root/radiance/ray/src/px/pcompos.c
Revision: 2.39
Committed: Thu Sep 2 16:10:01 2021 UTC (3 years, 9 months ago) by greg
Changes since 2.38: +13 -1 lines
feat(pcompos): added exposure metadata preservation when possible
2 static const char RCSid[] = "$Id: pcompos.c,v 2.38 2019/07/19 17:37:56 greg Exp $";
5 * pcompos.c - program to composite pictures.
6 *
7 * 6/30/87
8 */
9
10 #include <math.h>
11
12 #include "copyright.h"
13
14 #include "rtio.h"
15 #include "platform.h"
16 #include "paths.h"
17 #include "rterror.h"
18 #include "color.h"
19 #include "resolu.h"
20
21 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22 #undef getc
23 #define getc getc_unlocked
24 #endif
25
26 #define MAXFILE 1024
27
28 #define HASMIN 1
29 #define HASMAX 2
30
31 /* output picture size */
32 int xsiz = 0;
33 int ysiz = 0;
34 /* input dimensions */
35 int xmin = 0;
36 int ymin = 0;
37 int xmax = 0;
38 int ymax = 0;
39
40 COLR bgcolr = BLKCOLR; /* background color */
41
42 int labelht = 24; /* label height */
43
44 int checkthresh = 0; /* check threshold value */
45
46 char StandardInput[] = "<stdin>";
47 char Command[] = "<Command>";
48 char Label[] = "<Label>";
49
50 char *progname;
51
52 struct {
53 char *name; /* file or command name */
54 FILE *fp; /* stream pointer */
55 int xres, yres; /* picture size */
56 int xloc, yloc; /* anchor point */
57 int flags; /* HASMIN, HASMAX */
58 double thmin, thmax; /* thresholds */
59 } input[MAXFILE]; /* our input files */
60
61 int nfile; /* number of files */
62
63 int echoheader = 1;
64 char ourfmt[LPICFMT+1] = PICFMT;
65 int wrongformat = 0;
66 double common_expos = 1.;
67
68 double this_expos;
69
70 static gethfunc headline;
71 static void compos(void);
72 static int cmpcolr(COLR c1, double lv2);
73 static FILE * lblopen(char *s, int *xp, int *yp);
74
75
76
77 static int
78 headline( /* print line preceded by a tab */
79 char *s,
80 void *p
81 )
82 {
83 char fmt[MAXFMTLEN];
84
85 if (isheadid(s))
86 return(0);
87 if (isexpos(s))
88 this_expos *= exposval(s);
89 if (formatval(fmt, s)) {
90 if (globmatch(ourfmt, fmt)) {
91 wrongformat = 0;
92 strcpy(ourfmt, fmt);
93 } else
94 wrongformat = 1;
95 } else if (echoheader) {
96 fputc('\t', stdout);
97 fputs(s, stdout);
98 }
99 return(0);
100 }
101
102
103 int
104 main(
105 int argc,
106 char *argv[]
107 )
108 {
109 int ncolumns = 0;
110 int autolabel = 0;
111 int curcol = 0, x0 = 0, curx = 0, cury = 0, spacing = 0;
112 int xsgn, ysgn;
113 char *thislabel;
114 int an;
115 SET_DEFAULT_BINARY();
116 SET_FILE_BINARY(stdin);
117 SET_FILE_BINARY(stdout);
118 progname = argv[0];
119
120 for (an = 1; an < argc && argv[an][0] == '-'; an++)
121 switch (argv[an][1]) {
122 case 'h':
123 echoheader = !echoheader;
124 break;
125 case 'x':
126 xsiz = atoi(argv[++an]);
127 break;
128 case 'y':
129 ysiz = atoi(argv[++an]);
130 break;
131 case 'b':
132 setcolr(bgcolr, atof(argv[an+1]),
133 atof(argv[an+2]),
134 atof(argv[an+3]));
135 an += 3;
136 break;
137 case 'a':
138 ncolumns = atoi(argv[++an]);
139 break;
140 case 's':
141 spacing = atoi(argv[++an]);
142 break;
143 case 'o':
144 curx = x0 = atoi(argv[++an]);
145 cury = atoi(argv[++an]);
146 break;
147 case 'l':
148 switch (argv[an][2]) {
149 case 'a':
150 autolabel++;
151 break;
152 case 'h':
153 labelht = atoi(argv[++an]);
154 break;
155 case '\0':
156 goto dofiles;
157 default:
158 goto userr;
159 }
160 break;
161 case '\0':
162 case 't':
163 goto dofiles;
164 default:
165 goto userr;
166 }
167 dofiles:
168 newheader("RADIANCE", stdout);
169 fputnow(stdout);
170 for (nfile = 0; an < argc; nfile++) {
171 if (nfile >= MAXFILE)
172 goto toomany;
173 thislabel = NULL;
174 input[nfile].flags = 0;
175 xsgn = ysgn = '-';
176 while (an < argc && (argv[an][0] == '-' || argv[an][0] == '+'
177 || argv[an][0] == '=')) {
178 switch (argv[an][1]) {
179 case 't':
180 checkthresh = 1;
181 if (argv[an][0] == '-') {
182 input[nfile].flags |= HASMIN;
183 input[nfile].thmin = atof(argv[an+1]);
184 } else if (argv[an][0] == '+') {
185 input[nfile].flags |= HASMAX;
186 input[nfile].thmax = atof(argv[an+1]);
187 } else
188 goto userr;
189 an++;
190 break;
191 case 'l':
192 if (strcmp(argv[an], "-l"))
193 goto userr;
194 thislabel = argv[++an];
195 break;
196 case '+':
197 case '-':
198 case '0':
199 if (argv[an][0] != '=')
200 goto userr;
201 xsgn = argv[an][1];
202 ysgn = argv[an][2];
203 if (ysgn != '+' && ysgn != '-' && ysgn != '0')
204 goto userr;
205 break;
206 case '\0':
207 if (argv[an][0] == '-')
208 goto getfile;
209 goto userr;
210 default:
211 goto userr;
212 }
213 an++;
214 }
215 getfile:
216 if (argc-an < (ncolumns ? 1 : 3))
217 goto userr;
218 if (autolabel && thislabel == NULL)
219 thislabel = argv[an];
220 if (!strcmp(argv[an], "-")) {
221 input[nfile].name = StandardInput;
222 input[nfile].fp = stdin;
223 } else {
224 if (argv[an][0] == '!') {
225 input[nfile].name = Command;
226 input[nfile].fp = popen(argv[an]+1, "r");
227 } else {
228 input[nfile].name = argv[an];
229 input[nfile].fp = fopen(argv[an], "r");
230 }
231 if (input[nfile].fp == NULL) {
232 perror(argv[an]);
233 quit(1);
234 }
235 }
236 an++;
237 /* get header */
238 if (echoheader)
239 printf("%s:\n", input[nfile].name);
240 this_expos = 1;
241 getheader(input[nfile].fp, headline, NULL);
242 if (!nfile)
243 common_expos = this_expos;
244 else if (common_expos > 0 &&
245 fabs(this_expos/common_expos - 1.) > 0.02)
246 common_expos = 0;
247 if (wrongformat) {
248 fprintf(stderr, "%s: incompatible input format\n",
249 input[nfile].name);
250 quit(1);
251 }
252 /* get picture size */
253 if (fgetresolu(&input[nfile].xres, &input[nfile].yres,
254 input[nfile].fp) < 0) {
255 fprintf(stderr, "%s: bad picture size\n",
256 input[nfile].name);
257 quit(1);
258 }
259 if (ncolumns) {
260 if (curcol >= abs(ncolumns)) {
261 cury = ymax + spacing;
262 curx = x0;
263 curcol = 0;
264 }
265 input[nfile].xloc = curx;
266 input[nfile].yloc = cury;
267 curx += input[nfile].xres + spacing;
268 curcol++;
269 } else {
270 input[nfile].xloc = atoi(argv[an++]);
271 if (xsgn == '+')
272 input[nfile].xloc -= input[nfile].xres;
273 else if (xsgn == '0')
274 input[nfile].xloc -= input[nfile].xres/2;
275 input[nfile].yloc = atoi(argv[an++]);
276 if (ysgn == '+')
277 input[nfile].yloc -= input[nfile].yres;
278 else if (ysgn == '0')
279 input[nfile].yloc -= input[nfile].yres/2;
280 }
281 if (input[nfile].xloc < xmin)
282 xmin = input[nfile].xloc;
283 if (input[nfile].yloc < ymin)
284 ymin = input[nfile].yloc;
285 if (input[nfile].xloc+input[nfile].xres > xmax)
286 xmax = input[nfile].xloc+input[nfile].xres;
287 if (input[nfile].yloc+input[nfile].yres > ymax)
288 ymax = input[nfile].yloc+input[nfile].yres;
289 if (thislabel != NULL) {
290 if (++nfile >= MAXFILE)
291 goto toomany;
292 input[nfile].name = Label;
293 input[nfile].flags = 0;
294 input[nfile].xres = input[nfile-1].xres;
295 input[nfile].yres = labelht;
296 if ((input[nfile].fp = lblopen(thislabel,
297 &input[nfile].xres,
298 &input[nfile].yres)) == NULL)
299 goto labelerr;
300 input[nfile].xloc = input[nfile-1].xloc;
301 input[nfile].yloc = input[nfile-1].yloc +
302 input[nfile-1].yres-input[nfile].yres;
303 }
304 }
305 if (xsiz <= 0)
306 xsiz = xmax;
307 else if (xsiz > xmax)
308 xmax = xsiz;
309 if (ysiz <= 0)
310 ysiz = ymax;
311 else if (ysiz > ymax)
312 ymax = ysiz;
313 if (ncolumns < 0) { /* reverse rows if requested */
314 int i = nfile;
315 while (i--)
316 input[i].yloc = ymax - input[i].yres - input[i].yloc;
317 }
318 /* add new header info. */
319 printargs(argc, argv, stdout);
320 if (common_expos > 0) /* print exposure if shared */
321 fputexpos(common_expos, stdout);
322 if (strcmp(ourfmt, PICFMT))
323 fputformat(ourfmt, stdout); /* print format if known */
324 putchar('\n');
325 fprtresolu(xsiz, ysiz, stdout);
326
327 compos();
328
329 quit(0);
330 userr:
331 fprintf(stderr,
332 "Usage: %s [-h][-x xr][-y yr][-b r g b][-a n][-s p][-o x0 y0][-la][-lh h] ",
333 progname);
334 fprintf(stderr, "[-t min1][+t max1][-l lab][=SS] pic1 x1 y1 ..\n");
335 quit(1);
336 toomany:
337 fprintf(stderr, "%s: only %d files and labels allowed\n",
338 progname, MAXFILE);
339 quit(1);
340 labelerr:
341 fprintf(stderr, "%s: error opening label\n", progname);
342 quit(1);
343 return 1; /* pro forma return */
344 }
345
346
347 static void
348 compos(void) /* composite pictures */
349 {
350 COLR *scanin, *scanout;
351 int y;
352 register int x, i;
353
354 scanin = (COLR *)malloc((xmax-xmin)*sizeof(COLR));
355 if (scanin == NULL)
356 goto memerr;
357 scanin -= xmin;
358 if (checkthresh) {
359 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
360 if (scanout == NULL)
361 goto memerr;
362 } else
363 scanout = scanin;
364 for (y = ymax-1; y >= 0; y--) {
365 for (x = 0; x < xsiz; x++)
366 copycolr(scanout[x], bgcolr);
367 for (i = 0; i < nfile; i++) {
368 if (input[i].yloc > y ||
369 input[i].yloc+input[i].yres <= y)
370 continue;
371 if (freadcolrs(scanin+input[i].xloc,
372 input[i].xres, input[i].fp) < 0) {
373 fprintf(stderr, "%s: read error (y==%d)\n",
374 input[i].name,
375 y-input[i].yloc);
376 quit(1);
377 }
378 if (y >= ysiz)
379 continue;
380 if (checkthresh) {
381 x = input[i].xloc+input[i].xres;
382 if (x > xsiz)
383 x = xsiz;
384 for (x--; x >= 0 && x >= input[i].xloc; x--) {
385 if (input[i].flags & HASMIN &&
386 cmpcolr(scanin[x], input[i].thmin) <= 0)
387 continue;
388 if (input[i].flags & HASMAX &&
389 cmpcolr(scanin[x], input[i].thmax) >= 0)
390 continue;
391 copycolr(scanout[x], scanin[x]);
392 }
393 }
394 }
395 if (y >= ysiz)
396 continue;
397 if (fwritecolrs(scanout, xsiz, stdout) < 0) {
398 perror(progname);
399 quit(1);
400 }
401 }
402 /* read remainders from streams */
403 for (i = 0; i < nfile; i++)
404 if (input[i].name[0] == '<')
405 while (getc(input[i].fp) != EOF)
406 ;
407 return;
408 memerr:
409 perror(progname);
410 quit(1);
411 }
412
413
414 static int
415 cmpcolr( /* compare COLR to luminance */
416 register COLR c1,
417 double lv2
418 )
419 {
420 double lv1 = .0;
421
422 if (c1[EXP])
423 lv1 = ldexp((double)normbright(c1), (int)c1[EXP]-(COLXS+8));
424 if (lv1 < lv2) return(-1);
425 if (lv1 > lv2) return(1);
426 return(0);
427 }
428
429
430 static FILE *
431 lblopen( /* open pipe to label generator */
432 char *s,
433 int *xp,
434 int *yp
435 )
436 {
437 char com[PATH_MAX];
438 FILE *fp;
439
440 sprintf(com, "psign -s -.15 -a 2 -x %d -y %d '%.90s'", *xp, *yp, s);
441 if ((fp = popen(com, "r")) == NULL)
442 return(NULL);
443 if (checkheader(fp, COLRFMT, NULL) < 0)
444 goto err;
445 if (fgetresolu(xp, yp, fp) < 0)
446 goto err;
447 return(fp);
448 err:
449 pclose(fp);
450 return(NULL);
451 }
452
453
454 void
455 quit(code) /* exit gracefully */
456 int code;
457 {
458 register int i;
459 /* close input files */
460 for (i = 0; i < nfile; i++)
461 if (input[i].name == Command || input[i].name == Label)
462 pclose(input[i].fp);
463 else
464 fclose(input[i].fp);
465 exit(code);
466 }
