--- ray/src/px/pcomb.c 1991/04/18 08:05:57 1.8 +++ ray/src/px/pcomb.c 1991/05/24 14:46:14 1.15 @@ -19,11 +19,15 @@ static char SCCSid[] = "$SunId$ LBL"; #include "calcomp.h" #define MAXINP 32 /* maximum number of input files */ +#define WINSIZ 9 /* scanline window size */ +#define MIDSCN 4 /* current scan position */ +#define BRT (-1) /* special index for brightness */ + struct { char *name; /* file name */ FILE *fp; /* stream pointer */ - COLOR *scan; /* input scanline */ + COLOR *scan[WINSIZ]; /* input scanline window */ COLOR coef; /* coefficient */ } input[MAXINP]; /* input pictures */ @@ -31,8 +35,10 @@ int nfiles; /* number of input files */ char *vcolin[3] = {"ri", "gi", "bi"}; char *vcolout[3] = {"ro", "go", "bo"}; -#define vbrtin "li" -#define vbrtout "lo" +char vbrtin[] = "li"; +char vbrtout[] = "lo"; +char *vcolcoef[3] = {"rc", "gc", "bc"}; +char vbrtcoef[] = "lc"; #define vnfiles "nfiles" #define vxres "xres" @@ -42,60 +48,44 @@ char *vcolout[3] = {"ro", "go", "bo"}; int nowarn = 0; /* no warning messages? */ +int original = 0; /* origninal values? */ + int xres=0, yres=0; /* picture resolution */ int xpos, ypos; /* picture position */ +int wrongformat = 0; -tputs(s) /* put out string preceded by a tab */ -char *s; -{ - putchar('\t'); - fputs(s, stdout); -} - main(argc, argv) int argc; char *argv[]; { - extern double l_redin(), l_grnin(), l_bluin(), l_brtin(), atof(); double f; - int a; - - funset(vcolin[RED], 1, l_redin); - funset(vcolin[GRN], 1, l_grnin); - funset(vcolin[BLU], 1, l_bluin); - funset(vbrtin, 1, l_brtin); - - for (a = 1; a < argc; a++) + int a, i; + /* scan options */ + for (a = 1; a < argc; a++) { if (argv[a][0] == '-') switch (argv[a][1]) { - case '\0': - case 's': - case 'c': - goto getfiles; case 'x': xres = atoi(argv[++a]); - break; + continue; case 'y': yres = atoi(argv[++a]); - break; + continue; case 'w': nowarn = !nowarn; - break; + continue; + case 'o': + original = !original; + continue; case 'f': - fcompile(argv[++a]); - break; case 'e': - scompile(argv[++a], NULL, 0); - break; - default: - goto usage; + continue; } - else - break; -getfiles: + break; + } + /* process files */ for (nfiles = 0; nfiles < MAXINP; nfiles++) setcolor(input[nfiles].coef, 1.0, 1.0, 1.0); nfiles = 0; @@ -131,12 +121,86 @@ getfiles: quit(1); } } - fputs(input[nfiles].name, stdout); + nfiles++; + } + initfiles(); /* initialize files and variables */ + /* go back and get expressions */ + for (a = 1; a < argc; a++) { + if (argv[a][0] == '-') + switch (argv[a][1]) { + case 'x': + case 'y': + case 'w': + case 'o': + continue; + case 'f': + fcompile(argv[++a]); + continue; + case 'e': + scompile(argv[++a], NULL, 0); + continue; + } + break; + } + /* complete header */ + printargs(argc, argv, stdout); + fputformat(COLRFMT, stdout); + putchar('\n'); + fputresolu(YMAJOR|YDECR, xres, yres, stdout); + /* combine pictures */ + combine(); + quit(0); +usage: + eputs("Usage: "); + eputs(argv[0]); + eputs( +" [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-s f][-c r g b] pic ..]\n"); + quit(1); +} + + +tputs(s) /* put out string preceded by a tab */ +char *s; +{ + char fmt[32]; + double d; + COLOR ctmp; + + if (isformat(s)) { /* check format */ + formatval(fmt, s); + wrongformat = strcmp(fmt, COLRFMT); + } else if (original && isexpos(s)) { /* exposure */ + d = 1.0/exposval(s); + scalecolor(input[nfiles].coef, d); + } else if (original && iscolcor(s)) { /* color correction */ + colcorval(ctmp, s); + colval(input[nfiles].coef,RED) /= colval(ctmp,RED); + colval(input[nfiles].coef,GRN) /= colval(ctmp,GRN); + colval(input[nfiles].coef,BLU) /= colval(ctmp,BLU); + } else { /* echo unaffected line */ + putchar('\t'); + fputs(s, stdout); + } + +} + + +initfiles() /* ready files and set variables */ +{ + double l_colin(), l_coef(); + register int n, i; + /* process picture headers */ + for (n = 0; n < nfiles; n++) { + fputs(input[n].name, stdout); fputs(":\n", stdout); - getheader(input[nfiles].fp, tputs); - if (fgetresolu(&xpos, &ypos, input[nfiles].fp) != - (YMAJOR|YDECR)) { - eputs(input[nfiles].name); + getheader(input[n].fp, tputs, NULL); + if (wrongformat) { + eputs(input[n].name); + eputs(": not in Radiance picture format\n"); + quit(1); + } + if (fgetresolu(&xpos, &ypos, input[n].fp) != (YMAJOR|YDECR)) { + eputs(input[n].name); eputs(": bad picture size\n"); quit(1); } @@ -144,23 +208,27 @@ getfiles: xres = xpos; yres = ypos; } else if (xpos != xres || ypos != yres) { - eputs(argv[0]); + eputs(input[n].name); eputs(": resolution mismatch\n"); quit(1); } - input[nfiles].scan = (COLOR *)emalloc(xres*sizeof(COLOR)); - nfiles++; + for (i = 0; i < WINSIZ; i++) + input[n].scan[i] = (COLOR *)emalloc(xres*sizeof(COLOR)); } - printargs(argc, argv, stdout); - putchar('\n'); - fputresolu(YMAJOR|YDECR, xres, yres, stdout); - combine(); - quit(0); -usage: - eputs("Usage: "); - eputs(argv[0]); -eputs(" [-w][-x xr][-y yr][-e expr][-f file] [ [-s f][-c r g b] picture ..]\n"); - quit(1); + /* prime input */ + for (ypos = yres+(MIDSCN-1); ypos >= yres; ypos--) + advance(); + /* define constants */ + varset(vnfiles, ':', (double)nfiles); + varset(vxres, ':', (double)xres); + varset(vyres, ':', (double)yres); + /* set functions */ + for (i = 0; i < 3; i++) { + funset(vcolcoef[i], 1, ':', l_coef); + funset(vcolin[i], 1, '=', l_colin); + } + funset(vbrtcoef, 1, ':', l_coef); + funset(vbrtin, 1, '=', l_colin); } @@ -181,23 +249,14 @@ combine() /* combine pictures */ brtdef = eparse(vbrtout); else brtdef = NULL; - /* predefine variables */ - varset(vnfiles, (double)nfiles); - varset(vxres, (double)xres); - varset(vyres, (double)yres); /* allocate scanline */ scanout = (COLOR *)emalloc(xres*sizeof(COLOR)); /* combine files */ for (ypos = yres-1; ypos >= 0; ypos--) { - for (i = 0; i < nfiles; i++) - if (freadscan(input[i].scan, xres, input[i].fp) < 0) { - eputs(input[i].name); - eputs(": read error\n"); - quit(1); - } - varset(vypos, (double)ypos); + advance(); + varset(vypos, '=', (double)ypos); for (xpos = 0; xpos < xres; xpos++) { - varset(vxpos, (double)xpos); + varset(vxpos, '=', (double)xpos); eclock++; if (brtdef != NULL) { d = evalue(brtdef); @@ -207,16 +266,15 @@ combine() /* combine pictures */ } else { for (j = 0; j < 3; j++) { if (coldef[j] != NULL) { - colval(scanout[xpos],j) = evalue(coldef[j]); + d = evalue(coldef[j]); } else { - colval(scanout[xpos],j) = 0.0; + d = 0.0; for (i = 0; i < nfiles; i++) - colval(scanout[xpos],j) += - colval(input[i].coef,j) * - colval(input[i].scan[xpos],j); + d += colval(input[i].scan[MIDSCN][xpos],j); } - if (colval(scanout[xpos],j) < 0.0) - colval(scanout[xpos],j) = 0.0; + if (d < 0.0) + d = 0.0; + colval(scanout[xpos],j) = d; } } } @@ -229,54 +287,107 @@ combine() /* combine pictures */ } -double -colin(fn, ci) /* return color value for picture */ -register int fn, ci; +advance() /* read in next scanline */ { - if (fn == 0) - return((double)nfiles); - if (fn < 1 || fn > nfiles) { - errno = EDOM; - return(0.0); + register COLOR *st; + register int i, j; + + for (i = 0; i < nfiles; i++) { + st = input[i].scan[WINSIZ-1]; + for (j = WINSIZ-1; j > 0; j--) /* rotate window */ + input[i].scan[j] = input[i].scan[j-1]; + input[i].scan[0] = st; + if (ypos < MIDSCN) /* hit bottom */ + continue; + if (freadscan(st, xres, input[i].fp) < 0) { + eputs(input[i].name); + eputs(": read error\n"); + quit(1); + } + for (j = 0; j < xres; j++) /* adjust color */ + multcolor(st[j], input[i].coef); } - return(colval(input[fn-1].scan[xpos],ci)); } double -l_redin() /* get red color */ +l_coef(nam) /* return picture coefficients */ +register char *nam; { - return(colin((int)(argument(1)+.5), RED)); -} + register int fn, n; + double d; - -double -l_grnin() /* get green color */ -{ - return(colin((int)(argument(1)+.5), GRN)); + fn = (d = argument(1)) - .5; + if (d <= -.5 || fn >= nfiles) { + errno = EDOM; + return(0.0); + } + if (d < .5) + return((double)nfiles); + if (nam == vbrtcoef) + return(bright(input[fn].coef)); + n = 3; + while (n--) + if (nam == vcolcoef[n]) + return(colval(input[fn].coef,n)); + eputs("Bad call to l_coef()!\n"); + quit(1); } double -l_bluin() /* get blue color */ +l_colin(nam) /* return color value for picture */ +register char *nam; { - return(colin((int)(argument(1)+.5), BLU)); -} + int fn; + register int n, xoff, yoff; + double d; - -double -l_brtin() /* get brightness value */ -{ - register int fn; - - fn = argument(1)+.5; - if (fn == 0) - return((double)nfiles); - if (fn < 1 || fn > nfiles) { + fn = (d = argument(1)) - .5; + if (d <= -.5 || fn >= nfiles) { errno = EDOM; return(0.0); } - return(bright(input[fn-1].scan[xpos])); + if (d < .5) + return((double)nfiles); + xoff = yoff = 0; + n = nargum(); + if (n >= 2) { + d = argument(2); + if (d < 0.0) { + xoff = d-.5; + if (xpos+xoff < 0) + xoff = -xpos; + } else { + xoff = d+.5; + if (xpos+xoff >= xres) + xoff = xres-1-xpos; + } + } + if (n >= 3) { + d = argument(3); + if (d < 0.0) { + yoff = d-.5; + if (yoff+MIDSCN < 0) + yoff = -MIDSCN; + if (ypos+yoff < 0) + yoff = -ypos; + } else { + yoff = d+.5; + if (yoff+MIDSCN >= WINSIZ) + yoff = WINSIZ-1-MIDSCN; + if (ypos+yoff >= yres) + yoff = yres-1-ypos; + } + } + if (nam == vbrtin) + return(bright(input[fn].scan[MIDSCN+yoff][xpos+xoff])); + n = 3; + while (n--) + if (nam == vcolin[n]) + return(colval(input[fn].scan[MIDSCN+yoff][xpos+xoff],n)); + eputs("Bad call to l_colin()!\n"); + quit(1); }
