| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pcomb.c,v 2.54 2022/03/22 15:14:42 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Combine picture files according to calcomp functions.
| 6 |
| 7 |
* 1/4/89
| 8 |
| 9 |
| 10 |
#include "platform.h"
| 11 |
#include "standard.h"
| 12 |
#include "paths.h"
| 13 |
#include "color.h"
| 14 |
#include "calcomp.h"
| 15 |
#include "view.h"
| 16 |
| 17 |
#define MAXINP 1024 /* maximum number of input files */
| 18 |
#define WINSIZ 127 /* scanline window size */
| 19 |
#define MIDSCN ((WINSIZ-1)/2+1)
| 20 |
| 21 |
struct {
| 22 |
char *name; /* file or command name */
| 23 |
FILE *fp; /* stream pointer */
| 24 |
VIEW vw; /* view for picture */
| 25 |
RESOLU rs; /* image resolution and orientation */
| 26 |
float pa; /* pixel aspect ratio */
| 27 |
COLOR *scan[WINSIZ]; /* input scanline window */
| 28 |
COLOR coef; /* coefficient */
| 29 |
COLOR expos; /* recorded exposure */
| 30 |
} input[MAXINP]; /* input pictures */
| 31 |
| 32 |
int nfiles; /* number of input files */
| 33 |
| 34 |
VIEW *commvp = NULL; /* common view parameters */
| 35 |
| 36 |
char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
| 37 |
| 38 |
char StandardInput[] = "<stdin>";
| 39 |
char Command[] = "<Command>";
| 40 |
char vcolin[3][4] = {"ri", "gi", "bi"};
| 41 |
char vcolout[3][4] = {"ro", "go", "bo"};
| 42 |
char vbrtin[] = "li";
| 43 |
char vbrtout[] = "lo";
| 44 |
char vcolexp[3][4] = {"re", "ge", "be"};
| 45 |
char vbrtexp[] = "le";
| 46 |
char vpixaspect[] = "pa";
| 47 |
| 48 |
char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
| 49 |
| 50 |
char vpsize[] = "S";
| 51 |
| 52 |
char vnfiles[] = "nfiles";
| 53 |
char vwhteff[] = "WE";
| 54 |
char vxmax[] = "xmax";
| 55 |
char vymax[] = "ymax";
| 56 |
char vxres[] = "xres";
| 57 |
char vyres[] = "yres";
| 58 |
char vxpos[] = "x";
| 59 |
char vypos[] = "y";
| 60 |
| 61 |
int nowarn = 0; /* no warning messages? */
| 62 |
| 63 |
int xmax = 0, ymax = 0; /* input resolution */
| 64 |
| 65 |
int xscan, yscan; /* input position */
| 66 |
| 67 |
int xres, yres; /* output resolution */
| 68 |
| 69 |
int xpos, ypos; /* output position */
| 70 |
| 71 |
char *progname; /* global argv[0] */
| 72 |
| 73 |
int echoheader = 1;
| 74 |
int wrongformat = 0;
| 75 |
int gotview;
| 76 |
| 77 |
| 78 |
static gethfunc headline;
| 79 |
static void checkfile(int orig);
| 80 |
static double rgb_bright(COLOR clr);
| 81 |
static double xyz_bright(COLOR clr);
| 82 |
static void init(void);
| 83 |
static void combine(void);
| 84 |
static void advance(void);
| 85 |
static double l_expos(char *nam);
| 86 |
static double l_pixaspect(char *nm);
| 87 |
static double l_colin(char *nam);
| 88 |
static double l_ray(char *nam);
| 89 |
static double l_psize(char *nm);
| 90 |
| 91 |
| 92 |
int
| 93 |
main(
| 94 |
int argc,
| 95 |
char *argv[]
| 96 |
| 97 |
| 98 |
int original;
| 99 |
double f;
| 100 |
int a;
| 101 |
| 102 |
SET_DEFAULT_BINARY();
| 103 |
SET_FILE_BINARY(stdin);
| 104 |
SET_FILE_BINARY(stdout);
| 105 |
progname = argv[0];
| 106 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 107 |
esupport &= ~(E_OUTCHAN|E_INCHAN);
| 108 |
/* scan options */
| 109 |
for (a = 1; a < argc; a++) {
| 110 |
if (argv[a][0] == '-')
| 111 |
switch (argv[a][1]) {
| 112 |
case 'x':
| 113 |
case 'y':
| 114 |
a++;
| 115 |
continue;
| 116 |
case 'w':
| 117 |
nowarn = !nowarn;
| 118 |
continue;
| 119 |
case 'h':
| 120 |
echoheader = !echoheader;
| 121 |
continue;
| 122 |
case 'f':
| 123 |
case 'e':
| 124 |
a++;
| 125 |
continue;
| 126 |
| 127 |
break;
| 128 |
| 129 |
newheader("RADIANCE", stdout); /* start header */
| 130 |
fputnow(stdout);
| 131 |
/* process files */
| 132 |
for (nfiles = 0; nfiles < MAXINP; nfiles++) {
| 133 |
setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
| 134 |
setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
| 135 |
input[nfiles].vw = stdview;
| 136 |
input[nfiles].pa = 1.0;
| 137 |
| 138 |
nfiles = 0;
| 139 |
original = 0;
| 140 |
for ( ; a < argc; a++) {
| 141 |
if (nfiles >= MAXINP) {
| 142 |
eputs(argv[0]);
| 143 |
eputs(": too many picture files\n");
| 144 |
quit(1);
| 145 |
| 146 |
| 147 |
| 148 |
case '\0':
| 149 |
input[nfiles].name = StandardInput;
| 150 |
input[nfiles].fp = stdin;
| 151 |
break;
| 152 |
case 'o':
| 153 |
original++;
| 154 |
continue;
| 155 |
case 's':
| 156 |
f = atof(argv[++a]);
| 157 |
scalecolor(input[nfiles].coef, f);
| 158 |
continue;
| 159 |
case 'c':
| 160 |
colval(input[nfiles].coef,RED)*=atof(argv[++a]);
| 161 |
colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
| 162 |
colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
| 163 |
continue;
| 164 |
default:
| 165 |
goto usage;
| 166 |
| 167 |
else {
| 168 |
if (argv[a][0] == '!') {
| 169 |
input[nfiles].name = Command;
| 170 |
input[nfiles].fp = popen(argv[a]+1, "r");
| 171 |
} else {
| 172 |
input[nfiles].name = argv[a];
| 173 |
input[nfiles].fp = fopen(argv[a], "r");
| 174 |
| 175 |
if (input[nfiles].fp == NULL) {
| 176 |
perror(argv[a]);
| 177 |
quit(1);
| 178 |
| 179 |
| 180 |
checkfile(original);
| 181 |
nfiles++;
| 182 |
original = 0;
| 183 |
| 184 |
init(); /* set constants */
| 185 |
/* go back and get expressions */
| 186 |
| 187 |
char *fpath;
| 188 |
| 189 |
| 190 |
case 'x':
| 191 |
varset(vxres, ':', eval(argv[++a]));
| 192 |
continue;
| 193 |
case 'y':
| 194 |
varset(vyres, ':', eval(argv[++a]));
| 195 |
continue;
| 196 |
case 'w':
| 197 |
continue;
| 198 |
case 'h':
| 199 |
continue;
| 200 |
case 'f':
| 201 |
fpath = getpath(argv[++a], getrlibpath(), 0);
| 202 |
if (fpath == NULL) {
| 203 |
eputs(argv[0]);
| 204 |
eputs(": cannot find file '");
| 205 |
eputs(argv[a]);
| 206 |
eputs("'\n");
| 207 |
quit(1);
| 208 |
| 209 |
fcompile(fpath);
| 210 |
continue;
| 211 |
case 'e':
| 212 |
scompile(argv[++a], NULL, 0);
| 213 |
continue;
| 214 |
| 215 |
break;
| 216 |
| 217 |
/* get output resolution */
| 218 |
xres = varvalue(vxres) + .5;
| 219 |
yres = varvalue(vyres) + .5;
| 220 |
if (xres <= 0 || yres <= 0) {
| 221 |
eputs(argv[0]);
| 222 |
eputs(": illegal output resolution\n");
| 223 |
quit(1);
| 224 |
| 225 |
/* complete header */
| 226 |
printargs(argc, argv, stdout);
| 227 |
if (commvp != NULL) {
| 228 |
fputs(VIEWSTR, stdout);
| 229 |
fprintview(commvp, stdout);
| 230 |
fputc('\n', stdout);
| 231 |
| 232 |
if (strcmp(ourfmt, PICFMT))
| 233 |
fputformat(ourfmt, stdout); /* print format if known */
| 234 |
putchar('\n');
| 235 |
fprtresolu(xres, yres, stdout);
| 236 |
/* combine pictures */
| 237 |
combine();
| 238 |
quit(0);
| 239 |
usage:
| 240 |
eputs("Usage: ");
| 241 |
eputs(argv[0]);
| 242 |
eputs(
| 243 |
" [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n");
| 244 |
quit(1);
| 245 |
return 1; /* pro forma return */
| 246 |
| 247 |
| 248 |
| 249 |
static int
| 250 |
headline( /* check header line & echo if requested */
| 251 |
char *s,
| 252 |
void *p
| 253 |
| 254 |
| 255 |
int orig = *(int *)p;
| 256 |
char fmt[MAXFMTLEN];
| 257 |
double d;
| 258 |
COLOR ctmp;
| 259 |
| 260 |
if (isheadid(s)) /* header id */
| 261 |
return(0); /* don't echo */
| 262 |
if (formatval(fmt, s)) { /* check format */
| 263 |
if (globmatch(ourfmt, fmt)) {
| 264 |
wrongformat = 0;
| 265 |
strcpy(ourfmt, fmt);
| 266 |
} else
| 267 |
wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
| 268 |
| 269 |
| 270 |
if (orig) { /* undo exposure? */
| 271 |
if (isexpos(s)) {
| 272 |
d = 1./exposval(s);
| 273 |
scalecolor(input[nfiles].coef, d);
| 274 |
| 275 |
| 276 |
if (iscolcor(s)) {
| 277 |
int i;
| 278 |
colcorval(ctmp, s);
| 279 |
for (i = 3; i--; )
| 280 |
colval(input[nfiles].coef,i) /= colval(ctmp,i);
| 281 |
| 282 |
| 283 |
} else if (isexpos(s)) { /* record exposure? */
| 284 |
d = exposval(s);
| 285 |
scalecolor(input[nfiles].expos, d);
| 286 |
} else if (iscolcor(s)) {
| 287 |
colcorval(ctmp, s);
| 288 |
multcolor(input[nfiles].expos, ctmp);
| 289 |
| 290 |
if (isaspect(s))
| 291 |
input[nfiles].pa *= aspectval(s);
| 292 |
else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
| 293 |
gotview++;
| 294 |
| 295 |
if (echoheader) { /* echo line */
| 296 |
putchar('\t');
| 297 |
return(fputs(s, stdout));
| 298 |
| 299 |
return(0);
| 300 |
| 301 |
| 302 |
| 303 |
static void
| 304 |
checkfile(int orig) /* ready a file */
| 305 |
| 306 |
int i;
| 307 |
/* process header */
| 308 |
gotview = 0;
| 309 |
if (echoheader) {
| 310 |
fputs(input[nfiles].name, stdout);
| 311 |
fputs(":\n", stdout);
| 312 |
| 313 |
getheader(input[nfiles].fp, headline, &orig);
| 314 |
if (wrongformat < 0) {
| 315 |
eputs(input[nfiles].name);
| 316 |
eputs(": not a Radiance picture\n");
| 317 |
quit(1);
| 318 |
| 319 |
if (wrongformat > 0) {
| 320 |
wputs(input[nfiles].name);
| 321 |
wputs(": warning -- incompatible picture format\n");
| 322 |
| 323 |
if (!gotview || setview(&input[nfiles].vw) != NULL)
| 324 |
input[nfiles].vw.type = 0;
| 325 |
else if (commvp == NULL)
| 326 |
commvp = &input[nfiles].vw;
| 327 |
if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
| 328 |
| 329 |
eputs(": bad picture size\n");
| 330 |
quit(1);
| 331 |
| 332 |
if (xmax == 0 && ymax == 0) {
| 333 |
xmax = scanlen(&input[nfiles].rs);
| 334 |
ymax = numscans(&input[nfiles].rs);
| 335 |
} else if (scanlen(&input[nfiles].rs) != xmax ||
| 336 |
numscans(&input[nfiles].rs) != ymax) {
| 337 |
| 338 |
eputs(": resolution mismatch\n");
| 339 |
quit(1);
| 340 |
| 341 |
/* allocate scanlines */
| 342 |
for (i = 0; i < WINSIZ; i++)
| 343 |
input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
| 344 |
| 345 |
| 346 |
| 347 |
static double
| 348 |
rgb_bright(
| 349 |
COLOR clr
| 350 |
| 351 |
| 352 |
return(bright(clr));
| 353 |
| 354 |
| 355 |
| 356 |
static double
| 357 |
xyz_bright(
| 358 |
COLOR clr
| 359 |
| 360 |
| 361 |
return(clr[CIEY]);
| 362 |
| 363 |
| 364 |
| 365 |
double (*ourbright)() = rgb_bright;
| 366 |
| 367 |
| 368 |
static void
| 369 |
init(void) /* perform final setup */
| 370 |
| 371 |
int i;
| 372 |
/* define constants */
| 373 |
varset("PI", ':', PI);
| 374 |
varset(vnfiles, ':', (double)nfiles);
| 375 |
varset(vxmax, ':', (double)xmax);
| 376 |
varset(vymax, ':', (double)ymax);
| 377 |
/* set functions */
| 378 |
for (i = 0; i < 3; i++) {
| 379 |
funset(vcolexp[i], 1, ':', l_expos);
| 380 |
funset(vcolin[i], 1, '=', l_colin);
| 381 |
| 382 |
funset(vbrtexp, 1, ':', l_expos);
| 383 |
funset(vbrtin, 1, '=', l_colin);
| 384 |
funset(vpixaspect, 1, ':', l_pixaspect);
| 385 |
for (i = 0; i < 7; i++)
| 386 |
funset(vray[i], 1, '=', l_ray);
| 387 |
funset(vpsize, 1, '=', l_psize);
| 388 |
/* set brightness function */
| 389 |
if (!strcmp(ourfmt, CIEFMT)) {
| 390 |
varset(vwhteff, ':', 1.0);
| 391 |
ourbright = xyz_bright;
| 392 |
} else
| 393 |
varset(vwhteff, ':', WHTEFFICACY);
| 394 |
/* these may be overridden */
| 395 |
varset(vxres, ':', (double)xmax);
| 396 |
varset(vyres, ':', (double)ymax);
| 397 |
| 398 |
| 399 |
| 400 |
static void
| 401 |
combine(void) /* combine pictures */
| 402 |
| 403 |
EPNODE *coldef[3], *brtdef;
| 404 |
COLOR *scanout;
| 405 |
double d;
| 406 |
int i, j;
| 407 |
/* check defined variables */
| 408 |
for (j = 0; j < 3; j++) {
| 409 |
if (vardefined(vcolout[j]))
| 410 |
coldef[j] = eparse(vcolout[j]);
| 411 |
else
| 412 |
coldef[j] = NULL;
| 413 |
| 414 |
if (vardefined(vbrtout))
| 415 |
brtdef = eparse(vbrtout);
| 416 |
else
| 417 |
brtdef = NULL;
| 418 |
/* allocate scanline */
| 419 |
scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
| 420 |
/* set input position */
| 421 |
yscan = ymax+MIDSCN;
| 422 |
/* combine files */
| 423 |
for (ypos = yres-1; ypos >= 0; ypos--) {
| 424 |
advance();
| 425 |
varset(vypos, '=', (double)ypos);
| 426 |
for (xpos = 0; xpos < xres; xpos++) {
| 427 |
xscan = (xpos+.5)*xmax/xres;
| 428 |
varset(vxpos, '=', (double)xpos);
| 429 |
eclock++;
| 430 |
if (brtdef != NULL) {
| 431 |
d = evalue(brtdef);
| 432 |
if (d < 0.0)
| 433 |
d = 0.0;
| 434 |
setcolor(scanout[xpos], d, d, d);
| 435 |
} else {
| 436 |
| 437 |
if (coldef[j] != NULL) {
| 438 |
d = evalue(coldef[j]);
| 439 |
} else {
| 440 |
d = 0.0;
| 441 |
for (i = 0; i < nfiles; i++)
| 442 |
d += colval(input[i].scan[MIDSCN][xscan],j);
| 443 |
| 444 |
if (d < 0.0)
| 445 |
d = 0.0;
| 446 |
colval(scanout[xpos],j) = d;
| 447 |
| 448 |
| 449 |
| 450 |
if (fwritescan(scanout, xres, stdout) < 0) {
| 451 |
perror("write error");
| 452 |
quit(1);
| 453 |
| 454 |
| 455 |
efree((char *)scanout);
| 456 |
| 457 |
| 458 |
| 459 |
static void
| 460 |
advance(void) /* read in data for next scanline */
| 461 |
| 462 |
int ytarget;
| 463 |
COLOR *st;
| 464 |
int i, j;
| 465 |
| 466 |
for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--)
| 467 |
for (i = 0; i < nfiles; i++) {
| 468 |
st = input[i].scan[WINSIZ-1];
| 469 |
for (j = WINSIZ-1; j > 0; j--) /* rotate window */
| 470 |
input[i].scan[j] = input[i].scan[j-1];
| 471 |
input[i].scan[0] = st;
| 472 |
if (yscan <= MIDSCN) /* hit bottom? */
| 473 |
continue;
| 474 |
if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
| 475 |
eputs(input[i].name);
| 476 |
eputs(": read error\n");
| 477 |
quit(1);
| 478 |
| 479 |
for (j = 0; j < xmax; j++) /* adjust color */
| 480 |
multcolor(st[j], input[i].coef);
| 481 |
| 482 |
| 483 |
| 484 |
| 485 |
static double
| 486 |
l_expos( /* return picture exposure */
| 487 |
char *nam
| 488 |
| 489 |
| 490 |
int fn, n;
| 491 |
double d;
| 492 |
| 493 |
d = argument(1);
| 494 |
if (d <= -0.5 || d >= nfiles+0.5) {
| 495 |
errno = EDOM;
| 496 |
return(0.0);
| 497 |
| 498 |
if (d < 0.5)
| 499 |
return((double)nfiles);
| 500 |
fn = d - 0.5;
| 501 |
if (nam == vbrtexp)
| 502 |
return((*ourbright)(input[fn].expos));
| 503 |
n = 3;
| 504 |
while (n--)
| 505 |
if (nam == vcolexp[n])
| 506 |
return(colval(input[fn].expos,n));
| 507 |
eputs("Bad call to l_expos()!\n");
| 508 |
quit(1);
| 509 |
| 510 |
| 511 |
| 512 |
| 513 |
static double
| 514 |
l_pixaspect(char *nm) /* return pixel aspect ratio */
| 515 |
| 516 |
int fn;
| 517 |
double d;
| 518 |
| 519 |
d = argument(1);
| 520 |
| 521 |
errno = EDOM;
| 522 |
return(0.0);
| 523 |
| 524 |
if (d < 0.5)
| 525 |
| 526 |
fn = d - 0.5;
| 527 |
return(input[fn].pa);
| 528 |
| 529 |
| 530 |
| 531 |
static double
| 532 |
l_colin( /* return color value for picture */
| 533 |
char *nam
| 534 |
| 535 |
| 536 |
int fn;
| 537 |
int n, xoff, yoff;
| 538 |
double d;
| 539 |
| 540 |
d = argument(1);
| 541 |
| 542 |
errno = EDOM;
| 543 |
return(0.0);
| 544 |
| 545 |
if (d < 0.5)
| 546 |
| 547 |
fn = d - 0.5;
| 548 |
xoff = yoff = 0;
| 549 |
n = nargum();
| 550 |
if (n >= 2) {
| 551 |
d = argument(2);
| 552 |
if (d < 0.0) {
| 553 |
xoff = d-.5;
| 554 |
if (xscan+xoff < 0)
| 555 |
xoff = -xscan;
| 556 |
} else {
| 557 |
xoff = d+.5;
| 558 |
if (xscan+xoff >= xmax)
| 559 |
xoff = xmax-1-xscan;
| 560 |
| 561 |
| 562 |
if (n >= 3) {
| 563 |
d = argument(3);
| 564 |
if (d < 0.0) {
| 565 |
yoff = d-.5;
| 566 |
if (yoff+MIDSCN < 0)
| 567 |
yoff = -MIDSCN;
| 568 |
if (yscan+yoff < 0)
| 569 |
yoff = -yscan;
| 570 |
} else {
| 571 |
yoff = d+.5;
| 572 |
if (yoff+MIDSCN >= WINSIZ)
| 573 |
yoff = WINSIZ-1-MIDSCN;
| 574 |
if (yscan+yoff >= ymax)
| 575 |
yoff = ymax-1-yscan;
| 576 |
| 577 |
| 578 |
if (nam == vbrtin)
| 579 |
return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
| 580 |
n = 3;
| 581 |
while (n--)
| 582 |
if (nam == vcolin[n])
| 583 |
return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
| 584 |
eputs("Bad call to l_colin()!\n");
| 585 |
quit(1);
| 586 |
| 587 |
| 588 |
| 589 |
| 590 |
static double
| 591 |
l_ray( /* return ray origin or direction */
| 592 |
char *nam
| 593 |
| 594 |
| 595 |
static unsigned long ltick[MAXINP];
| 596 |
static FVECT lorg[MAXINP], ldir[MAXINP];
| 597 |
static double ldist[MAXINP];
| 598 |
RREAL loc[2];
| 599 |
double d;
| 600 |
int fn;
| 601 |
int i;
| 602 |
| 603 |
d = argument(1);
| 604 |
| 605 |
errno = EDOM;
| 606 |
return(0.0);
| 607 |
| 608 |
if (d < 0.5)
| 609 |
| 610 |
fn = d - 0.5;
| 611 |
if (ltick[fn] != eclock) { /* need to compute? */
| 612 |
lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
| 613 |
ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
| 614 |
ldist[fn] = -1.0;
| 615 |
if (input[fn].vw.type == 0)
| 616 |
errno = EDOM;
| 617 |
else {
| 618 |
pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
| 619 |
ldist[fn] = viewray(lorg[fn], ldir[fn],
| 620 |
&input[fn].vw, loc[0], loc[1]);
| 621 |
| 622 |
ltick[fn] = eclock;
| 623 |
| 624 |
if (nam == vray[i=6])
| 625 |
return(ldist[fn]);
| 626 |
while (i--)
| 627 |
if (nam == vray[i])
| 628 |
return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
| 629 |
eputs("Bad call to l_ray()!\n");
| 630 |
quit(1);
| 631 |
| 632 |
| 633 |
| 634 |
| 635 |
static double
| 636 |
l_psize(char *nm) /* compute pixel size in steradians */
| 637 |
| 638 |
| 639 |
static double psize[MAXINP];
| 640 |
FVECT dir0, org, dirx, diry;
| 641 |
RREAL locx[2], locy[2];
| 642 |
double d;
| 643 |
int fn;
| 644 |
int i;
| 645 |
| 646 |
d = argument(1);
| 647 |
| 648 |
errno = EDOM;
| 649 |
return(0.0);
| 650 |
| 651 |
if (d < 0.5)
| 652 |
| 653 |
fn = d - 0.5;
| 654 |
| 655 |
psize[fn] = 0.0;
| 656 |
| 657 |
errno = EDOM;
| 658 |
else if (input[fn].vw.type != VT_PAR &&
| 659 |
funvalue(vray[6], 1, &d) >= -FTINY) {
| 660 |
| 661 |
dir0[i] = funvalue(vray[3+i], 1, &d);
| 662 |
pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
| 663 |
pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
| 664 |
if (viewray(org, dirx, &input[fn].vw,
| 665 |
locx[0], locx[1]) >= -FTINY &&
| 666 |
viewray(org, diry, &input[fn].vw,
| 667 |
locy[0], locy[1]) >= -FTINY) {
| 668 |
/* approximate solid angle */
| 669 |
| 670 |
dirx[i] -= dir0[i];
| 671 |
diry[i] -= dir0[i];
| 672 |
| 673 |
fcross(dir0, dirx, diry);
| 674 |
psize[fn] = VLEN(dir0);
| 675 |
| 676 |
| 677 |
ltick[fn] = eclock;
| 678 |
| 679 |
return(psize[fn]);
| 680 |
| 681 |
| 682 |
| 683 |
extern void
| 684 |
wputs(const char *msg)
| 685 |
| 686 |
if (!nowarn)
| 687 |
eputs(msg);
| 688 |
| 689 |
| 690 |
| 691 |
extern void
| 692 |
eputs(const char *msg)
| 693 |
| 694 |
fputs(msg, stderr);
| 695 |
| 696 |
| 697 |
| 698 |
extern void
| 699 |
quit(int code) /* exit gracefully */
| 700 |
| 701 |
int i;
| 702 |
/* close input files */
| 703 |
| 704 |
if (input[i].name == Command)
| 705 |
pclose(input[i].fp);
| 706 |
else
| 707 |
fclose(input[i].fp);
| 708 |
exit(code);
| 709 |
