root/Development/ray/src/px/pcond.h
Revision: 3.16
Committed: Sat Jun 7 05:09:46 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 3.15: +2 -1 lines
1 /* RCSid: $Id: pcond.h,v 3.15 2017/11/30 18:43:05 greg Exp $ */
2 /*
3 * Header file for picture file conditioning.
4 */
5 #ifndef _RAD_PCOND_H_
6 #define _RAD_PCOND_H_
7
8 #include "standard.h"
9 #include "color.h"
10 #include "view.h"
11 #include "paths.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 #ifndef ADJ_VEIL
18 #define ADJ_VEIL 0 /* adjust veil to preserve contrast? */
19 #endif
20
21 #define SWNORM 2.26 /* scotopic/photopic ratio for white */
22 #define WHTSEFFICACY (SWNORM*WHTEFFICACY)
23
24 #define BotMesopic 5.62e-3 /* top of scotopic range */
25 #define TopMesopic 5.62 /* bottom of photopic range */
26
27 #define FOVDIA (1.0*PI/180.0) /* foveal diameter (radians) */
28
29 #define HISTRES 100 /* histogram resolution */
30 #define MAXPREHIST 1024 /* maximum precomputed histogram */
31
32 #define LMIN 1e-7 /* minimum visible world luminance */
33 #define LMAX 1e7 /* maximum visible world luminance */
34
35 #define Bl(Lw) log(Lw) /* brightness function */
36 #define Bl1(Lw) (1.0/(Lw)) /* first derivative of Bl(Lw) */
37 #define Lb(Bw) exp(Bw) /* inverse of brightness function */
38 #define Lb1(Bw) exp(Bw) /* first derivative of Lb(Bw) */
39
40 /* Flags of what to do */
41 #define DO_ACUITY 01
42 #define DO_VEIL 02
43 #define DO_HSENS 04
44 #define DO_COLOR 010
45 #define DO_CWEIGHT 020
46 #define DO_FIXHIST 040
47 #define DO_PREHIST 0100
48 #define DO_LINEAR 0200
49
50 #define DO_HUMAN (DO_ACUITY|DO_VEIL|DO_HSENS|DO_COLOR)
51
52 extern int what2do; /* desired adjustments */
53
54 extern double ldmax; /* maximum output luminance */
55 extern double lddyn; /* display dynamic range */
56 extern double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
57
58 extern char *progname; /* global argv[0] */
59
60 extern char *infn; /* input file name */
61 extern FILE *infp; /* input stream */
62 extern double (*lumf)(); /* input luminance function */
63 extern double inpexp; /* input exposure value */
64
65 #define plum(clr) ((*lumf)(clr,0)/inpexp)
66 #define slum(clr) ((*lumf)(clr,1)/inpexp)
67
68 #define ldmin (ldmax/lddyn)
69
70 extern COLOR *fovimg; /* foveal (1 degree) averaged image */
71 extern int fvxr, fvyr; /* foveal image resolution */
72 extern float *crfimg; /* contrast reduction factors */
73
74 #define fovscan(y) (fovimg+(y)*fvxr)
75 #define crfscan(y) (crfimg+(y)*fvxr)
76
77 extern double fixfrac; /* histogram share due to fixations */
78 extern short (*fixlst)[2]; /* fixation history list */
79 extern int nfixations; /* number of fixation points */
80
81 extern double bwhist[HISTRES]; /* luminance histogram */
82 extern double histot; /* total count of histogram */
83 extern double bwmin, bwmax; /* histogram limits */
84 extern double bwavg; /* mean brightness */
85
86 #define bwhi(B) (int)(HISTRES*((B)-bwmin)/(bwmax-bwmin))
87
88 extern RGBPRIMP inprims; /* input primaries */
89 extern COLORMAT inrgb2xyz; /* convert input RGB to XYZ */
90
91 extern RGBPRIMP outprims; /* output primaries */
92
93 extern double scalef; /* linear scaling factor */
94
95 extern VIEW ourview; /* picture view */
96 extern double pixaspect; /* pixel aspect ratio */
97 extern RESOLU inpres; /* input picture resolution */
98
99 extern char *mbcalfile; /* macbethcal mapping file */
100 extern char *cwarpfile; /* color warp mapping file */
101
102
103
104 /* defined in pcond.c */
105 extern void syserror(char *s);
106
107 /* defined in pcond2.c */
108 extern double rgblum(COLOR clr, int scotopic); /* compute (scotopic) luminance of RGB color */
109 extern double cielum(COLOR xyz, int scotopic); /* compute (scotopic) luminance of CIE color */
110 extern COLOR *nextscan(void); /* next processed scanline */
111 extern COLOR *firstscan(void); /* first processed scanline */
112
113 /* defined in pcond3.c */
114 extern void getfixations(FILE *fp); /* load fixation history list */
115 extern void gethisto(FILE *fp); /* load precomputed luminance histogram */
116 extern void comphist(void); /* create foveal sampling histogram */
117 extern double htcontrs(double La); /* human contrast sens. func. */
118 extern double clampf(double La); /* histogram clamping function */
119 extern double crfactor(double La); /* contrast reduction factor */
120 extern int mkbrmap(void); /* make dynamic range map */
121 extern void putmapping(FILE *fp); /* put out mapping function */
122 extern void scotscan(COLOR *scan, int xres); /* apply scotopic color sensitivity loss */
123 extern void mapscan(COLOR *scan, int xres); /* apply tone mapping operator to scanline */
124
125 /* defined in pcond4.c */
126 extern void compveil(void); /* compute veiling image */
127 #if ADJ_VEIL
128 extern void adjveil(void); /* adjust veil image */
129 #endif
130 extern void acuscan(COLOR *scln, int y); /* get acuity-sampled scanline */
131 extern void addveil(COLOR *sl, int y); /* add veil to scanline */
132 extern void initacuity(void); /* initialize variable acuity sampling */
133 extern double hacuity(double La); /* human acuity func. (cycles/deg.) */
134
135 #ifdef __cplusplus
136 }
137 #endif
138 #endif /* _RAD_PCOND_H_ */
