view.h" |
| 11 |
| 12 |
#ifdef __cplusplus |
| 13 |
extern "C" { |
| 14 |
#endif |
| 15 |
| 16 |
#ifndef ADJ_VEIL |
| 17 |
#define ADJ_VEIL        0               /* adjust veil to preserve contrast? */ |
| 18 |
#endif |
| 19 |
| 20 |
#define SWNORM          2.26            /* scotopic/photopic ratio for white */ |
| 21 |
#define WHTSEFFICACY    (SWNORM*WHTEFFICACY) |
| 22 |
| 23 |
#define BotMesopic      5.62e-3         /* top of scotopic range */ |
| 24 |
#define TopMesopic      5.62            /* bottom of photopic range */ |
| 25 |
| 26 |
#define FOVDIA          (1.0*PI/180.0)  /* foveal diameter (radians) */ |
| 27 |
| 28 |
#define HISTRES         100             /* histogram resolution */ |
| 29 |
#define MAXPREHIST      1024            /* maximum precomputed histogram */ |
| 30 |
| 31 |
#define LMIN            1e-7            /* minimum visible world luminance */ |
| 32 |
#define LMAX            1e5             /* maximum visible world luminance */ |
| 33 |
| 34 |
#define Bl(Lw)          log(Lw)         /* brightness function */ |
| 35 |
#define Bl1(Lw)         (1.0/(Lw))      /* first derivative of Bl(Lw) */ |
| 36 |
#define Lb(Bw)          exp(Bw)         /* inverse of brightness function */ |
| 37 |
#define Lb1(Bw)         exp(Bw)         /* first derivative of Lb(Bw) */ |
| 38 |
| 39 |
                                /* Flags of what to do */ |
| 40 |
#define DO_ACUITY       01 |
| 41 |
#define DO_VEIL         02 |
| 42 |
#define DO_HSENS        04 |
| 43 |
#define DO_COLOR        010 |
| 44 |
#define DO_CWEIGHT      020 |
| 45 |
#define DO_FIXHIST      040 |
| 46 |
#define DO_PREHIST      0100 |
| 47 |
#define DO_LINEAR       0200 |
| 48 |
| 49 |
#define DO_HUMAN        (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR) |
| 50 |
| 51 |
extern int      what2do;                /* desired adjustments */ |
| 52 |
| 53 |
extern double   ldmax;                  /* maximum output luminance */ |
| 54 |
extern double   lddyn;                  /* display dynamic range */ |
| 55 |
extern double   Bldmin, Bldmax;         /* Bl(ldmax/lddyn) and Bl(ldmax) */ |
| 56 |
| 57 |
extern char     *progname;              /* global argv[0] */ |
| 58 |
| 59 |
extern char     *infn;                  /* input file name */ |
| 60 |
extern FILE     *infp;                  /* input stream */ |
| 61 |
extern double   (*lumf)();              /* input luminance function */ |
| 62 |
extern double   inpexp;                 /* input exposure value */ |
| 63 |
| 64 |
#define plum(clr)       ((*lumf)(clr,0)/inpexp) |
| 65 |
#define slum(clr)       ((*lumf)(clr,1)/inpexp) |
| 66 |
| 67 |
#define ldmin           (ldmax/lddyn) |
| 68 |
| 69 |
extern COLOR    *fovimg;                /* foveal (1 degree) averaged image */ |
| 70 |
extern int      fvxr, fvyr;             /* foveal image resolution */ |
| 71 |
extern float    *crfimg;                /* contrast reduction factors */ |
| 72 |
| 73 |
#define fovscan(y)      (fovimg+(y)*fvxr) |
| 74 |
#define crfscan(y)      (crfimg+(y)*fvxr) |
| 75 |
| 76 |
extern double   fixfrac;                /* histogram share due to fixations */ |
| 77 |
extern short    (*fixlst)[2];           /* fixation history list */ |
| 78 |
extern int      nfixations;             /* number of fixation points */ |
| 79 |
| 80 |
extern double   bwhist[HISTRES];        /* luminance histogram */ |
| 81 |
extern double   histot;                 /* total count of histogram */ |
| 82 |
extern double   bwmin, bwmax;           /* histogram limits */ |
| 83 |
extern double   bwavg;                  /* mean brightness */ |
| 84 |
| 85 |
#define bwhi(B)         (int)(HISTRES*((B)-bwmin)/(bwmax-bwmin)) |
| 86 |
| 87 |
extern RGBPRIMP inprims;                /* input primaries */ |
| 88 |
extern COLORMAT inrgb2xyz;              /* convert input RGB to XYZ */ |
| 89 |
| 90 |
extern RGBPRIMP outprims;               /* output primaries */ |
| 91 |
| 92 |
extern double   scalef;                 /* linear scaling factor */ |
| 93 |
| 94 |
extern VIEW     ourview;                /* picture view */ |
| 95 |
extern double   pixaspect;              /* pixel aspect ratio */ |
| 96 |
extern RESOLU   inpres;                 /* input picture resolution */ |
| 97 |
| 98 |
extern char     *mbcalfile;             /* macbethcal mapping file */ |
| 99 |
extern char     *cwarpfile;             /* color warp mapping file */ |
| 100 |
| 101 |
| 102 |
| 103 |
        /* defined in pcond.c */ |
| 104 |
extern void syserror(char *s); |
| 105 |
| 106 |
        /* defined in pcond2.c */ |
| 107 |
extern double rgblum(COLOR clr, int scotopic);  /* compute (scotopic) luminance of RGB color */ |
| 108 |
extern double cielum(COLOR xyz, int scotopic);  /* compute (scotopic) luminance of CIE color */ |
| 109 |
extern COLOR    *nextscan(void);                /* next processed scanline */ |
| 110 |
extern COLOR    *firstscan(void);               /* first processed scanline */ |
| 111 |
| 112 |
        /* defined in pcond3.c */ |
| 113 |
extern void getfixations(FILE *fp);     /* load fixation history list */ |
| 114 |
extern void gethisto(FILE *fp);         /* load precomputed luminance histogram */ |
| 115 |
extern void comphist(void);             /* create foveal sampling histogram */ |
| 116 |
extern double htcontrs(double La);      /* human contrast sens. func. */ |
| 117 |
extern double clampf(double La);        /* histogram clamping function */ |
| 118 |
extern double crfactor(double La);      /* contrast reduction factor */ |
| 119 |
extern int mkbrmap(void);               /* make dynamic range map */ |
| 120 |
extern void putmapping(FILE     *fp);   /* put out mapping function */ |
| 121 |
extern void scotscan(COLOR *scan, int xres);    /* apply scotopic color sensitivity loss */ |
| 122 |
extern void mapscan(COLOR *scan, int xres);     /* apply tone mapping operator to scanline */ |
| 123 |
| 124 |
        /* defined in pcond4.c */ |
| 125 |
extern void compveil(void);             /* compute veiling image */ |
| 126 |
#if ADJ_VEIL |
| 127 |
extern void adjveil(void);              /* adjust veil image */ |
| 128 |
#endif |
| 129 |
extern void acuscan(COLOR *scln, int y);        /* get acuity-sampled scanline */ |
| 130 |
extern void addveil(COLOR *sl, int y);  /* add veil to scanline */ |
| 131 |
extern void initacuity(void);           /* initialize variable acuity sampling */ |
| 132 |
extern double hacuity(double La);       /* human acuity func. (cycles/deg.) */ |
| 133 |
| 134 |
| 135 |
| 136 |
#endif |
| 137 |
#endif /* _RAD_PCOND_H_ */ |
