root/radiance/ray/src/px/pcond.c
Revision: 3.10
Committed: Wed Feb 5 16:08:14 1997 UTC (28 years, 4 months ago) by greg
Changes since 3.9: +10 -4 lines
changed -m option to read in color warp map (old -m now -d)
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Condition Radiance picture for display/output
9 */
10
11 #include "pcond.h"
12
13
14 #define LDMAX 100 /* default max. display luminance */
15 #define LDMINF 0.01 /* default min. display lum. factor */
16
17 int what2do = 0; /* desired adjustments */
18
19 double ldmax = LDMAX; /* maximum output luminance */
20 double ldmin = 0.; /* minimum output luminance */
21 double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */
22
23 char *progname; /* global argv[0] */
24
25 char *infn; /* input file name */
26 FILE *infp; /* input stream */
27 FILE *mapfp = NULL; /* tone-mapping function stream */
28 VIEW ourview = STDVIEW; /* picture view */
29 int gotview = 0; /* picture has view */
30 double pixaspect = 1.0; /* pixel aspect ratio */
31 double fixfrac = 0.; /* histogram share due to fixations */
32 RESOLU inpres; /* input picture resolution */
33
34 COLOR *fovimg; /* foveal (1 degree) averaged image */
35 short fvxr, fvyr; /* foveal image resolution */
36 short (*fixlst)[2]; /* fixation history list */
37 int nfixations; /* number of fixation points */
38 float bwhist[HISTRES]; /* luminance histogram */
39 double histot; /* total count of histogram */
40 double bwmin, bwmax; /* histogram limits */
41 double bwavg; /* mean brightness */
42
43 double scalef = 0.; /* linear scaling factor */
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 static RGBPRIMS outprimS;
51 int i;
52 #define bool(flg) switch (argv[i][2]) { \
53 case '\0': what2do ^= flg; break; \
54 case 'y': case 'Y': case 't': case 'T': \
55 case '+': case '1': what2do |= flg; break; \
56 case 'n': case 'N': case 'f': case 'F': \
57 case '-': case '0': what2do &= ~(flg); break; \
58 default: goto userr; }
59
60 progname = argv[0];
61
62 for (i = 1; i < argc && argv[i][0] == '-'; i++)
63 switch (argv[i][1]) {
64 case 'h':
65 bool(DO_HUMAN);
66 break;
67 case 'a':
68 bool(DO_ACUITY);
69 break;
70 case 'v':
71 bool(DO_VEIL);
72 break;
73 case 's':
74 bool(DO_HSENS);
75 break;
76 case 'c':
77 bool(DO_COLOR);
78 break;
79 case 'w':
80 bool(DO_CWEIGHT);
81 break;
82 case 'i':
83 if (i+1 >= argc) goto userr;
84 fixfrac = atof(argv[++i]);
85 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
86 else what2do &= ~DO_FIXHIST;
87 break;
88 case 'l':
89 bool(DO_LINEAR);
90 break;
91 case 'p':
92 if (i+8 >= argc) goto userr;
93 outprimS[RED][CIEX] = atof(argv[++i]);
94 outprimS[RED][CIEY] = atof(argv[++i]);
95 outprimS[GRN][CIEX] = atof(argv[++i]);
96 outprimS[GRN][CIEY] = atof(argv[++i]);
97 outprimS[BLU][CIEX] = atof(argv[++i]);
98 outprimS[BLU][CIEY] = atof(argv[++i]);
99 outprimS[WHT][CIEX] = atof(argv[++i]);
100 outprimS[WHT][CIEY] = atof(argv[++i]);
101 outprims = outprimS;
102 break;
103 case 'e':
104 if (i+1 >= argc) goto userr;
105 scalef = atof(argv[++i]);
106 if (argv[i][0] == '+' | argv[i][0] == '-')
107 scalef = pow(2.0, scalef);
108 what2do |= DO_LINEAR;
109 break;
110 case 'f':
111 if (i+1 >= argc) goto userr;
112 mbcalfile = argv[++i];
113 break;
114 case 'm':
115 if (i+1 >= argc) goto userr;
116 cwarpfile = argv[++i];
117 break;
118 case 't':
119 if (i+1 >= argc) goto userr;
120 ldmax = atof(argv[++i]);
121 if (ldmax <= FTINY)
122 goto userr;
123 break;
124 case 'b':
125 if (i+1 >= argc) goto userr;
126 ldmin = atof(argv[++i]);
127 break;
128 case 'd':
129 if (i+1 >= argc) goto userr;
130 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
131 fprintf(stderr,
132 "%s: cannot open for writing\n",
133 argv[i]);
134 exit(1);
135 }
136 break;
137 default:
138 goto userr;
139 }
140 if ((mbcalfile != NULL) + (cwarpfile != NULL) +
141 (outprims != stdprims) > 1) {
142 fprintf(stderr,
143 "%s: only one of -p, -m or -f option supported\n",
144 progname);
145 exit(1);
146 }
147 if (outprims == stdprims & inprims != stdprims)
148 outprims = inprims;
149 if (ldmin <= FTINY)
150 ldmin = ldmax*LDMINF;
151 else if (ldmin >= ldmax) {
152 fprintf(stderr, "%s: Ldmin (%f) >= Ldmax (%f)!\n", progname,
153 ldmin, ldmax);
154 exit(1);
155 }
156 Bldmin = Bl(ldmin);
157 Bldmax = Bl(ldmax);
158 if (i >= argc || i+2 < argc)
159 goto userr;
160 /* open input file */
161 if ((infp = fopen(infn=argv[i], "r")) == NULL)
162 syserror(infn);
163 /* open output file */
164 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
165 syserror(argv[i+1]);
166 #ifdef MSDOS
167 setmode(fileno(infp), O_BINARY);
168 setmode(fileno(stdout), O_BINARY);
169 #endif
170 getahead(); /* load input header */
171 printargs(argc, argv, stdout); /* add to output header */
172 if (mbcalfile == NULL & outprims != stdprims)
173 fputprims(outprims, stdout);
174 getfovimg(); /* get foveal sample image */
175 if (what2do&DO_FIXHIST) /* get fixation history? */
176 getfixations(stdin);
177 mapimage(); /* map the picture */
178 if (mapfp != NULL) /* write out basic mapping */
179 putmapping(mapfp);
180 exit(0);
181 userr:
182 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-t Ldmax][-b Ldmin][-d mapfile] inpic [outpic]\n",
183 progname);
184 exit(1);
185 #undef bool
186 }
187
188
189 syserror(s) /* report system error and exit */
190 char *s;
191 {
192 fprintf(stderr, "%s: ", progname);
193 perror(s);
194 exit(2);
195 }
196
197
198 headline(s) /* process header line */
199 char *s;
200 {
201 static RGBPRIMS inprimS;
202 char fmt[32];
203
204 if (formatval(fmt, s)) { /* check if format string */
205 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
206 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
207 else lumf = NULL;
208 return; /* don't echo */
209 }
210 if (isprims(s)) { /* get input primaries */
211 primsval(inprimS, s);
212 inprims= inprimS;
213 return; /* don't echo */
214 }
215 if (isexpos(s)) { /* picture exposure */
216 inpexp *= exposval(s);
217 return; /* don't echo */
218 }
219 if (isaspect(s)) /* pixel aspect ratio */
220 pixaspect *= aspectval(s);
221 if (isview(s)) /* image view */
222 gotview += sscanview(&ourview, s);
223 fputs(s, stdout);
224 }
225
226
227 getahead() /* load picture header */
228 {
229 char *err;
230
231 getheader(infp, headline, NULL);
232 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
233 fprintf(stderr, "%s: %s: not a Radiance picture\n",
234 progname, infn);
235 exit(1);
236 }
237 if (lumf == rgblum)
238 comprgb2xyzmat(inrgb2xyz, inprims);
239 else if (mbcalfile != NULL) {
240 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
241 progname);
242 exit(1);
243 }
244 if (!gotview || ourview.type == VT_PAR) {
245 copystruct(&ourview, &stdview);
246 ourview.type = VT_PER;
247 if (pixaspect*inpres.yr < inpres.xr) {
248 ourview.horiz = 40.0;
249 ourview.vert = 2.*180./PI *
250 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
251 } else {
252 ourview.vert = 40.0;
253 ourview.horiz = 2.*180./PI *
254 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
255 }
256 }
257 if ((err = setview(&ourview)) != NULL) {
258 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
259 progname, infn, err);
260 exit(1);
261 }
262 }
263
264
265 mapimage() /* map picture and send to stdout */
266 {
267 COLOR *scan;
268
269 comphist(); /* generate adaptation histogram */
270 check2do(); /* modify what2do flags */
271 if (what2do&DO_VEIL)
272 compveil();
273 if (!(what2do&DO_LINEAR) && mkbrmap() < 0) /* make tone map */
274 what2do |= DO_LINEAR; /* failed! -- use linear scaling */
275 if (what2do&DO_LINEAR) {
276 if (scalef <= FTINY) {
277 if (what2do&DO_HSENS)
278 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
279 htcontrs(Lb(bwavg));
280 else
281 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
282 scalef *= WHTEFFICACY/(inpexp*ldmax);
283 }
284 fputexpos(inpexp*scalef, stdout); /* record exposure */
285 if (lumf == cielum) scalef /= WHTEFFICACY;
286 }
287 fputformat(COLRFMT, stdout); /* complete header */
288 putchar('\n');
289 fputsresolu(&inpres, stdout); /* resolution doesn't change */
290 /* condition our image */
291 for (scan = firstscan(); scan != NULL; scan = nextscan())
292 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
293 fprintf(stderr, "%s: scanline write error\n",
294 progname);
295 exit(1);
296 }
297 }
298
299
300 getfovimg() /* load foveal sampled image */
301 {
302 extern FILE *popen();
303 char combuf[128];
304 FILE *fp;
305 int x, y;
306 /* compute image size */
307 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
308 if (fvxr < 2) fvxr = 2;
309 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
310 if (fvyr < 2) fvyr = 2;
311 if (!(inpres.or & YMAJOR)) { /* picture is rotated? */
312 y = fvyr;
313 fvyr = fvxr;
314 fvxr = y;
315 }
316 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
317 syserror("malloc");
318 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d %s", fvxr, fvyr, infn);
319 if ((fp = popen(combuf, "r")) == NULL)
320 syserror("popen");
321 getheader(fp, NULL, NULL); /* skip header */
322 if (fgetresolu(&x, &y, fp) < 0 || x != fvxr | y != fvyr)
323 goto readerr;
324 for (y = 0; y < fvyr; y++)
325 if (freadscan(fovscan(y), fvxr, fp) < 0)
326 goto readerr;
327 pclose(fp);
328 return;
329 readerr:
330 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
331 progname);
332 exit(1);
333 }
334
335
336 check2do() /* check histogram to see what isn't worth doing */
337 {
338 double sum;
339 double b, l;
340 register int i;
341
342 /* check for within display range */
343 if (bwmax - bwmin <= Bldmax - Bldmin)
344 what2do |= DO_LINEAR;
345 /* determine if veiling significant */
346 if (bwmax - bwmin < 4.5) /* heuristic */
347 what2do &= ~DO_VEIL;
348
349 if (!(what2do & (DO_ACUITY|DO_COLOR)))
350 return;
351 /* find 5th percentile */
352 sum = histot*0.05;
353 for (i = 0; i < HISTRES; i++)
354 if ((sum -= bwhist[i]) <= 0)
355 break;
356 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
357 l = Lb(b);
358 /* determine if acuity adj. useful */
359 if (what2do&DO_ACUITY &&
360 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
361 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
362 what2do &= ~DO_ACUITY;
363 /* color sensitivity loss? */
364 if (l >= TopMesopic)
365 what2do &= ~DO_COLOR;
366 }
