root/radiance/ray/src/px/pcond.h
Revision: 3.14
Committed: Sun Nov 14 16:57:18 2004 UTC (20 years, 7 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1
Changes since 3.13: +2 -2 lines
# User Rev Content
1 greg 3.14 /* RCSid: $Id: pcond.h,v 3.13 2004/11/08 15:50:59 greg Exp $ */
2 greg 3.1 /*
3     * Header file for picture file conditioning.
4     */
5 schorsch 3.11 #ifndef _RAD_PCOND_H_
6     #define _RAD_PCOND_H_
7 greg 3.1
8     #include "standard.h"
9     #include "color.h"
10     #include "view.h"
11
12 schorsch 3.11 #ifdef __cplusplus
13     extern "C" {
14     #endif
15 greg 3.1
16 greg 3.10 #ifndef ADJ_VEIL
17     #define ADJ_VEIL 0 /* adjust veil to preserve contrast? */
18     #endif
19 greg 3.1
20     #define SWNORM 2.26 /* scotopic/photopic ratio for white */
21     #define WHTSEFFICACY (SWNORM*WHTEFFICACY)
22
23 greg 3.3 #define BotMesopic 5.62e-3 /* top of scotopic range */
24     #define TopMesopic 5.62 /* bottom of photopic range */
25
26 greg 3.10 #define FOVDIA (1.0*PI/180.0) /* foveal diameter (radians) */
27 greg 3.1
28     #define HISTRES 100 /* histogram resolution */
29 gwlarson 3.9 #define MAXPREHIST 1024 /* maximum precomputed histogram */
30 greg 3.1
31 gwlarson 3.8 #define LMIN 1e-7 /* minimum visible world luminance */
32 greg 3.1 #define LMAX 1e5 /* maximum visible world luminance */
33
34     #define Bl(Lw) log(Lw) /* brightness function */
35     #define Bl1(Lw) (1.0/(Lw)) /* first derivative of Bl(Lw) */
36     #define Lb(Bw) exp(Bw) /* inverse of brightness function */
37     #define Lb1(Bw) exp(Bw) /* first derivative of Lb(Bw) */
38
39     /* Flags of what to do */
40 greg 3.2 #define DO_ACUITY 01
41 greg 3.1 #define DO_VEIL 02
42     #define DO_HSENS 04
43     #define DO_COLOR 010
44     #define DO_CWEIGHT 020
45 greg 3.5 #define DO_FIXHIST 040
46 gwlarson 3.9 #define DO_PREHIST 0100
47     #define DO_LINEAR 0200
48 greg 3.1
49     #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR)
50
51     extern int what2do; /* desired adjustments */
52
53     extern double ldmax; /* maximum output luminance */
54 greg 3.7 extern double lddyn; /* display dynamic range */
55     extern double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
56 greg 3.1
57     extern char *progname; /* global argv[0] */
58
59     extern char *infn; /* input file name */
60     extern FILE *infp; /* input stream */
61     extern double (*lumf)(); /* input luminance function */
62     extern double inpexp; /* input exposure value */
63
64     #define plum(clr) ((*lumf)(clr,0)/inpexp)
65     #define slum(clr) ((*lumf)(clr,1)/inpexp)
66 greg 3.7
67     #define ldmin (ldmax/lddyn)
68 greg 3.1
69     extern COLOR *fovimg; /* foveal (1 degree) averaged image */
70 greg 3.10 extern int fvxr, fvyr; /* foveal image resolution */
71     extern float *crfimg; /* contrast reduction factors */
72 greg 3.1
73     #define fovscan(y) (fovimg+(y)*fvxr)
74 greg 3.10 #define crfscan(y) (crfimg+(y)*fvxr)
75 greg 3.5
76     extern double fixfrac; /* histogram share due to fixations */
77     extern short (*fixlst)[2]; /* fixation history list */
78     extern int nfixations; /* number of fixation points */
79 greg 3.1
80 greg 3.10 extern double bwhist[HISTRES]; /* luminance histogram */
81 greg 3.4 extern double histot; /* total count of histogram */
82 greg 3.1 extern double bwmin, bwmax; /* histogram limits */
83     extern double bwavg; /* mean brightness */
84
85 greg 3.4 #define bwhi(B) (int)(HISTRES*((B)-bwmin)/(bwmax-bwmin))
86 greg 3.1
87     extern RGBPRIMP inprims; /* input primaries */
88     extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
89
90     extern RGBPRIMP outprims; /* output primaries */
91
92     extern double scalef; /* linear scaling factor */
93
94     extern VIEW ourview; /* picture view */
95     extern double pixaspect; /* pixel aspect ratio */
96     extern RESOLU inpres; /* input picture resolution */
97
98     extern char *mbcalfile; /* macbethcal mapping file */
99 greg 3.6 extern char *cwarpfile; /* color warp mapping file */
100 greg 3.1
101
102 schorsch 3.12
103     /* defined in pcond.c */
104     extern void syserror(char *s);
105
106     /* defined in pcond2.c */
107     extern double rgblum(COLOR clr, int scotopic); /* compute (scotopic) luminance of RGB color */
108     extern double cielum(COLOR xyz, int scotopic); /* compute (scotopic) luminance of CIE color */
109     extern COLOR *nextscan(void); /* next processed scanline */
110     extern COLOR *firstscan(void); /* first processed scanline */
111
112     /* defined in pcond3.c */
113     extern void getfixations(FILE *fp); /* load fixation history list */
114     extern void gethisto(FILE *fp); /* load precomputed luminance histogram */
115     extern void comphist(void); /* create foveal sampling histogram */
116     extern double htcontrs(double La); /* human contrast sens. func. */
117     extern double clampf(double La); /* histogram clamping function */
118     extern double crfactor(double La); /* contrast reduction factor */
119     extern int mkbrmap(void); /* make dynamic range map */
120     extern void putmapping(FILE *fp); /* put out mapping function */
121     extern void scotscan(COLOR *scan, int xres); /* apply scotopic color sensitivity loss */
122     extern void mapscan(COLOR *scan, int xres); /* apply tone mapping operator to scanline */
123
124     /* defined in pcond4.c */
125     extern void compveil(void); /* compute veiling image */
126     #if ADJ_VEIL
127     extern void adjveil(void); /* adjust veil image */
128     #endif
129     extern void acuscan(COLOR *scln, int y); /* get acuity-sampled scanline */
130 greg 3.13 extern void addveil(COLOR *sl, int y); /* add veil to scanline */
131 greg 3.14 extern void initacuity(void); /* initialize variable acuity sampling */
132 schorsch 3.12 extern double hacuity(double La); /* human acuity func. (cycles/deg.) */
133 schorsch 3.11
134     #ifdef __cplusplus
135     }
136     #endif
137     #endif /* _RAD_PCOND_H_ */
