root/radiance/ray/src/px/pcomb.c
Revision: 2.26
Committed: Mon Jul 21 22:30:18 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: pcomb.c,v 2.25 2003/06/26 00:58:10 schorsch Exp $";
5 * Combine picture files according to calcomp functions.
6 *
7 * 1/4/89
8 */
9
10 #include "standard.h"
11 #include "platform.h"
12 #include "color.h"
13 #include "calcomp.h"
14 #include "view.h"
15
16 #define MAXINP 32 /* maximum number of input files */
17 #define WINSIZ 64 /* scanline window size */
18 #define MIDSCN ((WINSIZ-1)/2+1)
19
20 struct {
21 char *name; /* file or command name */
22 FILE *fp; /* stream pointer */
23 VIEW vw; /* view for picture */
24 RESOLU rs; /* image resolution and orientation */
25 float pa; /* pixel aspect ratio */
26 COLOR *scan[WINSIZ]; /* input scanline window */
27 COLOR coef; /* coefficient */
28 COLOR expos; /* recorded exposure */
29 } input[MAXINP]; /* input pictures */
30
31 int nfiles; /* number of input files */
32
33 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
34
35 char Command[] = "<Command>";
36 char vcolin[3][4] = {"ri", "gi", "bi"};
37 char vcolout[3][4] = {"ro", "go", "bo"};
38 char vbrtin[] = "li";
39 char vbrtout[] = "lo";
40 char vcolexp[3][4] = {"re", "ge", "be"};
41 char vbrtexp[] = "le";
42 char vpixaspect[] = "pa";
43
44 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
45
46 char vpsize[] = "S";
47
48 char vnfiles[] = "nfiles";
49 char vwhteff[] = "WE";
50 char vxmax[] = "xmax";
51 char vymax[] = "ymax";
52 char vxres[] = "xres";
53 char vyres[] = "yres";
54 char vxpos[] = "x";
55 char vypos[] = "y";
56
57 int nowarn = 0; /* no warning messages? */
58
59 int xmax = 0, ymax = 0; /* input resolution */
60
61 int xscan, yscan; /* input position */
62
63 int xres, yres; /* output resolution */
64
65 int xpos, ypos; /* output position */
66
67 char *progname; /* global argv[0] */
68
69 int wrongformat = 0;
70 int gotview;
71
72 FILE *popen();
73
74 extern char *emalloc();
75
76
77 main(argc, argv)
78 int argc;
79 char *argv[];
80 {
81 int original;
82 double f;
83 int a, i;
84 SET_DEFAULT_BINARY();
85 SET_FILE_BINARY(stdin);
86 SET_FILE_BINARY(stdout);
87 progname = argv[0];
88 /* scan options */
89 for (a = 1; a < argc; a++) {
90 if (argv[a][0] == '-')
91 switch (argv[a][1]) {
92 case 'x':
93 case 'y':
94 a++;
95 continue;
96 case 'w':
97 nowarn = !nowarn;
98 continue;
99 case 'f':
100 case 'e':
101 a++;
102 continue;
103 }
104 break;
105 }
106 newheader("RADIANCE", stdout); /* start header */
107 fputnow(stdout);
108 /* process files */
109 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
110 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
111 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
112 input[nfiles].vw = stdview;
113 input[nfiles].pa = 1.0;
114 }
115 nfiles = 0;
116 original = 0;
117 for ( ; a < argc; a++) {
118 if (nfiles >= MAXINP) {
119 eputs(argv[0]);
120 eputs(": too many picture files\n");
121 quit(1);
122 }
123 if (argv[a][0] == '-')
124 switch (argv[a][1]) {
125 case '\0':
126 input[nfiles].name = "<stdin>";
127 input[nfiles].fp = stdin;
128 break;
129 case 'o':
130 original++;
131 continue;
132 case 's':
133 f = atof(argv[++a]);
134 scalecolor(input[nfiles].coef, f);
135 continue;
136 case 'c':
137 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
138 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
139 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
140 continue;
141 default:
142 goto usage;
143 }
144 else {
145 if (argv[a][0] == '!') {
146 input[nfiles].name = Command;
147 input[nfiles].fp = popen(argv[a]+1, "r");
148 } else {
149 input[nfiles].name = argv[a];
150 input[nfiles].fp = fopen(argv[a], "r");
151 }
152 if (input[nfiles].fp == NULL) {
153 perror(argv[a]);
154 quit(1);
155 }
156 }
157 checkfile();
158 if (original) {
159 colval(input[nfiles].coef,RED) /=
160 colval(input[nfiles].expos,RED);
161 colval(input[nfiles].coef,GRN) /=
162 colval(input[nfiles].expos,GRN);
163 colval(input[nfiles].coef,BLU) /=
164 colval(input[nfiles].expos,BLU);
165 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
166 }
167 nfiles++;
168 original = 0;
169 }
170 init(); /* set constants */
171 /* go back and get expressions */
172 for (a = 1; a < argc; a++) {
173 if (argv[a][0] == '-')
174 switch (argv[a][1]) {
175 case 'x':
176 varset(vxres, ':', eval(argv[++a]));
177 continue;
178 case 'y':
179 varset(vyres, ':', eval(argv[++a]));
180 continue;
181 case 'w':
182 continue;
183 case 'f':
184 fcompile(argv[++a]);
185 continue;
186 case 'e':
187 scompile(argv[++a], NULL, 0);
188 continue;
189 }
190 break;
191 }
192 /* set/get output resolution */
193 if (!vardefined(vxres))
194 varset(vxres, ':', (double)xmax);
195 if (!vardefined(vyres))
196 varset(vyres, ':', (double)ymax);
197 xres = varvalue(vxres) + .5;
198 yres = varvalue(vyres) + .5;
199 if (xres <= 0 || yres <= 0) {
200 eputs(argv[0]);
201 eputs(": illegal output resolution\n");
202 quit(1);
203 }
204 /* complete header */
205 printargs(argc, argv, stdout);
206 if (strcmp(ourfmt, PICFMT))
207 fputformat(ourfmt, stdout); /* print format if known */
208 putchar('\n');
209 fprtresolu(xres, yres, stdout);
210 /* combine pictures */
211 combine();
212 quit(0);
213 usage:
214 eputs("Usage: ");
215 eputs(argv[0]);
216 eputs(
217 " [-w][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] pic ..]\n");
218 quit(1);
219 }
220
221
222 tabputs(s) /* put out string preceded by a tab */
223 char *s;
224 {
225 char fmt[32];
226 double d;
227 COLOR ctmp;
228
229 if (isheadid(s)) /* header id */
230 return(0); /* don't echo */
231 if (formatval(fmt, s)) { /* check format */
232 if (globmatch(ourfmt, fmt)) {
233 wrongformat = 0;
234 strcpy(ourfmt, fmt);
235 } else
236 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
237 return(0); /* don't echo */
238 }
239 if (isexpos(s)) { /* exposure */
240 d = exposval(s);
241 scalecolor(input[nfiles].expos, d);
242 } else if (iscolcor(s)) { /* color correction */
243 colcorval(ctmp, s);
244 multcolor(input[nfiles].expos, ctmp);
245 } else if (isaspect(s))
246 input[nfiles].pa *= aspectval(s);
247 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
248 gotview++;
249 /* echo line */
250 putchar('\t');
251 return(fputs(s, stdout));
252 }
253
254
255 checkfile() /* ready a file */
256 {
257 register int i;
258 /* process header */
259 gotview = 0;
260 fputs(input[nfiles].name, stdout);
261 fputs(":\n", stdout);
262 getheader(input[nfiles].fp, tabputs, NULL);
263 if (wrongformat < 0) {
264 eputs(input[nfiles].name);
265 eputs(": not a Radiance picture\n");
266 quit(1);
267 }
268 if (wrongformat > 0) {
269 wputs(input[nfiles].name);
270 wputs(": warning -- incompatible picture format\n");
271 }
272 if (!gotview || setview(&input[nfiles].vw) != NULL)
273 input[nfiles].vw.type = 0;
274 if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
275 eputs(input[nfiles].name);
276 eputs(": bad picture size\n");
277 quit(1);
278 }
279 if (xmax == 0 && ymax == 0) {
280 xmax = scanlen(&input[nfiles].rs);
281 ymax = numscans(&input[nfiles].rs);
282 } else if (scanlen(&input[nfiles].rs) != xmax ||
283 numscans(&input[nfiles].rs) != ymax) {
284 eputs(input[nfiles].name);
285 eputs(": resolution mismatch\n");
286 quit(1);
287 }
288 /* allocate scanlines */
289 for (i = 0; i < WINSIZ; i++)
290 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
291 }
292
293
294 double
295 rgb_bright(clr)
296 COLOR clr;
297 {
298 return(bright(clr));
299 }
300
301
302 double
303 xyz_bright(clr)
304 COLOR clr;
305 {
306 return(clr[CIEY]);
307 }
308
309
310 double (*ourbright)() = rgb_bright;
311
312
313 init() /* perform final setup */
314 {
315 double l_colin(), l_expos(), l_pixaspect(), l_ray(), l_psize();
316 register int i;
317 /* define constants */
318 varset("PI", ':', PI);
319 varset(vnfiles, ':', (double)nfiles);
320 varset(vxmax, ':', (double)xmax);
321 varset(vymax, ':', (double)ymax);
322 /* set functions */
323 for (i = 0; i < 3; i++) {
324 funset(vcolexp[i], 1, ':', l_expos);
325 funset(vcolin[i], 1, '=', l_colin);
326 }
327 funset(vbrtexp, 1, ':', l_expos);
328 funset(vbrtin, 1, '=', l_colin);
329 funset(vpixaspect, 1, ':', l_pixaspect);
330 for (i = 0; i < 7; i++)
331 funset(vray[i], 1, '=', l_ray);
332 funset(vpsize, 1, '=', l_psize);
333 /* set brightness function */
334 if (!strcmp(ourfmt, CIEFMT)) {
335 varset(vwhteff, ':', 1.0);
336 ourbright = xyz_bright;
337 } else
338 varset(vwhteff, ':', WHTEFFICACY);
339 }
340
341
342 combine() /* combine pictures */
343 {
344 EPNODE *coldef[3], *brtdef;
345 COLOR *scanout;
346 double d;
347 register int i, j;
348 /* check defined variables */
349 for (j = 0; j < 3; j++) {
350 if (vardefined(vcolout[j]))
351 coldef[j] = eparse(vcolout[j]);
352 else
353 coldef[j] = NULL;
354 }
355 if (vardefined(vbrtout))
356 brtdef = eparse(vbrtout);
357 else
358 brtdef = NULL;
359 /* allocate scanline */
360 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
361 /* set input position */
362 yscan = ymax+MIDSCN;
363 /* combine files */
364 for (ypos = yres-1; ypos >= 0; ypos--) {
365 advance();
366 varset(vypos, '=', (double)ypos);
367 for (xpos = 0; xpos < xres; xpos++) {
368 xscan = (long)xpos*xmax/xres;
369 varset(vxpos, '=', (double)xpos);
370 eclock++;
371 if (brtdef != NULL) {
372 d = evalue(brtdef);
373 if (d < 0.0)
374 d = 0.0;
375 setcolor(scanout[xpos], d, d, d);
376 } else {
377 for (j = 0; j < 3; j++) {
378 if (coldef[j] != NULL) {
379 d = evalue(coldef[j]);
380 } else {
381 d = 0.0;
382 for (i = 0; i < nfiles; i++)
383 d += colval(input[i].scan[MIDSCN][xscan],j);
384 }
385 if (d < 0.0)
386 d = 0.0;
387 colval(scanout[xpos],j) = d;
388 }
389 }
390 }
391 if (fwritescan(scanout, xres, stdout) < 0) {
392 perror("write error");
393 quit(1);
394 }
395 }
396 efree((char *)scanout);
397 }
398
399
400 advance() /* read in data for next scanline */
401 {
402 int ytarget;
403 register COLOR *st;
404 register int i, j;
405
406 for (ytarget = (long)ypos*ymax/yres; yscan > ytarget; yscan--)
407 for (i = 0; i < nfiles; i++) {
408 st = input[i].scan[WINSIZ-1];
409 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
410 input[i].scan[j] = input[i].scan[j-1];
411 input[i].scan[0] = st;
412 if (yscan <= MIDSCN) /* hit bottom? */
413 continue;
414 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
415 eputs(input[i].name);
416 eputs(": read error\n");
417 quit(1);
418 }
419 if (fabs(colval(input[i].coef,RED)-1.0) > 1e-3 ||
420 fabs(colval(input[i].coef,GRN)-1.0) > 1e-3 ||
421 fabs(colval(input[i].coef,BLU)-1.0) > 1e-3)
422 for (j = 0; j < xmax; j++) /* adjust color */
423 multcolor(st[j], input[i].coef);
424 }
425 }
426
427
428 double
429 l_expos(nam) /* return picture exposure */
430 register char *nam;
431 {
432 register int fn, n;
433
434 fn = argument(1) - .5;
435 if (fn < 0 || fn >= nfiles)
436 return(1.0);
437 if (nam == vbrtexp)
438 return((*ourbright)(input[fn].expos));
439 n = 3;
440 while (n--)
441 if (nam == vcolexp[n])
442 return(colval(input[fn].expos,n));
443 eputs("Bad call to l_expos()!\n");
444 quit(1);
445 }
446
447
448 double
449 l_pixaspect() /* return pixel aspect ratio */
450 {
451 register int fn;
452
453 fn = argument(1) - .5;
454 if (fn < 0 || fn >= nfiles)
455 return(1.0);
456 return(input[fn].pa);
457 }
458
459
460 double
461 l_colin(nam) /* return color value for picture */
462 register char *nam;
463 {
464 int fn;
465 register int n, xoff, yoff;
466 double d;
467
468 fn = argument(1) - .5;
469 if (fn < 0 || fn >= nfiles) {
470 errno = EDOM;
471 return(0.0);
472 }
473 xoff = yoff = 0;
474 n = nargum();
475 if (n >= 2) {
476 d = argument(2);
477 if (d < 0.0) {
478 xoff = d-.5;
479 if (xscan+xoff < 0)
480 xoff = -xscan;
481 } else {
482 xoff = d+.5;
483 if (xscan+xoff >= xmax)
484 xoff = xmax-1-xscan;
485 }
486 }
487 if (n >= 3) {
488 d = argument(3);
489 if (d < 0.0) {
490 yoff = d-.5;
491 if (yoff+MIDSCN < 0)
492 yoff = -MIDSCN;
493 if (yscan+yoff < 0)
494 yoff = -yscan;
495 } else {
496 yoff = d+.5;
497 if (yoff+MIDSCN >= WINSIZ)
498 yoff = WINSIZ-1-MIDSCN;
499 if (yscan+yoff >= ymax)
500 yoff = ymax-1-yscan;
501 }
502 }
503 if (nam == vbrtin)
504 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
505 n = 3;
506 while (n--)
507 if (nam == vcolin[n])
508 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
509 eputs("Bad call to l_colin()!\n");
510 quit(1);
511 }
512
513
514 double
515 l_ray(nam) /* return ray origin or direction */
516 register char *nam;
517 {
518 static unsigned long ltick[MAXINP];
519 static FVECT lorg[MAXINP], ldir[MAXINP];
520 static double ldist[MAXINP];
521 RREAL loc[2];
522 int fn;
523 register int i;
524
525 fn = argument(1) - .5;
526 if (fn < 0 || fn >= nfiles) {
527 errno = EDOM;
528 return(0.0);
529 }
530 if (ltick[fn] != eclock) { /* need to compute? */
531 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
532 ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
533 ldist[fn] = -1.0;
534 if (input[fn].vw.type == 0)
535 errno = EDOM;
536 else {
537 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
538 ldist[fn] = viewray(lorg[fn], ldir[fn],
539 &input[fn].vw, loc[0], loc[1]);
540 }
541 ltick[fn] = eclock;
542 }
543 if (nam == vray[i=6])
544 return(ldist[fn]);
545 while (i--)
546 if (nam == vray[i])
547 return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
548 eputs("Bad call to l_ray()!\n");
549 quit(1);
550 }
551
552
553 double
554 l_psize() /* compute pixel size in steradians */
555 {
556 static unsigned long ltick[MAXINP];
557 static double psize[MAXINP];
558 FVECT dir0, org, dirx, diry;
559 RREAL locx[2], locy[2];
560 double d;
561 int fn;
562 register int i;
563
564 d = argument(1);
565 if (d < .5 || d >= nfiles+.5) {
566 errno = EDOM;
567 return(0.0);
568 }
569 fn = d - .5;
570 if (ltick[fn] != eclock) { /* need to compute? */
571 psize[fn] = 0.0;
572 if (input[fn].vw.type == 0)
573 errno = EDOM;
574 else if (input[fn].vw.type != VT_PAR &&
575 funvalue(vray[6], 1, &d) >= 0) {
576 for (i = 0; i < 3; i++)
577 dir0[i] = funvalue(vray[3+i], 1, &d);
578 pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
579 pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
580 if (viewray(org, dirx, &input[fn].vw,
581 locx[0], locx[1]) >= 0 &&
582 viewray(org, diry, &input[fn].vw,
583 locy[0], locy[1]) >= 0) {
584 /* approximate solid angle */
585 for (i = 0; i < 3; i++) {
586 dirx[i] -= dir0[i];
587 diry[i] -= dir0[i];
588 }
589 fcross(dir0, dirx, diry);
590 psize[fn] = sqrt(DOT(dir0,dir0));
591 }
592 }
593 ltick[fn] = eclock;
594 }
595 return(psize[fn]);
596 }
597
598
599 void
600 wputs(msg)
601 char *msg;
602 {
603 if (!nowarn)
604 eputs(msg);
605 }
606
607
608 void
609 eputs(msg)
610 char *msg;
611 {
612 fputs(msg, stderr);
613 }
614
615
616 void
617 quit(code) /* exit gracefully */
618 int code;
619 {
620 register int i;
621 /* close input files */
622 for (i = 0; i < nfiles; i++)
623 if (input[i].name == Command)
624 pclose(input[i].fp);
625 else
626 fclose(input[i].fp);
627 exit(code);
628 }
