root/radiance/ray/src/px/pcond.c
Revision: 3.19
Committed: Mon Nov 10 11:54:23 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 3.18: +4 -3 lines
Fixed size of command line buffer, and allow spaces in input file path.
2 static const char RCSid[] = "$Id: pcond.c,v 3.18 2003/10/27 10:24:51 schorsch Exp $";
5 * Condition Radiance picture for display/output
6 * Added white-balance adjustment 10/01 (GW).
7 */
8
9 #include "platform.h"
10 #include "paths.h"
11 #include "rtprocess.h"
12 #include "pcond.h"
13
14
15 #define LDMAX 100 /* default max. display luminance */
16 #define LDDYN 32 /* default dynamic range */
17
18 int what2do = 0; /* desired adjustments */
19
20 double ldmax = LDMAX; /* maximum output luminance */
21 double lddyn = LDDYN; /* display dynamic range */
22 double Bldmin, Bldmax; /* Bl(ldmax/lddyn) and Bl(ldmax) */
23
24 char *progname; /* global argv[0] */
25
26 char *infn; /* input file name */
27 FILE *infp; /* input stream */
28 FILE *mapfp = NULL; /* tone-mapping function stream */
29 VIEW ourview = STDVIEW; /* picture view */
30 int gotview = 0; /* picture has view */
31 double pixaspect = 1.0; /* pixel aspect ratio */
32 double fixfrac = 0.; /* histogram share due to fixations */
33 RESOLU inpres; /* input picture resolution */
34
35 COLOR *fovimg; /* foveal (1 degree) averaged image */
36 int fvxr, fvyr; /* foveal image resolution */
37 float *crfimg; /* contrast reduction factors */
38 short (*fixlst)[2]; /* fixation history list */
39 int nfixations; /* number of fixation points */
40 double bwhist[HISTRES]; /* luminance histogram */
41 double histot; /* total count of histogram */
42 double bwmin, bwmax; /* histogram limits */
43 double bwavg; /* mean brightness */
44
45 double scalef = 0.; /* linear scaling factor */
46
47
48 main(argc, argv)
49 int argc;
50 char *argv[];
51 {
52 static RGBPRIMS outprimS;
53 int i;
54 #define bool(flg) switch (argv[i][2]) { \
55 case '\0': what2do ^= flg; break; \
56 case 'y': case 'Y': case 't': case 'T': \
57 case '+': case '1': what2do |= flg; break; \
58 case 'n': case 'N': case 'f': case 'F': \
59 case '-': case '0': what2do &= ~(flg); break; \
60 default: goto userr; }
61
62 progname = argv[0];
63
64 for (i = 1; i < argc && argv[i][0] == '-'; i++)
65 switch (argv[i][1]) {
66 case 'h':
67 bool(DO_HUMAN);
68 break;
69 case 'a':
70 bool(DO_ACUITY);
71 break;
72 case 'v':
73 bool(DO_VEIL);
74 break;
75 case 's':
76 bool(DO_HSENS);
77 break;
78 case 'c':
79 bool(DO_COLOR);
80 break;
81 case 'w':
82 bool(DO_CWEIGHT);
83 break;
84 case 'i':
85 if (i+1 >= argc) goto userr;
86 fixfrac = atof(argv[++i]);
87 if (fixfrac > FTINY) what2do |= DO_FIXHIST;
88 else what2do &= ~DO_FIXHIST;
89 break;
90 case 'I':
91 bool(DO_PREHIST);
92 break;
93 case 'l':
94 bool(DO_LINEAR);
95 break;
96 case 'p':
97 if (i+8 >= argc) goto userr;
98 outprimS[RED][CIEX] = atof(argv[++i]);
99 outprimS[RED][CIEY] = atof(argv[++i]);
100 outprimS[GRN][CIEX] = atof(argv[++i]);
101 outprimS[GRN][CIEY] = atof(argv[++i]);
102 outprimS[BLU][CIEX] = atof(argv[++i]);
103 outprimS[BLU][CIEY] = atof(argv[++i]);
104 outprimS[WHT][CIEX] = atof(argv[++i]);
105 outprimS[WHT][CIEY] = atof(argv[++i]);
106 outprims = outprimS;
107 break;
108 case 'e':
109 if (i+1 >= argc) goto userr;
110 scalef = atof(argv[++i]);
111 if ((argv[i][0] == '+') | (argv[i][0] == '-'))
112 scalef = pow(2.0, scalef);
113 what2do |= DO_LINEAR;
114 break;
115 case 'f':
116 if (i+1 >= argc) goto userr;
117 mbcalfile = argv[++i];
118 break;
119 case 'm':
120 if (i+1 >= argc) goto userr;
121 cwarpfile = argv[++i];
122 break;
123 case 'u':
124 if (i+1 >= argc) goto userr;
125 ldmax = atof(argv[++i]);
126 if (ldmax <= FTINY)
127 goto userr;
128 break;
129 case 'd':
130 if (i+1 >= argc) goto userr;
131 lddyn = atof(argv[++i]);
132 break;
133 case 'x':
134 if (i+1 >= argc) goto userr;
135 if ((mapfp = fopen(argv[++i], "w")) == NULL) {
136 fprintf(stderr,
137 "%s: cannot open for writing\n",
138 argv[i]);
139 exit(1);
140 }
141 break;
142 default:
143 goto userr;
144 }
145 if ((what2do & (DO_FIXHIST|DO_PREHIST)) == (DO_FIXHIST|DO_PREHIST)) {
146 fprintf(stderr, "%s: only one of -i or -I option\n", progname);
147 exit(1);
148 }
149 if ((mbcalfile != NULL) + (cwarpfile != NULL) +
150 (outprims != stdprims) > 1) {
151 fprintf(stderr,
152 "%s: only one of -p, -m or -f option supported\n",
153 progname);
154 exit(1);
155 }
156 if ((outprims == stdprims) & (inprims != stdprims))
157 outprims = inprims;
158 Bldmin = Bl(ldmax/lddyn);
159 Bldmax = Bl(ldmax);
160 if (i >= argc || i+2 < argc)
161 goto userr;
162 /* open input file */
163 if ((infp = fopen(infn=argv[i], "r")) == NULL)
164 syserror(infn);
165 /* open output file */
166 if (i+2 == argc && freopen(argv[i+1], "w", stdout) == NULL)
167 syserror(argv[i+1]);
168 SET_FILE_BINARY(infp);
169 SET_FILE_BINARY(stdout);
170 getahead(); /* load input header */
171 printargs(argc, argv, stdout); /* add to output header */
172 if ((mbcalfile == NULL) & (outprims != stdprims))
173 fputprims(outprims, stdout);
174 if ((what2do & (DO_PREHIST|DO_VEIL|DO_ACUITY)) != DO_PREHIST)
175 getfovimg(); /* get foveal sample image? */
176 if (what2do&DO_PREHIST) /* get histogram? */
177 gethisto(stdin);
178 else if (what2do&DO_FIXHIST) /* get fixation history? */
179 getfixations(stdin);
180 mapimage(); /* map the picture */
181 if (mapfp != NULL) /* write out basic mapping */
182 putmapping(mapfp);
183 exit(0);
184 userr:
185 fprintf(stderr, "Usage: %s [-{h|a|v|s|c|l|w}[+-]][-I|-i ffrac][-e ev][-p xr yr xg yg xb yb xw yw|-f mbf.cal|-m rgb.cwp][-u Ldmax][-d Lddyn][-x mapfile] inpic [outpic]\n",
186 progname);
187 exit(1);
188 #undef bool
189 }
190
191
192 syserror(s) /* report system error and exit */
193 char *s;
194 {
195 fprintf(stderr, "%s: ", progname);
196 perror(s);
197 exit(2);
198 }
199
200
201 headline(s) /* process header line */
202 char *s;
203 {
204 static RGBPRIMS inprimS;
205 char fmt[32];
206
207 if (formatval(fmt, s)) { /* check if format string */
208 if (!strcmp(fmt,COLRFMT)) lumf = rgblum;
209 else if (!strcmp(fmt,CIEFMT)) lumf = cielum;
210 else lumf = NULL;
211 return(0); /* don't echo */
212 }
213 if (isprims(s)) { /* get input primaries */
214 primsval(inprimS, s);
215 inprims= inprimS;
216 return(0); /* don't echo */
217 }
218 if (isexpos(s)) { /* picture exposure */
219 inpexp *= exposval(s);
220 return(0); /* don't echo */
221 }
222 if (isaspect(s)) /* pixel aspect ratio */
223 pixaspect *= aspectval(s);
224 if (isview(s)) /* image view */
225 gotview += sscanview(&ourview, s);
226 return(fputs(s, stdout));
227 }
228
229
230 getahead() /* load picture header */
231 {
232 char *err;
233
234 getheader(infp, headline, NULL);
235 if (lumf == NULL || !fgetsresolu(&inpres, infp)) {
236 fprintf(stderr, "%s: %s: not a Radiance picture\n",
237 progname, infn);
238 exit(1);
239 }
240 if (lumf == rgblum)
241 comprgb2xyzWBmat(inrgb2xyz, inprims);
242 else if (mbcalfile != NULL) {
243 fprintf(stderr, "%s: macbethcal only works with RGB pictures\n",
244 progname);
245 exit(1);
246 }
247 if (!gotview || ourview.type == VT_PAR) {
248 ourview = stdview;
249 ourview.type = VT_PER;
250 if (pixaspect*inpres.yr < inpres.xr) {
251 ourview.horiz = 40.0;
252 ourview.vert = 2.*180./PI *
253 atan(.3639702*pixaspect*inpres.yr/inpres.xr);
254 } else {
255 ourview.vert = 40.0;
256 ourview.horiz = 2.*180./PI *
257 atan(.3639702*inpres.xr/pixaspect/inpres.yr);
258 }
259 }
260 if ((err = setview(&ourview)) != NULL) {
261 fprintf(stderr, "%s: view error in picture \"%s\": %s\n",
262 progname, infn, err);
263 exit(1);
264 }
265 }
266
267
268 mapimage() /* map picture and send to stdout */
269 {
270 COLOR *scan;
271
272 comphist(); /* generate adaptation histogram */
273 check2do(); /* modify what2do flags */
274 if (what2do&DO_VEIL)
275 compveil(); /* compute veil image */
276 if (!(what2do&DO_LINEAR))
277 if (mkbrmap() < 0) /* make tone map */
278 what2do |= DO_LINEAR; /* failed! -- use linear */
279 #if ADJ_VEIL
280 else if (what2do&DO_VEIL)
281 adjveil(); /* else adjust veil image */
282 #endif
283 if (what2do&DO_LINEAR) {
284 if (scalef <= FTINY) {
285 if (what2do&DO_HSENS)
286 scalef = htcontrs(Lb(0.5*(Bldmax+Bldmin))) /
287 htcontrs(Lb(bwavg));
288 else
289 scalef = Lb(0.5*(Bldmax+Bldmin)) / Lb(bwavg);
290 scalef *= WHTEFFICACY/(inpexp*ldmax);
291 }
292 fputexpos(inpexp*scalef, stdout); /* record exposure */
293 if (lumf == cielum) scalef /= WHTEFFICACY;
294 }
295 fputformat(COLRFMT, stdout); /* complete header */
296 putchar('\n');
297 fputsresolu(&inpres, stdout); /* resolution doesn't change */
298 /* condition our image */
299 for (scan = firstscan(); scan != NULL; scan = nextscan())
300 if (fwritescan(scan, scanlen(&inpres), stdout) < 0) {
301 fprintf(stderr, "%s: scanline write error\n",
302 progname);
303 exit(1);
304 }
305 }
306
307
308 getfovimg() /* load foveal sampled image */
309 {
310 char combuf[PATH_MAX];
311 FILE *fp;
312 int x, y;
313 /* compute image size */
314 fvxr = sqrt(ourview.hn2)/FOVDIA + 0.5;
315 if (fvxr < 2) fvxr = 2;
316 fvyr = sqrt(ourview.vn2)/FOVDIA + 0.5;
317 if (fvyr < 2) fvyr = 2;
318 if (!(inpres.rt & YMAJOR)) { /* picture is rotated? */
319 y = fvyr;
320 fvyr = fvxr;
321 fvxr = y;
322 }
323 if ((fovimg = (COLOR *)malloc(fvxr*fvyr*sizeof(COLOR))) == NULL)
324 syserror("malloc");
325 sprintf(combuf, "pfilt -1 -b -pa 0 -x %d -y %d \"%s\"", fvxr, fvyr, infn);
326 if ((fp = popen(combuf, "r")) == NULL)
327 syserror("popen");
328 getheader(fp, NULL, NULL); /* skip header */
329 if (fgetresolu(&x, &y, fp) < 0 || (x != fvxr) | (y != fvyr))
330 goto readerr;
331 for (y = 0; y < fvyr; y++)
332 if (freadscan(fovscan(y), fvxr, fp) < 0)
333 goto readerr;
334 pclose(fp);
335 return;
336 readerr:
337 fprintf(stderr, "%s: error reading from pfilt process in fovimage\n",
338 progname);
339 exit(1);
340 }
341
342
343 check2do() /* check histogram to see what isn't worth doing */
344 {
345 double sum;
346 double b, l;
347 register int i;
348
349 /* check for within display range */
350 if (bwmax - bwmin <= Bldmax - Bldmin)
351 what2do |= DO_LINEAR;
352 /* determine if veiling significant */
353 if (bwmax - bwmin < 4.5) /* heuristic */
354 what2do &= ~DO_VEIL;
355
356 if (!(what2do & (DO_ACUITY|DO_COLOR)))
357 return;
358 /* find 5th percentile */
359 sum = histot*0.05;
360 for (i = 0; i < HISTRES; i++)
361 if ((sum -= bwhist[i]) <= 0)
362 break;
363 b = (i+.5)*(bwmax-bwmin)/HISTRES + bwmin;
364 l = Lb(b);
365 /* determine if acuity adj. useful */
366 if (what2do&DO_ACUITY &&
367 hacuity(l) >= (inpres.xr/sqrt(ourview.hn2) +
368 inpres.yr/sqrt(ourview.vn2))/(2.*180./PI))
369 what2do &= ~DO_ACUITY;
370 /* color sensitivity loss? */
371 if (l >= TopMesopic)
372 what2do &= ~DO_COLOR;
373 }
