1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pcond.c,v 3.32 2023/10/27 16:35:02 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Condition Radiance picture for display/output |
6 |
* Added white-balance adjustment 10/01 (GW). |
7 |
8 |
9 |
#include "platform.h" |
10 |
#include "paths.h" |
11 |
#include "pcond.h" |
12 |
13 |
14 |
#define LDMAX 100 /* default max. display luminance */ |
15 |
#define LDDYN 100 /* default dynamic range */ |
16 |
17 |
int what2do = 0; /* desired adjustments */ |
18 |
19 |
double ldmax = LDMAX; /* maximum output luminance */ |
20 |
double lddyn = LDDYN; /* display dynamic range */ |
21 |
double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */ |
22 |
23 |
char *progname; /* global argv[0] */ |
24 |
25 |
char *infn; /* input file name */ |
26 |
FILE *infp; /* input stream */ |
27 |
FILE *mapfp = NULL; /* tone-mapping function stream */ |
28 |
VIEW ourview = STDVIEW; /* picture view */ |
29 |
int gotview = 0; /* picture has view */ |
30 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
31 |
double fixfrac = 0.; /* histogram share due to fixations */ |
32 |
RESOLU inpres; /* input picture resolution */ |
33 |
34 |
COLOR *fovimg; /* foveal (1 degree) averaged image */ |
35 |
int fvxr, fvyr; /* foveal image resolution */ |
36 |
float *crfimg; /* contrast reduction factors */ |
37 |
short (*fixlst)[2]; /* fixation history list */ |
38 |
int nfixations; /* number of fixation points */ |
39 |
double bwhist[HISTRES]; /* luminance histogram */ |
40 |
double histot; /* total count of histogram */ |
41 |
double bwmin, bwmax; /* histogram limits */ |
42 |
double bwavg; /* mean brightness */ |
43 |
44 |
double scalef = 0.; /* linear scaling factor */ |
45 |
46 |
static gethfunc headline; |
47 |
static void getahead(void); |
48 |
static void mapimage(void); |
49 |
static void getfovimg(void); |
50 |
static void check2do(void); |
51 |
52 |
53 |
54 |
int |
55 |
main( |
56 |
int argc, |
57 |
char *argv[] |
58 |
59 |
60 |
static RGBPRIMS outprimS; |
61 |
int i; |
62 |
#define check_bool(flg) switch (argv[i][2]) { \ |
63 |
case '\0': what2do ^= flg; break; \ |
64 |
case 'y': case 'Y': case 't': case 'T': \ |
65 |
case '+': case '1': what2do |= flg; break; \ |
66 |
case 'n': case 'N': case 'f': case 'F': \ |
67 |
case '-': case '0': what2do &= ~(flg); break; \ |
68 |
default: goto userr; } |
69 |
70 |
progname = argv[0]; |
71 |
72 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
73 |
switch (argv[i][1]) { |
74 |
case 'h': |
75 |
check_bool(DO_HUMAN); |
76 |
break; |
77 |
case 'a': |
78 |
check_bool(DO_ACUITY); |
79 |
break; |
80 |
case 'v': |
81 |
check_bool(DO_VEIL); |
82 |
break; |
83 |
case 's': |
84 |
check_bool(DO_HSENS); |
85 |
break; |
86 |
case 'c': |
87 |
check_bool(DO_COLOR); |
88 |
break; |
89 |
case 'w': |
90 |
check_bool(DO_CWEIGHT); |
91 |
break; |
92 |
case 'i': |
93 |
if (i+1 >= argc) goto userr; |
94 |
fixfrac = atof(argv[++i]); |
95 |
if (fixfrac > FTINY) what2do |= DO_FIXHIST; |
96 |
else what2do &= ~DO_FIXHIST; |
97 |
break; |
98 |
case 'I': |
99 |
check_bool(DO_PREHIST); |
100 |
break; |
101 |
case 'l': |
102 |
check_bool(DO_LINEAR); |
103 |
break; |
104 |
case 'p': |
105 |
if (i+8 >= argc) goto userr; |
106 |
outprimS[RED][CIEX] = atof(argv[++i]); |
107 |
outprimS[RED][CIEY] = atof(argv[++i]); |
108 |
outprimS[GRN][CIEX] = atof(argv[++i]); |
109 |
outprimS[GRN][CIEY] = atof(argv[++i]); |
110 |
outprimS[BLU][CIEX] = atof(argv[++i]); |
111 |
outprimS[BLU][CIEY] = atof(argv[++i]); |
112 |
outprimS[WHT][CIEX] = atof(argv[++i]); |
113 |
outprimS[WHT][CIEY] = atof(argv[++i]); |
114 |
outprims = outprimS; |
115 |
break; |
116 |
case 'e': |
117 |
118 |
scalef = atof(argv[++i]); |
119 |
if ((argv[i][0] == '+') | (argv[i][0] == '-')) |
120 |
scalef = pow(2.0, scalef); |
121 |
what2do |= DO_LINEAR; |
122 |
break; |
123 |
case 'f': |
124 |
125 |
mbcalfile = argv[++i]; |
126 |
break; |
127 |
case 'm': |
128 |
129 |
cwarpfile = argv[++i]; |
130 |
break; |
131 |
case 'u': |
132 |
133 |
ldmax = atof(argv[++i]); |
134 |
if (ldmax <= FTINY) |
135 |
goto userr; |
136 |
break; |
137 |
case 'd': |
138 |
139 |
lddyn = atof(argv[++i]); |
140 |
break; |
141 |
case 'x': |
142 |
143 |
if ((mapfp = fopen(argv[++i], "w")) == NULL) { |
144 |
fprintf(stderr, |
145 |
"%s: cannot open for writing\n", |
146 |
argv[i]); |
147 |
exit(1); |
148 |
149 |
break; |
150 |
default: |
151 |
goto userr; |
152 |
153 |
if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) { |
154 |
fprintf(stderr, "%s: only one of -i or -I option\n", progname); |
155 |
exit(1); |
156 |
157 |
if ((mbcalfile != NULL) + (cwarpfile != NULL) + |
158 |
(outprims != stdprims) > 1) { |
159 |
fprintf(stderr, |
160 |
"%s: only one of -p, -m or -f option supported\n", |
161 |
progname); |
162 |
exit(1); |
163 |
164 |
if ((outprims == stdprims) & (inprims != stdprims)) |
165 |
outprims = inprims; |
166 |
Bldmin = Bl(ldmax/lddyn); |
167 |
Bldmax = Bl(ldmax); |
168 |
if (i >= argc || i+2 < argc) |
169 |
goto userr; |
170 |
/* open input file */ |
171 |
if ((infp = fopen(infn=argv[i], "r")) == NULL) |
172 |
syserror(infn); |
173 |
/* open output file */ |
174 |
if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL) |
175 |
syserror(argv[i+1]); |
176 |
SET_FILE_BINARY(infp); |
177 |
SET_FILE_BINARY(stdout); |
178 |
getahead(); /* load input header */ |
179 |
printargs(argc, argv, stdout); /* add to output header */ |
180 |
if ((mbcalfile == NULL) & (outprims != stdprims)) |
181 |
fputprims(outprims, stdout); |
182 |
if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST) |
183 |
getfovimg(); /* get foveal sample image? */ |
184 |
if (what2do&DO_PREHIST) /* get histogram? */ |
185 |
gethisto(stdin); |
186 |
else if (what2do&DO_FIXHIST) /* get fixation history? */ |
187 |
getfixations(stdin); |
188 |
mapimage(); /* map the picture */ |
189 |
if (mapfp != NULL) /* write out basic mapping */ |
190 |
putmapping(mapfp); |
191 |
exit(0); |
192 |
userr: |
193 |
fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n", |
194 |
progname); |
195 |
exit(1); |
196 |
return 1; /* pro forma return */ |
197 |
#undef check_bool |
198 |
199 |
200 |
201 |
void |
202 |
syserror( /* report system error and exit */ |
203 |
char *s |
204 |
205 |
206 |
fprintf(stderr, "%s: ", progname); |
207 |
perror(s); |
208 |
exit(2); |
209 |
210 |
211 |
212 |
static int |
213 |
headline( /* process header line */ |
214 |
char *s, |
215 |
void *p |
216 |
217 |
218 |
static RGBPRIMS inprimS; |
219 |
char fmt[MAXFMTLEN]; |
220 |
221 |
if (formatval(fmt, s)) { /* check if format string */ |
222 |
if (!strcmp(fmt,COLRFMT) || !strcmp(fmt,SPECFMT)) |
223 |
lumf = rgblum; |
224 |
else if (!strcmp(fmt,CIEFMT)) |
225 |
lumf = cielum; |
226 |
else |
227 |
lumf = NULL; |
228 |
return(0); /* don't echo */ |
229 |
230 |
if (isncomp(s)) { |
231 |
NCSAMP = ncompval(s); |
232 |
return(0); |
233 |
234 |
if (iswlsplit(s)) { |
235 |
wlsplitval(WLPART, s); |
236 |
return(0); |
237 |
238 |
/* get input primaries */ |
239 |
if (isprims(s) && primsval(inprimS, s)) { |
240 |
inprims = inprimS; |
241 |
242 |
243 |
if (isexpos(s)) { /* picture exposure */ |
244 |
inpexp *= exposval(s); |
245 |
246 |
247 |
if (isaspect(s)) /* pixel aspect ratio */ |
248 |
pixaspect *= aspectval(s); |
249 |
if (isview(s)) /* image view */ |
250 |
gotview += sscanview(&ourview, s); |
251 |
return(fputs(s, stdout)); |
252 |
253 |
254 |
255 |
static void |
256 |
getahead(void) /* load picture header */ |
257 |
258 |
char *err; |
259 |
260 |
getheader(infp, headline, NULL); |
261 |
if (lumf == NULL || !fgetsresolu(&inpres, infp)) { |
262 |
fprintf(stderr, "%s: %s: not a Radiance picture\n", |
263 |
progname, infn); |
264 |
exit(1); |
265 |
266 |
if (lumf == rgblum) |
267 |
comprgb2xyzWBmat(inrgb2xyz, inprims); |
268 |
else if (mbcalfile != NULL) { |
269 |
fprintf(stderr, "%s: macbethcal only works with RGB pictures\n", |
270 |
progname); |
271 |
exit(1); |
272 |
273 |
if (!gotview || ourview.type == VT_PAR || |
274 |
(ourview.horiz <= 5.) | (ourview.vert <= 5.)) { |
275 |
ourview = stdview; |
276 |
ourview.type = VT_PER; |
277 |
if (pixaspect*inpres.yr < inpres.xr) { |
278 |
ourview.horiz = 40.0; |
279 |
ourview.vert = 2.*180./PI * |
280 |
atan(.3639702*pixaspect*inpres.yr/inpres.xr); |
281 |
} else { |
282 |
ourview.vert = 40.0; |
283 |
ourview.horiz = 2.*180./PI * |
284 |
atan(.3639702*inpres.xr/pixaspect/inpres.yr); |
285 |
286 |
287 |
if ((err = setview(&ourview)) != NULL) { |
288 |
fprintf(stderr, "%s: view error in picture \"%s\": %s\n", |
289 |
progname, infn, err); |
290 |
exit(1); |
291 |
292 |
293 |
294 |
295 |
static void |
296 |
mapimage(void) /* map picture and send to stdout */ |
297 |
298 |
COLOR *scan; |
299 |
300 |
comphist(); /* generate adaptation histogram */ |
301 |
check2do(); /* modify what2do flags */ |
302 |
if (what2do&DO_VEIL) |
303 |
compveil(); /* compute veil image */ |
304 |
if (!(what2do&DO_LINEAR)) |
305 |
if (mkbrmap() < 0) /* make tone map */ |
306 |
what2do |= DO_LINEAR; /* failed! -- use linear */ |
307 |
#if ADJ_VEIL |
308 |
else if (what2do&DO_VEIL) |
309 |
adjveil(); /* else adjust veil image */ |
310 |
#endif |
311 |
if (what2do&DO_LINEAR) { |
312 |
if (scalef <= FTINY) { |
313 |
if (what2do&DO_HSENS) |
314 |
scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) / |
315 |
htcontrs(Lb(bwavg)); |
316 |
else |
317 |
scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg); |
318 |
scalef *= WHTEFFICACY/(inpexp*ldmax); |
319 |
320 |
fputexpos(inpexp*scalef, stdout); /* record exposure */ |
321 |
if (lumf == cielum) scalef /= WHTEFFICACY; |
322 |
323 |
fputformat(COLRFMT, stdout); /* complete header */ |
324 |
putchar('\n'); |
325 |
fputsresolu(&inpres, stdout); /* resolution doesn't change */ |
326 |
/* condition our image */ |
327 |
for (scan = firstscan(); scan != NULL; scan = nextscan()) |
328 |
if (fwritescan(scan, scanlen(&inpres), stdout) < 0) { |
329 |
fprintf(stderr, "%s: scanline write error\n", |
330 |
progname); |
331 |
exit(1); |
332 |
333 |
334 |
335 |
336 |
static void |
337 |
getfovimg(void) /* load foveal sampled image */ |
338 |
339 |
char combuf[PATH_MAX]; |
340 |
FILE *fp; |
341 |
int x, y; |
342 |
/* compute image size */ |
343 |
fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5; |
344 |
if (fvxr < 2) fvxr = 2; |
345 |
fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5; |
346 |
if (fvyr < 2) fvyr = 2; |
347 |
if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */ |
348 |
y = fvyr; |
349 |
fvyr = fvxr; |
350 |
fvxr = y; |
351 |
352 |
if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL) |
353 |
syserror("malloc"); |
354 |
sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d \"%s\"", fvxr, fvyr, infn); |
355 |
if ((fp = popen(combuf, "r")) == NULL) |
356 |
syserror("popen"); |
357 |
SET_FILE_BINARY(fp); |
358 |
getheader(fp, NULL, NULL); /* skip header */ |
359 |
if (fgetresolu(&x, &y, fp) < 0 || (x != fvxr) | (y != fvyr)) |
360 |
goto readerr; |
361 |
for (y = 0; y < fvyr; y++) |
362 |
if (fread2scan(fovscan(y), fvxr, fp, NCSAMP, WLPART) < 0) |
363 |
goto readerr; |
364 |
pclose(fp); |
365 |
return; |
366 |
readerr: |
367 |
fprintf(stderr, "%s: error reading from pfilt process in fovimage\n", |
368 |
progname); |
369 |
exit(1); |
370 |
371 |
372 |
373 |
static void |
374 |
check2do(void) /* check histogram to see what isn't worth doing */ |
375 |
376 |
double sum; |
377 |
double b, l; |
378 |
int i; |
379 |
380 |
/* check for within display range */ |
381 |
if (bwmax - bwmin <= Bldmax - Bldmin) |
382 |
383 |
/* determine if veiling significant */ |
384 |
if (bwmax - bwmin < 4.5) /* heuristic */ |
385 |
what2do &= ~DO_VEIL; |
386 |
387 |
if (!(what2do & (DO_ACUITY|DO_COLOR))) |
388 |
return; |
389 |
/* find 5th percentile */ |
390 |
sum = histot*0.05; |
391 |
for (i = 0; i < HISTRES; i++) |
392 |
if ((sum -= bwhist[i]) <= 0) |
393 |
break; |
394 |
b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin; |
395 |
l = Lb(b); |
396 |
/* determine if acuity adj. useful */ |
397 |
if (what2do&DO_ACUITY && |
398 |
hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) + |
399 |
inpres.yr/sqrt(ourview.vn2))/(2.*180./PI)) |
400 |
what2do &= ~DO_ACUITY; |
401 |
/* color sensitivity loss? */ |
402 |
if (l >= TopMesopic) |
403 |
what2do &= ~DO_COLOR; |
404 |
