Added Roland and Andreas' request to place images using -a from top-left
Upped limit on open files to 1024
Fixed long-standing inaccuracy of +/-t threshold options
Fixed size of command line buffers, and allow spaces in input file paths.
Various compatibility fixes.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added compatibility with alternate RADIANCE picture formats
added =SS option for changing sense of anchor points
added math.h for atof() usage
Changes for PC port
portability fixes
fixed bug in reading from processes with negative y-position
improved reaping of child processes
added -s and -o options and made -y compatible with -a
added error message about using -a with -y
added wait call so pcompos will wait for any child processes
increased MAXFILE from 32 to 64
improved labeling by using -x and -y options of psign
fixed bug in automatic labeling
added -s option to psign for proportionally spaced text
changed header information with commands
bug fix in -l option
added -lh and -la options and allowed individual label specs
fixed usage message
added ability to open commands and do arrays and labels automatically
Increased maximum number of files -- let system say otherwise
fixed bug in scanline allocation
Added diagnostic of read error scanline number
