--- ray/src/px/pcond.c 1997/01/09 13:56:23 3.8 +++ ray/src/px/pcond.c 2004/01/02 12:47:01 3.20 @@ -1,24 +1,25 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pcond.c,v 3.20 2004/01/02 12:47:01 schorsch Exp $"; #endif - /* * Condition Radiance picture for display/output + * Added white-balance adjustment 10/01 (GW). */ +#include "platform.h" +#include "paths.h" +#include "rtprocess.h" #include "pcond.h" #define LDMAX 100 /* default max. display luminance */ -#define LDMINF 0.01 /* default min. display lum. factor */ +#define LDDYN 32 /* default dynamic range */ int what2do = 0; /* desired adjustments */ double ldmax = LDMAX; /* maximum output luminance */ -double ldmin = 0.; /* minimum output luminance */ -double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */ +double lddyn = LDDYN; /* display dynamic range */ +double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */ char *progname; /* global argv[0] */ @@ -28,18 +29,24 @@ FILE *mapfp = NULL; /* tone-mapping function stream VIEW ourview = STDVIEW; /* picture view */ int gotview = 0; /* picture has view */ double pixaspect = 1.0; /* pixel aspect ratio */ +double fixfrac = 0.; /* histogram share due to fixations */ RESOLU inpres; /* input picture resolution */ COLOR *fovimg; /* foveal (1 degree) averaged image */ -short fvxr, fvyr; /* foveal image resolution */ -float bwhist[HISTRES]; /* luminance histogram */ +int fvxr, fvyr; /* foveal image resolution */ +float *crfimg; /* contrast reduction factors */ +short (*fixlst)[2]; /* fixation history list */ +int nfixations; /* number of fixation points */ +double bwhist[HISTRES]; /* luminance histogram */ double histot; /* total count of histogram */ double bwmin, bwmax; /* histogram limits */ double bwavg; /* mean brightness */ double scalef = 0.; /* linear scaling factor */ +static gethfunc headline; + main(argc, argv) int argc; char *argv[]; @@ -76,6 +83,15 @@ char *argv[]; case 'w': bool(DO_CWEIGHT); break; + case 'i': + if (i+1 >= argc) goto userr; + fixfrac = atof(argv[++i]); + if (fixfrac > FTINY) what2do |= DO_FIXHIST; + else what2do &= ~DO_FIXHIST; + break; + case 'I': + bool(DO_PREHIST); + break; case 'l': bool(DO_LINEAR); break; @@ -94,7 +110,7 @@ char *argv[]; case 'e': if (i+1 >= argc) goto userr; scalef = atof(argv[++i]); - if (argv[i][0] == '+' | argv[i][0] == '-') + if ((argv[i][0] == '+') | (argv[i][0] == '-')) scalef = pow(2.0, scalef); what2do |= DO_LINEAR; break; @@ -102,17 +118,21 @@ char *argv[]; if (i+1 >= argc) goto userr; mbcalfile = argv[++i]; break; - case 't': + case 'm': if (i+1 >= argc) goto userr; + cwarpfile = argv[++i]; + break; + case 'u': + if (i+1 >= argc) goto userr; ldmax = atof(argv[++i]); if (ldmax <= FTINY) goto userr; break; - case 'b': + case 'd': if (i+1 >= argc) goto userr; - ldmin = atof(argv[++i]); + lddyn = atof(argv[++i]); break; - case 'm': + case 'x': if (i+1 >= argc) goto userr; if ((mapfp = fopen(argv[++i], "w")) == NULL) { fprintf(stderr, @@ -124,42 +144,47 @@ char *argv[]; default: goto userr; } - if (mbcalfile != NULL & outprims != stdprims) { - fprintf(stderr, "%s: only one of -p or -f option supported\n", - progname); + if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) { + fprintf(stderr, "%s: only one of -i or -I option\n", progname); exit(1); } - if (outprims == stdprims & inprims != stdprims) - outprims = inprims; - if (ldmin <= FTINY) - ldmin = ldmax*LDMINF; - else if (ldmin >= ldmax) { - fprintf(stderr, "%s: Ldmin (%f) >= Ldmax (%f)!\n", progname, - ldmin, ldmax); + if ((mbcalfile != NULL) + (cwarpfile != NULL) + + (outprims != stdprims) > 1) { + fprintf(stderr, + "%s: only one of -p, -m or -f option supported\n", + progname); exit(1); } - Bldmin = Bl(ldmin); + if ((outprims == stdprims) & (inprims != stdprims)) + outprims = inprims; + Bldmin = Bl(ldmax/lddyn); Bldmax = Bl(ldmax); if (i >= argc || i+2 < argc) goto userr; + /* open input file */ if ((infp = fopen(infn=argv[i], "r")) == NULL) syserror(infn); + /* open output file */ if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL) syserror(argv[i+1]); -#ifdef MSDOS - setmode(fileno(infp), O_BINARY); - setmode(fileno(stdout), O_BINARY); -#endif + SET_FILE_BINARY(infp); + SET_FILE_BINARY(stdout); getahead(); /* load input header */ printargs(argc, argv, stdout); /* add to output header */ - if (outprims != inprims) + if ((mbcalfile == NULL) & (outprims != stdprims)) fputprims(outprims, stdout); + if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST) + getfovimg(); /* get foveal sample image? */ + if (what2do&DO_PREHIST) /* get histogram? */ + gethisto(stdin); + else if (what2do&DO_FIXHIST) /* get fixation history? */ + getfixations(stdin); mapimage(); /* map the picture */ if (mapfp != NULL) /* write out basic mapping */ putmapping(mapfp); exit(0); userr: - fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal][-t Ldmax][-b Ldmin][-m mapfile] inpic [outpic]\n", + fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n", progname); exit(1); #undef bool @@ -175,8 +200,11 @@ char *s; } -headline(s) /* process header line */ -char *s; +static int +headline( /* process header line */ + char *s, + void *p +) { static RGBPRIMS inprimS; char fmt[32]; @@ -185,22 +213,22 @@ char *s; if (!strcmp(fmt,COLRFMT)) lumf = rgblum; else if (!strcmp(fmt,CIEFMT)) lumf = cielum; else lumf = NULL; - return; /* don't echo */ + return(0); /* don't echo */ } if (isprims(s)) { /* get input primaries */ primsval(inprimS, s); inprims= inprimS; - return; /* don't echo */ + return(0); /* don't echo */ } if (isexpos(s)) { /* picture exposure */ inpexp *= exposval(s); - return; /* don't echo */ + return(0); /* don't echo */ } if (isaspect(s)) /* pixel aspect ratio */ pixaspect *= aspectval(s); if (isview(s)) /* image view */ gotview += sscanview(&ourview, s); - fputs(s, stdout); + return(fputs(s, stdout)); } @@ -215,14 +243,14 @@ getahead() /* load picture header */ exit(1); } if (lumf == rgblum) - comprgb2xyzmat(inrgb2xyz, inprims); + comprgb2xyzWBmat(inrgb2xyz, inprims); else if (mbcalfile != NULL) { fprintf(stderr, "%s: macbethcal only works with RGB pictures\n", progname); exit(1); } if (!gotview || ourview.type == VT_PAR) { - copystruct(&ourview, &stdview); + ourview = stdview; ourview.type = VT_PER; if (pixaspect*inpres.yr < inpres.xr) { ourview.horiz = 40.0; @@ -246,36 +274,17 @@ mapimage() /* map picture and send to stdout */ { COLOR *scan; -#ifdef DEBUG - fprintf(stderr, "%s: generating histogram...", progname); -#endif - getfovimg(); /* get foveal sample image */ comphist(); /* generate adaptation histogram */ -#ifdef DEBUG - fputs("done\n", stderr); -#endif check2do(); /* modify what2do flags */ - if (what2do&DO_VEIL) { -#ifdef DEBUG - fprintf(stderr, "%s: computing veiling...", progname); + if (what2do&DO_VEIL) + compveil(); /* compute veil image */ + if (!(what2do&DO_LINEAR)) + if (mkbrmap() < 0) /* make tone map */ + what2do |= DO_LINEAR; /* failed! -- use linear */ +#if ADJ_VEIL + else if (what2do&DO_VEIL) + adjveil(); /* else adjust veil image */ #endif - compveil(); -#ifdef DEBUG - fputs("done\n", stderr); -#endif - } -#ifdef DEBUG - fprintf(stderr, "%s: computing brightness mapping...", progname); -#endif - if (!(what2do&DO_LINEAR) && mkbrmap() < 0) { /* make tone map */ - what2do |= DO_LINEAR; /* use linear scaling */ -#ifdef DEBUG - fputs("failed!\n", stderr); - } else - fputs("done\n", stderr); -#else - } -#endif if (what2do&DO_LINEAR) { if (scalef <= FTINY) { if (what2do&DO_HSENS) @@ -285,16 +294,13 @@ mapimage() /* map picture and send to stdout */ scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg); scalef *= WHTEFFICACY/(inpexp*ldmax); } -#ifdef DEBUG - fprintf(stderr, "%s: linear scaling factor = %f\n", - progname, scalef); -#endif fputexpos(inpexp*scalef, stdout); /* record exposure */ if (lumf == cielum) scalef /= WHTEFFICACY; } - putchar('\n'); /* complete header */ + fputformat(COLRFMT, stdout); /* complete header */ + putchar('\n'); fputsresolu(&inpres, stdout); /* resolution doesn't change */ - + /* condition our image */ for (scan = firstscan(); scan != NULL; scan = nextscan()) if (fwritescan(scan, scanlen(&inpres), stdout) < 0) { fprintf(stderr, "%s: scanline write error\n", @@ -304,23 +310,9 @@ mapimage() /* map picture and send to stdout */ } -double -centprob(x, y) /* center-weighting probability function */ -int x, y; -{ - double xr, yr, p; - /* paraboloid, 0 at 90 degrees from center */ - xr = (x - .5*(fvxr-1))/90.; /* 180 degree fisheye has fv?r == 90 */ - yr = (y - .5*(fvyr-1))/90.; - p = 1. - xr*xr - yr*yr; - return(p < 0. ? 0. : p); -} - - getfovimg() /* load foveal sampled image */ { - extern FILE *popen(); - char combuf[128]; + char combuf[PATH_MAX]; FILE *fp; int x, y; /* compute image size */ @@ -328,18 +320,18 @@ getfovimg() /* load foveal sampled image */ if (fvxr < 2) fvxr = 2; fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5; if (fvyr < 2) fvyr = 2; - if (!(inpres.or & YMAJOR)) { /* picture is rotated? */ + if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */ y = fvyr; fvyr = fvxr; fvxr = y; } if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL) syserror("malloc"); - sprintf(combuf, "pfilt -1 -b -x %d -y %d %s", fvxr, fvyr, infn); + sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d \"%s\"", fvxr, fvyr, infn); if ((fp = popen(combuf, "r")) == NULL) syserror("popen"); getheader(fp, NULL, NULL); /* skip header */ - if (fgetresolu(&x, &y, fp) < 0 || x != fvxr | y != fvyr) + if (fgetresolu(&x, &y, fp) < 0 || (x != fvxr) | (y != fvyr)) goto readerr; for (y = 0; y < fvyr; y++) if (freadscan(fovscan(y), fvxr, fp) < 0) @@ -353,42 +345,6 @@ readerr: } -comphist() /* create foveal sampled image and histogram */ -{ - double l, b, lwmin, lwmax; - register int x, y; - - lwmin = 1e10; /* find extrema */ - lwmax = 0.; - for (y = 0; y < fvyr; y++) - for (x = 0; x < fvxr; x++) { - l = plum(fovscan(y)[x]); - if (l < lwmin) lwmin = l; - if (l > lwmax) lwmax = l; - } - lwmin -= FTINY; - lwmax += FTINY; - if (lwmin < LMIN) lwmin = LMIN; - if (lwmax > LMAX) lwmax = LMAX; - /* compute histogram */ - bwmin = Bl(lwmin); - bwmax = Bl(lwmax); - bwavg = 0.; - for (y = 0; y < fvyr; y++) - for (x = 0; x < fvxr; x++) { - l = plum(fovscan(y)[x]); - if (l < lwmin) continue; - if (l > lwmax) continue; - b = Bl(l); - bwavg += b; - l = what2do&DO_CWEIGHT ? centprob(x,y) : 1.; - bwhist[bwhi(b)] += l; - histot += l; - } - bwavg /= histot; -} - - check2do() /* check histogram to see what isn't worth doing */ { double sum; @@ -396,11 +352,10 @@ check2do() /* check histogram to see what isn't worth register int i; /* check for within display range */ - l = Lb(bwmax)/Lb(bwmin); - if (l <= ldmax/ldmin) + if (bwmax - bwmin <= Bldmax - Bldmin) what2do |= DO_LINEAR; /* determine if veiling significant */ - if (l < 100.) /* heuristic */ + if (bwmax - bwmin < 4.5) /* heuristic */ what2do &= ~DO_VEIL; if (!(what2do & (DO_ACUITY|DO_COLOR)))
