root/Development/ray/src/px/pcomb.c
Revision: 2.54
Committed: Tue Mar 22 15:14:42 2022 UTC (3 years, 9 months ago) by greg
Changes since 2.53: +3 -2 lines
fix(pcomb): Corrected recent bug introduced to header scanning
2 static const char RCSid[] = "$Id: pcomb.c,v 2.53 2022/03/18 18:31:47 greg Exp $";
5 * Combine picture files according to calcomp functions.
6 *
7 * 1/4/89
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "paths.h"
13 #include "color.h"
14 #include "calcomp.h"
15 #include "view.h"
16
17 #define MAXINP 1024 /* maximum number of input files */
18 #define WINSIZ 127 /* scanline window size */
19 #define MIDSCN ((WINSIZ-1)/2+1)
20
21 struct {
22 char *name; /* file or command name */
23 FILE *fp; /* stream pointer */
24 VIEW vw; /* view for picture */
25 RESOLU rs; /* image resolution and orientation */
26 float pa; /* pixel aspect ratio */
27 COLOR *scan[WINSIZ]; /* input scanline window */
28 COLOR coef; /* coefficient */
29 COLOR expos; /* recorded exposure */
30 } input[MAXINP]; /* input pictures */
31
32 int nfiles; /* number of input files */
33
34 VIEW *commvp = NULL; /* common view parameters */
35
36 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
37
38 char StandardInput[] = "<stdin>";
39 char Command[] = "<Command>";
40 char vcolin[3][4] = {"ri", "gi", "bi"};
41 char vcolout[3][4] = {"ro", "go", "bo"};
42 char vbrtin[] = "li";
43 char vbrtout[] = "lo";
44 char vcolexp[3][4] = {"re", "ge", "be"};
45 char vbrtexp[] = "le";
46 char vpixaspect[] = "pa";
47
48 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
49
50 char vpsize[] = "S";
51
52 char vnfiles[] = "nfiles";
53 char vwhteff[] = "WE";
54 char vxmax[] = "xmax";
55 char vymax[] = "ymax";
56 char vxres[] = "xres";
57 char vyres[] = "yres";
58 char vxpos[] = "x";
59 char vypos[] = "y";
60
61 int nowarn = 0; /* no warning messages? */
62
63 int xmax = 0, ymax = 0; /* input resolution */
64
65 int xscan, yscan; /* input position */
66
67 int xres, yres; /* output resolution */
68
69 int xpos, ypos; /* output position */
70
71 char *progname; /* global argv[0] */
72
73 int echoheader = 1;
74 int wrongformat = 0;
75 int gotview;
76
77
78 static gethfunc headline;
79 static void checkfile(int orig);
80 static double rgb_bright(COLOR clr);
81 static double xyz_bright(COLOR clr);
82 static void init(void);
83 static void combine(void);
84 static void advance(void);
85 static double l_expos(char *nam);
86 static double l_pixaspect(char *nm);
87 static double l_colin(char *nam);
88 static double l_ray(char *nam);
89 static double l_psize(char *nm);
90
91
92 int
93 main(
94 int argc,
95 char *argv[]
96 )
97 {
98 int original;
99 double f;
100 int a;
101
102 SET_DEFAULT_BINARY();
103 SET_FILE_BINARY(stdin);
104 SET_FILE_BINARY(stdout);
105 progname = argv[0];
106 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
107 esupport &= ~(E_OUTCHAN|E_INCHAN);
108 /* scan options */
109 for (a = 1; a < argc; a++) {
110 if (argv[a][0] == '-')
111 switch (argv[a][1]) {
112 case 'x':
113 case 'y':
114 a++;
115 continue;
116 case 'w':
117 nowarn = !nowarn;
118 continue;
119 case 'h':
120 echoheader = !echoheader;
121 continue;
122 case 'f':
123 case 'e':
124 a++;
125 continue;
126 }
127 break;
128 }
129 newheader("RADIANCE", stdout); /* start header */
130 fputnow(stdout);
131 /* process files */
132 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
133 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
134 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
135 input[nfiles].vw = stdview;
136 input[nfiles].pa = 1.0;
137 }
138 nfiles = 0;
139 original = 0;
140 for ( ; a < argc; a++) {
141 if (nfiles >= MAXINP) {
142 eputs(argv[0]);
143 eputs(": too many picture files\n");
144 quit(1);
145 }
146 if (argv[a][0] == '-')
147 switch (argv[a][1]) {
148 case '\0':
149 input[nfiles].name = StandardInput;
150 input[nfiles].fp = stdin;
151 break;
152 case 'o':
153 original++;
154 continue;
155 case 's':
156 f = atof(argv[++a]);
157 scalecolor(input[nfiles].coef, f);
158 continue;
159 case 'c':
160 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
161 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
162 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
163 continue;
164 default:
165 goto usage;
166 }
167 else {
168 if (argv[a][0] == '!') {
169 input[nfiles].name = Command;
170 input[nfiles].fp = popen(argv[a]+1, "r");
171 } else {
172 input[nfiles].name = argv[a];
173 input[nfiles].fp = fopen(argv[a], "r");
174 }
175 if (input[nfiles].fp == NULL) {
176 perror(argv[a]);
177 quit(1);
178 }
179 }
180 checkfile(original);
181 nfiles++;
182 original = 0;
183 }
184 init(); /* set constants */
185 /* go back and get expressions */
186 for (a = 1; a < argc; a++) {
187 char *fpath;
188 if (argv[a][0] == '-')
189 switch (argv[a][1]) {
190 case 'x':
191 varset(vxres, ':', eval(argv[++a]));
192 continue;
193 case 'y':
194 varset(vyres, ':', eval(argv[++a]));
195 continue;
196 case 'w':
197 continue;
198 case 'h':
199 continue;
200 case 'f':
201 fpath = getpath(argv[++a], getrlibpath(), 0);
202 if (fpath == NULL) {
203 eputs(argv[0]);
204 eputs(": cannot find file '");
205 eputs(argv[a]);
206 eputs("'\n");
207 quit(1);
208 }
209 fcompile(fpath);
210 continue;
211 case 'e':
212 scompile(argv[++a], NULL, 0);
213 continue;
214 }
215 break;
216 }
217 /* get output resolution */
218 xres = varvalue(vxres) + .5;
219 yres = varvalue(vyres) + .5;
220 if (xres <= 0 || yres <= 0) {
221 eputs(argv[0]);
222 eputs(": illegal output resolution\n");
223 quit(1);
224 }
225 /* complete header */
226 printargs(argc, argv, stdout);
227 if (commvp != NULL) {
228 fputs(VIEWSTR, stdout);
229 fprintview(commvp, stdout);
230 fputc('\n', stdout);
231 }
232 if (strcmp(ourfmt, PICFMT))
233 fputformat(ourfmt, stdout); /* print format if known */
234 putchar('\n');
235 fprtresolu(xres, yres, stdout);
236 /* combine pictures */
237 combine();
238 quit(0);
239 usage:
240 eputs("Usage: ");
241 eputs(argv[0]);
242 eputs(
243 " [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n");
244 quit(1);
245 return 1; /* pro forma return */
246 }
247
248
249 static int
250 headline( /* check header line & echo if requested */
251 char *s,
252 void *p
253 )
254 {
255 int orig = *(int *)p;
256 char fmt[MAXFMTLEN];
257 double d;
258 COLOR ctmp;
259
260 if (isheadid(s)) /* header id */
261 return(0); /* don't echo */
262 if (formatval(fmt, s)) { /* check format */
263 if (globmatch(ourfmt, fmt)) {
264 wrongformat = 0;
265 strcpy(ourfmt, fmt);
266 } else
267 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
268 return(0); /* don't echo */
269 }
270 if (orig) { /* undo exposure? */
271 if (isexpos(s)) {
272 d = 1./exposval(s);
273 scalecolor(input[nfiles].coef, d);
274 return(0); /* don't echo */
275 }
276 if (iscolcor(s)) {
277 int i;
278 colcorval(ctmp, s);
279 for (i = 3; i--; )
280 colval(input[nfiles].coef,i) /= colval(ctmp,i);
281 return(0); /* don't echo */
282 }
283 } else if (isexpos(s)) { /* record exposure? */
284 d = exposval(s);
285 scalecolor(input[nfiles].expos, d);
286 } else if (iscolcor(s)) {
287 colcorval(ctmp, s);
288 multcolor(input[nfiles].expos, ctmp);
289 }
290 if (isaspect(s))
291 input[nfiles].pa *= aspectval(s);
292 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
293 gotview++;
294
295 if (echoheader) { /* echo line */
296 putchar('\t');
297 return(fputs(s, stdout));
298 }
299 return(0);
300 }
301
302
303 static void
304 checkfile(int orig) /* ready a file */
305 {
306 int i;
307 /* process header */
308 gotview = 0;
309 if (echoheader) {
310 fputs(input[nfiles].name, stdout);
311 fputs(":\n", stdout);
312 }
313 getheader(input[nfiles].fp, headline, &orig);
314 if (wrongformat < 0) {
315 eputs(input[nfiles].name);
316 eputs(": not a Radiance picture\n");
317 quit(1);
318 }
319 if (wrongformat > 0) {
320 wputs(input[nfiles].name);
321 wputs(": warning -- incompatible picture format\n");
322 }
323 if (!gotview || setview(&input[nfiles].vw) != NULL)
324 input[nfiles].vw.type = 0;
325 else if (commvp == NULL)
326 commvp = &input[nfiles].vw;
327 if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
328 eputs(input[nfiles].name);
329 eputs(": bad picture size\n");
330 quit(1);
331 }
332 if (xmax == 0 && ymax == 0) {
333 xmax = scanlen(&input[nfiles].rs);
334 ymax = numscans(&input[nfiles].rs);
335 } else if (scanlen(&input[nfiles].rs) != xmax ||
336 numscans(&input[nfiles].rs) != ymax) {
337 eputs(input[nfiles].name);
338 eputs(": resolution mismatch\n");
339 quit(1);
340 }
341 /* allocate scanlines */
342 for (i = 0; i < WINSIZ; i++)
343 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
344 }
345
346
347 static double
348 rgb_bright(
349 COLOR clr
350 )
351 {
352 return(bright(clr));
353 }
354
355
356 static double
357 xyz_bright(
358 COLOR clr
359 )
360 {
361 return(clr[CIEY]);
362 }
363
364
365 double (*ourbright)() = rgb_bright;
366
367
368 static void
369 init(void) /* perform final setup */
370 {
371 int i;
372 /* define constants */
373 varset("PI", ':', PI);
374 varset(vnfiles, ':', (double)nfiles);
375 varset(vxmax, ':', (double)xmax);
376 varset(vymax, ':', (double)ymax);
377 /* set functions */
378 for (i = 0; i < 3; i++) {
379 funset(vcolexp[i], 1, ':', l_expos);
380 funset(vcolin[i], 1, '=', l_colin);
381 }
382 funset(vbrtexp, 1, ':', l_expos);
383 funset(vbrtin, 1, '=', l_colin);
384 funset(vpixaspect, 1, ':', l_pixaspect);
385 for (i = 0; i < 7; i++)
386 funset(vray[i], 1, '=', l_ray);
387 funset(vpsize, 1, '=', l_psize);
388 /* set brightness function */
389 if (!strcmp(ourfmt, CIEFMT)) {
390 varset(vwhteff, ':', 1.0);
391 ourbright = xyz_bright;
392 } else
393 varset(vwhteff, ':', WHTEFFICACY);
394 /* these may be overridden */
395 varset(vxres, ':', (double)xmax);
396 varset(vyres, ':', (double)ymax);
397 }
398
399
400 static void
401 combine(void) /* combine pictures */
402 {
403 EPNODE *coldef[3], *brtdef;
404 COLOR *scanout;
405 double d;
406 int i, j;
407 /* check defined variables */
408 for (j = 0; j < 3; j++) {
409 if (vardefined(vcolout[j]))
410 coldef[j] = eparse(vcolout[j]);
411 else
412 coldef[j] = NULL;
413 }
414 if (vardefined(vbrtout))
415 brtdef = eparse(vbrtout);
416 else
417 brtdef = NULL;
418 /* allocate scanline */
419 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
420 /* set input position */
421 yscan = ymax+MIDSCN;
422 /* combine files */
423 for (ypos = yres-1; ypos >= 0; ypos--) {
424 advance();
425 varset(vypos, '=', (double)ypos);
426 for (xpos = 0; xpos < xres; xpos++) {
427 xscan = (xpos+.5)*xmax/xres;
428 varset(vxpos, '=', (double)xpos);
429 eclock++;
430 if (brtdef != NULL) {
431 d = evalue(brtdef);
432 if (d < 0.0)
433 d = 0.0;
434 setcolor(scanout[xpos], d, d, d);
435 } else {
436 for (j = 0; j < 3; j++) {
437 if (coldef[j] != NULL) {
438 d = evalue(coldef[j]);
439 } else {
440 d = 0.0;
441 for (i = 0; i < nfiles; i++)
442 d += colval(input[i].scan[MIDSCN][xscan],j);
443 }
444 if (d < 0.0)
445 d = 0.0;
446 colval(scanout[xpos],j) = d;
447 }
448 }
449 }
450 if (fwritescan(scanout, xres, stdout) < 0) {
451 perror("write error");
452 quit(1);
453 }
454 }
455 efree((char *)scanout);
456 }
457
458
459 static void
460 advance(void) /* read in data for next scanline */
461 {
462 int ytarget;
463 COLOR *st;
464 int i, j;
465
466 for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--)
467 for (i = 0; i < nfiles; i++) {
468 st = input[i].scan[WINSIZ-1];
469 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
470 input[i].scan[j] = input[i].scan[j-1];
471 input[i].scan[0] = st;
472 if (yscan <= MIDSCN) /* hit bottom? */
473 continue;
474 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
475 eputs(input[i].name);
476 eputs(": read error\n");
477 quit(1);
478 }
479 for (j = 0; j < xmax; j++) /* adjust color */
480 multcolor(st[j], input[i].coef);
481 }
482 }
483
484
485 static double
486 l_expos( /* return picture exposure */
487 char *nam
488 )
489 {
490 int fn, n;
491 double d;
492
493 d = argument(1);
494 if (d <= -0.5 || d >= nfiles+0.5) {
495 errno = EDOM;
496 return(0.0);
497 }
498 if (d < 0.5)
499 return((double)nfiles);
500 fn = d - 0.5;
501 if (nam == vbrtexp)
502 return((*ourbright)(input[fn].expos));
503 n = 3;
504 while (n--)
505 if (nam == vcolexp[n])
506 return(colval(input[fn].expos,n));
507 eputs("Bad call to l_expos()!\n");
508 quit(1);
509 return 1; /* pro forma return */
510 }
511
512
513 static double
514 l_pixaspect(char *nm) /* return pixel aspect ratio */
515 {
516 int fn;
517 double d;
518
519 d = argument(1);
520 if (d <= -0.5 || d >= nfiles+0.5) {
521 errno = EDOM;
522 return(0.0);
523 }
524 if (d < 0.5)
525 return((double)nfiles);
526 fn = d - 0.5;
527 return(input[fn].pa);
528 }
529
530
531 static double
532 l_colin( /* return color value for picture */
533 char *nam
534 )
535 {
536 int fn;
537 int n, xoff, yoff;
538 double d;
539
540 d = argument(1);
541 if (d <= -0.5 || d >= nfiles+0.5) {
542 errno = EDOM;
543 return(0.0);
544 }
545 if (d < 0.5)
546 return((double)nfiles);
547 fn = d - 0.5;
548 xoff = yoff = 0;
549 n = nargum();
550 if (n >= 2) {
551 d = argument(2);
552 if (d < 0.0) {
553 xoff = d-.5;
554 if (xscan+xoff < 0)
555 xoff = -xscan;
556 } else {
557 xoff = d+.5;
558 if (xscan+xoff >= xmax)
559 xoff = xmax-1-xscan;
560 }
561 }
562 if (n >= 3) {
563 d = argument(3);
564 if (d < 0.0) {
565 yoff = d-.5;
566 if (yoff+MIDSCN < 0)
567 yoff = -MIDSCN;
568 if (yscan+yoff < 0)
569 yoff = -yscan;
570 } else {
571 yoff = d+.5;
572 if (yoff+MIDSCN >= WINSIZ)
573 yoff = WINSIZ-1-MIDSCN;
574 if (yscan+yoff >= ymax)
575 yoff = ymax-1-yscan;
576 }
577 }
578 if (nam == vbrtin)
579 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
580 n = 3;
581 while (n--)
582 if (nam == vcolin[n])
583 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
584 eputs("Bad call to l_colin()!\n");
585 quit(1);
586 return 1; /* pro forma return */
587 }
588
589
590 static double
591 l_ray( /* return ray origin or direction */
592 char *nam
593 )
594 {
595 static unsigned long ltick[MAXINP];
596 static FVECT lorg[MAXINP], ldir[MAXINP];
597 static double ldist[MAXINP];
598 RREAL loc[2];
599 double d;
600 int fn;
601 int i;
602
603 d = argument(1);
604 if (d <= -0.5 || d >= nfiles+0.5) {
605 errno = EDOM;
606 return(0.0);
607 }
608 if (d < 0.5)
609 return((double)nfiles);
610 fn = d - 0.5;
611 if (ltick[fn] != eclock) { /* need to compute? */
612 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
613 ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
614 ldist[fn] = -1.0;
615 if (input[fn].vw.type == 0)
616 errno = EDOM;
617 else {
618 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
619 ldist[fn] = viewray(lorg[fn], ldir[fn],
620 &input[fn].vw, loc[0], loc[1]);
621 }
622 ltick[fn] = eclock;
623 }
624 if (nam == vray[i=6])
625 return(ldist[fn]);
626 while (i--)
627 if (nam == vray[i])
628 return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
629 eputs("Bad call to l_ray()!\n");
630 quit(1);
631 return 1; /* pro forma return */
632 }
633
634
635 static double
636 l_psize(char *nm) /* compute pixel size in steradians */
637 {
638 static unsigned long ltick[MAXINP];
639 static double psize[MAXINP];
640 FVECT dir0, org, dirx, diry;
641 RREAL locx[2], locy[2];
642 double d;
643 int fn;
644 int i;
645
646 d = argument(1);
647 if (d <= -0.5 || d >= nfiles+0.5) {
648 errno = EDOM;
649 return(0.0);
650 }
651 if (d < 0.5)
652 return((double)nfiles);
653 fn = d - 0.5;
654 if (ltick[fn] != eclock) { /* need to compute? */
655 psize[fn] = 0.0;
656 if (input[fn].vw.type == 0)
657 errno = EDOM;
658 else if (input[fn].vw.type != VT_PAR &&
659 funvalue(vray[6], 1, &d) >= -FTINY) {
660 for (i = 0; i < 3; i++)
661 dir0[i] = funvalue(vray[3+i], 1, &d);
662 pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
663 pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
664 if (viewray(org, dirx, &input[fn].vw,
665 locx[0], locx[1]) >= -FTINY &&
666 viewray(org, diry, &input[fn].vw,
667 locy[0], locy[1]) >= -FTINY) {
668 /* approximate solid angle */
669 for (i = 0; i < 3; i++) {
670 dirx[i] -= dir0[i];
671 diry[i] -= dir0[i];
672 }
673 fcross(dir0, dirx, diry);
674 psize[fn] = VLEN(dir0);
675 }
676 }
677 ltick[fn] = eclock;
678 }
679 return(psize[fn]);
680 }
681
682
683 extern void
684 wputs(char *msg)
685 {
686 if (!nowarn)
687 eputs(msg);
688 }
689
690
691 extern void
692 eputs(char *msg)
693 {
694 fputs(msg, stderr);
695 }
696
697
698 extern void
699 quit(int code) /* exit gracefully */
700 {
701 int i;
702 /* close input files */
703 for (i = 0; i < nfiles; i++)
704 if (input[i].name == Command)
705 pclose(input[i].fp);
706 else
707 fclose(input[i].fp);
708 exit(code);
709 }
