--- ray/src/px/pcond.c 2004/01/02 12:47:01 3.20 +++ ray/src/px/pcond.c 2004/03/28 20:33:14 3.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pcond.c,v 3.20 2004/01/02 12:47:01 schorsch Exp $"; +static const char RCSid[] = "$Id: pcond.c,v 3.21 2004/03/28 20:33:14 schorsch Exp $"; #endif /* * Condition Radiance picture for display/output @@ -45,11 +45,18 @@ double bwavg; /* mean brightness */ double scalef = 0.; /* linear scaling factor */ static gethfunc headline; +static void getahead(void); +static void mapimage(void); +static void getfovimg(void); +static void check2do(void); -main(argc, argv) -int argc; -char *argv[]; + +int +main( + int argc, + char *argv[] +) { static RGBPRIMS outprimS; int i; @@ -187,12 +194,15 @@ userr: fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n", progname); exit(1); + return 1; /* pro forma return */ #undef bool } -syserror(s) /* report system error and exit */ -char *s; +extern void +syserror( /* report system error and exit */ + char *s +) { fprintf(stderr, "%s: ", progname); perror(s); @@ -232,7 +242,8 @@ headline( /* process header line */ } -getahead() /* load picture header */ +static void +getahead(void) /* load picture header */ { char *err; @@ -270,7 +281,8 @@ getahead() /* load picture header */ } -mapimage() /* map picture and send to stdout */ +static void +mapimage(void) /* map picture and send to stdout */ { COLOR *scan; @@ -310,7 +322,8 @@ mapimage() /* map picture and send to stdout */ } -getfovimg() /* load foveal sampled image */ +static void +getfovimg(void) /* load foveal sampled image */ { char combuf[PATH_MAX]; FILE *fp; @@ -345,7 +358,8 @@ readerr: } -check2do() /* check histogram to see what isn't worth doing */ +static void +check2do(void) /* check histogram to see what isn't worth doing */ { double sum; double b, l;
