root/radiance/ray/src/px/pcompos.c
Revision: 2.42
Committed: Sat Jun 7 05:09:46 2025 UTC (2 months ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.41: +1 -2 lines
2 static const char RCSid[] = "$Id: pcompos.c,v 2.41 2025/06/03 21:31:51 greg Exp $";
5 * pcompos.c - program to composite pictures.
6 *
7 * 6/30/87
8 */
9
10 #include <math.h>
11
12 #include "copyright.h"
13
14 #include "rtio.h"
15 #include "platform.h"
16 #include "rterror.h"
17 #include "color.h"
18 #include "resolu.h"
19
20 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
21 #undef getc
22 #define getc getc_unlocked
23 #endif
24
25 #define MAXFILE 1024
26
27 #define HASMIN 1
28 #define HASMAX 2
29
30 /* output picture size */
31 int xsiz = 0;
32 int ysiz = 0;
33 /* input dimensions */
34 int xmin = 0;
35 int ymin = 0;
36 int xmax = 0;
37 int ymax = 0;
38
39 COLR bgcolr = BLKCOLR; /* background color */
40
41 int labelht = 24; /* label height */
42
43 int checkthresh = 0; /* check threshold value */
44
45 char StandardInput[] = "<stdin>";
46 char Command[] = "<Command>";
47 char Label[] = "<Label>";
48
49 struct {
50 char *name; /* file or command name */
51 FILE *fp; /* stream pointer */
52 int xres, yres; /* picture size */
53 int xloc, yloc; /* anchor point */
54 int flags; /* HASMIN, HASMAX */
55 double thmin, thmax; /* thresholds */
56 } input[MAXFILE]; /* our input files */
57
58 int nfile; /* number of files */
59
60 int echoheader = 1;
61 char ourfmt[MAXFMTLEN] = PICFMT;
62 int wrongformat = 0;
63 double common_expos = 1.;
64
65 double this_expos;
66
67 static gethfunc headline;
68 static void compos(void);
69 static int cmpcolr(COLR c1, double lv2);
70 static FILE * lblopen(char *s, int *xp, int *yp);
71
72
73
74 static int
75 headline( /* print line preceded by a tab */
76 char *s,
77 void *p
78 )
79 {
80 char fmt[MAXFMTLEN];
81
82 if (isheadid(s))
83 return(0);
84 if (isexpos(s))
85 this_expos *= exposval(s);
86 if (formatval(fmt, s)) {
87 if (globmatch(ourfmt, fmt)) {
88 wrongformat = 0;
89 strcpy(ourfmt, fmt);
90 } else
91 wrongformat = 1;
92 } else if (echoheader) {
93 fputc('\t', stdout);
94 fputs(s, stdout);
95 }
96 return(0);
97 }
98
99
100 int
101 main(
102 int argc,
103 char *argv[]
104 )
105 {
106 int ncolumns = 0;
107 int autolabel = 0;
108 int curcol = 0, x0 = 0, curx = 0, cury = 0, spacing = 0;
109 int xsgn, ysgn;
110 char *thislabel;
111 int an;
112
113 SET_DEFAULT_BINARY();
114 SET_FILE_BINARY(stdin);
115 SET_FILE_BINARY(stdout);
116
117 fixargv0(argv[0]); /* sets global progname */
118
119 for (an = 1; an < argc && argv[an][0] == '-'; an++)
120 switch (argv[an][1]) {
121 case 'h':
122 echoheader = !echoheader;
123 break;
124 case 'x':
125 xsiz = atoi(argv[++an]);
126 break;
127 case 'y':
128 ysiz = atoi(argv[++an]);
129 break;
130 case 'b':
131 setcolr(bgcolr, atof(argv[an+1]),
132 atof(argv[an+2]),
133 atof(argv[an+3]));
134 an += 3;
135 break;
136 case 'a':
137 ncolumns = atoi(argv[++an]);
138 break;
139 case 's':
140 spacing = atoi(argv[++an]);
141 break;
142 case 'o':
143 curx = x0 = atoi(argv[++an]);
144 cury = atoi(argv[++an]);
145 break;
146 case 'l':
147 switch (argv[an][2]) {
148 case 'a':
149 autolabel++;
150 break;
151 case 'h':
152 labelht = atoi(argv[++an]);
153 break;
154 case '\0':
155 goto dofiles;
156 default:
157 goto userr;
158 }
159 break;
160 case '\0':
161 case 't':
162 goto dofiles;
163 default:
164 goto userr;
165 }
166 dofiles:
167 newheader("RADIANCE", stdout);
168 fputnow(stdout);
169 for (nfile = 0; an < argc; nfile++) {
170 if (nfile >= MAXFILE)
171 goto toomany;
172 thislabel = NULL;
173 input[nfile].flags = 0;
174 xsgn = ysgn = '-';
175 while (an < argc && (argv[an][0] == '-' || argv[an][0] == '+'
176 || argv[an][0] == '=')) {
177 switch (argv[an][1]) {
178 case 't':
179 checkthresh = 1;
180 if (argv[an][0] == '-') {
181 input[nfile].flags |= HASMIN;
182 input[nfile].thmin = atof(argv[an+1]);
183 } else if (argv[an][0] == '+') {
184 input[nfile].flags |= HASMAX;
185 input[nfile].thmax = atof(argv[an+1]);
186 } else
187 goto userr;
188 an++;
189 break;
190 case 'l':
191 if (strcmp(argv[an], "-l"))
192 goto userr;
193 thislabel = argv[++an];
194 break;
195 case '+':
196 case '-':
197 case '0':
198 if (argv[an][0] != '=')
199 goto userr;
200 xsgn = argv[an][1];
201 ysgn = argv[an][2];
202 if (ysgn != '+' && ysgn != '-' && ysgn != '0')
203 goto userr;
204 break;
205 case '\0':
206 if (argv[an][0] == '-')
207 goto getfile;
208 goto userr;
209 default:
210 goto userr;
211 }
212 an++;
213 }
214 getfile:
215 if (argc-an < (ncolumns ? 1 : 3))
216 goto userr;
217 if (autolabel && thislabel == NULL)
218 thislabel = argv[an];
219 if (!strcmp(argv[an], "-")) {
220 input[nfile].name = StandardInput;
221 input[nfile].fp = stdin;
222 } else {
223 if (argv[an][0] == '!') {
224 input[nfile].name = Command;
225 input[nfile].fp = popen(argv[an]+1, "r");
226 } else {
227 input[nfile].name = argv[an];
228 input[nfile].fp = fopen(argv[an], "r");
229 }
230 if (input[nfile].fp == NULL) {
231 perror(argv[an]);
232 quit(1);
233 }
234 }
235 an++;
236 /* get header */
237 if (echoheader)
238 printf("%s:\n", input[nfile].name);
239 this_expos = 1;
240 getheader(input[nfile].fp, headline, NULL);
241 if (!nfile)
242 common_expos = this_expos;
243 else if (common_expos > 0 &&
244 fabs(this_expos/common_expos - 1.) > 0.02)
245 common_expos = 0;
246 if (wrongformat) {
247 fprintf(stderr, "%s: incompatible input format\n",
248 input[nfile].name);
249 quit(1);
250 }
251 /* get picture size */
252 if (fgetresolu(&input[nfile].xres, &input[nfile].yres,
253 input[nfile].fp) < 0) {
254 fprintf(stderr, "%s: bad picture size\n",
255 input[nfile].name);
256 quit(1);
257 }
258 if (ncolumns) {
259 if (curcol >= abs(ncolumns)) {
260 cury = ymax + spacing;
261 curx = x0;
262 curcol = 0;
263 }
264 input[nfile].xloc = curx;
265 input[nfile].yloc = cury;
266 curx += input[nfile].xres + spacing;
267 curcol++;
268 } else {
269 input[nfile].xloc = atoi(argv[an++]);
270 if (xsgn == '+')
271 input[nfile].xloc -= input[nfile].xres;
272 else if (xsgn == '0')
273 input[nfile].xloc -= input[nfile].xres/2;
274 input[nfile].yloc = atoi(argv[an++]);
275 if (ysgn == '+')
276 input[nfile].yloc -= input[nfile].yres;
277 else if (ysgn == '0')
278 input[nfile].yloc -= input[nfile].yres/2;
279 }
280 if (input[nfile].xloc < xmin)
281 xmin = input[nfile].xloc;
282 if (input[nfile].yloc < ymin)
283 ymin = input[nfile].yloc;
284 if (input[nfile].xloc+input[nfile].xres > xmax)
285 xmax = input[nfile].xloc+input[nfile].xres;
286 if (input[nfile].yloc+input[nfile].yres > ymax)
287 ymax = input[nfile].yloc+input[nfile].yres;
288 if (thislabel != NULL) {
289 if (++nfile >= MAXFILE)
290 goto toomany;
291 input[nfile].name = Label;
292 input[nfile].flags = 0;
293 input[nfile].xres = input[nfile-1].xres;
294 input[nfile].yres = labelht;
295 if ((input[nfile].fp = lblopen(thislabel,
296 &input[nfile].xres,
297 &input[nfile].yres)) == NULL)
298 goto labelerr;
299 input[nfile].xloc = input[nfile-1].xloc;
300 input[nfile].yloc = input[nfile-1].yloc +
301 input[nfile-1].yres-input[nfile].yres;
302 }
303 }
304 if (xsiz <= 0)
305 xsiz = xmax;
306 else if (xsiz > xmax)
307 xmax = xsiz;
308 if (ysiz <= 0)
309 ysiz = ymax;
310 else if (ysiz > ymax)
311 ymax = ysiz;
312 if (ncolumns < 0) { /* reverse rows if requested */
313 int i = nfile;
314 while (i--)
315 input[i].yloc = ymax - input[i].yres - input[i].yloc;
316 }
317 /* add new header info. */
318 printargs(argc, argv, stdout);
319 if (common_expos > 0) /* print exposure if shared */
320 fputexpos(common_expos, stdout);
321 if (strcmp(ourfmt, PICFMT))
322 fputformat(ourfmt, stdout); /* print format if known */
323 putchar('\n');
324 fprtresolu(xsiz, ysiz, stdout);
325
326 compos();
327
328 quit(0);
329 userr:
330 fprintf(stderr,
331 "Usage: %s [-h][-x xr][-y yr][-b r g b][-a n][-s p][-o x0 y0][-la][-lh h] ",
332 progname);
333 fprintf(stderr, "[-t min1][+t max1][-l lab][=SS] pic1 x1 y1 ..\n");
334 quit(1);
335 toomany:
336 fprintf(stderr, "%s: only %d files and labels allowed\n",
337 progname, MAXFILE);
338 quit(1);
339 labelerr:
340 fprintf(stderr, "%s: error opening label\n", progname);
341 quit(1);
342 return 1; /* pro forma return */
343 }
344
345
346 static void
347 compos(void) /* composite pictures */
348 {
349 COLR *scanin, *scanout;
350 int y;
351 register int x, i;
352
353 scanin = (COLR *)malloc((xmax-xmin)*sizeof(COLR));
354 if (scanin == NULL)
355 goto memerr;
356 scanin -= xmin;
357 if (checkthresh) {
358 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
359 if (scanout == NULL)
360 goto memerr;
361 } else
362 scanout = scanin;
363 for (y = ymax-1; y >= 0; y--) {
364 for (x = 0; x < xsiz; x++)
365 copycolr(scanout[x], bgcolr);
366 for (i = 0; i < nfile; i++) {
367 if (input[i].yloc > y ||
368 input[i].yloc+input[i].yres <= y)
369 continue;
370 if (freadcolrs(scanin+input[i].xloc,
371 input[i].xres, input[i].fp) < 0) {
372 fprintf(stderr, "%s: read error (y==%d)\n",
373 input[i].name,
374 y-input[i].yloc);
375 quit(1);
376 }
377 if (y >= ysiz)
378 continue;
379 if (checkthresh) {
380 x = input[i].xloc+input[i].xres;
381 if (x > xsiz)
382 x = xsiz;
383 for (x--; x >= 0 && x >= input[i].xloc; x--) {
384 if (input[i].flags & HASMIN &&
385 cmpcolr(scanin[x], input[i].thmin) <= 0)
386 continue;
387 if (input[i].flags & HASMAX &&
388 cmpcolr(scanin[x], input[i].thmax) >= 0)
389 continue;
390 copycolr(scanout[x], scanin[x]);
391 }
392 }
393 }
394 if (y >= ysiz)
395 continue;
396 if (fwritecolrs(scanout, xsiz, stdout) < 0) {
397 perror(progname);
398 quit(1);
399 }
400 }
401 /* read remainders from streams */
402 for (i = 0; i < nfile; i++)
403 if (input[i].name[0] == '<')
404 while (getc(input[i].fp) != EOF)
405 ;
406 return;
407 memerr:
408 perror(progname);
409 quit(1);
410 }
411
412
413 static int
414 cmpcolr( /* compare COLR to luminance */
415 register COLR c1,
416 double lv2
417 )
418 {
419 double lv1 = .0;
420
421 if (c1[EXP])
422 lv1 = ldexp((double)normbright(c1), (int)c1[EXP]-(COLXS+8));
423 if (lv1 < lv2) return(-1);
424 if (lv1 > lv2) return(1);
425 return(0);
426 }
427
428
429 static FILE *
430 lblopen( /* open pipe to label generator */
431 char *s,
432 int *xp,
433 int *yp
434 )
435 {
436 char com[PATH_MAX];
437 FILE *fp;
438
439 sprintf(com, "psign -s -.15 -a 2 -x %d -y %d '%.90s'", *xp, *yp, s);
440 if ((fp = popen(com, "r")) == NULL)
441 return(NULL);
442 if (checkheader(fp, COLRFMT, NULL) < 0)
443 goto err;
444 if (fgetresolu(xp, yp, fp) < 0)
445 goto err;
446 return(fp);
447 err:
448 pclose(fp);
449 return(NULL);
450 }
451
452
453 void
454 quit(code) /* exit gracefully */
455 int code;
456 {
457 register int i;
458 /* close input files */
459 for (i = 0; i < nfile; i++)
460 if (input[i].name == Command || input[i].name == Label)
461 pclose(input[i].fp);
462 else
463 fclose(input[i].fp);
464 exit(code);
465 }
