1 |
greg |
1.1 |
#ifndef lint |
2 |
greg |
2.62 |
static const char RCSid[] = "$Id: pcomb.c,v 2.61 2025/06/03 21:31:51 greg Exp $"; |
3 |
greg |
1.1 |
#endif |
4 |
5 |
* Combine picture files according to calcomp functions. |
6 |
7 |
* 1/4/89 |
8 |
9 |
10 |
greg |
2.28 |
#include "platform.h" |
11 |
greg |
2.33 |
#include "standard.h" |
12 |
greg |
1.1 |
#include "color.h" |
13 |
#include "calcomp.h" |
14 |
greg |
2.10 |
#include "view.h" |
15 |
16 |
greg |
2.44 |
#define MAXINP 1024 /* maximum number of input files */ |
17 |
greg |
2.46 |
#define WINSIZ 127 /* scanline window size */ |
18 |
greg |
2.13 |
#define MIDSCN ((WINSIZ-1)/2+1) |
19 |
greg |
1.1 |
20 |
struct { |
21 |
greg |
1.19 |
char *name; /* file or command name */ |
22 |
greg |
1.1 |
FILE *fp; /* stream pointer */ |
23 |
greg |
2.10 |
VIEW vw; /* view for picture */ |
24 |
RESOLU rs; /* image resolution and orientation */ |
25 |
greg |
2.57 |
int infloat; /* input is floating point (#comp)? */ |
26 |
greg |
2.17 |
float pa; /* pixel aspect ratio */ |
27 |
greg |
1.14 |
COLOR *scan[WINSIZ]; /* input scanline window */ |
28 |
greg |
1.3 |
COLOR coef; /* coefficient */ |
29 |
greg |
1.17 |
COLOR expos; /* recorded exposure */ |
30 |
greg |
1.1 |
} input[MAXINP]; /* input pictures */ |
31 |
32 |
int nfiles; /* number of input files */ |
33 |
34 |
greg |
2.52 |
VIEW *commvp = NULL; /* common view parameters */ |
35 |
greg |
2.49 |
36 |
greg |
2.56 |
char ourfmt[MAXFMTLEN] = PICFMT; /* input picture format */ |
37 |
greg |
2.57 |
int outfloat = 0; /* #component float output? */ |
38 |
greg |
2.16 |
39 |
greg |
2.31 |
char StandardInput[] = "<stdin>"; |
40 |
greg |
2.6 |
char Command[] = "<Command>"; |
41 |
greg |
1.21 |
char vcolin[3][4] = {"ri", "gi", "bi"}; |
42 |
char vcolout[3][4] = {"ro", "go", "bo"}; |
43 |
greg |
1.15 |
char vbrtin[] = "li"; |
44 |
char vbrtout[] = "lo"; |
45 |
greg |
1.21 |
char vcolexp[3][4] = {"re", "ge", "be"}; |
46 |
greg |
1.17 |
char vbrtexp[] = "le"; |
47 |
greg |
2.18 |
char vpixaspect[] = "pa"; |
48 |
greg |
1.1 |
49 |
greg |
2.18 |
char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"}; |
50 |
greg |
2.10 |
51 |
greg |
2.17 |
char vpsize[] = "S"; |
52 |
53 |
greg |
1.18 |
char vnfiles[] = "nfiles"; |
54 |
greg |
2.18 |
char vwhteff[] = "WE"; |
55 |
greg |
1.18 |
char vxmax[] = "xmax"; |
56 |
char vymax[] = "ymax"; |
57 |
char vxres[] = "xres"; |
58 |
char vyres[] = "yres"; |
59 |
char vxpos[] = "x"; |
60 |
char vypos[] = "y"; |
61 |
greg |
1.1 |
62 |
int nowarn = 0; /* no warning messages? */ |
63 |
64 |
greg |
1.18 |
int xmax = 0, ymax = 0; /* input resolution */ |
65 |
greg |
1.9 |
66 |
greg |
1.18 |
int xscan, yscan; /* input position */ |
67 |
greg |
1.1 |
68 |
greg |
1.18 |
int xres, yres; /* output resolution */ |
69 |
greg |
1.1 |
70 |
greg |
1.18 |
int xpos, ypos; /* output position */ |
71 |
72 |
greg |
2.39 |
int echoheader = 1; |
73 |
greg |
1.10 |
int wrongformat = 0; |
74 |
greg |
2.10 |
int gotview; |
75 |
greg |
1.1 |
76 |
greg |
1.10 |
77 |
greg |
2.39 |
static gethfunc headline; |
78 |
greg |
2.53 |
static void checkfile(int orig); |
79 |
schorsch |
2.32 |
static double rgb_bright(COLOR clr); |
80 |
static double xyz_bright(COLOR clr); |
81 |
static void init(void); |
82 |
static void combine(void); |
83 |
static void advance(void); |
84 |
static double l_expos(char *nam); |
85 |
static double l_pixaspect(char *nm); |
86 |
static double l_colin(char *nam); |
87 |
static double l_ray(char *nam); |
88 |
static double l_psize(char *nm); |
89 |
90 |
91 |
int |
92 |
main( |
93 |
int argc, |
94 |
char *argv[] |
95 |
96 |
greg |
1.1 |
97 |
greg |
1.18 |
int original; |
98 |
greg |
1.3 |
double f; |
99 |
schorsch |
2.32 |
int a; |
100 |
greg |
2.47 |
101 |
schorsch |
2.23 |
SET_DEFAULT_BINARY(); |
102 |
SET_FILE_BINARY(stdin); |
103 |
SET_FILE_BINARY(stdout); |
104 |
greg |
2.61 |
fixargv0(argv[0]); /* sets global progname */ |
105 |
greg |
2.47 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; |
106 |
esupport &= ~(E_OUTCHAN|E_INCHAN); |
107 |
greg |
1.15 |
/* scan options */ |
108 |
for (a = 1; a < argc; a++) { |
109 |
greg |
1.1 |
if (argv[a][0] == '-') |
110 |
switch (argv[a][1]) { |
111 |
case 'x': |
112 |
case 'y': |
113 |
greg |
1.18 |
a++; |
114 |
greg |
1.15 |
continue; |
115 |
greg |
1.1 |
case 'w': |
116 |
nowarn = !nowarn; |
117 |
greg |
1.15 |
continue; |
118 |
greg |
2.39 |
case 'h': |
119 |
echoheader = !echoheader; |
120 |
continue; |
121 |
greg |
1.1 |
case 'f': |
122 |
greg |
2.57 |
if (argv[a][2]) { |
123 |
outfloat = (argv[a][2] == 'f'); |
124 |
continue; |
125 |
126 |
/* fall through */ |
127 |
greg |
1.1 |
case 'e': |
128 |
greg |
1.16 |
a++; |
129 |
greg |
1.15 |
continue; |
130 |
greg |
1.1 |
131 |
greg |
1.15 |
break; |
132 |
133 |
greg |
2.14 |
newheader("RADIANCE", stdout); /* start header */ |
134 |
greg |
2.22 |
fputnow(stdout); |
135 |
greg |
1.15 |
/* process files */ |
136 |
greg |
1.17 |
for (nfiles = 0; nfiles < MAXINP; nfiles++) { |
137 |
greg |
1.3 |
setcolor(input[nfiles].coef, 1.0, 1.0, 1.0); |
138 |
greg |
1.17 |
setcolor(input[nfiles].expos, 1.0, 1.0, 1.0); |
139 |
schorsch |
2.26 |
input[nfiles].vw = stdview; |
140 |
greg |
2.17 |
input[nfiles].pa = 1.0; |
141 |
greg |
1.17 |
142 |
greg |
1.1 |
nfiles = 0; |
143 |
greg |
1.18 |
original = 0; |
144 |
greg |
1.1 |
for ( ; a < argc; a++) { |
145 |
if (nfiles >= MAXINP) { |
146 |
eputs(argv[0]); |
147 |
eputs(": too many picture files\n"); |
148 |
quit(1); |
149 |
150 |
greg |
1.3 |
151 |
152 |
case '\0': |
153 |
greg |
2.31 |
input[nfiles].name = StandardInput; |
154 |
greg |
1.3 |
input[nfiles].fp = stdin; |
155 |
break; |
156 |
greg |
1.17 |
case 'o': |
157 |
original++; |
158 |
greg |
1.22 |
continue; |
159 |
greg |
1.3 |
case 's': |
160 |
f = atof(argv[++a]); |
161 |
scalecolor(input[nfiles].coef, f); |
162 |
continue; |
163 |
case 'c': |
164 |
colval(input[nfiles].coef,RED)*=atof(argv[++a]); |
165 |
colval(input[nfiles].coef,GRN)*=atof(argv[++a]); |
166 |
colval(input[nfiles].coef,BLU)*=atof(argv[++a]); |
167 |
continue; |
168 |
default: |
169 |
goto usage; |
170 |
171 |
else { |
172 |
greg |
2.2 |
if (argv[a][0] == '!') { |
173 |
greg |
2.6 |
input[nfiles].name = Command; |
174 |
greg |
2.2 |
input[nfiles].fp = popen(argv[a]+1, "r"); |
175 |
} else { |
176 |
input[nfiles].name = argv[a]; |
177 |
input[nfiles].fp = fopen(argv[a], "r"); |
178 |
179 |
greg |
1.1 |
if (input[nfiles].fp == NULL) { |
180 |
greg |
1.6 |
perror(argv[a]); |
181 |
greg |
1.1 |
quit(1); |
182 |
183 |
184 |
greg |
2.53 |
checkfile(original); |
185 |
greg |
1.18 |
nfiles++; |
186 |
greg |
1.17 |
original = 0; |
187 |
greg |
1.15 |
188 |
greg |
1.18 |
init(); /* set constants */ |
189 |
greg |
1.15 |
/* go back and get expressions */ |
190 |
191 |
greg |
2.50 |
char *fpath; |
192 |
greg |
1.15 |
193 |
194 |
case 'x': |
195 |
greg |
1.21 |
varset(vxres, ':', eval(argv[++a])); |
196 |
greg |
1.18 |
continue; |
197 |
greg |
1.15 |
case 'y': |
198 |
greg |
1.21 |
varset(vyres, ':', eval(argv[++a])); |
199 |
greg |
1.16 |
continue; |
200 |
greg |
1.15 |
case 'w': |
201 |
continue; |
202 |
greg |
2.40 |
case 'h': |
203 |
continue; |
204 |
greg |
1.15 |
case 'f': |
205 |
greg |
2.57 |
if (argv[a][2]) |
206 |
continue; |
207 |
greg |
2.50 |
fpath = getpath(argv[++a], getrlibpath(), 0); |
208 |
if (fpath == NULL) { |
209 |
eputs(argv[0]); |
210 |
eputs(": cannot find file '"); |
211 |
eputs(argv[a]); |
212 |
eputs("'\n"); |
213 |
quit(1); |
214 |
215 |
fcompile(fpath); |
216 |
greg |
1.15 |
continue; |
217 |
case 'e': |
218 |
scompile(argv[++a], NULL, 0); |
219 |
continue; |
220 |
221 |
break; |
222 |
223 |
greg |
2.48 |
/* get output resolution */ |
224 |
greg |
1.18 |
xres = varvalue(vxres) + .5; |
225 |
yres = varvalue(vyres) + .5; |
226 |
if (xres <= 0 || yres <= 0) { |
227 |
eputs(argv[0]); |
228 |
eputs(": illegal output resolution\n"); |
229 |
quit(1); |
230 |
231 |
greg |
2.57 |
if (!vardefined(vbrtout)) /* single or 3-channel? */ |
232 |
outfloat *= 3; |
233 |
234 |
printargs(argc, argv, stdout); /* complete header */ |
235 |
greg |
2.52 |
if (commvp != NULL) { |
236 |
greg |
2.49 |
fputs(VIEWSTR, stdout); |
237 |
greg |
2.52 |
fprintview(commvp, stdout); |
238 |
greg |
2.49 |
fputc('\n', stdout); |
239 |
240 |
greg |
2.60 |
if (outfloat) { /* print output format */ |
241 |
greg |
2.57 |
printf("NROWS=%d\nNCOLS=%d\n", yres, xres); |
242 |
fputncomp(outfloat, stdout); |
243 |
fputendian(stdout); |
244 |
fputformat("float", stdout); |
245 |
} else if (strcmp(ourfmt, PICFMT)) |
246 |
fputformat(ourfmt, stdout); |
247 |
greg |
2.60 |
else |
248 |
fputformat(COLRFMT, stdout); |
249 |
greg |
2.57 |
fputc('\n', stdout); /* end header */ |
250 |
if (!outfloat) |
251 |
fprtresolu(xres, yres, stdout); |
252 |
253 |
greg |
2.59 |
doptimize(1); /* optimize definitions */ |
254 |
greg |
2.57 |
combine(); /* combine pictures */ |
255 |
greg |
1.15 |
quit(0); |
256 |
usage: |
257 |
eputs("Usage: "); |
258 |
eputs(argv[0]); |
259 |
eputs( |
260 |
greg |
2.57 |
" [-w][-h][-ff][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n"); |
261 |
greg |
1.15 |
quit(1); |
262 |
schorsch |
2.32 |
return 1; /* pro forma return */ |
263 |
greg |
1.15 |
264 |
265 |
266 |
schorsch |
2.30 |
static int |
267 |
greg |
2.39 |
headline( /* check header line & echo if requested */ |
268 |
schorsch |
2.30 |
char *s, |
269 |
void *p |
270 |
271 |
greg |
1.15 |
272 |
greg |
2.53 |
int orig = *(int *)p; |
273 |
greg |
2.51 |
char fmt[MAXFMTLEN]; |
274 |
greg |
1.15 |
double d; |
275 |
greg |
2.57 |
int bigend; |
276 |
greg |
1.15 |
COLOR ctmp; |
277 |
278 |
greg |
2.14 |
if (isheadid(s)) /* header id */ |
279 |
gwlarson |
2.21 |
return(0); /* don't echo */ |
280 |
greg |
2.14 |
if (formatval(fmt, s)) { /* check format */ |
281 |
greg |
2.16 |
if (globmatch(ourfmt, fmt)) { |
282 |
wrongformat = 0; |
283 |
strcpy(ourfmt, fmt); |
284 |
greg |
2.57 |
} else if (!strcmp("float", fmt)) |
285 |
input[nfiles].infloat *= -1; |
286 |
else |
287 |
greg |
2.22 |
wrongformat = globmatch(PICFMT, fmt) ? 1 : -1; |
288 |
gwlarson |
2.21 |
289 |
greg |
1.17 |
290 |
greg |
2.57 |
if ((bigend = isbigendian(s)) >= 0) { |
291 |
if (bigend != nativebigendian()) { |
292 |
eputs(input[nfiles].name); |
293 |
eputs(": unsupported input byte ordering\n"); |
294 |
quit(1); |
295 |
296 |
297 |
298 |
if (!strncmp("NROWS=", s, 6)) { /* X-resolution */ |
299 |
input[nfiles].rs.yr = atoi(s+6); |
300 |
301 |
302 |
if (!strncmp("NCOLS=", s, 6)) { /* Y-resolution */ |
303 |
input[nfiles].rs.xr = atoi(s+6); |
304 |
305 |
306 |
if (isncomp(s)) /* # components */ |
307 |
input[nfiles].infloat *= ncompval(s); |
308 |
309 |
greg |
2.53 |
if (orig) { /* undo exposure? */ |
310 |
if (isexpos(s)) { |
311 |
d = 1./exposval(s); |
312 |
scalecolor(input[nfiles].coef, d); |
313 |
314 |
315 |
if (iscolcor(s)) { |
316 |
int i; |
317 |
colcorval(ctmp, s); |
318 |
for (i = 3; i--; ) |
319 |
colval(input[nfiles].coef,i) /= colval(ctmp,i); |
320 |
321 |
322 |
} else if (isexpos(s)) { /* record exposure? */ |
323 |
greg |
1.17 |
d = exposval(s); |
324 |
scalecolor(input[nfiles].expos, d); |
325 |
greg |
2.53 |
} else if (iscolcor(s)) { |
326 |
greg |
1.15 |
327 |
greg |
1.17 |
multcolor(input[nfiles].expos, ctmp); |
328 |
greg |
2.54 |
329 |
if (isaspect(s)) |
330 |
greg |
2.17 |
input[nfiles].pa *= aspectval(s); |
331 |
greg |
2.18 |
else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0) |
332 |
greg |
2.10 |
gotview++; |
333 |
greg |
2.39 |
334 |
if (echoheader) { /* echo line */ |
335 |
putchar('\t'); |
336 |
return(fputs(s, stdout)); |
337 |
338 |
return(0); |
339 |
greg |
1.16 |
340 |
greg |
1.15 |
341 |
greg |
1.16 |
342 |
schorsch |
2.32 |
static void |
343 |
greg |
2.53 |
checkfile(int orig) /* ready a file */ |
344 |
greg |
1.16 |
345 |
greg |
2.47 |
int i; |
346 |
greg |
1.16 |
/* process header */ |
347 |
greg |
2.10 |
gotview = 0; |
348 |
greg |
2.57 |
input[nfiles].infloat = -1; |
349 |
input[nfiles].rs.rt = PIXSTANDARD; |
350 |
input[nfiles].rs.xr = input[nfiles].rs.yr = 0; |
351 |
greg |
2.39 |
if (echoheader) { |
352 |
fputs(input[nfiles].name, stdout); |
353 |
fputs(":\n", stdout); |
354 |
355 |
greg |
2.53 |
getheader(input[nfiles].fp, headline, &orig); |
356 |
greg |
2.57 |
357 |
if (input[nfiles].infloat <= 0) |
358 |
input[nfiles].infloat = 0; |
359 |
else if ((input[nfiles].infloat != 3) & |
360 |
(input[nfiles].infloat != 1)) { |
361 |
362 |
eputs(": unsupported number of components\n"); |
363 |
quit(1); |
364 |
365 |
greg |
2.22 |
if (wrongformat < 0) { |
366 |
greg |
1.16 |
367 |
greg |
2.57 |
eputs(": not a Radiance picture or float matrix\n"); |
368 |
greg |
1.16 |
quit(1); |
369 |
370 |
greg |
2.22 |
if (wrongformat > 0) { |
371 |
wputs(input[nfiles].name); |
372 |
wputs(": warning -- incompatible picture format\n"); |
373 |
374 |
greg |
2.10 |
if (!gotview || setview(&input[nfiles].vw) != NULL) |
375 |
input[nfiles].vw.type = 0; |
376 |
greg |
2.52 |
else if (commvp == NULL) |
377 |
commvp = &input[nfiles].vw; |
378 |
greg |
2.57 |
if ((input[nfiles].rs.xr <= 0) | (input[nfiles].rs.yr <= 0) && |
379 |
!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) { |
380 |
greg |
1.16 |
381 |
eputs(": bad picture size\n"); |
382 |
quit(1); |
383 |
384 |
greg |
1.18 |
if (xmax == 0 && ymax == 0) { |
385 |
greg |
2.10 |
xmax = scanlen(&input[nfiles].rs); |
386 |
ymax = numscans(&input[nfiles].rs); |
387 |
} else if (scanlen(&input[nfiles].rs) != xmax || |
388 |
numscans(&input[nfiles].rs) != ymax) { |
389 |
greg |
1.16 |
390 |
eputs(": resolution mismatch\n"); |
391 |
quit(1); |
392 |
393 |
/* allocate scanlines */ |
394 |
for (i = 0; i < WINSIZ; i++) |
395 |
greg |
1.18 |
input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR)); |
396 |
greg |
1.15 |
397 |
398 |
399 |
schorsch |
2.32 |
static double |
400 |
rgb_bright( |
401 |
COLOR clr |
402 |
403 |
greg |
2.16 |
404 |
return(bright(clr)); |
405 |
406 |
407 |
408 |
schorsch |
2.32 |
static double |
409 |
xyz_bright( |
410 |
COLOR clr |
411 |
412 |
greg |
2.16 |
413 |
return(clr[CIEY]); |
414 |
415 |
416 |
417 |
double (*ourbright)() = rgb_bright; |
418 |
419 |
420 |
schorsch |
2.32 |
static void |
421 |
init(void) /* perform final setup */ |
422 |
greg |
1.15 |
423 |
greg |
2.47 |
int i; |
424 |
greg |
1.15 |
/* define constants */ |
425 |
greg |
2.19 |
varset("PI", ':', PI); |
426 |
greg |
1.15 |
varset(vnfiles, ':', (double)nfiles); |
427 |
greg |
1.18 |
varset(vxmax, ':', (double)xmax); |
428 |
varset(vymax, ':', (double)ymax); |
429 |
greg |
1.15 |
/* set functions */ |
430 |
for (i = 0; i < 3; i++) { |
431 |
greg |
1.17 |
funset(vcolexp[i], 1, ':', l_expos); |
432 |
greg |
1.15 |
funset(vcolin[i], 1, '=', l_colin); |
433 |
434 |
greg |
1.17 |
funset(vbrtexp, 1, ':', l_expos); |
435 |
greg |
1.15 |
funset(vbrtin, 1, '=', l_colin); |
436 |
greg |
2.18 |
funset(vpixaspect, 1, ':', l_pixaspect); |
437 |
for (i = 0; i < 7; i++) |
438 |
greg |
2.10 |
funset(vray[i], 1, '=', l_ray); |
439 |
greg |
2.17 |
funset(vpsize, 1, '=', l_psize); |
440 |
greg |
2.16 |
/* set brightness function */ |
441 |
greg |
2.18 |
if (!strcmp(ourfmt, CIEFMT)) { |
442 |
varset(vwhteff, ':', 1.0); |
443 |
greg |
2.16 |
ourbright = xyz_bright; |
444 |
greg |
2.18 |
} else |
445 |
varset(vwhteff, ':', WHTEFFICACY); |
446 |
greg |
2.48 |
/* these may be overridden */ |
447 |
varset(vxres, ':', (double)xmax); |
448 |
varset(vyres, ':', (double)ymax); |
449 |
greg |
1.1 |
450 |
451 |
452 |
schorsch |
2.32 |
static void |
453 |
combine(void) /* combine pictures */ |
454 |
greg |
1.1 |
455 |
greg |
1.8 |
EPNODE *coldef[3], *brtdef; |
456 |
greg |
2.58 |
int set_x, set_y; |
457 |
greg |
1.1 |
COLOR *scanout; |
458 |
greg |
1.8 |
double d; |
459 |
greg |
2.47 |
int i, j; |
460 |
greg |
1.1 |
/* check defined variables */ |
461 |
greg |
1.4 |
for (j = 0; j < 3; j++) { |
462 |
if (vardefined(vcolout[j])) |
463 |
coldef[j] = eparse(vcolout[j]); |
464 |
else |
465 |
coldef[j] = NULL; |
466 |
467 |
greg |
1.8 |
if (vardefined(vbrtout)) |
468 |
brtdef = eparse(vbrtout); |
469 |
else |
470 |
brtdef = NULL; |
471 |
greg |
2.58 |
/* what to set */ |
472 |
set_x = varlookup(vxpos) != NULL && !vardefined(vxpos); |
473 |
set_y = varlookup(vypos) != NULL && !vardefined(vypos); |
474 |
greg |
1.1 |
/* allocate scanline */ |
475 |
scanout = (COLOR *)emalloc(xres*sizeof(COLOR)); |
476 |
greg |
1.18 |
/* set input position */ |
477 |
yscan = ymax+MIDSCN; |
478 |
greg |
1.1 |
/* combine files */ |
479 |
for (ypos = yres-1; ypos >= 0; ypos--) { |
480 |
greg |
1.14 |
advance(); |
481 |
greg |
2.58 |
if (set_y) varset(vypos, '=', (double)ypos); |
482 |
greg |
1.8 |
for (xpos = 0; xpos < xres; xpos++) { |
483 |
greg |
2.42 |
xscan = (xpos+.5)*xmax/xres; |
484 |
greg |
2.58 |
if (set_x) varset(vxpos, '=', (double)xpos); |
485 |
greg |
1.8 |
eclock++; |
486 |
if (brtdef != NULL) { |
487 |
d = evalue(brtdef); |
488 |
greg |
2.57 |
d *= (outfloat > 0) | (d >= 0); |
489 |
greg |
1.8 |
setcolor(scanout[xpos], d, d, d); |
490 |
} else { |
491 |
492 |
if (coldef[j] != NULL) { |
493 |
greg |
1.13 |
d = evalue(coldef[j]); |
494 |
greg |
1.8 |
} else { |
495 |
greg |
1.13 |
d = 0.0; |
496 |
greg |
1.8 |
for (i = 0; i < nfiles; i++) |
497 |
greg |
1.18 |
d += colval(input[i].scan[MIDSCN][xscan],j); |
498 |
greg |
1.1 |
499 |
greg |
2.57 |
500 |
greg |
1.13 |
colval(scanout[xpos],j) = d; |
501 |
greg |
1.8 |
502 |
greg |
1.1 |
503 |
greg |
1.8 |
504 |
greg |
2.57 |
switch (outfloat) { |
505 |
case 3: /* writing out float triplets */ |
506 |
if (fwrite(scanout, sizeof(float)*3, xres, stdout) != xres) |
507 |
goto writerr; |
508 |
break; |
509 |
case 1: /* writing out gray float values */ |
510 |
for (xpos = 0; xpos < xres; xpos++) |
511 |
if (putbinary(&scanout[xpos][CIEY], |
512 |
sizeof(float), 1, stdout) != 1) |
513 |
goto writerr; |
514 |
break; |
515 |
default: /* writing out Radiance picture */ |
516 |
if (fwritescan(scanout, xres, stdout) < 0) |
517 |
goto writerr; |
518 |
break; |
519 |
greg |
1.8 |
520 |
greg |
1.1 |
521 |
greg |
2.22 |
efree((char *)scanout); |
522 |
greg |
2.57 |
return; |
523 |
writerr: |
524 |
perror("write error"); |
525 |
quit(1); |
526 |
greg |
1.1 |
527 |
528 |
529 |
schorsch |
2.32 |
static void |
530 |
advance(void) /* read in data for next scanline */ |
531 |
greg |
1.14 |
532 |
greg |
1.18 |
int ytarget; |
533 |
greg |
2.47 |
COLOR *st; |
534 |
int i, j; |
535 |
greg |
1.14 |
536 |
greg |
2.42 |
for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--) |
537 |
greg |
1.18 |
for (i = 0; i < nfiles; i++) { |
538 |
st = input[i].scan[WINSIZ-1]; |
539 |
for (j = WINSIZ-1; j > 0; j--) /* rotate window */ |
540 |
input[i].scan[j] = input[i].scan[j-1]; |
541 |
input[i].scan[0] = st; |
542 |
if (yscan <= MIDSCN) /* hit bottom? */ |
543 |
continue; |
544 |
greg |
2.57 |
/* read scanline */ |
545 |
if (input[i].infloat) { |
546 |
if (fread(st, sizeof(float)*input[i].infloat, |
547 |
xmax, input[i].fp) != xmax) |
548 |
goto readerr; |
549 |
if (input[i].infloat == 1) { |
550 |
const COLORV *f = st[0] + xmax; |
551 |
int x = xmax; |
552 |
while (x-- > 0) |
553 |
st[x][BLU] = st[x][GRN] = |
554 |
st[x][RED] = *--f; |
555 |
556 |
} else if (freadscan(st, xmax, input[i].fp) < 0) |
557 |
goto readerr; |
558 |
greg |
2.37 |
for (j = 0; j < xmax; j++) /* adjust color */ |
559 |
multcolor(st[j], input[i].coef); |
560 |
greg |
1.14 |
561 |
greg |
2.57 |
return; |
562 |
readerr: |
563 |
eputs(input[i].name); |
564 |
eputs(": read error\n"); |
565 |
quit(1); |
566 |
greg |
1.14 |
567 |
568 |
569 |
schorsch |
2.32 |
static double |
570 |
l_expos( /* return picture exposure */ |
571 |
greg |
2.42 |
char *nam |
572 |
schorsch |
2.32 |
573 |
greg |
1.1 |
574 |
greg |
2.42 |
int fn, n; |
575 |
double d; |
576 |
greg |
1.14 |
577 |
greg |
2.42 |
d = argument(1); |
578 |
if (d <= -0.5 || d >= nfiles+0.5) { |
579 |
errno = EDOM; |
580 |
return(0.0); |
581 |
582 |
if (d < 0.5) |
583 |
return((double)nfiles); |
584 |
fn = d - 0.5; |
585 |
greg |
1.17 |
if (nam == vbrtexp) |
586 |
greg |
2.16 |
return((*ourbright)(input[fn].expos)); |
587 |
greg |
1.15 |
n = 3; |
588 |
while (n--) |
589 |
greg |
1.17 |
if (nam == vcolexp[n]) |
590 |
return(colval(input[fn].expos,n)); |
591 |
eputs("Bad call to l_expos()!\n"); |
592 |
greg |
1.15 |
quit(1); |
593 |
schorsch |
2.32 |
594 |
greg |
1.15 |
595 |
596 |
597 |
schorsch |
2.32 |
static double |
598 |
greg |
2.27 |
l_pixaspect(char *nm) /* return pixel aspect ratio */ |
599 |
greg |
2.18 |
600 |
greg |
2.42 |
int fn; |
601 |
double d; |
602 |
greg |
2.18 |
603 |
greg |
2.42 |
d = argument(1); |
604 |
605 |
errno = EDOM; |
606 |
return(0.0); |
607 |
608 |
if (d < 0.5) |
609 |
610 |
fn = d - 0.5; |
611 |
greg |
2.18 |
return(input[fn].pa); |
612 |
613 |
614 |
615 |
schorsch |
2.32 |
static double |
616 |
l_colin( /* return color value for picture */ |
617 |
greg |
2.47 |
char *nam |
618 |
schorsch |
2.32 |
619 |
greg |
1.15 |
620 |
int fn; |
621 |
greg |
2.47 |
int n, xoff, yoff; |
622 |
greg |
1.15 |
double d; |
623 |
624 |
greg |
2.42 |
d = argument(1); |
625 |
626 |
greg |
1.15 |
errno = EDOM; |
627 |
return(0.0); |
628 |
629 |
greg |
2.42 |
if (d < 0.5) |
630 |
631 |
fn = d - 0.5; |
632 |
greg |
1.14 |
xoff = yoff = 0; |
633 |
n = nargum(); |
634 |
if (n >= 2) { |
635 |
d = argument(2); |
636 |
if (d < 0.0) { |
637 |
xoff = d-.5; |
638 |
greg |
1.18 |
if (xscan+xoff < 0) |
639 |
xoff = -xscan; |
640 |
greg |
1.14 |
} else { |
641 |
xoff = d+.5; |
642 |
greg |
1.18 |
if (xscan+xoff >= xmax) |
643 |
xoff = xmax-1-xscan; |
644 |
greg |
1.14 |
645 |
646 |
if (n >= 3) { |
647 |
d = argument(3); |
648 |
if (d < 0.0) { |
649 |
yoff = d-.5; |
650 |
if (yoff+MIDSCN < 0) |
651 |
yoff = -MIDSCN; |
652 |
greg |
1.18 |
if (yscan+yoff < 0) |
653 |
yoff = -yscan; |
654 |
greg |
1.14 |
} else { |
655 |
yoff = d+.5; |
656 |
if (yoff+MIDSCN >= WINSIZ) |
657 |
yoff = WINSIZ-1-MIDSCN; |
658 |
greg |
1.18 |
if (yscan+yoff >= ymax) |
659 |
yoff = ymax-1-yscan; |
660 |
greg |
1.14 |
661 |
662 |
greg |
1.15 |
if (nam == vbrtin) |
663 |
greg |
2.16 |
return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff])); |
664 |
greg |
1.15 |
n = 3; |
665 |
while (n--) |
666 |
if (nam == vcolin[n]) |
667 |
greg |
1.18 |
return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n)); |
668 |
greg |
1.15 |
eputs("Bad call to l_colin()!\n"); |
669 |
greg |
2.10 |
quit(1); |
670 |
schorsch |
2.32 |
671 |
greg |
2.10 |
672 |
673 |
674 |
schorsch |
2.32 |
static double |
675 |
l_ray( /* return ray origin or direction */ |
676 |
greg |
2.47 |
char *nam |
677 |
schorsch |
2.32 |
678 |
greg |
2.10 |
679 |
greg |
2.15 |
static unsigned long ltick[MAXINP]; |
680 |
greg |
2.10 |
static FVECT lorg[MAXINP], ldir[MAXINP]; |
681 |
greg |
2.18 |
static double ldist[MAXINP]; |
682 |
schorsch |
2.25 |
RREAL loc[2]; |
683 |
greg |
2.42 |
double d; |
684 |
greg |
2.10 |
int fn; |
685 |
greg |
2.47 |
int i; |
686 |
greg |
2.10 |
687 |
greg |
2.42 |
d = argument(1); |
688 |
689 |
greg |
2.10 |
errno = EDOM; |
690 |
return(0.0); |
691 |
692 |
greg |
2.42 |
if (d < 0.5) |
693 |
694 |
fn = d - 0.5; |
695 |
greg |
2.22 |
if (ltick[fn] != eclock) { /* need to compute? */ |
696 |
greg |
2.57 |
if (input[fn].vw.type == 0) { |
697 |
lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0; |
698 |
ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0; |
699 |
ldist[fn] = -1.0; |
700 |
greg |
2.12 |
errno = EDOM; |
701 |
greg |
2.57 |
} else { |
702 |
greg |
2.11 |
pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan); |
703 |
greg |
2.18 |
ldist[fn] = viewray(lorg[fn], ldir[fn], |
704 |
&input[fn].vw, loc[0], loc[1]); |
705 |
greg |
2.57 |
if (ldist[fn] < -FTINY) |
706 |
errno = EDOM; |
707 |
greg |
2.10 |
708 |
greg |
2.18 |
ltick[fn] = eclock; |
709 |
greg |
2.10 |
710 |
greg |
2.18 |
if (nam == vray[i=6]) |
711 |
return(ldist[fn]); |
712 |
greg |
2.10 |
while (i--) |
713 |
if (nam == vray[i]) |
714 |
return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]); |
715 |
eputs("Bad call to l_ray()!\n"); |
716 |
greg |
1.15 |
quit(1); |
717 |
schorsch |
2.32 |
718 |
greg |
2.17 |
719 |
720 |
721 |
schorsch |
2.32 |
static double |
722 |
greg |
2.27 |
l_psize(char *nm) /* compute pixel size in steradians */ |
723 |
greg |
2.17 |
724 |
725 |
static double psize[MAXINP]; |
726 |
greg |
2.18 |
FVECT dir0, org, dirx, diry; |
727 |
schorsch |
2.25 |
RREAL locx[2], locy[2]; |
728 |
greg |
2.17 |
double d; |
729 |
int fn; |
730 |
greg |
2.47 |
int i; |
731 |
greg |
2.17 |
732 |
d = argument(1); |
733 |
greg |
2.42 |
734 |
greg |
2.17 |
errno = EDOM; |
735 |
return(0.0); |
736 |
737 |
greg |
2.42 |
if (d < 0.5) |
738 |
739 |
fn = d - 0.5; |
740 |
greg |
2.22 |
741 |
greg |
2.18 |
psize[fn] = 0.0; |
742 |
if (input[fn].vw.type == 0) |
743 |
greg |
2.17 |
errno = EDOM; |
744 |
greg |
2.18 |
else if (input[fn].vw.type != VT_PAR && |
745 |
greg |
2.36 |
funvalue(vray[6], 1, &d) >= -FTINY) { |
746 |
greg |
2.18 |
for (i = 0; i < 3; i++) |
747 |
dir0[i] = funvalue(vray[3+i], 1, &d); |
748 |
pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan); |
749 |
pix2loc(locy, &input[fn].rs, xscan, ymax-yscan); |
750 |
if (viewray(org, dirx, &input[fn].vw, |
751 |
greg |
2.35 |
locx[0], locx[1]) >= -FTINY && |
752 |
greg |
2.18 |
viewray(org, diry, &input[fn].vw, |
753 |
greg |
2.35 |
locy[0], locy[1]) >= -FTINY) { |
754 |
greg |
2.17 |
/* approximate solid angle */ |
755 |
greg |
2.18 |
756 |
dirx[i] -= dir0[i]; |
757 |
diry[i] -= dir0[i]; |
758 |
759 |
fcross(dir0, dirx, diry); |
760 |
greg |
2.35 |
psize[fn] = VLEN(dir0); |
761 |
greg |
2.17 |
762 |
763 |
greg |
2.18 |
764 |
765 |
greg |
2.17 |
return(psize[fn]); |
766 |
greg |
1.1 |
767 |
768 |
769 |
schorsch |
2.29 |
extern void |
770 |
greg |
2.55 |
wputs(const char *msg) |
771 |
greg |
1.1 |
772 |
if (!nowarn) |
773 |
eputs(msg); |
774 |
775 |
776 |
777 |
schorsch |
2.29 |
extern void |
778 |
greg |
2.55 |
eputs(const char *msg) |
779 |
greg |
1.1 |
780 |
fputs(msg, stderr); |
781 |
782 |
783 |
784 |
schorsch |
2.29 |
extern void |
785 |
quit(int code) /* exit gracefully */ |
786 |
greg |
2.4 |
787 |
greg |
2.47 |
int i; |
788 |
greg |
2.5 |
/* close input files */ |
789 |
790 |
greg |
2.6 |
if (input[i].name == Command) |
791 |
pclose(input[i].fp); |
792 |
else |
793 |
fclose(input[i].fp); |
794 |
greg |
1.1 |
exit(code); |
795 |
