root/radiance/ray/src/px/pcond.c
Revision: 3.20
Committed: Fri Jan 2 12:47:01 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 3.19: +8 -3 lines
2 static const char RCSid[] = "$Id: pcond.c,v 3.19 2003/11/10 11:54:23 schorsch Exp $";
5 * Condition Radiance picture for display/output
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "platform.h"
10 #include "paths.h"
11 #include "rtprocess.h"
12 #include "pcond.h"
13
14
15 #define LDMAX 100 /* default max. display luminance */
16 #define LDDYN 32 /* default dynamic range */
17
18 int what2do = 0; /* desired adjustments */
19
20 double ldmax = LDMAX; /* maximum output luminance */
21 double lddyn = LDDYN; /* display dynamic range */
22 double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
23
24 char *progname; /* global argv[0] */
25
26 char *infn; /* input file name */
27 FILE *infp; /* input stream */
28 FILE *mapfp = NULL; /* tone-mapping function stream */
29 VIEW ourview = STDVIEW; /* picture view */
30 int gotview = 0; /* picture has view */
31 double pixaspect = 1.0; /* pixel aspect ratio */
32 double fixfrac = 0.; /* histogram share due to fixations */
33 RESOLU inpres; /* input picture resolution */
34
35 COLOR *fovimg; /* foveal (1 degree) averaged image */
36 int fvxr, fvyr; /* foveal image resolution */
37 float *crfimg; /* contrast reduction factors */
38 short (*fixlst)[2]; /* fixation history list */
39 int nfixations; /* number of fixation points */
40 double bwhist[HISTRES]; /* luminance histogram */
41 double histot; /* total count of histogram */
42 double bwmin, bwmax; /* histogram limits */
43 double bwavg; /* mean brightness */
44
45 double scalef = 0.; /* linear scaling factor */
46
47 static gethfunc headline;
48
49
50 main(argc, argv)
51 int argc;
52 char *argv[];
53 {
54 static RGBPRIMS outprimS;
55 int i;
56 #define bool(flg) switch (argv[i][2]) { \
57 case '\0': what2do ^= flg; break; \
58 case 'y': case 'Y': case 't': case 'T': \
59 case '+': case '1': what2do |= flg; break; \
60 case 'n': case 'N': case 'f': case 'F': \
61 case '-': case '0': what2do &= ~(flg); break; \
62 default: goto userr; }
63
64 progname = argv[0];
65
66 for (i = 1; i < argc && argv[i][0] == '-'; i++)
67 switch (argv[i][1]) {
68 case 'h':
69 bool(DO_HUMAN);
70 break;
71 case 'a':
72 bool(DO_ACUITY);
73 break;
74 case 'v':
75 bool(DO_VEIL);
76 break;
77 case 's':
78 bool(DO_HSENS);
79 break;
80 case 'c':
81 bool(DO_COLOR);
82 break;
83 case 'w':
84 bool(DO_CWEIGHT);
85 break;
86 case 'i':
87 if (i+1 >= argc) goto userr;
88 fixfrac = atof(argv[++i]);
89 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
90 else what2do &= ~DO_FIXHIST;
91 break;
92 case 'I':
93 bool(DO_PREHIST);
94 break;
95 case 'l':
96 bool(DO_LINEAR);
97 break;
98 case 'p':
99 if (i+8 >= argc) goto userr;
100 outprimS[RED][CIEX] = atof(argv[++i]);
101 outprimS[RED][CIEY] = atof(argv[++i]);
102 outprimS[GRN][CIEX] = atof(argv[++i]);
103 outprimS[GRN][CIEY] = atof(argv[++i]);
104 outprimS[BLU][CIEX] = atof(argv[++i]);
105 outprimS[BLU][CIEY] = atof(argv[++i]);
106 outprimS[WHT][CIEX] = atof(argv[++i]);
107 outprimS[WHT][CIEY] = atof(argv[++i]);
108 outprims = outprimS;
109 break;
110 case 'e':
111 if (i+1 >= argc) goto userr;
112 scalef = atof(argv[++i]);
113 if ((argv[i][0] == '+') | (argv[i][0] == '-'))
114 scalef = pow(2.0, scalef);
115 what2do |= DO_LINEAR;
116 break;
117 case 'f':
118 if (i+1 >= argc) goto userr;
119 mbcalfile = argv[++i];
120 break;
121 case 'm':
122 if (i+1 >= argc) goto userr;
123 cwarpfile = argv[++i];
124 break;
125 case 'u':
126 if (i+1 >= argc) goto userr;
127 ldmax = atof(argv[++i]);
128 if (ldmax <= FTINY)
129 goto userr;
130 break;
131 case 'd':
132 if (i+1 >= argc) goto userr;
133 lddyn = atof(argv[++i]);
134 break;
135 case 'x':
136 if (i+1 >= argc) goto userr;
137 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
138 fprintf(stderr,
139 "%s: cannot open for writing\n",
140 argv[i]);
141 exit(1);
142 }
143 break;
144 default:
145 goto userr;
146 }
147 if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) {
148 fprintf(stderr, "%s: only one of -i or -I option\n", progname);
149 exit(1);
150 }
151 if ((mbcalfile != NULL) + (cwarpfile != NULL) +
152 (outprims != stdprims) > 1) {
153 fprintf(stderr,
154 "%s: only one of -p, -m or -f option supported\n",
155 progname);
156 exit(1);
157 }
158 if ((outprims == stdprims) & (inprims != stdprims))
159 outprims = inprims;
160 Bldmin = Bl(ldmax/lddyn);
161 Bldmax = Bl(ldmax);
162 if (i >= argc || i+2 < argc)
163 goto userr;
164 /* open input file */
165 if ((infp = fopen(infn=argv[i], "r")) == NULL)
166 syserror(infn);
167 /* open output file */
168 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
169 syserror(argv[i+1]);
170 SET_FILE_BINARY(infp);
171 SET_FILE_BINARY(stdout);
172 getahead(); /* load input header */
173 printargs(argc, argv, stdout); /* add to output header */
174 if ((mbcalfile == NULL) & (outprims != stdprims))
175 fputprims(outprims, stdout);
176 if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST)
177 getfovimg(); /* get foveal sample image? */
178 if (what2do&DO_PREHIST) /* get histogram? */
179 gethisto(stdin);
180 else if (what2do&DO_FIXHIST) /* get fixation history? */
181 getfixations(stdin);
182 mapimage(); /* map the picture */
183 if (mapfp != NULL) /* write out basic mapping */
184 putmapping(mapfp);
185 exit(0);
186 userr:
187 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n",
188 progname);
189 exit(1);
190 #undef bool
191 }
192
193
194 syserror(s) /* report system error and exit */
195 char *s;
196 {
197 fprintf(stderr, "%s: ", progname);
198 perror(s);
199 exit(2);
200 }
201
202
203 static int
204 headline( /* process header line */
205 char *s,
206 void *p
207 )
208 {
209 static RGBPRIMS inprimS;
210 char fmt[32];
211
212 if (formatval(fmt, s)) { /* check if format string */
213 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
214 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
215 else lumf = NULL;
216 return(0); /* don't echo */
217 }
218 if (isprims(s)) { /* get input primaries */
219 primsval(inprimS, s);
220 inprims= inprimS;
221 return(0); /* don't echo */
222 }
223 if (isexpos(s)) { /* picture exposure */
224 inpexp *= exposval(s);
225 return(0); /* don't echo */
226 }
227 if (isaspect(s)) /* pixel aspect ratio */
228 pixaspect *= aspectval(s);
229 if (isview(s)) /* image view */
230 gotview += sscanview(&ourview, s);
231 return(fputs(s, stdout));
232 }
233
234
235 getahead() /* load picture header */
236 {
237 char *err;
238
239 getheader(infp, headline, NULL);
240 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
241 fprintf(stderr, "%s: %s: not a Radiance picture\n",
242 progname, infn);
243 exit(1);
244 }
245 if (lumf == rgblum)
246 comprgb2xyzWBmat(inrgb2xyz, inprims);
247 else if (mbcalfile != NULL) {
248 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
249 progname);
250 exit(1);
251 }
252 if (!gotview || ourview.type == VT_PAR) {
253 ourview = stdview;
254 ourview.type = VT_PER;
255 if (pixaspect*inpres.yr < inpres.xr) {
256 ourview.horiz = 40.0;
257 ourview.vert = 2.*180./PI *
258 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
259 } else {
260 ourview.vert = 40.0;
261 ourview.horiz = 2.*180./PI *
262 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
263 }
264 }
265 if ((err = setview(&ourview)) != NULL) {
266 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
267 progname, infn, err);
268 exit(1);
269 }
270 }
271
272
273 mapimage() /* map picture and send to stdout */
274 {
275 COLOR *scan;
276
277 comphist(); /* generate adaptation histogram */
278 check2do(); /* modify what2do flags */
279 if (what2do&DO_VEIL)
280 compveil(); /* compute veil image */
281 if (!(what2do&DO_LINEAR))
282 if (mkbrmap() < 0) /* make tone map */
283 what2do |= DO_LINEAR; /* failed! -- use linear */
284 #if ADJ_VEIL
285 else if (what2do&DO_VEIL)
286 adjveil(); /* else adjust veil image */
287 #endif
288 if (what2do&DO_LINEAR) {
289 if (scalef <= FTINY) {
290 if (what2do&DO_HSENS)
291 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
292 htcontrs(Lb(bwavg));
293 else
294 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
295 scalef *= WHTEFFICACY/(inpexp*ldmax);
296 }
297 fputexpos(inpexp*scalef, stdout); /* record exposure */
298 if (lumf == cielum) scalef /= WHTEFFICACY;
299 }
300 fputformat(COLRFMT, stdout); /* complete header */
301 putchar('\n');
302 fputsresolu(&inpres, stdout); /* resolution doesn't change */
303 /* condition our image */
304 for (scan = firstscan(); scan != NULL; scan = nextscan())
305 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
306 fprintf(stderr, "%s: scanline write error\n",
307 progname);
308 exit(1);
309 }
310 }
311
312
313 getfovimg() /* load foveal sampled image */
314 {
315 char combuf[PATH_MAX];
316 FILE *fp;
317 int x, y;
318 /* compute image size */
319 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
320 if (fvxr < 2) fvxr = 2;
321 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
322 if (fvyr < 2) fvyr = 2;
323 if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */
324 y = fvyr;
325 fvyr = fvxr;
326 fvxr = y;
327 }
328 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
329 syserror("malloc");
330 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d \"%s\"", fvxr, fvyr, infn);
331 if ((fp = popen(combuf, "r")) == NULL)
332 syserror("popen");
333 getheader(fp, NULL, NULL); /* skip header */
334 if (fgetresolu(&x, &y, fp) < 0 || (x != fvxr) | (y != fvyr))
335 goto readerr;
336 for (y = 0; y < fvyr; y++)
337 if (freadscan(fovscan(y), fvxr, fp) < 0)
338 goto readerr;
339 pclose(fp);
340 return;
341 readerr:
342 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
343 progname);
344 exit(1);
345 }
346
347
348 check2do() /* check histogram to see what isn't worth doing */
349 {
350 double sum;
351 double b, l;
352 register int i;
353
354 /* check for within display range */
355 if (bwmax - bwmin <= Bldmax - Bldmin)
356 what2do |= DO_LINEAR;
357 /* determine if veiling significant */
358 if (bwmax - bwmin < 4.5) /* heuristic */
359 what2do &= ~DO_VEIL;
360
361 if (!(what2do & (DO_ACUITY|DO_COLOR)))
362 return;
363 /* find 5th percentile */
364 sum = histot*0.05;
365 for (i = 0; i < HISTRES; i++)
366 if ((sum -= bwhist[i]) <= 0)
367 break;
368 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
369 l = Lb(b);
370 /* determine if acuity adj. useful */
371 if (what2do&DO_ACUITY &&
372 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
373 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
374 what2do &= ~DO_ACUITY;
375 /* color sensitivity loss? */
376 if (l >= TopMesopic)
377 what2do &= ~DO_COLOR;
378 }
