root/radiance/ray/src/px/pcond.c
Revision: 3.9
Committed: Wed Jan 29 13:22:08 1997 UTC (27 years, 4 months ago) by greg
Changes since 3.8: +25 -88 lines
added -i option to take fixation points on standard input
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Condition Radiance picture for display/output
9 */
10
11 #include "pcond.h"
12
13
14 #define LDMAX 100 /* default max. display luminance */
15 #define LDMINF 0.01 /* default min. display lum. factor */
16
17 int what2do = 0; /* desired adjustments */
18
19 double ldmax = LDMAX; /* maximum output luminance */
20 double ldmin = 0.; /* minimum output luminance */
21 double Bldmin, Bldmax; /* Bl(ldmin) and Bl(ldmax) */
22
23 char *progname; /* global argv[0] */
24
25 char *infn; /* input file name */
26 FILE *infp; /* input stream */
27 FILE *mapfp = NULL; /* tone-mapping function stream */
28 VIEW ourview = STDVIEW; /* picture view */
29 int gotview = 0; /* picture has view */
30 double pixaspect = 1.0; /* pixel aspect ratio */
31 double fixfrac = 0.; /* histogram share due to fixations */
32 RESOLU inpres; /* input picture resolution */
33
34 COLOR *fovimg; /* foveal (1 degree) averaged image */
35 short fvxr, fvyr; /* foveal image resolution */
36 short (*fixlst)[2]; /* fixation history list */
37 int nfixations; /* number of fixation points */
38 float bwhist[HISTRES]; /* luminance histogram */
39 double histot; /* total count of histogram */
40 double bwmin, bwmax; /* histogram limits */
41 double bwavg; /* mean brightness */
42
43 double scalef = 0.; /* linear scaling factor */
44
45
46 main(argc, argv)
47 int argc;
48 char *argv[];
49 {
50 static RGBPRIMS outprimS;
51 int i;
52 #define bool(flg) switch (argv[i][2]) { \
53 case '\0': what2do ^= flg; break; \
54 case 'y': case 'Y': case 't': case 'T': \
55 case '+': case '1': what2do |= flg; break; \
56 case 'n': case 'N': case 'f': case 'F': \
57 case '-': case '0': what2do &= ~(flg); break; \
58 default: goto userr; }
59
60 progname = argv[0];
61
62 for (i = 1; i < argc && argv[i][0] == '-'; i++)
63 switch (argv[i][1]) {
64 case 'h':
65 bool(DO_HUMAN);
66 break;
67 case 'a':
68 bool(DO_ACUITY);
69 break;
70 case 'v':
71 bool(DO_VEIL);
72 break;
73 case 's':
74 bool(DO_HSENS);
75 break;
76 case 'c':
77 bool(DO_COLOR);
78 break;
79 case 'w':
80 bool(DO_CWEIGHT);
81 break;
82 case 'i':
83 if (i+1 >= argc) goto userr;
84 fixfrac = atof(argv[++i]);
85 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
86 else what2do &= ~DO_FIXHIST;
87 break;
88 case 'l':
89 bool(DO_LINEAR);
90 break;
91 case 'p':
92 if (i+8 >= argc) goto userr;
93 outprimS[RED][CIEX] = atof(argv[++i]);
94 outprimS[RED][CIEY] = atof(argv[++i]);
95 outprimS[GRN][CIEX] = atof(argv[++i]);
96 outprimS[GRN][CIEY] = atof(argv[++i]);
97 outprimS[BLU][CIEX] = atof(argv[++i]);
98 outprimS[BLU][CIEY] = atof(argv[++i]);
99 outprimS[WHT][CIEX] = atof(argv[++i]);
100 outprimS[WHT][CIEY] = atof(argv[++i]);
101 outprims = outprimS;
102 break;
103 case 'e':
104 if (i+1 >= argc) goto userr;
105 scalef = atof(argv[++i]);
106 if (argv[i][0] == '+' | argv[i][0] == '-')
107 scalef = pow(2.0, scalef);
108 what2do |= DO_LINEAR;
109 break;
110 case 'f':
111 if (i+1 >= argc) goto userr;
112 mbcalfile = argv[++i];
113 break;
114 case 't':
115 if (i+1 >= argc) goto userr;
116 ldmax = atof(argv[++i]);
117 if (ldmax <= FTINY)
118 goto userr;
119 break;
120 case 'b':
121 if (i+1 >= argc) goto userr;
122 ldmin = atof(argv[++i]);
123 break;
124 case 'm':
125 if (i+1 >= argc) goto userr;
126 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
127 fprintf(stderr,
128 "%s: cannot open for writing\n",
129 argv[i]);
130 exit(1);
131 }
132 break;
133 default:
134 goto userr;
135 }
136 if (mbcalfile != NULL & outprims != stdprims) {
137 fprintf(stderr, "%s: only one of -p or -f option supported\n",
138 progname);
139 exit(1);
140 }
141 if (outprims == stdprims & inprims != stdprims)
142 outprims = inprims;
143 if (ldmin <= FTINY)
144 ldmin = ldmax*LDMINF;
145 else if (ldmin >= ldmax) {
146 fprintf(stderr, "%s: Ldmin (%f) >= Ldmax (%f)!\n", progname,
147 ldmin, ldmax);
148 exit(1);
149 }
150 Bldmin = Bl(ldmin);
151 Bldmax = Bl(ldmax);
152 if (i >= argc || i+2 < argc)
153 goto userr;
154 /* open input file */
155 if ((infp = fopen(infn=argv[i], "r")) == NULL)
156 syserror(infn);
157 /* open output file */
158 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
159 syserror(argv[i+1]);
160 #ifdef MSDOS
161 setmode(fileno(infp), O_BINARY);
162 setmode(fileno(stdout), O_BINARY);
163 #endif
164 getahead(); /* load input header */
165 printargs(argc, argv, stdout); /* add to output header */
166 if (mbcalfile == NULL & outprims != stdprims)
167 fputprims(outprims, stdout);
168 getfovimg(); /* get foveal sample image */
169 if (what2do&DO_FIXHIST) /* get fixation history? */
170 getfixations(stdin);
171 mapimage(); /* map the picture */
172 if (mapfp != NULL) /* write out basic mapping */
173 putmapping(mapfp);
174 exit(0);
175 userr:
176 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal][-t Ldmax][-b Ldmin][-m mapfile] inpic [outpic]\n",
177 progname);
178 exit(1);
179 #undef bool
180 }
181
182
183 syserror(s) /* report system error and exit */
184 char *s;
185 {
186 fprintf(stderr, "%s: ", progname);
187 perror(s);
188 exit(2);
189 }
190
191
192 headline(s) /* process header line */
193 char *s;
194 {
195 static RGBPRIMS inprimS;
196 char fmt[32];
197
198 if (formatval(fmt, s)) { /* check if format string */
199 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
200 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
201 else lumf = NULL;
202 return; /* don't echo */
203 }
204 if (isprims(s)) { /* get input primaries */
205 primsval(inprimS, s);
206 inprims= inprimS;
207 return; /* don't echo */
208 }
209 if (isexpos(s)) { /* picture exposure */
210 inpexp *= exposval(s);
211 return; /* don't echo */
212 }
213 if (isaspect(s)) /* pixel aspect ratio */
214 pixaspect *= aspectval(s);
215 if (isview(s)) /* image view */
216 gotview += sscanview(&ourview, s);
217 fputs(s, stdout);
218 }
219
220
221 getahead() /* load picture header */
222 {
223 char *err;
224
225 getheader(infp, headline, NULL);
226 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
227 fprintf(stderr, "%s: %s: not a Radiance picture\n",
228 progname, infn);
229 exit(1);
230 }
231 if (lumf == rgblum)
232 comprgb2xyzmat(inrgb2xyz, inprims);
233 else if (mbcalfile != NULL) {
234 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
235 progname);
236 exit(1);
237 }
238 if (!gotview || ourview.type == VT_PAR) {
239 copystruct(&ourview, &stdview);
240 ourview.type = VT_PER;
241 if (pixaspect*inpres.yr < inpres.xr) {
242 ourview.horiz = 40.0;
243 ourview.vert = 2.*180./PI *
244 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
245 } else {
246 ourview.vert = 40.0;
247 ourview.horiz = 2.*180./PI *
248 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
249 }
250 }
251 if ((err = setview(&ourview)) != NULL) {
252 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
253 progname, infn, err);
254 exit(1);
255 }
256 }
257
258
259 mapimage() /* map picture and send to stdout */
260 {
261 COLOR *scan;
262
263 comphist(); /* generate adaptation histogram */
264 check2do(); /* modify what2do flags */
265 if (what2do&DO_VEIL)
266 compveil();
267 if (!(what2do&DO_LINEAR) && mkbrmap() < 0) /* make tone map */
268 what2do |= DO_LINEAR; /* failed! -- use linear scaling */
269 if (what2do&DO_LINEAR) {
270 if (scalef <= FTINY) {
271 if (what2do&DO_HSENS)
272 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
273 htcontrs(Lb(bwavg));
274 else
275 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
276 scalef *= WHTEFFICACY/(inpexp*ldmax);
277 }
278 fputexpos(inpexp*scalef, stdout); /* record exposure */
279 if (lumf == cielum) scalef /= WHTEFFICACY;
280 }
281 fputformat(COLRFMT, stdout); /* complete header */
282 putchar('\n');
283 fputsresolu(&inpres, stdout); /* resolution doesn't change */
284 /* condition our image */
285 for (scan = firstscan(); scan != NULL; scan = nextscan())
286 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
287 fprintf(stderr, "%s: scanline write error\n",
288 progname);
289 exit(1);
290 }
291 }
292
293
294 getfovimg() /* load foveal sampled image */
295 {
296 extern FILE *popen();
297 char combuf[128];
298 FILE *fp;
299 int x, y;
300 /* compute image size */
301 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
302 if (fvxr < 2) fvxr = 2;
303 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
304 if (fvyr < 2) fvyr = 2;
305 if (!(inpres.or & YMAJOR)) { /* picture is rotated? */
306 y = fvyr;
307 fvyr = fvxr;
308 fvxr = y;
309 }
310 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
311 syserror("malloc");
312 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d %s", fvxr, fvyr, infn);
313 if ((fp = popen(combuf, "r")) == NULL)
314 syserror("popen");
315 getheader(fp, NULL, NULL); /* skip header */
316 if (fgetresolu(&x, &y, fp) < 0 || x != fvxr | y != fvyr)
317 goto readerr;
318 for (y = 0; y < fvyr; y++)
319 if (freadscan(fovscan(y), fvxr, fp) < 0)
320 goto readerr;
321 pclose(fp);
322 return;
323 readerr:
324 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
325 progname);
326 exit(1);
327 }
328
329
330 check2do() /* check histogram to see what isn't worth doing */
331 {
332 double sum;
333 double b, l;
334 register int i;
335
336 /* check for within display range */
337 if (bwmax - bwmin <= Bldmax - Bldmin)
338 what2do |= DO_LINEAR;
339 /* determine if veiling significant */
340 if (bwmax - bwmin < 4.5) /* heuristic */
341 what2do &= ~DO_VEIL;
342
343 if (!(what2do & (DO_ACUITY|DO_COLOR)))
344 return;
345 /* find 5th percentile */
346 sum = histot*0.05;
347 for (i = 0; i < HISTRES; i++)
348 if ((sum -= bwhist[i]) <= 0)
349 break;
350 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
351 l = Lb(b);
352 /* determine if acuity adj. useful */
353 if (what2do&DO_ACUITY &&
354 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
355 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
356 what2do &= ~DO_ACUITY;
357 /* color sensitivity loss? */
358 if (l >= TopMesopic)
359 what2do &= ~DO_COLOR;
360 }
