root/radiance/ray/src/px/pcompos.c
Revision: 1.4
Committed: Tue Sep 12 13:04:24 1989 UTC (34 years, 9 months ago) by greg
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pcompos.c - program to composite pictures.
9 *
10 * 6/30/87
11 */
12
13 #include <stdio.h>
14
15 #include "color.h"
16
17
18 #define MAXFILE 16
19
20 /* output picture size */
21 int xsiz = 0;
22 int ysiz = 0;
23 /* input dimensions */
24 int xmin = 0;
25 int ymin = 0;
26 int xmax = 0;
27 int ymax = 0;
28
29 COLR bgcolr = BLKCOLR; /* background color */
30
31 int checkthresh = 0; /* check threshold value */
32
33 char *progname;
34
35 struct {
36 char *name; /* file name */
37 FILE *fp; /* stream pointer */
38 int xres, yres; /* picture size */
39 int xloc, yloc; /* anchor point */
40 int hasmin, hasmax; /* has threshold values */
41 COLR thmin, thmax; /* thresholds */
42 } input[MAXFILE]; /* our input files */
43
44 int nfile; /* number of files */
45
46
47 tabputs(s) /* print line preceded by a tab */
48 char *s;
49 {
50 putc('\t', stdout);
51 fputs(s, stdout);
52 }
53
54
55 main(argc, argv)
56 int argc;
57 char *argv[];
58 {
59 double atof();
60 int an;
61
62 progname = argv[0];
63
64 for (an = 1; an < argc && argv[an][0] == '-'; an++)
65 switch (argv[an][1]) {
66 case 'x':
67 xmax = xsiz = atoi(argv[++an]);
68 break;
69 case 'y':
70 ymax = ysiz = atoi(argv[++an]);
71 break;
72 case 'b':
73 setcolr(bgcolr, atof(argv[an+1]),
74 atof(argv[an+2]),
75 atof(argv[an+3]));
76 an += 3;
77 break;
78 case '\0':
79 case 't':
80 goto dofiles;
81 default:
82 goto userr;
83 }
84 dofiles:
85 for (nfile = 0; an < argc; nfile++) {
86 if (nfile >= MAXFILE) {
87 fprintf(stderr, "%s: too many files\n", progname);
88 quit(1);
89 }
90 input[nfile].hasmin = input[nfile].hasmax = 0;
91 while (an < argc && (argv[an][0] == '-' || argv[an][0] == '+'))
92 switch (argv[an][1]) {
93 case 't':
94 checkthresh = 1;
95 if (argv[an][0] == '-') {
96 input[nfile].hasmin = 1;
97 setcolr(input[nfile].thmin,
98 atof(argv[an+1]),
99 atof(argv[an+1]),
100 atof(argv[an+1]));
101 } else {
102 input[nfile].hasmax = 1;
103 setcolr(input[nfile].thmax,
104 atof(argv[an+1]),
105 atof(argv[an+1]),
106 atof(argv[an+1]));
107 }
108 an += 2;
109 break;
110 case '\0':
111 if (argv[an][0] == '-')
112 goto getfile;
113 /* fall through */
114 default:
115 goto userr;
116 }
117 getfile:
118 if (argc-an < 3)
119 goto userr;
120 if (!strcmp(argv[an], "-")) {
121 input[nfile].name = "<stdin>";
122 input[nfile].fp = stdin;
123 } else {
124 input[nfile].name = argv[an];
125 if ((input[nfile].fp = fopen(argv[an], "r")) == NULL) {
126 fprintf(stderr, "%s: cannot open\n", argv[an]);
127 quit(1);
128 }
129 }
130 an++;
131 /* get header */
132 printf("%s:\n", input[nfile].name);
133 getheader(input[nfile].fp, tabputs);
134 /* get picture size */
135 if (fgetresolu(&input[nfile].xres, &input[nfile].yres,
136 input[nfile].fp) != (YMAJOR|YDECR)) {
137 fprintf(stderr, "%s: bad picture size\n",
138 input[nfile].name);
139 quit(1);
140 }
141 input[nfile].xloc = atoi(argv[an++]);
142 input[nfile].yloc = atoi(argv[an++]);
143 if (input[nfile].xloc < xmin)
144 xmin = input[nfile].xloc;
145 if (input[nfile].yloc < ymin)
146 ymin = input[nfile].yloc;
147 if (input[nfile].xloc+input[nfile].xres > xmax)
148 xmax = input[nfile].xloc+input[nfile].xres;
149 if (input[nfile].yloc+input[nfile].yres > ymax)
150 ymax = input[nfile].yloc+input[nfile].yres;
151 }
152 if (xsiz <= 0)
153 xsiz = xmax;
154 if (ysiz <= 0)
155 ysiz = ymax;
156 /* add new header info. */
157 printargs(argc, argv, stdout);
158 printf("\n-Y %d +X %d\n", ysiz, xsiz);
159
160 compos();
161
162 quit(0);
163 userr:
164 fprintf(stderr, "Usage: %s [-x xres][-y yres][-b r g b] ", progname);
165 fprintf(stderr, "[-t min1][+t max1] file1 x1 y1 ..\n");
166 quit(1);
167 }
168
169
170 compos() /* composite pictures */
171 {
172 COLR *scanin, *scanout;
173 int y;
174 register int x, i;
175
176 scanin = (COLR *)malloc((xmax-xmin)*sizeof(COLR));
177 if (scanin == NULL)
178 goto memerr;
179 scanin -= xmin;
180 if (checkthresh) {
181 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
182 if (scanout == NULL)
183 goto memerr;
184 } else
185 scanout = scanin;
186 for (y = ymax-1; y >= 0; y--) {
187 for (x = 0; x < xsiz; x++)
188 copycolr(scanout[x], bgcolr);
189 for (i = 0; i < nfile; i++) {
190 if (input[i].yloc > y ||
191 input[i].yloc+input[i].yres <= y)
192 continue;
193 if (freadcolrs(scanin+input[i].xloc,
194 input[i].xres, input[i].fp) < 0) {
195 fprintf(stderr, "%s: read error (y==%d)\n",
196 input[i].name,
197 y-input[i].yloc);
198 quit(1);
199 }
200 if (y >= ysiz)
201 continue;
202 if (checkthresh) {
203 x = input[i].xloc+input[i].xres;
204 if (x > xsiz)
205 x = xsiz;
206 for (x--; x >= 0 && x >= input[i].xloc; x--) {
207 if (input[i].hasmin &&
208 cmpcolr(scanin[x], input[i].thmin) <= 0)
209 continue;
210 if (input[i].hasmax &&
211 cmpcolr(scanin[x], input[i].thmax) >= 0)
212 continue;
213 copycolr(scanout[x], scanin[x]);
214 }
215 }
216 }
217 if (y >= ysiz)
218 continue;
219 if (fwritecolrs(scanout, xsiz, stdout) < 0) {
220 fprintf(stderr, "%s: write error\n", progname);
221 quit(1);
222 }
223 }
224 return;
225 memerr:
226 fprintf(stderr, "%s: out of memory\n", progname);
227 quit(1);
228 }
229
230
231 int
232 cmpcolr(c1, c2) /* compare two colr's (improvisation) */
233 register COLR c1, c2;
234 {
235 register int i, j;
236
237 j = 4; /* check exponents first! */
238 while (j--)
239 if (i = c1[j] - c2[j])
240 return(i);
241 return(0);
242 }
243
244
245 quit(code) /* exit gracefully */
246 int code;
247 {
248 exit(code);
249 }
