root/radiance/ray/src/px/pcond.c
Revision: 3.18
Committed: Mon Oct 27 10:24:51 2003 UTC (20 years, 6 months ago) by schorsch
Various compatibility fixes.
2 static const char RCSid[] = "$Id: pcond.c,v 3.17 2003/07/27 22:12:03 schorsch Exp $";
5 * Condition Radiance picture for display/output
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "platform.h"
10 #include "rtprocess.h"
11 #include "pcond.h"
12
13
14 #define LDMAX 100 /* default max. display luminance */
15 #define LDDYN 32 /* default dynamic range */
16
17 int what2do = 0; /* desired adjustments */
18
19 double ldmax = LDMAX; /* maximum output luminance */
20 double lddyn = LDDYN; /* display dynamic range */
21 double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
22
23 char *progname; /* global argv[0] */
24
25 char *infn; /* input file name */
26 FILE *infp; /* input stream */
27 FILE *mapfp = NULL; /* tone-mapping function stream */
28 VIEW ourview = STDVIEW; /* picture view */
29 int gotview = 0; /* picture has view */
30 double pixaspect = 1.0; /* pixel aspect ratio */
31 double fixfrac = 0.; /* histogram share due to fixations */
32 RESOLU inpres; /* input picture resolution */
33
34 COLOR *fovimg; /* foveal (1 degree) averaged image */
35 int fvxr, fvyr; /* foveal image resolution */
36 float *crfimg; /* contrast reduction factors */
37 short (*fixlst)[2]; /* fixation history list */
38 int nfixations; /* number of fixation points */
39 double bwhist[HISTRES]; /* luminance histogram */
40 double histot; /* total count of histogram */
41 double bwmin, bwmax; /* histogram limits */
42 double bwavg; /* mean brightness */
43
44 double scalef = 0.; /* linear scaling factor */
45
46
47 main(argc, argv)
48 int argc;
49 char *argv[];
50 {
51 static RGBPRIMS outprimS;
52 int i;
53 #define bool(flg) switch (argv[i][2]) { \
54 case '\0': what2do ^= flg; break; \
55 case 'y': case 'Y': case 't': case 'T': \
56 case '+': case '1': what2do |= flg; break; \
57 case 'n': case 'N': case 'f': case 'F': \
58 case '-': case '0': what2do &= ~(flg); break; \
59 default: goto userr; }
60
61 progname = argv[0];
62
63 for (i = 1; i < argc && argv[i][0] == '-'; i++)
64 switch (argv[i][1]) {
65 case 'h':
66 bool(DO_HUMAN);
67 break;
68 case 'a':
69 bool(DO_ACUITY);
70 break;
71 case 'v':
72 bool(DO_VEIL);
73 break;
74 case 's':
75 bool(DO_HSENS);
76 break;
77 case 'c':
78 bool(DO_COLOR);
79 break;
80 case 'w':
81 bool(DO_CWEIGHT);
82 break;
83 case 'i':
84 if (i+1 >= argc) goto userr;
85 fixfrac = atof(argv[++i]);
86 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
87 else what2do &= ~DO_FIXHIST;
88 break;
89 case 'I':
90 bool(DO_PREHIST);
91 break;
92 case 'l':
93 bool(DO_LINEAR);
94 break;
95 case 'p':
96 if (i+8 >= argc) goto userr;
97 outprimS[RED][CIEX] = atof(argv[++i]);
98 outprimS[RED][CIEY] = atof(argv[++i]);
99 outprimS[GRN][CIEX] = atof(argv[++i]);
100 outprimS[GRN][CIEY] = atof(argv[++i]);
101 outprimS[BLU][CIEX] = atof(argv[++i]);
102 outprimS[BLU][CIEY] = atof(argv[++i]);
103 outprimS[WHT][CIEX] = atof(argv[++i]);
104 outprimS[WHT][CIEY] = atof(argv[++i]);
105 outprims = outprimS;
106 break;
107 case 'e':
108 if (i+1 >= argc) goto userr;
109 scalef = atof(argv[++i]);
110 if ((argv[i][0] == '+') | (argv[i][0] == '-'))
111 scalef = pow(2.0, scalef);
112 what2do |= DO_LINEAR;
113 break;
114 case 'f':
115 if (i+1 >= argc) goto userr;
116 mbcalfile = argv[++i];
117 break;
118 case 'm':
119 if (i+1 >= argc) goto userr;
120 cwarpfile = argv[++i];
121 break;
122 case 'u':
123 if (i+1 >= argc) goto userr;
124 ldmax = atof(argv[++i]);
125 if (ldmax <= FTINY)
126 goto userr;
127 break;
128 case 'd':
129 if (i+1 >= argc) goto userr;
130 lddyn = atof(argv[++i]);
131 break;
132 case 'x':
133 if (i+1 >= argc) goto userr;
134 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
135 fprintf(stderr,
136 "%s: cannot open for writing\n",
137 argv[i]);
138 exit(1);
139 }
140 break;
141 default:
142 goto userr;
143 }
144 if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) {
145 fprintf(stderr, "%s: only one of -i or -I option\n", progname);
146 exit(1);
147 }
148 if ((mbcalfile != NULL) + (cwarpfile != NULL) +
149 (outprims != stdprims) > 1) {
150 fprintf(stderr,
151 "%s: only one of -p, -m or -f option supported\n",
152 progname);
153 exit(1);
154 }
155 if ((outprims == stdprims) & (inprims != stdprims))
156 outprims = inprims;
157 Bldmin = Bl(ldmax/lddyn);
158 Bldmax = Bl(ldmax);
159 if (i >= argc || i+2 < argc)
160 goto userr;
161 /* open input file */
162 if ((infp = fopen(infn=argv[i], "r")) == NULL)
163 syserror(infn);
164 /* open output file */
165 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
166 syserror(argv[i+1]);
167 SET_FILE_BINARY(infp);
168 SET_FILE_BINARY(stdout);
169 getahead(); /* load input header */
170 printargs(argc, argv, stdout); /* add to output header */
171 if ((mbcalfile == NULL) & (outprims != stdprims))
172 fputprims(outprims, stdout);
173 if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST)
174 getfovimg(); /* get foveal sample image? */
175 if (what2do&DO_PREHIST) /* get histogram? */
176 gethisto(stdin);
177 else if (what2do&DO_FIXHIST) /* get fixation history? */
178 getfixations(stdin);
179 mapimage(); /* map the picture */
180 if (mapfp != NULL) /* write out basic mapping */
181 putmapping(mapfp);
182 exit(0);
183 userr:
184 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n",
185 progname);
186 exit(1);
187 #undef bool
188 }
189
190
191 syserror(s) /* report system error and exit */
192 char *s;
193 {
194 fprintf(stderr, "%s: ", progname);
195 perror(s);
196 exit(2);
197 }
198
199
200 headline(s) /* process header line */
201 char *s;
202 {
203 static RGBPRIMS inprimS;
204 char fmt[32];
205
206 if (formatval(fmt, s)) { /* check if format string */
207 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
208 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
209 else lumf = NULL;
210 return(0); /* don't echo */
211 }
212 if (isprims(s)) { /* get input primaries */
213 primsval(inprimS, s);
214 inprims= inprimS;
215 return(0); /* don't echo */
216 }
217 if (isexpos(s)) { /* picture exposure */
218 inpexp *= exposval(s);
219 return(0); /* don't echo */
220 }
221 if (isaspect(s)) /* pixel aspect ratio */
222 pixaspect *= aspectval(s);
223 if (isview(s)) /* image view */
224 gotview += sscanview(&ourview, s);
225 return(fputs(s, stdout));
226 }
227
228
229 getahead() /* load picture header */
230 {
231 char *err;
232
233 getheader(infp, headline, NULL);
234 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
235 fprintf(stderr, "%s: %s: not a Radiance picture\n",
236 progname, infn);
237 exit(1);
238 }
239 if (lumf == rgblum)
240 comprgb2xyzWBmat(inrgb2xyz, inprims);
241 else if (mbcalfile != NULL) {
242 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
243 progname);
244 exit(1);
245 }
246 if (!gotview || ourview.type == VT_PAR) {
247 ourview = stdview;
248 ourview.type = VT_PER;
249 if (pixaspect*inpres.yr < inpres.xr) {
250 ourview.horiz = 40.0;
251 ourview.vert = 2.*180./PI *
252 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
253 } else {
254 ourview.vert = 40.0;
255 ourview.horiz = 2.*180./PI *
256 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
257 }
258 }
259 if ((err = setview(&ourview)) != NULL) {
260 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
261 progname, infn, err);
262 exit(1);
263 }
264 }
265
266
267 mapimage() /* map picture and send to stdout */
268 {
269 COLOR *scan;
270
271 comphist(); /* generate adaptation histogram */
272 check2do(); /* modify what2do flags */
273 if (what2do&DO_VEIL)
274 compveil(); /* compute veil image */
275 if (!(what2do&DO_LINEAR))
276 if (mkbrmap() < 0) /* make tone map */
277 what2do |= DO_LINEAR; /* failed! -- use linear */
278 #if ADJ_VEIL
279 else if (what2do&DO_VEIL)
280 adjveil(); /* else adjust veil image */
281 #endif
282 if (what2do&DO_LINEAR) {
283 if (scalef <= FTINY) {
284 if (what2do&DO_HSENS)
285 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
286 htcontrs(Lb(bwavg));
287 else
288 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
289 scalef *= WHTEFFICACY/(inpexp*ldmax);
290 }
291 fputexpos(inpexp*scalef, stdout); /* record exposure */
292 if (lumf == cielum) scalef /= WHTEFFICACY;
293 }
294 fputformat(COLRFMT, stdout); /* complete header */
295 putchar('\n');
296 fputsresolu(&inpres, stdout); /* resolution doesn't change */
297 /* condition our image */
298 for (scan = firstscan(); scan != NULL; scan = nextscan())
299 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
300 fprintf(stderr, "%s: scanline write error\n",
301 progname);
302 exit(1);
303 }
304 }
305
306
307 getfovimg() /* load foveal sampled image */
308 {
309 char combuf[128];
310 FILE *fp;
311 int x, y;
312 /* compute image size */
313 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
314 if (fvxr < 2) fvxr = 2;
315 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
316 if (fvyr < 2) fvyr = 2;
317 if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */
318 y = fvyr;
319 fvyr = fvxr;
320 fvxr = y;
321 }
322 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
323 syserror("malloc");
324 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d %s", fvxr, fvyr, infn);
325 if ((fp = popen(combuf, "r")) == NULL)
326 syserror("popen");
327 getheader(fp, NULL, NULL); /* skip header */
328 if (fgetresolu(&x, &y, fp) < 0 || (x != fvxr) | (y != fvyr))
329 goto readerr;
330 for (y = 0; y < fvyr; y++)
331 if (freadscan(fovscan(y), fvxr, fp) < 0)
332 goto readerr;
333 pclose(fp);
334 return;
335 readerr:
336 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
337 progname);
338 exit(1);
339 }
340
341
342 check2do() /* check histogram to see what isn't worth doing */
343 {
344 double sum;
345 double b, l;
346 register int i;
347
348 /* check for within display range */
349 if (bwmax - bwmin <= Bldmax - Bldmin)
350 what2do |= DO_LINEAR;
351 /* determine if veiling significant */
352 if (bwmax - bwmin < 4.5) /* heuristic */
353 what2do &= ~DO_VEIL;
354
355 if (!(what2do & (DO_ACUITY|DO_COLOR)))
356 return;
357 /* find 5th percentile */
358 sum = histot*0.05;
359 for (i = 0; i < HISTRES; i++)
360 if ((sum -= bwhist[i]) <= 0)
361 break;
362 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
363 l = Lb(b);
364 /* determine if acuity adj. useful */
365 if (what2do&DO_ACUITY &&
366 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
367 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
368 what2do &= ~DO_ACUITY;
369 /* color sensitivity loss? */
370 if (l >= TopMesopic)
371 what2do &= ~DO_COLOR;
372 }
