1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pcomb.c,v 2.58 2023/12/11 15:13:39 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Combine picture files according to calcomp functions. |
6 |
7 |
* 1/4/89 |
8 |
9 |
10 |
#include "platform.h" |
11 |
#include "standard.h" |
12 |
#include "paths.h" |
13 |
#include "color.h" |
14 |
#include "calcomp.h" |
15 |
#include "view.h" |
16 |
17 |
#define MAXINP 1024 /* maximum number of input files */ |
18 |
#define WINSIZ 127 /* scanline window size */ |
19 |
#define MIDSCN ((WINSIZ-1)/2+1) |
20 |
21 |
struct { |
22 |
char *name; /* file or command name */ |
23 |
FILE *fp; /* stream pointer */ |
24 |
VIEW vw; /* view for picture */ |
25 |
RESOLU rs; /* image resolution and orientation */ |
26 |
int infloat; /* input is floating point (#comp)? */ |
27 |
float pa; /* pixel aspect ratio */ |
28 |
COLOR *scan[WINSIZ]; /* input scanline window */ |
29 |
COLOR coef; /* coefficient */ |
30 |
COLOR expos; /* recorded exposure */ |
31 |
} input[MAXINP]; /* input pictures */ |
32 |
33 |
int nfiles; /* number of input files */ |
34 |
35 |
VIEW *commvp = NULL; /* common view parameters */ |
36 |
37 |
char ourfmt[MAXFMTLEN] = PICFMT; /* input picture format */ |
38 |
int outfloat = 0; /* #component float output? */ |
39 |
40 |
char StandardInput[] = "<stdin>"; |
41 |
char Command[] = "<Command>"; |
42 |
char vcolin[3][4] = {"ri", "gi", "bi"}; |
43 |
char vcolout[3][4] = {"ro", "go", "bo"}; |
44 |
char vbrtin[] = "li"; |
45 |
char vbrtout[] = "lo"; |
46 |
char vcolexp[3][4] = {"re", "ge", "be"}; |
47 |
char vbrtexp[] = "le"; |
48 |
char vpixaspect[] = "pa"; |
49 |
50 |
char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"}; |
51 |
52 |
char vpsize[] = "S"; |
53 |
54 |
char vnfiles[] = "nfiles"; |
55 |
char vwhteff[] = "WE"; |
56 |
char vxmax[] = "xmax"; |
57 |
char vymax[] = "ymax"; |
58 |
char vxres[] = "xres"; |
59 |
char vyres[] = "yres"; |
60 |
char vxpos[] = "x"; |
61 |
char vypos[] = "y"; |
62 |
63 |
int nowarn = 0; /* no warning messages? */ |
64 |
65 |
int xmax = 0, ymax = 0; /* input resolution */ |
66 |
67 |
int xscan, yscan; /* input position */ |
68 |
69 |
int xres, yres; /* output resolution */ |
70 |
71 |
int xpos, ypos; /* output position */ |
72 |
73 |
char *progname; /* global argv[0] */ |
74 |
75 |
int echoheader = 1; |
76 |
int wrongformat = 0; |
77 |
int gotview; |
78 |
79 |
80 |
static gethfunc headline; |
81 |
static void checkfile(int orig); |
82 |
static double rgb_bright(COLOR clr); |
83 |
static double xyz_bright(COLOR clr); |
84 |
static void init(void); |
85 |
static void combine(void); |
86 |
static void advance(void); |
87 |
static double l_expos(char *nam); |
88 |
static double l_pixaspect(char *nm); |
89 |
static double l_colin(char *nam); |
90 |
static double l_ray(char *nam); |
91 |
static double l_psize(char *nm); |
92 |
93 |
94 |
int |
95 |
main( |
96 |
int argc, |
97 |
char *argv[] |
98 |
99 |
100 |
int original; |
101 |
double f; |
102 |
int a; |
103 |
104 |
SET_DEFAULT_BINARY(); |
105 |
SET_FILE_BINARY(stdin); |
106 |
SET_FILE_BINARY(stdout); |
107 |
progname = argv[0]; |
108 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; |
109 |
esupport &= ~(E_OUTCHAN|E_INCHAN); |
110 |
/* scan options */ |
111 |
for (a = 1; a < argc; a++) { |
112 |
if (argv[a][0] == '-') |
113 |
switch (argv[a][1]) { |
114 |
case 'x': |
115 |
case 'y': |
116 |
a++; |
117 |
continue; |
118 |
case 'w': |
119 |
nowarn = !nowarn; |
120 |
continue; |
121 |
case 'h': |
122 |
echoheader = !echoheader; |
123 |
continue; |
124 |
case 'f': |
125 |
if (argv[a][2]) { |
126 |
outfloat = (argv[a][2] == 'f'); |
127 |
continue; |
128 |
129 |
/* fall through */ |
130 |
case 'e': |
131 |
a++; |
132 |
continue; |
133 |
134 |
break; |
135 |
136 |
newheader("RADIANCE", stdout); /* start header */ |
137 |
fputnow(stdout); |
138 |
/* process files */ |
139 |
for (nfiles = 0; nfiles < MAXINP; nfiles++) { |
140 |
setcolor(input[nfiles].coef, 1.0, 1.0, 1.0); |
141 |
setcolor(input[nfiles].expos, 1.0, 1.0, 1.0); |
142 |
input[nfiles].vw = stdview; |
143 |
input[nfiles].pa = 1.0; |
144 |
145 |
nfiles = 0; |
146 |
original = 0; |
147 |
for ( ; a < argc; a++) { |
148 |
if (nfiles >= MAXINP) { |
149 |
eputs(argv[0]); |
150 |
eputs(": too many picture files\n"); |
151 |
quit(1); |
152 |
153 |
154 |
155 |
case '\0': |
156 |
input[nfiles].name = StandardInput; |
157 |
input[nfiles].fp = stdin; |
158 |
break; |
159 |
case 'o': |
160 |
original++; |
161 |
continue; |
162 |
case 's': |
163 |
f = atof(argv[++a]); |
164 |
scalecolor(input[nfiles].coef, f); |
165 |
continue; |
166 |
case 'c': |
167 |
colval(input[nfiles].coef,RED)*=atof(argv[++a]); |
168 |
colval(input[nfiles].coef,GRN)*=atof(argv[++a]); |
169 |
colval(input[nfiles].coef,BLU)*=atof(argv[++a]); |
170 |
continue; |
171 |
default: |
172 |
goto usage; |
173 |
174 |
else { |
175 |
if (argv[a][0] == '!') { |
176 |
input[nfiles].name = Command; |
177 |
input[nfiles].fp = popen(argv[a]+1, "r"); |
178 |
} else { |
179 |
input[nfiles].name = argv[a]; |
180 |
input[nfiles].fp = fopen(argv[a], "r"); |
181 |
182 |
if (input[nfiles].fp == NULL) { |
183 |
perror(argv[a]); |
184 |
quit(1); |
185 |
186 |
187 |
checkfile(original); |
188 |
nfiles++; |
189 |
original = 0; |
190 |
191 |
init(); /* set constants */ |
192 |
/* go back and get expressions */ |
193 |
194 |
char *fpath; |
195 |
196 |
197 |
case 'x': |
198 |
varset(vxres, ':', eval(argv[++a])); |
199 |
continue; |
200 |
case 'y': |
201 |
varset(vyres, ':', eval(argv[++a])); |
202 |
continue; |
203 |
case 'w': |
204 |
continue; |
205 |
case 'h': |
206 |
continue; |
207 |
case 'f': |
208 |
if (argv[a][2]) |
209 |
continue; |
210 |
fpath = getpath(argv[++a], getrlibpath(), 0); |
211 |
if (fpath == NULL) { |
212 |
eputs(argv[0]); |
213 |
eputs(": cannot find file '"); |
214 |
eputs(argv[a]); |
215 |
eputs("'\n"); |
216 |
quit(1); |
217 |
218 |
fcompile(fpath); |
219 |
continue; |
220 |
case 'e': |
221 |
scompile(argv[++a], NULL, 0); |
222 |
continue; |
223 |
224 |
break; |
225 |
226 |
/* get output resolution */ |
227 |
xres = varvalue(vxres) + .5; |
228 |
yres = varvalue(vyres) + .5; |
229 |
if (xres <= 0 || yres <= 0) { |
230 |
eputs(argv[0]); |
231 |
eputs(": illegal output resolution\n"); |
232 |
quit(1); |
233 |
234 |
if (!vardefined(vbrtout)) /* single or 3-channel? */ |
235 |
outfloat *= 3; |
236 |
237 |
printargs(argc, argv, stdout); /* complete header */ |
238 |
if (commvp != NULL) { |
239 |
fputs(VIEWSTR, stdout); |
240 |
fprintview(commvp, stdout); |
241 |
fputc('\n', stdout); |
242 |
243 |
if (outfloat) { /* print format if known */ |
244 |
printf("NROWS=%d\nNCOLS=%d\n", yres, xres); |
245 |
fputncomp(outfloat, stdout); |
246 |
fputendian(stdout); |
247 |
fputformat("float", stdout); |
248 |
} else if (strcmp(ourfmt, PICFMT)) |
249 |
fputformat(ourfmt, stdout); |
250 |
fputc('\n', stdout); /* end header */ |
251 |
if (!outfloat) |
252 |
fprtresolu(xres, yres, stdout); |
253 |
254 |
doptimize(1); /* optimize definitions */ |
255 |
combine(); /* combine pictures */ |
256 |
quit(0); |
257 |
usage: |
258 |
eputs("Usage: "); |
259 |
eputs(argv[0]); |
260 |
eputs( |
261 |
" [-w][-h][-ff][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n"); |
262 |
quit(1); |
263 |
return 1; /* pro forma return */ |
264 |
265 |
266 |
267 |
static int |
268 |
headline( /* check header line & echo if requested */ |
269 |
char *s, |
270 |
void *p |
271 |
272 |
273 |
int orig = *(int *)p; |
274 |
char fmt[MAXFMTLEN]; |
275 |
double d; |
276 |
int bigend; |
277 |
COLOR ctmp; |
278 |
279 |
if (isheadid(s)) /* header id */ |
280 |
return(0); /* don't echo */ |
281 |
if (formatval(fmt, s)) { /* check format */ |
282 |
if (globmatch(ourfmt, fmt)) { |
283 |
wrongformat = 0; |
284 |
strcpy(ourfmt, fmt); |
285 |
} else if (!strcmp("float", fmt)) |
286 |
input[nfiles].infloat *= -1; |
287 |
else |
288 |
wrongformat = globmatch(PICFMT, fmt) ? 1 : -1; |
289 |
290 |
291 |
if ((bigend = isbigendian(s)) >= 0) { |
292 |
if (bigend != nativebigendian()) { |
293 |
eputs(input[nfiles].name); |
294 |
eputs(": unsupported input byte ordering\n"); |
295 |
quit(1); |
296 |
297 |
298 |
299 |
if (!strncmp("NROWS=", s, 6)) { /* X-resolution */ |
300 |
input[nfiles].rs.yr = atoi(s+6); |
301 |
302 |
303 |
if (!strncmp("NCOLS=", s, 6)) { /* Y-resolution */ |
304 |
input[nfiles].rs.xr = atoi(s+6); |
305 |
306 |
307 |
if (isncomp(s)) /* # components */ |
308 |
input[nfiles].infloat *= ncompval(s); |
309 |
310 |
if (orig) { /* undo exposure? */ |
311 |
if (isexpos(s)) { |
312 |
d = 1./exposval(s); |
313 |
scalecolor(input[nfiles].coef, d); |
314 |
315 |
316 |
if (iscolcor(s)) { |
317 |
int i; |
318 |
colcorval(ctmp, s); |
319 |
for (i = 3; i--; ) |
320 |
colval(input[nfiles].coef,i) /= colval(ctmp,i); |
321 |
322 |
323 |
} else if (isexpos(s)) { /* record exposure? */ |
324 |
d = exposval(s); |
325 |
scalecolor(input[nfiles].expos, d); |
326 |
} else if (iscolcor(s)) { |
327 |
328 |
multcolor(input[nfiles].expos, ctmp); |
329 |
330 |
if (isaspect(s)) |
331 |
input[nfiles].pa *= aspectval(s); |
332 |
else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0) |
333 |
gotview++; |
334 |
335 |
if (echoheader) { /* echo line */ |
336 |
putchar('\t'); |
337 |
return(fputs(s, stdout)); |
338 |
339 |
return(0); |
340 |
341 |
342 |
343 |
static void |
344 |
checkfile(int orig) /* ready a file */ |
345 |
346 |
int i; |
347 |
/* process header */ |
348 |
gotview = 0; |
349 |
input[nfiles].infloat = -1; |
350 |
input[nfiles].rs.rt = PIXSTANDARD; |
351 |
input[nfiles].rs.xr = input[nfiles].rs.yr = 0; |
352 |
if (echoheader) { |
353 |
fputs(input[nfiles].name, stdout); |
354 |
fputs(":\n", stdout); |
355 |
356 |
getheader(input[nfiles].fp, headline, &orig); |
357 |
358 |
if (input[nfiles].infloat <= 0) |
359 |
input[nfiles].infloat = 0; |
360 |
else if ((input[nfiles].infloat != 3) & |
361 |
(input[nfiles].infloat != 1)) { |
362 |
363 |
eputs(": unsupported number of components\n"); |
364 |
quit(1); |
365 |
366 |
if (wrongformat < 0) { |
367 |
368 |
eputs(": not a Radiance picture or float matrix\n"); |
369 |
quit(1); |
370 |
371 |
if (wrongformat > 0) { |
372 |
wputs(input[nfiles].name); |
373 |
wputs(": warning -- incompatible picture format\n"); |
374 |
375 |
if (!gotview || setview(&input[nfiles].vw) != NULL) |
376 |
input[nfiles].vw.type = 0; |
377 |
else if (commvp == NULL) |
378 |
commvp = &input[nfiles].vw; |
379 |
if ((input[nfiles].rs.xr <= 0) | (input[nfiles].rs.yr <= 0) && |
380 |
!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) { |
381 |
382 |
eputs(": bad picture size\n"); |
383 |
quit(1); |
384 |
385 |
if (xmax == 0 && ymax == 0) { |
386 |
xmax = scanlen(&input[nfiles].rs); |
387 |
ymax = numscans(&input[nfiles].rs); |
388 |
} else if (scanlen(&input[nfiles].rs) != xmax || |
389 |
numscans(&input[nfiles].rs) != ymax) { |
390 |
391 |
eputs(": resolution mismatch\n"); |
392 |
quit(1); |
393 |
394 |
/* allocate scanlines */ |
395 |
for (i = 0; i < WINSIZ; i++) |
396 |
input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR)); |
397 |
398 |
399 |
400 |
static double |
401 |
rgb_bright( |
402 |
COLOR clr |
403 |
404 |
405 |
return(bright(clr)); |
406 |
407 |
408 |
409 |
static double |
410 |
xyz_bright( |
411 |
COLOR clr |
412 |
413 |
414 |
return(clr[CIEY]); |
415 |
416 |
417 |
418 |
double (*ourbright)() = rgb_bright; |
419 |
420 |
421 |
static void |
422 |
init(void) /* perform final setup */ |
423 |
424 |
int i; |
425 |
/* define constants */ |
426 |
varset("PI", ':', PI); |
427 |
varset(vnfiles, ':', (double)nfiles); |
428 |
varset(vxmax, ':', (double)xmax); |
429 |
varset(vymax, ':', (double)ymax); |
430 |
/* set functions */ |
431 |
for (i = 0; i < 3; i++) { |
432 |
funset(vcolexp[i], 1, ':', l_expos); |
433 |
funset(vcolin[i], 1, '=', l_colin); |
434 |
435 |
funset(vbrtexp, 1, ':', l_expos); |
436 |
funset(vbrtin, 1, '=', l_colin); |
437 |
funset(vpixaspect, 1, ':', l_pixaspect); |
438 |
for (i = 0; i < 7; i++) |
439 |
funset(vray[i], 1, '=', l_ray); |
440 |
funset(vpsize, 1, '=', l_psize); |
441 |
/* set brightness function */ |
442 |
if (!strcmp(ourfmt, CIEFMT)) { |
443 |
varset(vwhteff, ':', 1.0); |
444 |
ourbright = xyz_bright; |
445 |
} else |
446 |
varset(vwhteff, ':', WHTEFFICACY); |
447 |
/* these may be overridden */ |
448 |
varset(vxres, ':', (double)xmax); |
449 |
varset(vyres, ':', (double)ymax); |
450 |
451 |
452 |
453 |
static void |
454 |
combine(void) /* combine pictures */ |
455 |
456 |
EPNODE *coldef[3], *brtdef; |
457 |
int set_x, set_y; |
458 |
COLOR *scanout; |
459 |
double d; |
460 |
int i, j; |
461 |
/* check defined variables */ |
462 |
for (j = 0; j < 3; j++) { |
463 |
if (vardefined(vcolout[j])) |
464 |
coldef[j] = eparse(vcolout[j]); |
465 |
else |
466 |
coldef[j] = NULL; |
467 |
468 |
if (vardefined(vbrtout)) |
469 |
brtdef = eparse(vbrtout); |
470 |
else |
471 |
brtdef = NULL; |
472 |
/* what to set */ |
473 |
set_x = varlookup(vxpos) != NULL && !vardefined(vxpos); |
474 |
set_y = varlookup(vypos) != NULL && !vardefined(vypos); |
475 |
/* allocate scanline */ |
476 |
scanout = (COLOR *)emalloc(xres*sizeof(COLOR)); |
477 |
/* set input position */ |
478 |
yscan = ymax+MIDSCN; |
479 |
/* combine files */ |
480 |
for (ypos = yres-1; ypos >= 0; ypos--) { |
481 |
advance(); |
482 |
if (set_y) varset(vypos, '=', (double)ypos); |
483 |
for (xpos = 0; xpos < xres; xpos++) { |
484 |
xscan = (xpos+.5)*xmax/xres; |
485 |
if (set_x) varset(vxpos, '=', (double)xpos); |
486 |
eclock++; |
487 |
if (brtdef != NULL) { |
488 |
d = evalue(brtdef); |
489 |
d *= (outfloat > 0) | (d >= 0); |
490 |
setcolor(scanout[xpos], d, d, d); |
491 |
} else { |
492 |
493 |
if (coldef[j] != NULL) { |
494 |
d = evalue(coldef[j]); |
495 |
} else { |
496 |
d = 0.0; |
497 |
for (i = 0; i < nfiles; i++) |
498 |
d += colval(input[i].scan[MIDSCN][xscan],j); |
499 |
500 |
501 |
colval(scanout[xpos],j) = d; |
502 |
503 |
504 |
505 |
switch (outfloat) { |
506 |
case 3: /* writing out float triplets */ |
507 |
if (fwrite(scanout, sizeof(float)*3, xres, stdout) != xres) |
508 |
goto writerr; |
509 |
break; |
510 |
case 1: /* writing out gray float values */ |
511 |
for (xpos = 0; xpos < xres; xpos++) |
512 |
if (putbinary(&scanout[xpos][CIEY], |
513 |
sizeof(float), 1, stdout) != 1) |
514 |
goto writerr; |
515 |
break; |
516 |
default: /* writing out Radiance picture */ |
517 |
if (fwritescan(scanout, xres, stdout) < 0) |
518 |
goto writerr; |
519 |
break; |
520 |
521 |
522 |
efree((char *)scanout); |
523 |
return; |
524 |
writerr: |
525 |
perror("write error"); |
526 |
quit(1); |
527 |
528 |
529 |
530 |
static void |
531 |
advance(void) /* read in data for next scanline */ |
532 |
533 |
int ytarget; |
534 |
COLOR *st; |
535 |
int i, j; |
536 |
537 |
for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--) |
538 |
for (i = 0; i < nfiles; i++) { |
539 |
st = input[i].scan[WINSIZ-1]; |
540 |
for (j = WINSIZ-1; j > 0; j--) /* rotate window */ |
541 |
input[i].scan[j] = input[i].scan[j-1]; |
542 |
input[i].scan[0] = st; |
543 |
if (yscan <= MIDSCN) /* hit bottom? */ |
544 |
continue; |
545 |
/* read scanline */ |
546 |
if (input[i].infloat) { |
547 |
if (fread(st, sizeof(float)*input[i].infloat, |
548 |
xmax, input[i].fp) != xmax) |
549 |
goto readerr; |
550 |
if (input[i].infloat == 1) { |
551 |
const COLORV *f = st[0] + xmax; |
552 |
int x = xmax; |
553 |
while (x-- > 0) |
554 |
st[x][BLU] = st[x][GRN] = |
555 |
st[x][RED] = *--f; |
556 |
557 |
} else if (freadscan(st, xmax, input[i].fp) < 0) |
558 |
goto readerr; |
559 |
for (j = 0; j < xmax; j++) /* adjust color */ |
560 |
multcolor(st[j], input[i].coef); |
561 |
562 |
return; |
563 |
readerr: |
564 |
eputs(input[i].name); |
565 |
eputs(": read error\n"); |
566 |
quit(1); |
567 |
568 |
569 |
570 |
static double |
571 |
l_expos( /* return picture exposure */ |
572 |
char *nam |
573 |
574 |
575 |
int fn, n; |
576 |
double d; |
577 |
578 |
d = argument(1); |
579 |
if (d <= -0.5 || d >= nfiles+0.5) { |
580 |
errno = EDOM; |
581 |
return(0.0); |
582 |
583 |
if (d < 0.5) |
584 |
return((double)nfiles); |
585 |
fn = d - 0.5; |
586 |
if (nam == vbrtexp) |
587 |
return((*ourbright)(input[fn].expos)); |
588 |
n = 3; |
589 |
while (n--) |
590 |
if (nam == vcolexp[n]) |
591 |
return(colval(input[fn].expos,n)); |
592 |
eputs("Bad call to l_expos()!\n"); |
593 |
quit(1); |
594 |
595 |
596 |
597 |
598 |
static double |
599 |
l_pixaspect(char *nm) /* return pixel aspect ratio */ |
600 |
601 |
int fn; |
602 |
double d; |
603 |
604 |
d = argument(1); |
605 |
606 |
errno = EDOM; |
607 |
return(0.0); |
608 |
609 |
if (d < 0.5) |
610 |
611 |
fn = d - 0.5; |
612 |
return(input[fn].pa); |
613 |
614 |
615 |
616 |
static double |
617 |
l_colin( /* return color value for picture */ |
618 |
char *nam |
619 |
620 |
621 |
int fn; |
622 |
int n, xoff, yoff; |
623 |
double d; |
624 |
625 |
d = argument(1); |
626 |
627 |
errno = EDOM; |
628 |
return(0.0); |
629 |
630 |
if (d < 0.5) |
631 |
632 |
fn = d - 0.5; |
633 |
xoff = yoff = 0; |
634 |
n = nargum(); |
635 |
if (n >= 2) { |
636 |
d = argument(2); |
637 |
if (d < 0.0) { |
638 |
xoff = d-.5; |
639 |
if (xscan+xoff < 0) |
640 |
xoff = -xscan; |
641 |
} else { |
642 |
xoff = d+.5; |
643 |
if (xscan+xoff >= xmax) |
644 |
xoff = xmax-1-xscan; |
645 |
646 |
647 |
if (n >= 3) { |
648 |
d = argument(3); |
649 |
if (d < 0.0) { |
650 |
yoff = d-.5; |
651 |
if (yoff+MIDSCN < 0) |
652 |
yoff = -MIDSCN; |
653 |
if (yscan+yoff < 0) |
654 |
yoff = -yscan; |
655 |
} else { |
656 |
yoff = d+.5; |
657 |
if (yoff+MIDSCN >= WINSIZ) |
658 |
yoff = WINSIZ-1-MIDSCN; |
659 |
if (yscan+yoff >= ymax) |
660 |
yoff = ymax-1-yscan; |
661 |
662 |
663 |
if (nam == vbrtin) |
664 |
return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff])); |
665 |
n = 3; |
666 |
while (n--) |
667 |
if (nam == vcolin[n]) |
668 |
return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n)); |
669 |
eputs("Bad call to l_colin()!\n"); |
670 |
quit(1); |
671 |
672 |
673 |
674 |
675 |
static double |
676 |
l_ray( /* return ray origin or direction */ |
677 |
char *nam |
678 |
679 |
680 |
static unsigned long ltick[MAXINP]; |
681 |
static FVECT lorg[MAXINP], ldir[MAXINP]; |
682 |
static double ldist[MAXINP]; |
683 |
RREAL loc[2]; |
684 |
double d; |
685 |
int fn; |
686 |
int i; |
687 |
688 |
d = argument(1); |
689 |
690 |
errno = EDOM; |
691 |
return(0.0); |
692 |
693 |
if (d < 0.5) |
694 |
695 |
fn = d - 0.5; |
696 |
if (ltick[fn] != eclock) { /* need to compute? */ |
697 |
if (input[fn].vw.type == 0) { |
698 |
lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0; |
699 |
ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0; |
700 |
ldist[fn] = -1.0; |
701 |
errno = EDOM; |
702 |
} else { |
703 |
pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan); |
704 |
ldist[fn] = viewray(lorg[fn], ldir[fn], |
705 |
&input[fn].vw, loc[0], loc[1]); |
706 |
if (ldist[fn] < -FTINY) |
707 |
errno = EDOM; |
708 |
709 |
ltick[fn] = eclock; |
710 |
711 |
if (nam == vray[i=6]) |
712 |
return(ldist[fn]); |
713 |
while (i--) |
714 |
if (nam == vray[i]) |
715 |
return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]); |
716 |
eputs("Bad call to l_ray()!\n"); |
717 |
quit(1); |
718 |
719 |
720 |
721 |
722 |
static double |
723 |
l_psize(char *nm) /* compute pixel size in steradians */ |
724 |
725 |
726 |
static double psize[MAXINP]; |
727 |
FVECT dir0, org, dirx, diry; |
728 |
RREAL locx[2], locy[2]; |
729 |
double d; |
730 |
int fn; |
731 |
int i; |
732 |
733 |
d = argument(1); |
734 |
735 |
errno = EDOM; |
736 |
return(0.0); |
737 |
738 |
if (d < 0.5) |
739 |
740 |
fn = d - 0.5; |
741 |
742 |
psize[fn] = 0.0; |
743 |
if (input[fn].vw.type == 0) |
744 |
errno = EDOM; |
745 |
else if (input[fn].vw.type != VT_PAR && |
746 |
funvalue(vray[6], 1, &d) >= -FTINY) { |
747 |
for (i = 0; i < 3; i++) |
748 |
dir0[i] = funvalue(vray[3+i], 1, &d); |
749 |
pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan); |
750 |
pix2loc(locy, &input[fn].rs, xscan, ymax-yscan); |
751 |
if (viewray(org, dirx, &input[fn].vw, |
752 |
locx[0], locx[1]) >= -FTINY && |
753 |
viewray(org, diry, &input[fn].vw, |
754 |
locy[0], locy[1]) >= -FTINY) { |
755 |
/* approximate solid angle */ |
756 |
757 |
dirx[i] -= dir0[i]; |
758 |
diry[i] -= dir0[i]; |
759 |
760 |
fcross(dir0, dirx, diry); |
761 |
psize[fn] = VLEN(dir0); |
762 |
763 |
764 |
765 |
766 |
return(psize[fn]); |
767 |
768 |
769 |
770 |
extern void |
771 |
wputs(const char *msg) |
772 |
773 |
if (!nowarn) |
774 |
eputs(msg); |
775 |
776 |
777 |
778 |
extern void |
779 |
eputs(const char *msg) |
780 |
781 |
fputs(msg, stderr); |
782 |
783 |
784 |
785 |
extern void |
786 |
quit(int code) /* exit gracefully */ |
787 |
788 |
int i; |
789 |
/* close input files */ |
790 |
791 |
if (input[i].name == Command) |
792 |
pclose(input[i].fp); |
793 |
else |
794 |
fclose(input[i].fp); |
795 |
exit(code); |
796 |
