perf(rmtxcomb,pcomb): Avoid calling varset() if unnecessary
feat(pcomb): Added support for 1- and 3-component float matrix i/o
refactor: Eliminated LPICFMT macro
fix(pcomb): Corrected recent bug introduced to header scanning
fix(pcomb): Changed behavior to elide exposure from indented header for evalglare
Changed common view parameters to a pointer
Decided to share first input view in the output of pcomb
Fixed issue introduced with xres and yres definitions
Added missing esupport settings for constant expression reduction
Increased scanline buffer size
Upped limit on open files to 1024
Fixed problem in last change -- pixel position should work, now
Fixed bug in -h option
Removed wasteful test for unit multiplier coefficient
Last minor change broke solid angle calculation -- fixed
Minor fixes to solid angle math
Removed redundant function declarations
Various compatibility fixes.
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added default value of -1 to T(n) for pictures w/o view parameters
added definition of constant PI
fixed S(n) function and added T(n) function and pa(n) and WE constants
added computation of pixel solid angle ("S" variable)
added compatibility with Radiance XYZE picture format
fixed potential bug in eclock tracking
increased default window to +/- 8 pixels instead of 4
changed a range error to a domain error in l_ray()
fixed bug in computation of image location in l_ray()
added origin and direction functions O[xyz](i), D[xyz](i)
fixed Usage message (added -o)
Changes for PC port
portability fixes
slight change to quit() routine
improved reaping of child processes
added wait call to reap child processes
changed header information for commands
bug fix
inconsequential changes
fixed outdated usages message
added ability to open commands as well as files
changed code for output resolution to allow changes from input
changed operation of -o option
bug fixes after last change
made it so constants are assigned before expressions are compiled added rc, gc, bc, and lc functions for returning image coefficients
added access to adjacent pixels for filtering, etc.
changed assignment slightly for efficiency
arguments to varset() changed
added -o option for original values
added variables for luminance in and out, xres, yres, nfiles
Increased maximum number of files -- let system say otherwise
Changed variable evaluation to use pointer
Added coefficient for faster combination
Changed default from average to sum
