root/radiance/ray/src/px/pcond.c
Revision: 3.12
Committed: Thu Mar 12 15:47:33 1998 UTC (27 years, 1 month ago) by gwlarson
Changes since 3.11: +13 -3 lines
added -I option for precomputed histogram
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Condition Radiance picture for display/output
9 */
10
11 #include "pcond.h"
12
13
14 #define LDMAX 100 /* default max. display luminance */
15 #define LDDYN 32 /* default dynamic range */
16
17 int what2do = 0; /* desired adjustments */
18
19 double ldmax = LDMAX; /* maximum output luminance */
20 double lddyn = LDDYN; /* display dynamic range */
21 double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
22
23 char *progname; /* global argv[0] */
24
25 char *infn; /* input file name */
26 FILE *infp; /* input stream */
27 FILE *mapfp = NULL; /* tone-mapping function stream */
28 VIEW ourview = STDVIEW; /* picture view */
29 int gotview = 0; /* picture has view */
30 double pixaspect = 1.0; /* pixel aspect ratio */
31 double fixfrac = 0.; /* histogram share due to fixations */
32 RESOLU inpres; /* input picture resolution */
33
34 COLOR *fovimg; /* foveal (1 degree) averaged image */
35 short fvxr, fvyr; /* foveal image resolution */
36 short (*fixlst)[2]; /* fixation history list */
37 int nfixations; /* number of fixation points */
38 float bwhist[HISTRES]; /* luminance histogram */
39 double histot; /* total count of histogram */
40 double bwmin, bwmax; /* histogram limits */
41 double bwavg; /* mean brightness */
42
43 double scalef = 0.; /* linear scaling factor */
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 static RGBPRIMS outprimS;
51 int i;
52 #define bool(flg) switch (argv[i][2]) { \
53 case '\0': what2do ^= flg; break; \
54 case 'y': case 'Y': case 't': case 'T': \
55 case '+': case '1': what2do |= flg; break; \
56 case 'n': case 'N': case 'f': case 'F': \
57 case '-': case '0': what2do &= ~(flg); break; \
58 default: goto userr; }
59
60 progname = argv[0];
61
62 for (i = 1; i < argc && argv[i][0] == '-'; i++)
63 switch (argv[i][1]) {
64 case 'h':
65 bool(DO_HUMAN);
66 break;
67 case 'a':
68 bool(DO_ACUITY);
69 break;
70 case 'v':
71 bool(DO_VEIL);
72 break;
73 case 's':
74 bool(DO_HSENS);
75 break;
76 case 'c':
77 bool(DO_COLOR);
78 break;
79 case 'w':
80 bool(DO_CWEIGHT);
81 break;
82 case 'i':
83 if (i+1 >= argc) goto userr;
84 fixfrac = atof(argv[++i]);
85 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
86 else what2do &= ~DO_FIXHIST;
87 break;
88 case 'I':
89 bool(DO_PREHIST);
90 break;
91 case 'l':
92 bool(DO_LINEAR);
93 break;
94 case 'p':
95 if (i+8 >= argc) goto userr;
96 outprimS[RED][CIEX] = atof(argv[++i]);
97 outprimS[RED][CIEY] = atof(argv[++i]);
98 outprimS[GRN][CIEX] = atof(argv[++i]);
99 outprimS[GRN][CIEY] = atof(argv[++i]);
100 outprimS[BLU][CIEX] = atof(argv[++i]);
101 outprimS[BLU][CIEY] = atof(argv[++i]);
102 outprimS[WHT][CIEX] = atof(argv[++i]);
103 outprimS[WHT][CIEY] = atof(argv[++i]);
104 outprims = outprimS;
105 break;
106 case 'e':
107 if (i+1 >= argc) goto userr;
108 scalef = atof(argv[++i]);
109 if (argv[i][0] == '+' | argv[i][0] == '-')
110 scalef = pow(2.0, scalef);
111 what2do |= DO_LINEAR;
112 break;
113 case 'f':
114 if (i+1 >= argc) goto userr;
115 mbcalfile = argv[++i];
116 break;
117 case 'm':
118 if (i+1 >= argc) goto userr;
119 cwarpfile = argv[++i];
120 break;
121 case 'u':
122 if (i+1 >= argc) goto userr;
123 ldmax = atof(argv[++i]);
124 if (ldmax <= FTINY)
125 goto userr;
126 break;
127 case 'd':
128 if (i+1 >= argc) goto userr;
129 lddyn = atof(argv[++i]);
130 break;
131 case 'x':
132 if (i+1 >= argc) goto userr;
133 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
134 fprintf(stderr,
135 "%s: cannot open for writing\n",
136 argv[i]);
137 exit(1);
138 }
139 break;
140 default:
141 goto userr;
142 }
143 if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) {
144 fprintf(stderr, "%s: only one of -i or -I option\n", progname);
145 exit(1);
146 }
147 if ((mbcalfile != NULL) + (cwarpfile != NULL) +
148 (outprims != stdprims) > 1) {
149 fprintf(stderr,
150 "%s: only one of -p, -m or -f option supported\n",
151 progname);
152 exit(1);
153 }
154 if (outprims == stdprims & inprims != stdprims)
155 outprims = inprims;
156 Bldmin = Bl(ldmax/lddyn);
157 Bldmax = Bl(ldmax);
158 if (i >= argc || i+2 < argc)
159 goto userr;
160 /* open input file */
161 if ((infp = fopen(infn=argv[i], "r")) == NULL)
162 syserror(infn);
163 /* open output file */
164 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
165 syserror(argv[i+1]);
166 #ifdef MSDOS
167 setmode(fileno(infp), O_BINARY);
168 setmode(fileno(stdout), O_BINARY);
169 #endif
170 getahead(); /* load input header */
171 printargs(argc, argv, stdout); /* add to output header */
172 if (mbcalfile == NULL & outprims != stdprims)
173 fputprims(outprims, stdout);
174 if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST)
175 getfovimg(); /* get foveal sample image? */
176 if (what2do&DO_PREHIST) /* get histogram? */
177 gethisto(stdin);
178 else if (what2do&DO_FIXHIST) /* get fixation history? */
179 getfixations(stdin);
180 mapimage(); /* map the picture */
181 if (mapfp != NULL) /* write out basic mapping */
182 putmapping(mapfp);
183 exit(0);
184 userr:
185 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n",
186 progname);
187 exit(1);
188 #undef bool
189 }
190
191
192 syserror(s) /* report system error and exit */
193 char *s;
194 {
195 fprintf(stderr, "%s: ", progname);
196 perror(s);
197 exit(2);
198 }
199
200
201 headline(s) /* process header line */
202 char *s;
203 {
204 static RGBPRIMS inprimS;
205 char fmt[32];
206
207 if (formatval(fmt, s)) { /* check if format string */
208 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
209 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
210 else lumf = NULL;
211 return; /* don't echo */
212 }
213 if (isprims(s)) { /* get input primaries */
214 primsval(inprimS, s);
215 inprims= inprimS;
216 return; /* don't echo */
217 }
218 if (isexpos(s)) { /* picture exposure */
219 inpexp *= exposval(s);
220 return; /* don't echo */
221 }
222 if (isaspect(s)) /* pixel aspect ratio */
223 pixaspect *= aspectval(s);
224 if (isview(s)) /* image view */
225 gotview += sscanview(&ourview, s);
226 fputs(s, stdout);
227 }
228
229
230 getahead() /* load picture header */
231 {
232 char *err;
233
234 getheader(infp, headline, NULL);
235 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
236 fprintf(stderr, "%s: %s: not a Radiance picture\n",
237 progname, infn);
238 exit(1);
239 }
240 if (lumf == rgblum)
241 comprgb2xyzmat(inrgb2xyz, inprims);
242 else if (mbcalfile != NULL) {
243 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
244 progname);
245 exit(1);
246 }
247 if (!gotview || ourview.type == VT_PAR) {
248 copystruct(&ourview, &stdview);
249 ourview.type = VT_PER;
250 if (pixaspect*inpres.yr < inpres.xr) {
251 ourview.horiz = 40.0;
252 ourview.vert = 2.*180./PI *
253 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
254 } else {
255 ourview.vert = 40.0;
256 ourview.horiz = 2.*180./PI *
257 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
258 }
259 }
260 if ((err = setview(&ourview)) != NULL) {
261 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
262 progname, infn, err);
263 exit(1);
264 }
265 }
266
267
268 mapimage() /* map picture and send to stdout */
269 {
270 COLOR *scan;
271
272 comphist(); /* generate adaptation histogram */
273 check2do(); /* modify what2do flags */
274 if (what2do&DO_VEIL)
275 compveil();
276 if (!(what2do&DO_LINEAR) && mkbrmap() < 0) /* make tone map */
277 what2do |= DO_LINEAR; /* failed! -- use linear scaling */
278 if (what2do&DO_LINEAR) {
279 if (scalef <= FTINY) {
280 if (what2do&DO_HSENS)
281 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
282 htcontrs(Lb(bwavg));
283 else
284 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
285 scalef *= WHTEFFICACY/(inpexp*ldmax);
286 }
287 fputexpos(inpexp*scalef, stdout); /* record exposure */
288 if (lumf == cielum) scalef /= WHTEFFICACY;
289 }
290 fputformat(COLRFMT, stdout); /* complete header */
291 putchar('\n');
292 fputsresolu(&inpres, stdout); /* resolution doesn't change */
293 /* condition our image */
294 for (scan = firstscan(); scan != NULL; scan = nextscan())
295 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
296 fprintf(stderr, "%s: scanline write error\n",
297 progname);
298 exit(1);
299 }
300 }
301
302
303 getfovimg() /* load foveal sampled image */
304 {
305 extern FILE *popen();
306 char combuf[128];
307 FILE *fp;
308 int x, y;
309 /* compute image size */
310 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
311 if (fvxr < 2) fvxr = 2;
312 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
313 if (fvyr < 2) fvyr = 2;
314 if (!(inpres.or & YMAJOR)) { /* picture is rotated? */
315 y = fvyr;
316 fvyr = fvxr;
317 fvxr = y;
318 }
319 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
320 syserror("malloc");
321 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d %s", fvxr, fvyr, infn);
322 if ((fp = popen(combuf, "r")) == NULL)
323 syserror("popen");
324 getheader(fp, NULL, NULL); /* skip header */
325 if (fgetresolu(&x, &y, fp) < 0 || x != fvxr | y != fvyr)
326 goto readerr;
327 for (y = 0; y < fvyr; y++)
328 if (freadscan(fovscan(y), fvxr, fp) < 0)
329 goto readerr;
330 pclose(fp);
331 return;
332 readerr:
333 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
334 progname);
335 exit(1);
336 }
337
338
339 check2do() /* check histogram to see what isn't worth doing */
340 {
341 double sum;
342 double b, l;
343 register int i;
344
345 /* check for within display range */
346 if (bwmax - bwmin <= Bldmax - Bldmin)
347 what2do |= DO_LINEAR;
348 /* determine if veiling significant */
349 if (bwmax - bwmin < 4.5) /* heuristic */
350 what2do &= ~DO_VEIL;
351
352 if (!(what2do & (DO_ACUITY|DO_COLOR)))
353 return;
354 /* find 5th percentile */
355 sum = histot*0.05;
356 for (i = 0; i < HISTRES; i++)
357 if ((sum -= bwhist[i]) <= 0)
358 break;
359 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
360 l = Lb(b);
361 /* determine if acuity adj. useful */
362 if (what2do&DO_ACUITY &&
363 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
364 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
365 what2do &= ~DO_ACUITY;
366 /* color sensitivity loss? */
367 if (l >= TopMesopic)
368 what2do &= ~DO_COLOR;
369 }
