--- ray/src/px/pcond.h 1996/10/11 10:46:59 3.3 +++ ray/src/px/pcond.h 2003/02/22 02:07:27 3.10 @@ -1,7 +1,4 @@ -/* Copyright (c) 1996 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: pcond.h,v 3.10 2003/02/22 02:07:27 greg Exp $ */ /* * Header file for picture file conditioning. */ @@ -12,8 +9,10 @@ #include "view.h" -#include "resolu.h" +#ifndef ADJ_VEIL +#define ADJ_VEIL 0 /* adjust veil to preserve contrast? */ +#endif #define SWNORM 2.26 /* scotopic/photopic ratio for white */ #define WHTSEFFICACY (SWNORM*WHTEFFICACY) @@ -21,11 +20,12 @@ #define BotMesopic 5.62e-3 /* top of scotopic range */ #define TopMesopic 5.62 /* bottom of photopic range */ -#define FOVDIA (1.0*PI/180.) /* foveal diameter (radians) */ +#define FOVDIA (1.0*PI/180.0) /* foveal diameter (radians) */ #define HISTRES 100 /* histogram resolution */ +#define MAXPREHIST 1024 /* maximum precomputed histogram */ -#define LMIN 1e-4 /* minimum visible world luminance */ +#define LMIN 1e-7 /* minimum visible world luminance */ #define LMAX 1e5 /* maximum visible world luminance */ #define Bl(Lw) log(Lw) /* brightness function */ @@ -39,15 +39,17 @@ #define DO_HSENS 04 #define DO_COLOR 010 #define DO_CWEIGHT 020 -#define DO_LINEAR 040 +#define DO_FIXHIST 040 +#define DO_PREHIST 0100 +#define DO_LINEAR 0200 #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR) extern int what2do; /* desired adjustments */ extern double ldmax; /* maximum output luminance */ -extern double ldmin; /* minimum output luminance */ -extern double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */ +extern double lddyn; /* display dynamic range */ +extern double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */ extern char *progname; /* global argv[0] */ @@ -60,17 +62,25 @@ extern double inpexp; /* input exposure value */ #define plum(clr) ((*lumf)(clr,0)/inpexp) #define slum(clr) ((*lumf)(clr,1)/inpexp) +#define ldmin (ldmax/lddyn) + extern COLOR *fovimg; /* foveal (1 degree) averaged image */ -extern short fvxr, fvyr; /* foveal image resolution */ +extern int fvxr, fvyr; /* foveal image resolution */ +extern float *crfimg; /* contrast reduction factors */ #define fovscan(y) (fovimg+(y)*fvxr) +#define crfscan(y) (crfimg+(y)*fvxr) -extern int bwhist[HISTRES]; /* luminance histogram */ -extern long histot; /* total count of histogram */ +extern double fixfrac; /* histogram share due to fixations */ +extern short (*fixlst)[2]; /* fixation history list */ +extern int nfixations; /* number of fixation points */ + +extern double bwhist[HISTRES]; /* luminance histogram */ +extern double histot; /* total count of histogram */ extern double bwmin, bwmax; /* histogram limits */ extern double bwavg; /* mean brightness */ -#define bwhc(B) bwhist[(int)(HISTRES*((B)-bwmin)/(bwmax-bwmin))] +#define bwhi(B) (int)(HISTRES*((B)-bwmin)/(bwmax-bwmin)) extern RGBPRIMP inprims; /* input primaries */ extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */ @@ -84,9 +94,12 @@ extern double pixaspect; /* pixel aspect ratio */ extern RESOLU inpres; /* input picture resolution */ extern char *mbcalfile; /* macbethcal mapping file */ +extern char *cwarpfile; /* color warp mapping file */ extern double hacuity(); /* human acuity func. (cycles/deg.) */ extern double htcontrs(); /* human contrast sens. func. */ +extern double clampf(); /* histogram clamping function */ +extern double crfactor(); /* contrast reduction factor */ extern COLOR *firstscan(); /* first processed scanline */ extern COLOR *nextscan(); /* next processed scanline */
