root/Development/ray/src/px/pcond.c
Revision: 3.15
Committed: Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.14: +4 -5 lines
2 static const char RCSid[] = "$Id: pcond.c,v 3.14 2003/02/22 02:07:27 greg Exp $";
5 * Condition Radiance picture for display/output
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "platform.h"
10 #include "pcond.h"
11
12
13 #define LDMAX 100 /* default max. display luminance */
14 #define LDDYN 32 /* default dynamic range */
15
16 int what2do = 0; /* desired adjustments */
17
18 double ldmax = LDMAX; /* maximum output luminance */
19 double lddyn = LDDYN; /* display dynamic range */
20 double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
21
22 char *progname; /* global argv[0] */
23
24 char *infn; /* input file name */
25 FILE *infp; /* input stream */
26 FILE *mapfp = NULL; /* tone-mapping function stream */
27 VIEW ourview = STDVIEW; /* picture view */
28 int gotview = 0; /* picture has view */
29 double pixaspect = 1.0; /* pixel aspect ratio */
30 double fixfrac = 0.; /* histogram share due to fixations */
31 RESOLU inpres; /* input picture resolution */
32
33 COLOR *fovimg; /* foveal (1 degree) averaged image */
34 int fvxr, fvyr; /* foveal image resolution */
35 float *crfimg; /* contrast reduction factors */
36 short (*fixlst)[2]; /* fixation history list */
37 int nfixations; /* number of fixation points */
38 double bwhist[HISTRES]; /* luminance histogram */
39 double histot; /* total count of histogram */
40 double bwmin, bwmax; /* histogram limits */
41 double bwavg; /* mean brightness */
42
43 double scalef = 0.; /* linear scaling factor */
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 static RGBPRIMS outprimS;
51 int i;
52 #define bool(flg) switch (argv[i][2]) { \
53 case '\0': what2do ^= flg; break; \
54 case 'y': case 'Y': case 't': case 'T': \
55 case '+': case '1': what2do |= flg; break; \
56 case 'n': case 'N': case 'f': case 'F': \
57 case '-': case '0': what2do &= ~(flg); break; \
58 default: goto userr; }
59
60 progname = argv[0];
61
62 for (i = 1; i < argc && argv[i][0] == '-'; i++)
63 switch (argv[i][1]) {
64 case 'h':
65 bool(DO_HUMAN);
66 break;
67 case 'a':
68 bool(DO_ACUITY);
69 break;
70 case 'v':
71 bool(DO_VEIL);
72 break;
73 case 's':
74 bool(DO_HSENS);
75 break;
76 case 'c':
77 bool(DO_COLOR);
78 break;
79 case 'w':
80 bool(DO_CWEIGHT);
81 break;
82 case 'i':
83 if (i+1 >= argc) goto userr;
84 fixfrac = atof(argv[++i]);
85 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
86 else what2do &= ~DO_FIXHIST;
87 break;
88 case 'I':
89 bool(DO_PREHIST);
90 break;
91 case 'l':
92 bool(DO_LINEAR);
93 break;
94 case 'p':
95 if (i+8 >= argc) goto userr;
96 outprimS[RED][CIEX] = atof(argv[++i]);
97 outprimS[RED][CIEY] = atof(argv[++i]);
98 outprimS[GRN][CIEX] = atof(argv[++i]);
99 outprimS[GRN][CIEY] = atof(argv[++i]);
100 outprimS[BLU][CIEX] = atof(argv[++i]);
101 outprimS[BLU][CIEY] = atof(argv[++i]);
102 outprimS[WHT][CIEX] = atof(argv[++i]);
103 outprimS[WHT][CIEY] = atof(argv[++i]);
104 outprims = outprimS;
105 break;
106 case 'e':
107 if (i+1 >= argc) goto userr;
108 scalef = atof(argv[++i]);
109 if (argv[i][0] == '+' | argv[i][0] == '-')
110 scalef = pow(2.0, scalef);
111 what2do |= DO_LINEAR;
112 break;
113 case 'f':
114 if (i+1 >= argc) goto userr;
115 mbcalfile = argv[++i];
116 break;
117 case 'm':
118 if (i+1 >= argc) goto userr;
119 cwarpfile = argv[++i];
120 break;
121 case 'u':
122 if (i+1 >= argc) goto userr;
123 ldmax = atof(argv[++i]);
124 if (ldmax <= FTINY)
125 goto userr;
126 break;
127 case 'd':
128 if (i+1 >= argc) goto userr;
129 lddyn = atof(argv[++i]);
130 break;
131 case 'x':
132 if (i+1 >= argc) goto userr;
133 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
134 fprintf(stderr,
135 "%s: cannot open for writing\n",
136 argv[i]);
137 exit(1);
138 }
139 break;
140 default:
141 goto userr;
142 }
143 if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) {
144 fprintf(stderr, "%s: only one of -i or -I option\n", progname);
145 exit(1);
146 }
147 if ((mbcalfile != NULL) + (cwarpfile != NULL) +
148 (outprims != stdprims) > 1) {
149 fprintf(stderr,
150 "%s: only one of -p, -m or -f option supported\n",
151 progname);
152 exit(1);
153 }
154 if (outprims == stdprims & inprims != stdprims)
155 outprims = inprims;
156 Bldmin = Bl(ldmax/lddyn);
157 Bldmax = Bl(ldmax);
158 if (i >= argc || i+2 < argc)
159 goto userr;
160 /* open input file */
161 if ((infp = fopen(infn=argv[i], "r")) == NULL)
162 syserror(infn);
163 /* open output file */
164 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
165 syserror(argv[i+1]);
166 SET_FILE_BINARY(infp);
167 SET_FILE_BINARY(stdout);
168 getahead(); /* load input header */
169 printargs(argc, argv, stdout); /* add to output header */
170 if (mbcalfile == NULL & outprims != stdprims)
171 fputprims(outprims, stdout);
172 if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST)
173 getfovimg(); /* get foveal sample image? */
174 if (what2do&DO_PREHIST) /* get histogram? */
175 gethisto(stdin);
176 else if (what2do&DO_FIXHIST) /* get fixation history? */
177 getfixations(stdin);
178 mapimage(); /* map the picture */
179 if (mapfp != NULL) /* write out basic mapping */
180 putmapping(mapfp);
181 exit(0);
182 userr:
183 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n",
184 progname);
185 exit(1);
186 #undef bool
187 }
188
189
190 syserror(s) /* report system error and exit */
191 char *s;
192 {
193 fprintf(stderr, "%s: ", progname);
194 perror(s);
195 exit(2);
196 }
197
198
199 headline(s) /* process header line */
200 char *s;
201 {
202 static RGBPRIMS inprimS;
203 char fmt[32];
204
205 if (formatval(fmt, s)) { /* check if format string */
206 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
207 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
208 else lumf = NULL;
209 return(0); /* don't echo */
210 }
211 if (isprims(s)) { /* get input primaries */
212 primsval(inprimS, s);
213 inprims= inprimS;
214 return(0); /* don't echo */
215 }
216 if (isexpos(s)) { /* picture exposure */
217 inpexp *= exposval(s);
218 return(0); /* don't echo */
219 }
220 if (isaspect(s)) /* pixel aspect ratio */
221 pixaspect *= aspectval(s);
222 if (isview(s)) /* image view */
223 gotview += sscanview(&ourview, s);
224 return(fputs(s, stdout));
225 }
226
227
228 getahead() /* load picture header */
229 {
230 char *err;
231
232 getheader(infp, headline, NULL);
233 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
234 fprintf(stderr, "%s: %s: not a Radiance picture\n",
235 progname, infn);
236 exit(1);
237 }
238 if (lumf == rgblum)
239 comprgb2xyzWBmat(inrgb2xyz, inprims);
240 else if (mbcalfile != NULL) {
241 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
242 progname);
243 exit(1);
244 }
245 if (!gotview || ourview.type == VT_PAR) {
246 copystruct(&ourview, &stdview);
247 ourview.type = VT_PER;
248 if (pixaspect*inpres.yr < inpres.xr) {
249 ourview.horiz = 40.0;
250 ourview.vert = 2.*180./PI *
251 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
252 } else {
253 ourview.vert = 40.0;
254 ourview.horiz = 2.*180./PI *
255 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
256 }
257 }
258 if ((err = setview(&ourview)) != NULL) {
259 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
260 progname, infn, err);
261 exit(1);
262 }
263 }
264
265
266 mapimage() /* map picture and send to stdout */
267 {
268 COLOR *scan;
269
270 comphist(); /* generate adaptation histogram */
271 check2do(); /* modify what2do flags */
272 if (what2do&DO_VEIL)
273 compveil(); /* compute veil image */
274 if (!(what2do&DO_LINEAR))
275 if (mkbrmap() < 0) /* make tone map */
276 what2do |= DO_LINEAR; /* failed! -- use linear */
277 #if ADJ_VEIL
278 else if (what2do&DO_VEIL)
279 adjveil(); /* else adjust veil image */
280 #endif
281 if (what2do&DO_LINEAR) {
282 if (scalef <= FTINY) {
283 if (what2do&DO_HSENS)
284 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
285 htcontrs(Lb(bwavg));
286 else
287 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
288 scalef *= WHTEFFICACY/(inpexp*ldmax);
289 }
290 fputexpos(inpexp*scalef, stdout); /* record exposure */
291 if (lumf == cielum) scalef /= WHTEFFICACY;
292 }
293 fputformat(COLRFMT, stdout); /* complete header */
294 putchar('\n');
295 fputsresolu(&inpres, stdout); /* resolution doesn't change */
296 /* condition our image */
297 for (scan = firstscan(); scan != NULL; scan = nextscan())
298 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
299 fprintf(stderr, "%s: scanline write error\n",
300 progname);
301 exit(1);
302 }
303 }
304
305
306 getfovimg() /* load foveal sampled image */
307 {
308 extern FILE *popen();
309 char combuf[128];
310 FILE *fp;
311 int x, y;
312 /* compute image size */
313 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
314 if (fvxr < 2) fvxr = 2;
315 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
316 if (fvyr < 2) fvyr = 2;
317 if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */
318 y = fvyr;
319 fvyr = fvxr;
320 fvxr = y;
321 }
322 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
323 syserror("malloc");
324 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d %s", fvxr, fvyr, infn);
325 if ((fp = popen(combuf, "r")) == NULL)
326 syserror("popen");
327 getheader(fp, NULL, NULL); /* skip header */
328 if (fgetresolu(&x, &y, fp) < 0 || x != fvxr | y != fvyr)
329 goto readerr;
330 for (y = 0; y < fvyr; y++)
331 if (freadscan(fovscan(y), fvxr, fp) < 0)
332 goto readerr;
333 pclose(fp);
334 return;
335 readerr:
336 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
337 progname);
338 exit(1);
339 }
340
341
342 check2do() /* check histogram to see what isn't worth doing */
343 {
344 double sum;
345 double b, l;
346 register int i;
347
348 /* check for within display range */
349 if (bwmax - bwmin <= Bldmax - Bldmin)
350 what2do |= DO_LINEAR;
351 /* determine if veiling significant */
352 if (bwmax - bwmin < 4.5) /* heuristic */
353 what2do &= ~DO_VEIL;
354
355 if (!(what2do & (DO_ACUITY|DO_COLOR)))
356 return;
357 /* find 5th percentile */
358 sum = histot*0.05;
359 for (i = 0; i < HISTRES; i++)
360 if ((sum -= bwhist[i]) <= 0)
361 break;
362 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
363 l = Lb(b);
364 /* determine if acuity adj. useful */
365 if (what2do&DO_ACUITY &&
366 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
367 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
368 what2do &= ~DO_ACUITY;
369 /* color sensitivity loss? */
370 if (l >= TopMesopic)
371 what2do &= ~DO_COLOR;
372 }
