root/radiance/ray/src/px/pcomb.c
Revision: 2.48
Committed: Sat Jan 13 00:35:55 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.47: +5 -6 lines
Fixed issue introduced with xres and yres definitions
2 static const char RCSid[] = "$Id: pcomb.c,v 2.47 2018/01/12 00:50:17 greg Exp $";
5 * Combine picture files according to calcomp functions.
6 *
7 * 1/4/89
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "paths.h"
13 #include "color.h"
14 #include "calcomp.h"
15 #include "view.h"
16
17 #define MAXINP 1024 /* maximum number of input files */
18 #define WINSIZ 127 /* scanline window size */
19 #define MIDSCN ((WINSIZ-1)/2+1)
20
21 struct {
22 char *name; /* file or command name */
23 FILE *fp; /* stream pointer */
24 VIEW vw; /* view for picture */
25 RESOLU rs; /* image resolution and orientation */
26 float pa; /* pixel aspect ratio */
27 COLOR *scan[WINSIZ]; /* input scanline window */
28 COLOR coef; /* coefficient */
29 COLOR expos; /* recorded exposure */
30 } input[MAXINP]; /* input pictures */
31
32 int nfiles; /* number of input files */
33
34 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
35
36 char StandardInput[] = "<stdin>";
37 char Command[] = "<Command>";
38 char vcolin[3][4] = {"ri", "gi", "bi"};
39 char vcolout[3][4] = {"ro", "go", "bo"};
40 char vbrtin[] = "li";
41 char vbrtout[] = "lo";
42 char vcolexp[3][4] = {"re", "ge", "be"};
43 char vbrtexp[] = "le";
44 char vpixaspect[] = "pa";
45
46 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
47
48 char vpsize[] = "S";
49
50 char vnfiles[] = "nfiles";
51 char vwhteff[] = "WE";
52 char vxmax[] = "xmax";
53 char vymax[] = "ymax";
54 char vxres[] = "xres";
55 char vyres[] = "yres";
56 char vxpos[] = "x";
57 char vypos[] = "y";
58
59 int nowarn = 0; /* no warning messages? */
60
61 int xmax = 0, ymax = 0; /* input resolution */
62
63 int xscan, yscan; /* input position */
64
65 int xres, yres; /* output resolution */
66
67 int xpos, ypos; /* output position */
68
69 char *progname; /* global argv[0] */
70
71 int echoheader = 1;
72 int wrongformat = 0;
73 int gotview;
74
75
76 static gethfunc headline;
77 static void checkfile(void);
78 static double rgb_bright(COLOR clr);
79 static double xyz_bright(COLOR clr);
80 static void init(void);
81 static void combine(void);
82 static void advance(void);
83 static double l_expos(char *nam);
84 static double l_pixaspect(char *nm);
85 static double l_colin(char *nam);
86 static double l_ray(char *nam);
87 static double l_psize(char *nm);
88
89
90 int
91 main(
92 int argc,
93 char *argv[]
94 )
95 {
96 int original;
97 double f;
98 int a;
99
100 SET_DEFAULT_BINARY();
101 SET_FILE_BINARY(stdin);
102 SET_FILE_BINARY(stdout);
103 progname = argv[0];
104 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
105 esupport &= ~(E_OUTCHAN|E_INCHAN);
106 /* scan options */
107 for (a = 1; a < argc; a++) {
108 if (argv[a][0] == '-')
109 switch (argv[a][1]) {
110 case 'x':
111 case 'y':
112 a++;
113 continue;
114 case 'w':
115 nowarn = !nowarn;
116 continue;
117 case 'h':
118 echoheader = !echoheader;
119 continue;
120 case 'f':
121 case 'e':
122 a++;
123 continue;
124 }
125 break;
126 }
127 newheader("RADIANCE", stdout); /* start header */
128 fputnow(stdout);
129 /* process files */
130 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
131 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
132 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
133 input[nfiles].vw = stdview;
134 input[nfiles].pa = 1.0;
135 }
136 nfiles = 0;
137 original = 0;
138 for ( ; a < argc; a++) {
139 if (nfiles >= MAXINP) {
140 eputs(argv[0]);
141 eputs(": too many picture files\n");
142 quit(1);
143 }
144 if (argv[a][0] == '-')
145 switch (argv[a][1]) {
146 case '\0':
147 input[nfiles].name = StandardInput;
148 input[nfiles].fp = stdin;
149 break;
150 case 'o':
151 original++;
152 continue;
153 case 's':
154 f = atof(argv[++a]);
155 scalecolor(input[nfiles].coef, f);
156 continue;
157 case 'c':
158 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
159 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
160 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
161 continue;
162 default:
163 goto usage;
164 }
165 else {
166 if (argv[a][0] == '!') {
167 input[nfiles].name = Command;
168 input[nfiles].fp = popen(argv[a]+1, "r");
169 } else {
170 input[nfiles].name = argv[a];
171 input[nfiles].fp = fopen(argv[a], "r");
172 }
173 if (input[nfiles].fp == NULL) {
174 perror(argv[a]);
175 quit(1);
176 }
177 }
178 checkfile();
179 if (original) {
180 colval(input[nfiles].coef,RED) /=
181 colval(input[nfiles].expos,RED);
182 colval(input[nfiles].coef,GRN) /=
183 colval(input[nfiles].expos,GRN);
184 colval(input[nfiles].coef,BLU) /=
185 colval(input[nfiles].expos,BLU);
186 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
187 }
188 nfiles++;
189 original = 0;
190 }
191 init(); /* set constants */
192 /* go back and get expressions */
193 for (a = 1; a < argc; a++) {
194 if (argv[a][0] == '-')
195 switch (argv[a][1]) {
196 case 'x':
197 varset(vxres, ':', eval(argv[++a]));
198 continue;
199 case 'y':
200 varset(vyres, ':', eval(argv[++a]));
201 continue;
202 case 'w':
203 continue;
204 case 'h':
205 continue;
206 case 'f':
207 fcompile(argv[++a]);
208 continue;
209 case 'e':
210 scompile(argv[++a], NULL, 0);
211 continue;
212 }
213 break;
214 }
215 /* get output resolution */
216 xres = varvalue(vxres) + .5;
217 yres = varvalue(vyres) + .5;
218 if (xres <= 0 || yres <= 0) {
219 eputs(argv[0]);
220 eputs(": illegal output resolution\n");
221 quit(1);
222 }
223 /* complete header */
224 printargs(argc, argv, stdout);
225 if (strcmp(ourfmt, PICFMT))
226 fputformat(ourfmt, stdout); /* print format if known */
227 putchar('\n');
228 fprtresolu(xres, yres, stdout);
229 /* combine pictures */
230 combine();
231 quit(0);
232 usage:
233 eputs("Usage: ");
234 eputs(argv[0]);
235 eputs(
236 " [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n");
237 quit(1);
238 return 1; /* pro forma return */
239 }
240
241
242 static int
243 headline( /* check header line & echo if requested */
244 char *s,
245 void *p
246 )
247 {
248 char fmt[32];
249 double d;
250 COLOR ctmp;
251
252 if (isheadid(s)) /* header id */
253 return(0); /* don't echo */
254 if (formatval(fmt, s)) { /* check format */
255 if (globmatch(ourfmt, fmt)) {
256 wrongformat = 0;
257 strcpy(ourfmt, fmt);
258 } else
259 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
260 return(0); /* don't echo */
261 }
262 if (isexpos(s)) { /* exposure */
263 d = exposval(s);
264 scalecolor(input[nfiles].expos, d);
265 } else if (iscolcor(s)) { /* color correction */
266 colcorval(ctmp, s);
267 multcolor(input[nfiles].expos, ctmp);
268 } else if (isaspect(s))
269 input[nfiles].pa *= aspectval(s);
270 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
271 gotview++;
272
273 if (echoheader) { /* echo line */
274 putchar('\t');
275 return(fputs(s, stdout));
276 }
277 return(0);
278 }
279
280
281 static void
282 checkfile(void) /* ready a file */
283 {
284 int i;
285 /* process header */
286 gotview = 0;
287 if (echoheader) {
288 fputs(input[nfiles].name, stdout);
289 fputs(":\n", stdout);
290 }
291 getheader(input[nfiles].fp, headline, NULL);
292 if (wrongformat < 0) {
293 eputs(input[nfiles].name);
294 eputs(": not a Radiance picture\n");
295 quit(1);
296 }
297 if (wrongformat > 0) {
298 wputs(input[nfiles].name);
299 wputs(": warning -- incompatible picture format\n");
300 }
301 if (!gotview || setview(&input[nfiles].vw) != NULL)
302 input[nfiles].vw.type = 0;
303 if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
304 eputs(input[nfiles].name);
305 eputs(": bad picture size\n");
306 quit(1);
307 }
308 if (xmax == 0 && ymax == 0) {
309 xmax = scanlen(&input[nfiles].rs);
310 ymax = numscans(&input[nfiles].rs);
311 } else if (scanlen(&input[nfiles].rs) != xmax ||
312 numscans(&input[nfiles].rs) != ymax) {
313 eputs(input[nfiles].name);
314 eputs(": resolution mismatch\n");
315 quit(1);
316 }
317 /* allocate scanlines */
318 for (i = 0; i < WINSIZ; i++)
319 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
320 }
321
322
323 static double
324 rgb_bright(
325 COLOR clr
326 )
327 {
328 return(bright(clr));
329 }
330
331
332 static double
333 xyz_bright(
334 COLOR clr
335 )
336 {
337 return(clr[CIEY]);
338 }
339
340
341 double (*ourbright)() = rgb_bright;
342
343
344 static void
345 init(void) /* perform final setup */
346 {
347 int i;
348 /* define constants */
349 varset("PI", ':', PI);
350 varset(vnfiles, ':', (double)nfiles);
351 varset(vxmax, ':', (double)xmax);
352 varset(vymax, ':', (double)ymax);
353 /* set functions */
354 for (i = 0; i < 3; i++) {
355 funset(vcolexp[i], 1, ':', l_expos);
356 funset(vcolin[i], 1, '=', l_colin);
357 }
358 funset(vbrtexp, 1, ':', l_expos);
359 funset(vbrtin, 1, '=', l_colin);
360 funset(vpixaspect, 1, ':', l_pixaspect);
361 for (i = 0; i < 7; i++)
362 funset(vray[i], 1, '=', l_ray);
363 funset(vpsize, 1, '=', l_psize);
364 /* set brightness function */
365 if (!strcmp(ourfmt, CIEFMT)) {
366 varset(vwhteff, ':', 1.0);
367 ourbright = xyz_bright;
368 } else
369 varset(vwhteff, ':', WHTEFFICACY);
370 /* these may be overridden */
371 varset(vxres, ':', (double)xmax);
372 varset(vyres, ':', (double)ymax);
373 }
374
375
376 static void
377 combine(void) /* combine pictures */
378 {
379 EPNODE *coldef[3], *brtdef;
380 COLOR *scanout;
381 double d;
382 int i, j;
383 /* check defined variables */
384 for (j = 0; j < 3; j++) {
385 if (vardefined(vcolout[j]))
386 coldef[j] = eparse(vcolout[j]);
387 else
388 coldef[j] = NULL;
389 }
390 if (vardefined(vbrtout))
391 brtdef = eparse(vbrtout);
392 else
393 brtdef = NULL;
394 /* allocate scanline */
395 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
396 /* set input position */
397 yscan = ymax+MIDSCN;
398 /* combine files */
399 for (ypos = yres-1; ypos >= 0; ypos--) {
400 advance();
401 varset(vypos, '=', (double)ypos);
402 for (xpos = 0; xpos < xres; xpos++) {
403 xscan = (xpos+.5)*xmax/xres;
404 varset(vxpos, '=', (double)xpos);
405 eclock++;
406 if (brtdef != NULL) {
407 d = evalue(brtdef);
408 if (d < 0.0)
409 d = 0.0;
410 setcolor(scanout[xpos], d, d, d);
411 } else {
412 for (j = 0; j < 3; j++) {
413 if (coldef[j] != NULL) {
414 d = evalue(coldef[j]);
415 } else {
416 d = 0.0;
417 for (i = 0; i < nfiles; i++)
418 d += colval(input[i].scan[MIDSCN][xscan],j);
419 }
420 if (d < 0.0)
421 d = 0.0;
422 colval(scanout[xpos],j) = d;
423 }
424 }
425 }
426 if (fwritescan(scanout, xres, stdout) < 0) {
427 perror("write error");
428 quit(1);
429 }
430 }
431 efree((char *)scanout);
432 }
433
434
435 static void
436 advance(void) /* read in data for next scanline */
437 {
438 int ytarget;
439 COLOR *st;
440 int i, j;
441
442 for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--)
443 for (i = 0; i < nfiles; i++) {
444 st = input[i].scan[WINSIZ-1];
445 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
446 input[i].scan[j] = input[i].scan[j-1];
447 input[i].scan[0] = st;
448 if (yscan <= MIDSCN) /* hit bottom? */
449 continue;
450 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
451 eputs(input[i].name);
452 eputs(": read error\n");
453 quit(1);
454 }
455 for (j = 0; j < xmax; j++) /* adjust color */
456 multcolor(st[j], input[i].coef);
457 }
458 }
459
460
461 static double
462 l_expos( /* return picture exposure */
463 char *nam
464 )
465 {
466 int fn, n;
467 double d;
468
469 d = argument(1);
470 if (d <= -0.5 || d >= nfiles+0.5) {
471 errno = EDOM;
472 return(0.0);
473 }
474 if (d < 0.5)
475 return((double)nfiles);
476 fn = d - 0.5;
477 if (nam == vbrtexp)
478 return((*ourbright)(input[fn].expos));
479 n = 3;
480 while (n--)
481 if (nam == vcolexp[n])
482 return(colval(input[fn].expos,n));
483 eputs("Bad call to l_expos()!\n");
484 quit(1);
485 return 1; /* pro forma return */
486 }
487
488
489 static double
490 l_pixaspect(char *nm) /* return pixel aspect ratio */
491 {
492 int fn;
493 double d;
494
495 d = argument(1);
496 if (d <= -0.5 || d >= nfiles+0.5) {
497 errno = EDOM;
498 return(0.0);
499 }
500 if (d < 0.5)
501 return((double)nfiles);
502 fn = d - 0.5;
503 return(input[fn].pa);
504 }
505
506
507 static double
508 l_colin( /* return color value for picture */
509 char *nam
510 )
511 {
512 int fn;
513 int n, xoff, yoff;
514 double d;
515
516 d = argument(1);
517 if (d <= -0.5 || d >= nfiles+0.5) {
518 errno = EDOM;
519 return(0.0);
520 }
521 if (d < 0.5)
522 return((double)nfiles);
523 fn = d - 0.5;
524 xoff = yoff = 0;
525 n = nargum();
526 if (n >= 2) {
527 d = argument(2);
528 if (d < 0.0) {
529 xoff = d-.5;
530 if (xscan+xoff < 0)
531 xoff = -xscan;
532 } else {
533 xoff = d+.5;
534 if (xscan+xoff >= xmax)
535 xoff = xmax-1-xscan;
536 }
537 }
538 if (n >= 3) {
539 d = argument(3);
540 if (d < 0.0) {
541 yoff = d-.5;
542 if (yoff+MIDSCN < 0)
543 yoff = -MIDSCN;
544 if (yscan+yoff < 0)
545 yoff = -yscan;
546 } else {
547 yoff = d+.5;
548 if (yoff+MIDSCN >= WINSIZ)
549 yoff = WINSIZ-1-MIDSCN;
550 if (yscan+yoff >= ymax)
551 yoff = ymax-1-yscan;
552 }
553 }
554 if (nam == vbrtin)
555 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
556 n = 3;
557 while (n--)
558 if (nam == vcolin[n])
559 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
560 eputs("Bad call to l_colin()!\n");
561 quit(1);
562 return 1; /* pro forma return */
563 }
564
565
566 static double
567 l_ray( /* return ray origin or direction */
568 char *nam
569 )
570 {
571 static unsigned long ltick[MAXINP];
572 static FVECT lorg[MAXINP], ldir[MAXINP];
573 static double ldist[MAXINP];
574 RREAL loc[2];
575 double d;
576 int fn;
577 int i;
578
579 d = argument(1);
580 if (d <= -0.5 || d >= nfiles+0.5) {
581 errno = EDOM;
582 return(0.0);
583 }
584 if (d < 0.5)
585 return((double)nfiles);
586 fn = d - 0.5;
587 if (ltick[fn] != eclock) { /* need to compute? */
588 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
589 ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
590 ldist[fn] = -1.0;
591 if (input[fn].vw.type == 0)
592 errno = EDOM;
593 else {
594 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
595 ldist[fn] = viewray(lorg[fn], ldir[fn],
596 &input[fn].vw, loc[0], loc[1]);
597 }
598 ltick[fn] = eclock;
599 }
600 if (nam == vray[i=6])
601 return(ldist[fn]);
602 while (i--)
603 if (nam == vray[i])
604 return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
605 eputs("Bad call to l_ray()!\n");
606 quit(1);
607 return 1; /* pro forma return */
608 }
609
610
611 static double
612 l_psize(char *nm) /* compute pixel size in steradians */
613 {
614 static unsigned long ltick[MAXINP];
615 static double psize[MAXINP];
616 FVECT dir0, org, dirx, diry;
617 RREAL locx[2], locy[2];
618 double d;
619 int fn;
620 int i;
621
622 d = argument(1);
623 if (d <= -0.5 || d >= nfiles+0.5) {
624 errno = EDOM;
625 return(0.0);
626 }
627 if (d < 0.5)
628 return((double)nfiles);
629 fn = d - 0.5;
630 if (ltick[fn] != eclock) { /* need to compute? */
631 psize[fn] = 0.0;
632 if (input[fn].vw.type == 0)
633 errno = EDOM;
634 else if (input[fn].vw.type != VT_PAR &&
635 funvalue(vray[6], 1, &d) >= -FTINY) {
636 for (i = 0; i < 3; i++)
637 dir0[i] = funvalue(vray[3+i], 1, &d);
638 pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
639 pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
640 if (viewray(org, dirx, &input[fn].vw,
641 locx[0], locx[1]) >= -FTINY &&
642 viewray(org, diry, &input[fn].vw,
643 locy[0], locy[1]) >= -FTINY) {
644 /* approximate solid angle */
645 for (i = 0; i < 3; i++) {
646 dirx[i] -= dir0[i];
647 diry[i] -= dir0[i];
648 }
649 fcross(dir0, dirx, diry);
650 psize[fn] = VLEN(dir0);
651 }
652 }
653 ltick[fn] = eclock;
654 }
655 return(psize[fn]);
656 }
657
658
659 extern void
660 wputs(char *msg)
661 {
662 if (!nowarn)
663 eputs(msg);
664 }
665
666
667 extern void
668 eputs(char *msg)
669 {
670 fputs(msg, stderr);
671 }
672
673
674 extern void
675 quit(int code) /* exit gracefully */
676 {
677 int i;
678 /* close input files */
679 for (i = 0; i < nfiles; i++)
680 if (input[i].name == Command)
681 pclose(input[i].fp);
682 else
683 fclose(input[i].fp);
684 exit(code);
685 }
