root/radiance/ray/src/px/pcompos.c
Revision: 2.38
Committed: Fri Jul 19 17:37:56 2019 UTC (5 years, 9 months ago) by greg
Changes since 2.37: +2 -4 lines
2 static const char RCSid[] = "$Id: pcompos.c,v 2.37 2018/08/02 18:33:43 greg Exp $";
5 * pcompos.c - program to composite pictures.
6 *
7 * 6/30/87
8 */
9
10 #include <math.h>
11
12 #include "copyright.h"
13
14 #include "rtio.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rterror.h"
18 #include "color.h"
19 #include "resolu.h"
20
21 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22 #undef getc
23 #define getc getc_unlocked
24 #endif
25
26 #define MAXFILE 1024
27
28 #define HASMIN 1
29 #define HASMAX 2
30
31 /* output picture size */
32 int xsiz = 0;
33 int ysiz = 0;
34 /* input dimensions */
35 int xmin = 0;
36 int ymin = 0;
37 int xmax = 0;
38 int ymax = 0;
39
40 COLR bgcolr = BLKCOLR; /* background color */
41
42 int labelht = 24; /* label height */
43
44 int checkthresh = 0; /* check threshold value */
45
46 char StandardInput[] = "<stdin>";
47 char Command[] = "<Command>";
48 char Label[] = "<Label>";
49
50 char *progname;
51
52 struct {
53 char *name; /* file or command name */
54 FILE *fp; /* stream pointer */
55 int xres, yres; /* picture size */
56 int xloc, yloc; /* anchor point */
57 int flags; /* HASMIN, HASMAX */
58 double thmin, thmax; /* thresholds */
59 } input[MAXFILE]; /* our input files */
60
61 int nfile; /* number of files */
62
63 int echoheader = 1;
64 char ourfmt[LPICFMT+1] = PICFMT;
65 int wrongformat = 0;
66
67
68 static gethfunc headline;
69 static void compos(void);
70 static int cmpcolr(COLR c1, double lv2);
71 static FILE * lblopen(char *s, int *xp, int *yp);
72
73
74
75 static int
76 headline( /* print line preceded by a tab */
77 char *s,
78 void *p
79 )
80 {
81 char fmt[MAXFMTLEN];
82
83 if (isheadid(s))
84 return(0);
85 if (formatval(fmt, s)) {
86 if (globmatch(ourfmt, fmt)) {
87 wrongformat = 0;
88 strcpy(ourfmt, fmt);
89 } else
90 wrongformat = 1;
91 } else if (echoheader) {
92 fputc('\t', stdout);
93 fputs(s, stdout);
94 }
95 return(0);
96 }
97
98
99 int
100 main(
101 int argc,
102 char *argv[]
103 )
104 {
105 int ncolumns = 0;
106 int autolabel = 0;
107 int curcol = 0, x0 = 0, curx = 0, cury = 0, spacing = 0;
108 int xsgn, ysgn;
109 char *thislabel;
110 int an;
111 SET_DEFAULT_BINARY();
112 SET_FILE_BINARY(stdin);
113 SET_FILE_BINARY(stdout);
114 progname = argv[0];
115
116 for (an = 1; an < argc && argv[an][0] == '-'; an++)
117 switch (argv[an][1]) {
118 case 'h':
119 echoheader = !echoheader;
120 break;
121 case 'x':
122 xsiz = atoi(argv[++an]);
123 break;
124 case 'y':
125 ysiz = atoi(argv[++an]);
126 break;
127 case 'b':
128 setcolr(bgcolr, atof(argv[an+1]),
129 atof(argv[an+2]),
130 atof(argv[an+3]));
131 an += 3;
132 break;
133 case 'a':
134 ncolumns = atoi(argv[++an]);
135 break;
136 case 's':
137 spacing = atoi(argv[++an]);
138 break;
139 case 'o':
140 curx = x0 = atoi(argv[++an]);
141 cury = atoi(argv[++an]);
142 break;
143 case 'l':
144 switch (argv[an][2]) {
145 case 'a':
146 autolabel++;
147 break;
148 case 'h':
149 labelht = atoi(argv[++an]);
150 break;
151 case '\0':
152 goto dofiles;
153 default:
154 goto userr;
155 }
156 break;
157 case '\0':
158 case 't':
159 goto dofiles;
160 default:
161 goto userr;
162 }
163 dofiles:
164 newheader("RADIANCE", stdout);
165 fputnow(stdout);
166 for (nfile = 0; an < argc; nfile++) {
167 if (nfile >= MAXFILE)
168 goto toomany;
169 thislabel = NULL;
170 input[nfile].flags = 0;
171 xsgn = ysgn = '-';
172 while (an < argc && (argv[an][0] == '-' || argv[an][0] == '+'
173 || argv[an][0] == '=')) {
174 switch (argv[an][1]) {
175 case 't':
176 checkthresh = 1;
177 if (argv[an][0] == '-') {
178 input[nfile].flags |= HASMIN;
179 input[nfile].thmin = atof(argv[an+1]);
180 } else if (argv[an][0] == '+') {
181 input[nfile].flags |= HASMAX;
182 input[nfile].thmax = atof(argv[an+1]);
183 } else
184 goto userr;
185 an++;
186 break;
187 case 'l':
188 if (strcmp(argv[an], "-l"))
189 goto userr;
190 thislabel = argv[++an];
191 break;
192 case '+':
193 case '-':
194 case '0':
195 if (argv[an][0] != '=')
196 goto userr;
197 xsgn = argv[an][1];
198 ysgn = argv[an][2];
199 if (ysgn != '+' && ysgn != '-' && ysgn != '0')
200 goto userr;
201 break;
202 case '\0':
203 if (argv[an][0] == '-')
204 goto getfile;
205 goto userr;
206 default:
207 goto userr;
208 }
209 an++;
210 }
211 getfile:
212 if (argc-an < (ncolumns ? 1 : 3))
213 goto userr;
214 if (autolabel && thislabel == NULL)
215 thislabel = argv[an];
216 if (!strcmp(argv[an], "-")) {
217 input[nfile].name = StandardInput;
218 input[nfile].fp = stdin;
219 } else {
220 if (argv[an][0] == '!') {
221 input[nfile].name = Command;
222 input[nfile].fp = popen(argv[an]+1, "r");
223 } else {
224 input[nfile].name = argv[an];
225 input[nfile].fp = fopen(argv[an], "r");
226 }
227 if (input[nfile].fp == NULL) {
228 perror(argv[an]);
229 quit(1);
230 }
231 }
232 an++;
233 /* get header */
234 if (echoheader)
235 printf("%s:\n", input[nfile].name);
236 getheader(input[nfile].fp, headline, NULL);
237 if (wrongformat) {
238 fprintf(stderr, "%s: incompatible input format\n",
239 input[nfile].name);
240 quit(1);
241 }
242 /* get picture size */
243 if (fgetresolu(&input[nfile].xres, &input[nfile].yres,
244 input[nfile].fp) < 0) {
245 fprintf(stderr, "%s: bad picture size\n",
246 input[nfile].name);
247 quit(1);
248 }
249 if (ncolumns) {
250 if (curcol >= abs(ncolumns)) {
251 cury = ymax + spacing;
252 curx = x0;
253 curcol = 0;
254 }
255 input[nfile].xloc = curx;
256 input[nfile].yloc = cury;
257 curx += input[nfile].xres + spacing;
258 curcol++;
259 } else {
260 input[nfile].xloc = atoi(argv[an++]);
261 if (xsgn == '+')
262 input[nfile].xloc -= input[nfile].xres;
263 else if (xsgn == '0')
264 input[nfile].xloc -= input[nfile].xres/2;
265 input[nfile].yloc = atoi(argv[an++]);
266 if (ysgn == '+')
267 input[nfile].yloc -= input[nfile].yres;
268 else if (ysgn == '0')
269 input[nfile].yloc -= input[nfile].yres/2;
270 }
271 if (input[nfile].xloc < xmin)
272 xmin = input[nfile].xloc;
273 if (input[nfile].yloc < ymin)
274 ymin = input[nfile].yloc;
275 if (input[nfile].xloc+input[nfile].xres > xmax)
276 xmax = input[nfile].xloc+input[nfile].xres;
277 if (input[nfile].yloc+input[nfile].yres > ymax)
278 ymax = input[nfile].yloc+input[nfile].yres;
279 if (thislabel != NULL) {
280 if (++nfile >= MAXFILE)
281 goto toomany;
282 input[nfile].name = Label;
283 input[nfile].flags = 0;
284 input[nfile].xres = input[nfile-1].xres;
285 input[nfile].yres = labelht;
286 if ((input[nfile].fp = lblopen(thislabel,
287 &input[nfile].xres,
288 &input[nfile].yres)) == NULL)
289 goto labelerr;
290 input[nfile].xloc = input[nfile-1].xloc;
291 input[nfile].yloc = input[nfile-1].yloc +
292 input[nfile-1].yres-input[nfile].yres;
293 }
294 }
295 if (xsiz <= 0)
296 xsiz = xmax;
297 else if (xsiz > xmax)
298 xmax = xsiz;
299 if (ysiz <= 0)
300 ysiz = ymax;
301 else if (ysiz > ymax)
302 ymax = ysiz;
303 if (ncolumns < 0) { /* reverse rows if requested */
304 int i = nfile;
305 while (i--)
306 input[i].yloc = ymax - input[i].yres - input[i].yloc;
307 }
308 /* add new header info. */
309 printargs(argc, argv, stdout);
310 if (strcmp(ourfmt, PICFMT))
311 fputformat(ourfmt, stdout); /* print format if known */
312 putchar('\n');
313 fprtresolu(xsiz, ysiz, stdout);
314
315 compos();
316
317 quit(0);
318 userr:
319 fprintf(stderr,
320 "Usage: %s [-h][-x xr][-y yr][-b r g b][-a n][-s p][-o x0 y0][-la][-lh h] ",
321 progname);
322 fprintf(stderr, "[-t min1][+t max1][-l lab][=SS] pic1 x1 y1 ..\n");
323 quit(1);
324 toomany:
325 fprintf(stderr, "%s: only %d files and labels allowed\n",
326 progname, MAXFILE);
327 quit(1);
328 labelerr:
329 fprintf(stderr, "%s: error opening label\n", progname);
330 quit(1);
331 return 1; /* pro forma return */
332 }
333
334
335 static void
336 compos(void) /* composite pictures */
337 {
338 COLR *scanin, *scanout;
339 int y;
340 register int x, i;
341
342 scanin = (COLR *)malloc((xmax-xmin)*sizeof(COLR));
343 if (scanin == NULL)
344 goto memerr;
345 scanin -= xmin;
346 if (checkthresh) {
347 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
348 if (scanout == NULL)
349 goto memerr;
350 } else
351 scanout = scanin;
352 for (y = ymax-1; y >= 0; y--) {
353 for (x = 0; x < xsiz; x++)
354 copycolr(scanout[x], bgcolr);
355 for (i = 0; i < nfile; i++) {
356 if (input[i].yloc > y ||
357 input[i].yloc+input[i].yres <= y)
358 continue;
359 if (freadcolrs(scanin+input[i].xloc,
360 input[i].xres, input[i].fp) < 0) {
361 fprintf(stderr, "%s: read error (y==%d)\n",
362 input[i].name,
363 y-input[i].yloc);
364 quit(1);
365 }
366 if (y >= ysiz)
367 continue;
368 if (checkthresh) {
369 x = input[i].xloc+input[i].xres;
370 if (x > xsiz)
371 x = xsiz;
372 for (x--; x >= 0 && x >= input[i].xloc; x--) {
373 if (input[i].flags & HASMIN &&
374 cmpcolr(scanin[x], input[i].thmin) <= 0)
375 continue;
376 if (input[i].flags & HASMAX &&
377 cmpcolr(scanin[x], input[i].thmax) >= 0)
378 continue;
379 copycolr(scanout[x], scanin[x]);
380 }
381 }
382 }
383 if (y >= ysiz)
384 continue;
385 if (fwritecolrs(scanout, xsiz, stdout) < 0) {
386 perror(progname);
387 quit(1);
388 }
389 }
390 /* read remainders from streams */
391 for (i = 0; i < nfile; i++)
392 if (input[i].name[0] == '<')
393 while (getc(input[i].fp) != EOF)
394 ;
395 return;
396 memerr:
397 perror(progname);
398 quit(1);
399 }
400
401
402 static int
403 cmpcolr( /* compare COLR to luminance */
404 register COLR c1,
405 double lv2
406 )
407 {
408 double lv1 = .0;
409
410 if (c1[EXP])
411 lv1 = ldexp((double)normbright(c1), (int)c1[EXP]-(COLXS+8));
412 if (lv1 < lv2) return(-1);
413 if (lv1 > lv2) return(1);
414 return(0);
415 }
416
417
418 static FILE *
419 lblopen( /* open pipe to label generator */
420 char *s,
421 int *xp,
422 int *yp
423 )
424 {
425 char com[PATH_MAX];
426 FILE *fp;
427
428 sprintf(com, "psign -s -.15 -a 2 -x %d -y %d '%.90s'", *xp, *yp, s);
429 if ((fp = popen(com, "r")) == NULL)
430 return(NULL);
431 if (checkheader(fp, COLRFMT, NULL) < 0)
432 goto err;
433 if (fgetresolu(xp, yp, fp) < 0)
434 goto err;
435 return(fp);
436 err:
437 pclose(fp);
438 return(NULL);
439 }
440
441
442 void
443 quit(code) /* exit gracefully */
444 int code;
445 {
446 register int i;
447 /* close input files */
448 for (i = 0; i < nfile; i++)
449 if (input[i].name == Command || input[i].name == Label)
450 pclose(input[i].fp);
451 else
452 fclose(input[i].fp);
453 exit(code);
454 }
