--- ray/src/px/pcond.h 1997/01/09 13:56:26 3.4 +++ ray/src/px/pcond.h 2004/03/28 20:33:14 3.12 @@ -1,19 +1,21 @@ -/* Copyright (c) 1996 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: pcond.h,v 3.12 2004/03/28 20:33:14 schorsch Exp $ */ /* * Header file for picture file conditioning. */ +#ifndef _RAD_PCOND_H_ +#define _RAD_PCOND_H_ #include "standard.h" - #include "color.h" - #include "view.h" -#include "resolu.h" +#ifdef __cplusplus +extern "C" { +#endif +#ifndef ADJ_VEIL +#define ADJ_VEIL 0 /* adjust veil to preserve contrast? */ +#endif #define SWNORM 2.26 /* scotopic/photopic ratio for white */ #define WHTSEFFICACY (SWNORM*WHTEFFICACY) @@ -21,11 +23,12 @@ #define BotMesopic 5.62e-3 /* top of scotopic range */ #define TopMesopic 5.62 /* bottom of photopic range */ -#define FOVDIA (1.0*PI/180.) /* foveal diameter (radians) */ +#define FOVDIA (1.0*PI/180.0) /* foveal diameter (radians) */ #define HISTRES 100 /* histogram resolution */ +#define MAXPREHIST 1024 /* maximum precomputed histogram */ -#define LMIN 1e-4 /* minimum visible world luminance */ +#define LMIN 1e-7 /* minimum visible world luminance */ #define LMAX 1e5 /* maximum visible world luminance */ #define Bl(Lw) log(Lw) /* brightness function */ @@ -39,33 +42,42 @@ #define DO_HSENS 04 #define DO_COLOR 010 #define DO_CWEIGHT 020 -#define DO_LINEAR 040 +#define DO_FIXHIST 040 +#define DO_PREHIST 0100 +#define DO_LINEAR 0200 #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR) extern int what2do; /* desired adjustments */ extern double ldmax; /* maximum output luminance */ -extern double ldmin; /* minimum output luminance */ -extern double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */ +extern double lddyn; /* display dynamic range */ +extern double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */ extern char *progname; /* global argv[0] */ extern char *infn; /* input file name */ extern FILE *infp; /* input stream */ -extern double rgblum(), cielum(); /* luminance functions */ extern double (*lumf)(); /* input luminance function */ extern double inpexp; /* input exposure value */ #define plum(clr) ((*lumf)(clr,0)/inpexp) #define slum(clr) ((*lumf)(clr,1)/inpexp) +#define ldmin (ldmax/lddyn) + extern COLOR *fovimg; /* foveal (1 degree) averaged image */ -extern short fvxr, fvyr; /* foveal image resolution */ +extern int fvxr, fvyr; /* foveal image resolution */ +extern float *crfimg; /* contrast reduction factors */ #define fovscan(y) (fovimg+(y)*fvxr) +#define crfscan(y) (crfimg+(y)*fvxr) -extern float bwhist[HISTRES]; /* luminance histogram */ +extern double fixfrac; /* histogram share due to fixations */ +extern short (*fixlst)[2]; /* fixation history list */ +extern int nfixations; /* number of fixation points */ + +extern double bwhist[HISTRES]; /* luminance histogram */ extern double histot; /* total count of histogram */ extern double bwmin, bwmax; /* histogram limits */ extern double bwavg; /* mean brightness */ @@ -84,9 +96,42 @@ extern double pixaspect; /* pixel aspect ratio */ extern RESOLU inpres; /* input picture resolution */ extern char *mbcalfile; /* macbethcal mapping file */ +extern char *cwarpfile; /* color warp mapping file */ -extern double hacuity(); /* human acuity func. (cycles/deg.) */ -extern double htcontrs(); /* human contrast sens. func. */ -extern COLOR *firstscan(); /* first processed scanline */ -extern COLOR *nextscan(); /* next processed scanline */ + + /* defined in pcond.c */ +extern void syserror(char *s); + + /* defined in pcond2.c */ +extern double rgblum(COLOR clr, int scotopic); /* compute (scotopic) luminance of RGB color */ +extern double cielum(COLOR xyz, int scotopic); /* compute (scotopic) luminance of CIE color */ +extern COLOR *nextscan(void); /* next processed scanline */ +extern COLOR *firstscan(void); /* first processed scanline */ + + /* defined in pcond3.c */ +extern void getfixations(FILE *fp); /* load fixation history list */ +extern void gethisto(FILE *fp); /* load precomputed luminance histogram */ +extern void comphist(void); /* create foveal sampling histogram */ +extern double htcontrs(double La); /* human contrast sens. func. */ +extern double clampf(double La); /* histogram clamping function */ +extern double crfactor(double La); /* contrast reduction factor */ +extern int mkbrmap(void); /* make dynamic range map */ +extern void putmapping(FILE *fp); /* put out mapping function */ +extern void scotscan(COLOR *scan, int xres); /* apply scotopic color sensitivity loss */ +extern void mapscan(COLOR *scan, int xres); /* apply tone mapping operator to scanline */ + + /* defined in pcond4.c */ +extern void compveil(void); /* compute veiling image */ +#if ADJ_VEIL +extern void adjveil(void); /* adjust veil image */ +#endif +extern void acuscan(COLOR *scln, int y); /* get acuity-sampled scanline */ +extern void addveil(COLOR *sl, int y); /* add veil to scanline */ +extern void initacuity(void); /* initialize variable acuity sampling */ +extern double hacuity(double La); /* human acuity func. (cycles/deg.) */ + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_PCOND_H_ */
