root/Development/ray/src/px/pcond.c
Sat Jun 7 05:09:46 2025 UTC (5 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 3.34: +1 -2 lines
Diff to previous 3.34 , to selected 3.33
Tue Jun 3 21:31:51 2025 UTC (5 months, 1 week ago) by greg
Changes since 3.33: +2 -4 lines
Diff to previous 3.33
Revision 3.33 - (view) (download) (annotate) - [selected]
Wed Sep 11 18:56:11 2024 UTC (14 months ago) by greg
Changes since 3.32: +16 -5 lines
Diff to previous 3.32
feat(pcond,pvalue): Added hyperspectral input handling
Fri Oct 27 16:35:02 2023 UTC (2 years ago) by greg
Changes since 3.31: +1 -2 lines
Diff to previous 3.31 , to selected 3.33
style: Removed repeated #include, spotted by Randolph Fritz
Wed Apr 7 21:13:52 2021 UTC (4 years, 7 months ago) by greg
Changes since 3.30: +2 -2 lines
Diff to previous 3.30 , to selected 3.33
perf: changed default dynamic range from 32 to 100 to reflect modern displays
Mon Nov 11 21:19:41 2019 UTC (6 years ago) by greg
Changes since 3.29: +4 -4 lines
Diff to previous 3.29 , to selected 3.33
Minor improvement to error-checking of header
Thu Aug 2 18:33:44 2018 UTC (7 years, 3 months ago) by greg
Changes since 3.28: +2 -2 lines
Diff to previous 3.28 , to selected 3.33
Thu Mar 10 18:25:46 2016 UTC (9 years, 8 months ago) by schorsch
Changes since 3.27: +11 -11 lines
Diff to previous 3.27 , to selected 3.33
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Tue Feb 2 18:02:32 2016 UTC (9 years, 9 months ago) by greg
Changes since 3.26: +2 -2 lines
Diff to previous 3.26 , to selected 3.33
Fri Aug 21 05:48:28 2015 UTC (10 years, 2 months ago) by greg
Changes since 3.25: +3 -3 lines
Diff to previous 3.25 , to selected 3.33
Fixed issue with undersampled histogram in phisto
Mon Oct 20 13:42:13 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2P2
Changes since 3.24: +2 -1 lines
Diff to previous 3.24 , to selected 3.33
Setting binary mode for input from pfilt (bug fix for latest Windows vers.)
Wed Jun 7 17:52:04 2006 UTC (19 years, 5 months ago) by schorsch
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1
Diff to previous 3.23 , to selected 3.33
Sun Nov 14 22:19:50 2004 UTC (21 years ago) by greg
Diff to previous 3.22 , to selected 3.33
Increased minimum view angle from 3 to 5 degrees
Sun Nov 14 16:57:18 2004 UTC (21 years ago) by greg
Changes since 3.21: +3 -2 lines
Diff to previous 3.21 , to selected 3.33
Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 3.20: +24 -10 lines
Diff to previous 3.20 , to selected 3.33
Fri Jan 2 12:47:01 2004 UTC (21 years, 10 months ago) by schorsch
Changes since 3.19: +8 -3 lines
Diff to previous 3.19 , to selected 3.33
Mon Nov 10 11:54:23 2003 UTC (22 years ago) by schorsch
Changes since 3.18: +4 -3 lines
Diff to previous 3.18 , to selected 3.33
Fixed size of command line buffer, and allow spaces in input file path.
Mon Oct 27 10:24:51 2003 UTC (22 years ago) by schorsch
Diff to previous 3.17 , to selected 3.33
Various compatibility fixes.
Sun Jul 27 22:12:03 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.16: +5 -5 lines
Diff to previous 3.16 , to selected 3.33
Mon Jul 21 22:30:18 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 3.15 , to selected 3.33
Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.14: +4 -5 lines
Diff to previous 3.14 , to selected 3.33
Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Changes since 3.13: +15 -11 lines
Diff to previous 3.13 , to selected 3.33
Tue Oct 27 09:08:26 1998 UTC (27 years ago) by gwlarson
Changes since 3.12: +4 -4 lines
Diff to previous 3.12 , to selected 3.33
Thu Mar 12 15:47:33 1998 UTC (27 years, 8 months ago) by gwlarson
Changes since 3.11: +13 -3 lines
Diff to previous 3.11 , to selected 3.33
added -I option for precomputed histogram
Wed Mar 19 13:04:09 1997 UTC (28 years, 8 months ago) by greg
Changes since 3.10: +9 -16 lines
Diff to previous 3.10 , to selected 3.33
changed -t option to -u, -d option to -x and -b option to -d
Wed Feb 5 16:08:14 1997 UTC (28 years, 9 months ago) by greg
Changes since 3.9: +10 -4 lines
Diff to previous 3.9 , to selected 3.33
changed -m option to read in color warp map (old -m now -d)
Wed Jan 29 13:22:08 1997 UTC (28 years, 9 months ago) by greg
Changes since 3.8: +25 -88 lines
Diff to previous 3.8 , to selected 3.33
added -i option to take fixation points on standard input
Thu Jan 9 13:56:23 1997 UTC (28 years, 10 months ago) by greg
Changes since 3.7: +33 -26 lines
Diff to previous 3.7 , to selected 3.33
Wed Jan 8 21:40:38 1997 UTC (28 years, 10 months ago) by greg
Changes since 3.6: +5 -5 lines
Diff to previous 3.6 , to selected 3.33
fixed bad calls to log() in fovhist()
Tue Jan 7 14:48:50 1997 UTC (28 years, 10 months ago) by greg
Changes since 3.5: +13 -1 lines
Diff to previous 3.5 , to selected 3.33
added -m option for putting out luminance mapping function
Fri Oct 11 10:46:57 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.4: +2 -2 lines
Diff to previous 3.4 , to selected 3.33
corrected tests in check2do()
Thu Oct 10 17:09:24 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.3: +1 -2 lines
Diff to previous 3.3 , to selected 3.33
fixed bugs in color scaling
Sat Oct 5 11:16:51 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.2: +6 -13 lines
Diff to previous 3.2 , to selected 3.33
changed check for significant veiling
Fri Oct 4 16:10:39 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.1: +0 -2 lines
Diff to previous 3.1 , to selected 3.33
Thu Oct 3 16:52:46 1996 UTC (29 years, 1 month ago) by greg
Diff to selected 3.33
