root/Development/ray/src/px/pcompos.c
Sat Jun 7 05:09:46 2025 UTC (6 months, 4 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.41: +1 -2 lines
Diff to previous 2.41
Tue Jun 3 21:31:51 2025 UTC (7 months ago) by greg
Changes since 2.40: +4 -4 lines
Diff to previous 2.40
Mon Nov 20 21:44:29 2023 UTC (2 years, 1 month ago) by greg
Diff to previous 2.39
refactor: Eliminated LPICFMT macro
Thu Sep 2 16:10:01 2021 UTC (4 years, 4 months ago) by greg
Changes since 2.38: +13 -1 lines
Diff to previous 2.38
feat(pcompos): added exposure metadata preservation when possible
Fri Jul 19 17:37:56 2019 UTC (6 years, 5 months ago) by greg
Changes since 2.37: +2 -4 lines
Diff to previous 2.37
Thu Aug 2 18:33:43 2018 UTC (7 years, 5 months ago) by greg
Diff to previous 2.36
Mon Apr 16 19:40:37 2018 UTC (7 years, 8 months ago) by greg
Changes since 2.35: +7 -2 lines
Diff to previous 2.35
Added call to getc_unlocked() to speed up reading of stream remainder
Tue Feb 2 18:02:32 2016 UTC (9 years, 11 months ago) by greg
Diff to previous 2.34
Thu Jun 4 01:19:30 2015 UTC (10 years, 7 months ago) by greg
Changes since 2.33: +8 -3 lines
Diff to previous 2.33
Added Roland and Andreas' request to place images using -a from top-left
Mon Aug 10 04:26:38 2009 UTC (16 years, 5 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Diff to previous 2.32
Upped limit on open files to 1024
Fri Sep 8 21:38:25 2006 UTC (19 years, 4 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.31: +12 -7 lines
Diff to previous 2.31
Tue Jun 6 19:13:00 2006 UTC (19 years, 7 months ago) by greg
Changes since 2.30: +13 -19 lines
Diff to previous 2.30
Fixed long-standing inaccuracy of +/-t threshold options
Wed May 25 04:44:26 2005 UTC (20 years, 7 months ago) by greg
Diff to previous 2.29
Sun Mar 28 20:33:14 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.28: +25 -14 lines
Diff to previous 2.28
Mon Mar 15 21:16:54 2004 UTC (21 years, 9 months ago) by greg
Changes since 2.27: +8 -2 lines
Diff to previous 2.27
Fri Jan 2 12:47:01 2004 UTC (22 years ago) by schorsch
Changes since 2.26: +8 -3 lines
Diff to previous 2.26
Mon Nov 10 12:28:56 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 2.25
Fixed size of command line buffers, and allow spaces in input file paths.
Mon Oct 27 10:24:51 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.24: +2 -1 lines
Diff to previous 2.24
Various compatibility fixes.
Sun Jul 27 22:12:03 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.23
Thu Jul 3 22:41:44 2003 UTC (22 years, 6 months ago) by schorsch
Changes since 2.22: +2 -1 lines
Diff to previous 2.22
Thu Jun 5 19:29:34 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 2.21: +7 -14 lines
Diff to previous 2.21
Sat Feb 22 02:07:27 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.20: +8 -8 lines
Diff to previous 2.20
Tue Oct 27 09:08:25 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 2.19: +2 -1 lines
Diff to previous 2.19
Mon Oct 16 11:40:09 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.18: +11 -5 lines
Diff to previous 2.18
added compatibility with alternate RADIANCE picture formats
Sun Feb 27 10:17:04 1994 UTC (31 years, 10 months ago) by greg
Changes since 2.17: +5 -3 lines
Diff to previous 2.17
Wed Dec 29 09:48:12 1993 UTC (32 years ago) by greg
Changes since 2.16: +41 -15 lines
Diff to previous 2.16
added =SS option for changing sense of anchor points
Fri Jun 4 14:47:01 1993 UTC (32 years, 7 months ago) by greg
Changes since 2.15: +2 -0 lines
Diff to previous 2.15
added math.h for atof() usage
Mon Sep 21 12:13:57 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.14: +13 -2 lines
Diff to previous 2.14
Changes for PC port
Tue Sep 8 10:36:22 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.13: +10 -19 lines
Diff to previous 2.13
portability fixes
Fri Aug 28 16:29:20 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.12: +6 -11 lines
Diff to previous 2.12
fixed bug in reading from processes with negative y-position
Thu Aug 13 10:49:04 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.11: +22 -4 lines
improved reaping of child processes
Wed Aug 12 12:39:52 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.10: +19 -12 lines
added -s and -o options and made -y compatible with -a
Tue Aug 11 18:40:57 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.9: +5 -0 lines
added error message about using -a with -y
Mon Aug 10 11:23:13 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.8: +6 -0 lines
added wait call so pcompos will wait for any child processes
Mon Jul 13 15:04:15 1992 UTC (33 years, 6 months ago) by greg
increased MAXFILE from 32 to 64
Tue Jul 7 18:36:09 1992 UTC (33 years, 6 months ago) by greg
improved labeling by using -x and -y options of psign
Mon Jun 22 14:14:40 1992 UTC (33 years, 6 months ago) by greg
Changes since 2.5: +3 -4 lines
fixed bug in automatic labeling
Tue Jun 16 16:48:41 1992 UTC (33 years, 6 months ago) by greg
added -s option to psign for proportionally spaced text
Wed Feb 19 17:08:00 1992 UTC (33 years, 10 months ago) by greg
Changes since 2.3: +8 -4 lines
changed header information with commands
Tue Feb 11 08:51:50 1992 UTC (33 years, 11 months ago) by greg
bug fix in -l option
Thu Dec 19 14:51:50 1991 UTC (34 years ago) by greg
Tue Nov 12 16:04:44 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.10
Mon Nov 11 14:01:42 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.9: +5 -3 lines
Diff to previous 1.9
Fri May 31 10:21:31 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.8: +67 -37 lines
Diff to previous 1.8
added -lh and -la options and allowed individual label specs
Thu May 30 10:33:30 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.7: +4 -6 lines
Diff to previous 1.7
fixed usage message
Thu May 30 09:44:36 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +69 -7 lines
Diff to previous 1.6
added ability to open commands and do arrays and labels automatically
Thu Apr 18 14:35:19 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.5: +18 -3 lines
Diff to previous 1.5
Thu Sep 14 09:20:36 1989 UTC (36 years, 4 months ago) by greg
Changes since 1.4: +4 -4 lines
Diff to previous 1.4
Increased maximum number of files -- let system say otherwise
Tue Sep 12 13:04:24 1989 UTC (36 years, 4 months ago) by greg
Diff to previous 1.3
Mon Jul 24 09:12:18 1989 UTC (36 years, 5 months ago) by greg
Changes since 1.2: +1 -2 lines
Diff to previous 1.2
fixed bug in scanline allocation
Mon Jun 12 10:07:29 1989 UTC (36 years, 7 months ago) by greg
Added diagnostic of read error scanline number
Thu Feb 2 10:49:23 1989 UTC (36 years, 11 months ago) by greg
