| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pcond.c,v 3.28 2016/03/10 18:25:46 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Condition Radiance picture for display/output
| 6 |
* Added white-balance adjustment 10/01 (GW).
| 7 |
| 8 |
| 9 |
#include "platform.h"
| 10 |
#include "paths.h"
| 11 |
#include "paths.h"
| 12 |
#include "pcond.h"
| 13 |
| 14 |
| 15 |
#define LDMAX 100 /* default max. display luminance */
| 16 |
#define LDDYN 32 /* default dynamic range */
| 17 |
| 18 |
int what2do = 0; /* desired adjustments */
| 19 |
| 20 |
double ldmax = LDMAX; /* maximum output luminance */
| 21 |
double lddyn = LDDYN; /* display dynamic range */
| 22 |
double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
| 23 |
| 24 |
char *progname; /* global argv[0] */
| 25 |
| 26 |
char *infn; /* input file name */
| 27 |
FILE *infp; /* input stream */
| 28 |
FILE *mapfp = NULL; /* tone-mapping function stream */
| 29 |
VIEW ourview = STDVIEW; /* picture view */
| 30 |
int gotview = 0; /* picture has view */
| 31 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 32 |
double fixfrac = 0.; /* histogram share due to fixations */
| 33 |
RESOLU inpres; /* input picture resolution */
| 34 |
| 35 |
COLOR *fovimg; /* foveal (1 degree) averaged image */
| 36 |
int fvxr, fvyr; /* foveal image resolution */
| 37 |
float *crfimg; /* contrast reduction factors */
| 38 |
short (*fixlst)[2]; /* fixation history list */
| 39 |
int nfixations; /* number of fixation points */
| 40 |
double bwhist[HISTRES]; /* luminance histogram */
| 41 |
double histot; /* total count of histogram */
| 42 |
double bwmin, bwmax; /* histogram limits */
| 43 |
double bwavg; /* mean brightness */
| 44 |
| 45 |
double scalef = 0.; /* linear scaling factor */
| 46 |
| 47 |
static gethfunc headline;
| 48 |
static void getahead(void);
| 49 |
static void mapimage(void);
| 50 |
static void getfovimg(void);
| 51 |
static void check2do(void);
| 52 |
| 53 |
| 54 |
| 55 |
int
| 56 |
main(
| 57 |
int argc,
| 58 |
char *argv[]
| 59 |
| 60 |
| 61 |
static RGBPRIMS outprimS;
| 62 |
int i;
| 63 |
#define check_bool(flg) switch (argv[i][2]) { \
| 64 |
case '\0': what2do ^= flg; break; \
| 65 |
case 'y': case 'Y': case 't': case 'T': \
| 66 |
case '+': case '1': what2do |= flg; break; \
| 67 |
case 'n': case 'N': case 'f': case 'F': \
| 68 |
case '-': case '0': what2do &= ~(flg); break; \
| 69 |
default: goto userr; }
| 70 |
| 71 |
progname = argv[0];
| 72 |
| 73 |
for (i = 1; i < argc && argv[i][0] == '-'; i++)
| 74 |
switch (argv[i][1]) {
| 75 |
case 'h':
| 76 |
check_bool(DO_HUMAN);
| 77 |
break;
| 78 |
case 'a':
| 79 |
check_bool(DO_ACUITY);
| 80 |
break;
| 81 |
case 'v':
| 82 |
check_bool(DO_VEIL);
| 83 |
break;
| 84 |
case 's':
| 85 |
check_bool(DO_HSENS);
| 86 |
break;
| 87 |
case 'c':
| 88 |
check_bool(DO_COLOR);
| 89 |
break;
| 90 |
case 'w':
| 91 |
check_bool(DO_CWEIGHT);
| 92 |
break;
| 93 |
case 'i':
| 94 |
if (i+1 >= argc) goto userr;
| 95 |
fixfrac = atof(argv[++i]);
| 96 |
if (fixfrac > FTINY) what2do |= DO_FIXHIST;
| 97 |
else what2do &= ~DO_FIXHIST;
| 98 |
break;
| 99 |
case 'I':
| 100 |
check_bool(DO_PREHIST);
| 101 |
break;
| 102 |
case 'l':
| 103 |
check_bool(DO_LINEAR);
| 104 |
break;
| 105 |
case 'p':
| 106 |
if (i+8 >= argc) goto userr;
| 107 |
outprimS[RED][CIEX] = atof(argv[++i]);
| 108 |
outprimS[RED][CIEY] = atof(argv[++i]);
| 109 |
outprimS[GRN][CIEX] = atof(argv[++i]);
| 110 |
outprimS[GRN][CIEY] = atof(argv[++i]);
| 111 |
outprimS[BLU][CIEX] = atof(argv[++i]);
| 112 |
outprimS[BLU][CIEY] = atof(argv[++i]);
| 113 |
outprimS[WHT][CIEX] = atof(argv[++i]);
| 114 |
outprimS[WHT][CIEY] = atof(argv[++i]);
| 115 |
outprims = outprimS;
| 116 |
break;
| 117 |
case 'e':
| 118 |
| 119 |
scalef = atof(argv[++i]);
| 120 |
if ((argv[i][0] == '+') | (argv[i][0] == '-'))
| 121 |
scalef = pow(2.0, scalef);
| 122 |
what2do |= DO_LINEAR;
| 123 |
break;
| 124 |
case 'f':
| 125 |
| 126 |
mbcalfile = argv[++i];
| 127 |
break;
| 128 |
case 'm':
| 129 |
| 130 |
cwarpfile = argv[++i];
| 131 |
break;
| 132 |
case 'u':
| 133 |
| 134 |
ldmax = atof(argv[++i]);
| 135 |
if (ldmax <= FTINY)
| 136 |
goto userr;
| 137 |
break;
| 138 |
case 'd':
| 139 |
| 140 |
lddyn = atof(argv[++i]);
| 141 |
break;
| 142 |
case 'x':
| 143 |
| 144 |
if ((mapfp = fopen(argv[++i], "w")) == NULL) {
| 145 |
fprintf(stderr,
| 146 |
"%s: cannot open for writing\n",
| 147 |
argv[i]);
| 148 |
exit(1);
| 149 |
| 150 |
break;
| 151 |
default:
| 152 |
goto userr;
| 153 |
| 154 |
if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) {
| 155 |
fprintf(stderr, "%s: only one of -i or -I option\n", progname);
| 156 |
exit(1);
| 157 |
| 158 |
if ((mbcalfile != NULL) + (cwarpfile != NULL) +
| 159 |
(outprims != stdprims) > 1) {
| 160 |
fprintf(stderr,
| 161 |
"%s: only one of -p, -m or -f option supported\n",
| 162 |
progname);
| 163 |
exit(1);
| 164 |
| 165 |
if ((outprims == stdprims) & (inprims != stdprims))
| 166 |
outprims = inprims;
| 167 |
Bldmin = Bl(ldmax/lddyn);
| 168 |
Bldmax = Bl(ldmax);
| 169 |
if (i >= argc || i+2 < argc)
| 170 |
goto userr;
| 171 |
/* open input file */
| 172 |
if ((infp = fopen(infn=argv[i], "r")) == NULL)
| 173 |
syserror(infn);
| 174 |
/* open output file */
| 175 |
if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
| 176 |
syserror(argv[i+1]);
| 177 |
SET_FILE_BINARY(infp);
| 178 |
SET_FILE_BINARY(stdout);
| 179 |
getahead(); /* load input header */
| 180 |
printargs(argc, argv, stdout); /* add to output header */
| 181 |
if ((mbcalfile == NULL) & (outprims != stdprims))
| 182 |
fputprims(outprims, stdout);
| 183 |
if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST)
| 184 |
getfovimg(); /* get foveal sample image? */
| 185 |
if (what2do&DO_PREHIST) /* get histogram? */
| 186 |
gethisto(stdin);
| 187 |
else if (what2do&DO_FIXHIST) /* get fixation history? */
| 188 |
getfixations(stdin);
| 189 |
mapimage(); /* map the picture */
| 190 |
if (mapfp != NULL) /* write out basic mapping */
| 191 |
putmapping(mapfp);
| 192 |
exit(0);
| 193 |
userr:
| 194 |
fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n",
| 195 |
progname);
| 196 |
exit(1);
| 197 |
return 1; /* pro forma return */
| 198 |
#undef check_bool
| 199 |
| 200 |
| 201 |
| 202 |
void
| 203 |
syserror( /* report system error and exit */
| 204 |
char *s
| 205 |
| 206 |
| 207 |
fprintf(stderr, "%s: ", progname);
| 208 |
perror(s);
| 209 |
exit(2);
| 210 |
| 211 |
| 212 |
| 213 |
static int
| 214 |
headline( /* process header line */
| 215 |
char *s,
| 216 |
void *p
| 217 |
| 218 |
| 219 |
static RGBPRIMS inprimS;
| 220 |
char fmt[MAXFMTLEN];
| 221 |
| 222 |
if (formatval(fmt, s)) { /* check if format string */
| 223 |
if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
| 224 |
else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
| 225 |
else lumf = NULL;
| 226 |
return(0); /* don't echo */
| 227 |
| 228 |
if (isprims(s)) { /* get input primaries */
| 229 |
primsval(inprimS, s);
| 230 |
inprims= inprimS;
| 231 |
| 232 |
| 233 |
if (isexpos(s)) { /* picture exposure */
| 234 |
inpexp *= exposval(s);
| 235 |
| 236 |
| 237 |
if (isaspect(s)) /* pixel aspect ratio */
| 238 |
pixaspect *= aspectval(s);
| 239 |
if (isview(s)) /* image view */
| 240 |
gotview += sscanview(&ourview, s);
| 241 |
return(fputs(s, stdout));
| 242 |
| 243 |
| 244 |
| 245 |
static void
| 246 |
getahead(void) /* load picture header */
| 247 |
| 248 |
char *err;
| 249 |
| 250 |
getheader(infp, headline, NULL);
| 251 |
if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
| 252 |
fprintf(stderr, "%s: %s: not a Radiance picture\n",
| 253 |
progname, infn);
| 254 |
exit(1);
| 255 |
| 256 |
if (lumf == rgblum)
| 257 |
comprgb2xyzWBmat(inrgb2xyz, inprims);
| 258 |
else if (mbcalfile != NULL) {
| 259 |
fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
| 260 |
progname);
| 261 |
exit(1);
| 262 |
| 263 |
if (!gotview || ourview.type == VT_PAR ||
| 264 |
(ourview.horiz <= 5.) | (ourview.vert <= 5.)) {
| 265 |
ourview = stdview;
| 266 |
ourview.type = VT_PER;
| 267 |
if (pixaspect*inpres.yr < inpres.xr) {
| 268 |
ourview.horiz = 40.0;
| 269 |
ourview.vert = 2.*180./PI *
| 270 |
atan(.3639702*pixaspect*inpres.yr/inpres.xr);
| 271 |
} else {
| 272 |
ourview.vert = 40.0;
| 273 |
ourview.horiz = 2.*180./PI *
| 274 |
atan(.3639702*inpres.xr/pixaspect/inpres.yr);
| 275 |
| 276 |
| 277 |
if ((err = setview(&ourview)) != NULL) {
| 278 |
fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
| 279 |
progname, infn, err);
| 280 |
exit(1);
| 281 |
| 282 |
| 283 |
| 284 |
| 285 |
static void
| 286 |
mapimage(void) /* map picture and send to stdout */
| 287 |
| 288 |
COLOR *scan;
| 289 |
| 290 |
comphist(); /* generate adaptation histogram */
| 291 |
check2do(); /* modify what2do flags */
| 292 |
if (what2do&DO_VEIL)
| 293 |
compveil(); /* compute veil image */
| 294 |
if (!(what2do&DO_LINEAR))
| 295 |
if (mkbrmap() < 0) /* make tone map */
| 296 |
what2do |= DO_LINEAR; /* failed! -- use linear */
| 297 |
#if ADJ_VEIL
| 298 |
else if (what2do&DO_VEIL)
| 299 |
adjveil(); /* else adjust veil image */
| 300 |
#endif
| 301 |
if (what2do&DO_LINEAR) {
| 302 |
if (scalef <= FTINY) {
| 303 |
if (what2do&DO_HSENS)
| 304 |
scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
| 305 |
htcontrs(Lb(bwavg));
| 306 |
else
| 307 |
scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
| 308 |
scalef *= WHTEFFICACY/(inpexp*ldmax);
| 309 |
| 310 |
fputexpos(inpexp*scalef, stdout); /* record exposure */
| 311 |
if (lumf == cielum) scalef /= WHTEFFICACY;
| 312 |
| 313 |
fputformat(COLRFMT, stdout); /* complete header */
| 314 |
putchar('\n');
| 315 |
fputsresolu(&inpres, stdout); /* resolution doesn't change */
| 316 |
/* condition our image */
| 317 |
for (scan = firstscan(); scan != NULL; scan = nextscan())
| 318 |
if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
| 319 |
fprintf(stderr, "%s: scanline write error\n",
| 320 |
progname);
| 321 |
exit(1);
| 322 |
| 323 |
| 324 |
| 325 |
| 326 |
static void
| 327 |
getfovimg(void) /* load foveal sampled image */
| 328 |
| 329 |
char combuf[PATH_MAX];
| 330 |
FILE *fp;
| 331 |
int x, y;
| 332 |
/* compute image size */
| 333 |
fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
| 334 |
if (fvxr < 2) fvxr = 2;
| 335 |
fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
| 336 |
if (fvyr < 2) fvyr = 2;
| 337 |
if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */
| 338 |
y = fvyr;
| 339 |
fvyr = fvxr;
| 340 |
fvxr = y;
| 341 |
| 342 |
if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
| 343 |
syserror("malloc");
| 344 |
sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d \"%s\"", fvxr, fvyr, infn);
| 345 |
if ((fp = popen(combuf, "r")) == NULL)
| 346 |
syserror("popen");
| 347 |
SET_FILE_BINARY(fp);
| 348 |
getheader(fp, NULL, NULL); /* skip header */
| 349 |
if (fgetresolu(&x, &y, fp) < 0 || (x != fvxr) | (y != fvyr))
| 350 |
goto readerr;
| 351 |
for (y = 0; y < fvyr; y++)
| 352 |
if (freadscan(fovscan(y), fvxr, fp) < 0)
| 353 |
goto readerr;
| 354 |
pclose(fp);
| 355 |
return;
| 356 |
readerr:
| 357 |
fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
| 358 |
progname);
| 359 |
exit(1);
| 360 |
| 361 |
| 362 |
| 363 |
static void
| 364 |
check2do(void) /* check histogram to see what isn't worth doing */
| 365 |
| 366 |
double sum;
| 367 |
double b, l;
| 368 |
int i;
| 369 |
| 370 |
/* check for within display range */
| 371 |
if (bwmax - bwmin <= Bldmax - Bldmin)
| 372 |
| 373 |
/* determine if veiling significant */
| 374 |
if (bwmax - bwmin < 4.5) /* heuristic */
| 375 |
what2do &= ~DO_VEIL;
| 376 |
| 377 |
if (!(what2do & (DO_ACUITY|DO_COLOR)))
| 378 |
return;
| 379 |
/* find 5th percentile */
| 380 |
sum = histot*0.05;
| 381 |
for (i = 0; i < HISTRES; i++)
| 382 |
if ((sum -= bwhist[i]) <= 0)
| 383 |
break;
| 384 |
b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
| 385 |
l = Lb(b);
| 386 |
/* determine if acuity adj. useful */
| 387 |
if (what2do&DO_ACUITY &&
| 388 |
hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
| 389 |
inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
| 390 |
what2do &= ~DO_ACUITY;
| 391 |
/* color sensitivity loss? */
| 392 |
if (l >= TopMesopic)
| 393 |
what2do &= ~DO_COLOR;
| 394 |
