--- ray/src/px/pcond.h 2003/07/14 22:24:00 3.11 +++ ray/src/px/pcond.h 2004/11/08 15:50:59 3.13 @@ -1,4 +1,4 @@ -/* RCSid: $Id: pcond.h,v 3.11 2003/07/14 22:24:00 schorsch Exp $ */ +/* RCSid: $Id: pcond.h,v 3.13 2004/11/08 15:50:59 greg Exp $ */ /* * Header file for picture file conditioning. */ @@ -58,7 +58,6 @@ extern char *progname; /* global argv[0] */ extern char *infn; /* input file name */ extern FILE *infp; /* input stream */ -extern double rgblum(), cielum(); /* luminance functions */ extern double (*lumf)(); /* input luminance function */ extern double inpexp; /* input exposure value */ @@ -99,13 +98,38 @@ extern RESOLU inpres; /* input picture resolution */ extern char *mbcalfile; /* macbethcal mapping file */ extern char *cwarpfile; /* color warp mapping file */ -extern double hacuity(); /* human acuity func. (cycles/deg.) */ -extern double htcontrs(); /* human contrast sens. func. */ -extern double clampf(); /* histogram clamping function */ -extern double crfactor(); /* contrast reduction factor */ -extern COLOR *firstscan(); /* first processed scanline */ -extern COLOR *nextscan(); /* next processed scanline */ + + /* defined in pcond.c */ +extern void syserror(char *s); + + /* defined in pcond2.c */ +extern double rgblum(COLOR clr, int scotopic); /* compute (scotopic) luminance of RGB color */ +extern double cielum(COLOR xyz, int scotopic); /* compute (scotopic) luminance of CIE color */ +extern COLOR *nextscan(void); /* next processed scanline */ +extern COLOR *firstscan(void); /* first processed scanline */ + + /* defined in pcond3.c */ +extern void getfixations(FILE *fp); /* load fixation history list */ +extern void gethisto(FILE *fp); /* load precomputed luminance histogram */ +extern void comphist(void); /* create foveal sampling histogram */ +extern double htcontrs(double La); /* human contrast sens. func. */ +extern double clampf(double La); /* histogram clamping function */ +extern double crfactor(double La); /* contrast reduction factor */ +extern int mkbrmap(void); /* make dynamic range map */ +extern void putmapping(FILE *fp); /* put out mapping function */ +extern void scotscan(COLOR *scan, int xres); /* apply scotopic color sensitivity loss */ +extern void mapscan(COLOR *scan, int xres); /* apply tone mapping operator to scanline */ + + /* defined in pcond4.c */ +extern void compveil(void); /* compute veiling image */ +#if ADJ_VEIL +extern void adjveil(void); /* adjust veil image */ +#endif +extern void acuscan(COLOR *scln, int y); /* get acuity-sampled scanline */ +extern void addveil(COLOR *sl, int y); /* add veil to scanline */ +extern int initacuity(void); /* initialize variable acuity sampling */ +extern double hacuity(double La); /* human acuity func. (cycles/deg.) */ #ifdef __cplusplus }
