Setting binary mode for input from pfilt (bug fix for latest Windows vers.)
Increased minimum view angle from 3 to 5 degrees
Fixed size of command line buffer, and allow spaces in input file path.
Various compatibility fixes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added -I option for precomputed histogram
changed -t option to -u, -d option to -x and -b option to -d
changed -m option to read in color warp map (old -m now -d)
added -i option to take fixation points on standard input
changed to histogram truncation made veiling reflection modify FOV sample image
fixed bad calls to log() in fovhist()
added -m option for putting out luminance mapping function
corrected tests in check2do()
fixed bugs in color scaling
changed check for significant veiling
