1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
/* SCCSid "$SunId$ SGI" */ |
4 |
5 |
6 |
* Header file for picture file conditioning. |
7 |
8 |
9 |
#include "standard.h" |
10 |
11 |
#include "color.h" |
12 |
13 |
#include "view.h" |
14 |
15 |
#include "resolu.h" |
16 |
17 |
18 |
#define SWNORM 2.26 /* scotopic/photopic ratio for white */ |
19 |
#define WHTSEFFICACY (SWNORM*WHTEFFICACY) |
20 |
21 |
#define BotMesopic 5.62e-3 /* top of scotopic range */ |
22 |
#define TopMesopic 5.62 /* bottom of photopic range */ |
23 |
24 |
#define FOVDIA (1.0*PI/180.) /* foveal diameter (radians) */ |
25 |
26 |
#define HISTRES 100 /* histogram resolution */ |
27 |
#define MAXPREHIST 1024 /* maximum precomputed histogram */ |
28 |
29 |
#define LMIN 1e-7 /* minimum visible world luminance */ |
30 |
#define LMAX 1e5 /* maximum visible world luminance */ |
31 |
32 |
#define Bl(Lw) log(Lw) /* brightness function */ |
33 |
#define Bl1(Lw) (1.0/(Lw)) /* first derivative of Bl(Lw) */ |
34 |
#define Lb(Bw) exp(Bw) /* inverse of brightness function */ |
35 |
#define Lb1(Bw) exp(Bw) /* first derivative of Lb(Bw) */ |
36 |
37 |
/* Flags of what to do */ |
38 |
#define DO_ACUITY 01 |
39 |
#define DO_VEIL 02 |
40 |
#define DO_HSENS 04 |
41 |
#define DO_COLOR 010 |
42 |
#define DO_CWEIGHT 020 |
43 |
#define DO_FIXHIST 040 |
44 |
#define DO_PREHIST 0100 |
45 |
#define DO_LINEAR 0200 |
46 |
47 |
#define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR) |
48 |
49 |
extern int what2do; /* desired adjustments */ |
50 |
51 |
extern double ldmax; /* maximum output luminance */ |
52 |
extern double lddyn; /* display dynamic range */ |
53 |
extern double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */ |
54 |
55 |
extern char *progname; /* global argv[0] */ |
56 |
57 |
extern char *infn; /* input file name */ |
58 |
extern FILE *infp; /* input stream */ |
59 |
extern double rgblum(), cielum(); /* luminance functions */ |
60 |
extern double (*lumf)(); /* input luminance function */ |
61 |
extern double inpexp; /* input exposure value */ |
62 |
63 |
#define plum(clr) ((*lumf)(clr,0)/inpexp) |
64 |
#define slum(clr) ((*lumf)(clr,1)/inpexp) |
65 |
66 |
#define ldmin (ldmax/lddyn) |
67 |
68 |
extern COLOR *fovimg; /* foveal (1 degree) averaged image */ |
69 |
extern short fvxr, fvyr; /* foveal image resolution */ |
70 |
71 |
#define fovscan(y) (fovimg+(y)*fvxr) |
72 |
73 |
extern double fixfrac; /* histogram share due to fixations */ |
74 |
extern short (*fixlst)[2]; /* fixation history list */ |
75 |
extern int nfixations; /* number of fixation points */ |
76 |
77 |
extern float bwhist[HISTRES]; /* luminance histogram */ |
78 |
extern double histot; /* total count of histogram */ |
79 |
extern double bwmin, bwmax; /* histogram limits */ |
80 |
extern double bwavg; /* mean brightness */ |
81 |
82 |
#define bwhi(B) (int)(HISTRES*((B)-bwmin)/(bwmax-bwmin)) |
83 |
84 |
extern RGBPRIMP inprims; /* input primaries */ |
85 |
extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */ |
86 |
87 |
extern RGBPRIMP outprims; /* output primaries */ |
88 |
89 |
extern double scalef; /* linear scaling factor */ |
90 |
91 |
extern VIEW ourview; /* picture view */ |
92 |
extern double pixaspect; /* pixel aspect ratio */ |
93 |
extern RESOLU inpres; /* input picture resolution */ |
94 |
95 |
extern char *mbcalfile; /* macbethcal mapping file */ |
96 |
extern char *cwarpfile; /* color warp mapping file */ |
97 |
98 |
extern double hacuity(); /* human acuity func. (cycles/deg.) */ |
99 |
extern double htcontrs(); /* human contrast sens. func. */ |
100 |
101 |
extern COLOR *firstscan(); /* first processed scanline */ |
102 |
extern COLOR *nextscan(); /* next processed scanline */ |
