root/radiance/ray/src/px/pcomb.c
Thu Aug 2 18:33:43 2018 UTC (6 years, 9 months ago) by greg
Diff to previous 2.50 , to selected 1.18
Fri May 4 23:56:49 2018 UTC (7 years ago) by greg
Changes since 2.49: +11 -2 lines
Diff to previous 2.49 , to selected 1.18
Mon Feb 5 20:07:17 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.48: +10 -1 lines
Diff to previous 2.48 , to selected 1.18
Decided to share first input view in the output of pcomb
Sat Jan 13 00:35:55 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.47: +5 -6 lines
Diff to previous 2.47 , to selected 1.18
Fixed issue introduced with xres and yres definitions
Fri Jan 12 00:50:17 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.46: +15 -12 lines
Diff to previous 2.46 , to selected 1.18
Added missing esupport settings for constant expression reduction
Mon Aug 1 00:08:53 2016 UTC (8 years, 9 months ago) by greg
Diff to previous 2.45 , to selected 1.18
Increased scanline buffer size
Tue Feb 2 18:02:32 2016 UTC (9 years, 3 months ago) by greg
Diff to previous 2.44 , to selected 1.18
Mon Aug 10 04:26:38 2009 UTC (15 years, 9 months ago) by greg
Diff to previous 2.43 , to selected 1.18
Upped limit on open files to 1024
Mon Nov 10 19:08:19 2008 UTC (16 years, 6 months ago) by greg
Diff to previous 2.42 , to selected 1.18
Wed Nov 7 05:40:06 2007 UTC (17 years, 6 months ago) by greg
Changes since 2.41: +39 -18 lines
Diff to previous 2.41 , to selected 1.18
Fixed problem in last change -- pixel position should work, now
Mon Nov 5 23:40:26 2007 UTC (17 years, 6 months ago) by greg
Diff to previous 2.40 , to selected 1.18
Mon Oct 22 17:56:36 2007 UTC (17 years, 6 months ago) by greg
Changes since 2.39: +3 -1 lines
Diff to previous 2.39 , to selected 1.18
Fixed bug in -h option
Fri Sep 8 21:38:25 2006 UTC (18 years, 8 months ago) by greg
Changes since 2.38: +19 -10 lines
Diff to previous 2.38 , to selected 1.18
Wed May 25 04:44:25 2005 UTC (19 years, 11 months ago) by greg
Diff to previous 2.37 , to selected 1.18
Tue Mar 1 23:16:42 2005 UTC (20 years, 2 months ago) by greg
Changes since 2.36: +3 -6 lines
Diff to previous 2.36 , to selected 1.18
Removed wasteful test for unit multiplier coefficient
Wed Feb 16 03:26:33 2005 UTC (20 years, 2 months ago) by greg
Diff to previous 2.35 , to selected 1.18
Last minor change broke solid angle calculation -- fixed
Mon Jan 24 19:29:39 2005 UTC (20 years, 3 months ago) by greg
Changes since 2.34: +5 -5 lines
Diff to previous 2.34 , to selected 1.18
Minor fixes to solid angle math
Tue Aug 31 18:52:27 2004 UTC (20 years, 8 months ago) by greg
Changes since 2.33: +1 -3 lines
Diff to previous 2.33 , to selected 1.18
Removed redundant function declarations
Tue Jun 8 19:48:30 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.32: +2 -3 lines
Diff to previous 2.32 , to selected 1.18
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 2.31: +55 -29 lines
Diff to previous 2.31 , to selected 1.18
Mon Mar 15 21:16:54 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.30: +3 -2 lines
Diff to previous 2.30 , to selected 1.18
Fri Jan 2 12:47:01 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.29: +7 -3 lines
Diff to previous 2.29 , to selected 1.18
Mon Oct 27 10:24:51 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 2.28: +9 -12 lines
Diff to previous 2.28 , to selected 1.18
Various compatibility fixes.
Wed Oct 22 02:06:35 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 2.27 , to selected 1.18
Mon Aug 4 22:37:53 2003 UTC (21 years, 9 months ago) by greg
Changes since 2.26: +5 -4 lines
Diff to previous 2.26 , to selected 1.18
Mon Jul 21 22:30:18 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.25 , to selected 1.18
Thu Jun 26 00:58:10 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.24: +3 -3 lines
Diff to previous 2.24 , to selected 1.18
Sun Jun 8 12:03:10 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.23: +2 -1 lines
Diff to previous 2.23 , to selected 1.18
Thu Jun 5 19:29:34 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.22: +4 -10 lines
Diff to previous 2.22 , to selected 1.18
Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.21: +20 -16 lines
Diff to previous 2.21 , to selected 1.18
Tue Oct 27 09:08:25 1998 UTC (26 years, 6 months ago) by gwlarson
Diff to previous 2.20 , to selected 1.18
Thu Sep 19 12:10:46 1996 UTC (28 years, 7 months ago) by greg
Changes since 2.19: +1 -0 lines
Diff to previous 2.19 , to selected 1.18
added default value of -1 to T(n) for pictures w/o view parameters
Thu Sep 5 10:38:53 1996 UTC (28 years, 8 months ago) by greg
Changes since 2.18: +1 -0 lines
Diff to previous 2.18 , to selected 1.18
added definition of constant PI
Tue Sep 3 11:30:37 1996 UTC (28 years, 8 months ago) by greg
Changes since 2.17: +58 -48 lines
Diff to previous 2.17 , to selected 1.18
fixed S(n) function and added T(n) function and pa(n) and WE constants
Fri Aug 30 17:39:39 1996 UTC (28 years, 8 months ago) by greg
Changes since 2.16: +57 -2 lines
Diff to previous 2.16 , to selected 1.18
added computation of pixel solid angle ("S" variable)
Mon Oct 16 12:04:33 1995 UTC (29 years, 7 months ago) by greg
Changes since 2.15: +33 -4 lines
Diff to previous 2.15 , to selected 1.18
added compatibility with Radiance XYZE picture format
Fri Feb 17 18:37:20 1995 UTC (30 years, 2 months ago) by greg
Diff to previous 2.14 , to selected 1.18
fixed potential bug in eclock tracking
Sun Feb 27 10:16:52 1994 UTC (31 years, 2 months ago) by greg
Diff to previous 2.13 , to selected 1.18
Mon Jun 14 15:59:46 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.12 , to selected 1.18
increased default window to +/- 8 pixels instead of 4
Mon May 3 12:13:03 1993 UTC (32 years ago) by greg
Diff to previous 2.11 , to selected 1.18
changed a range error to a domain error in l_ray()
Thu Apr 29 15:46:48 1993 UTC (32 years ago) by greg
Diff to previous 2.10 , to selected 1.18
fixed bug in computation of image location in l_ray()
Thu Apr 29 14:32:07 1993 UTC (32 years ago) by greg
Changes since 2.9: +66 -16 lines
Diff to previous 2.9 , to selected 1.18
added origin and direction functions O[xyz](i), D[xyz](i)
Fri Apr 9 09:49:36 1993 UTC (32 years, 1 month ago) by greg
Diff to previous 2.8 , to selected 1.18
fixed Usage message (added -o)
Fri Oct 2 16:22:51 1992 UTC (32 years, 7 months ago) by greg
Diff to previous 2.7 , to selected 1.18
Mon Sep 21 12:13:48 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.6: +12 -0 lines
Diff to previous 2.6 , to selected 1.18
Changes for PC port
Tue Sep 8 10:35:05 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.5: +7 -20 lines
Diff to previous 2.5 , to selected 1.18
portability fixes
Fri Aug 28 21:41:49 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.4: +5 -8 lines
Diff to previous 2.4 , to selected 1.18
slight change to quit() routine
Thu Aug 13 10:49:08 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.3: +30 -8 lines
Diff to previous 2.3 , to selected 1.18
improved reaping of child processes
Mon Aug 10 12:10:26 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.2: +6 -0 lines
Diff to previous 2.2 , to selected 1.18
added wait call to reap child processes
Fri Mar 27 10:04:12 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.1: +7 -4 lines
Diff to previous 2.1 , to selected 1.18
changed header information for commands
Tue Nov 12 16:04:51 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.23: +0 -0 lines
Diff to previous 1.23 , to selected 1.18
Mon Nov 11 14:01:24 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.22: +4 -2 lines
Diff to previous 1.22 , to selected 1.18
Mon Aug 19 13:43:33 1991 UTC (33 years, 8 months ago) by greg
Diff to previous 1.21 , to selected 1.18
bug fix
Wed Aug 14 15:00:34 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.20: +5 -14 lines
Diff to previous 1.20 , to selected 1.18
inconsequential changes
Thu May 30 10:14:39 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.19 , to selected 1.18
fixed outdated usages message
Thu May 30 09:47:14 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.18: +6 -2 lines
Diff to previous 1.18
added ability to open commands as well as files
Revision 1.18 - (view) (download) (annotate) - [selected]
Mon May 27 09:01:05 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.17: +91 -68 lines
Diff to previous 1.17
changed code for output resolution to allow changes from input
Fri May 24 17:14:49 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.16: +36 -26 lines
Diff to previous 1.16 , to selected 1.18
changed operation of -o option
Fri May 24 15:47:53 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.15: +47 -37 lines
Diff to previous 1.15 , to selected 1.18
bug fixes after last change
Fri May 24 14:46:14 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.14: +141 -122 lines
Diff to previous 1.14 , to selected 1.18
made it so constants are assigned before expressions are compiled
added rc, gc, bc, and lc functions for returning image coefficients
Thu May 23 13:46:05 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.13: +94 -35 lines
Diff to previous 1.13 , to selected 1.18
added access to adjacent pixels for filtering, etc.
Wed May 22 14:56:51 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.12: +6 -6 lines
Diff to previous 1.12 , to selected 1.18
changed assignment slightly for efficiency
Tue Apr 23 15:49:53 1991 UTC (34 years ago) by greg
Changes since 1.11: +4 -4 lines
Diff to previous 1.11 , to selected 1.18
Tue Apr 23 13:03:31 1991 UTC (34 years ago) by greg
Diff to previous 1.10 , to selected 1.18
arguments to varset() changed
Thu Apr 18 14:35:17 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.9: +20 -9 lines
Diff to previous 1.9 , to selected 1.18
Thu Apr 18 10:19:48 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.8: +24 -2 lines
Diff to previous 1.8 , to selected 1.18
added -o option for original values
Thu Apr 18 08:05:57 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.7: +67 -30 lines
Diff to previous 1.7 , to selected 1.18
added variables for luminance in and out, xres, yres, nfiles
Fri Jul 20 14:38:06 1990 UTC (34 years, 9 months ago) by greg
Diff to previous 1.6 , to selected 1.18
Thu Sep 14 09:20:38 1989 UTC (35 years, 8 months ago) by greg
Changes since 1.5: +3 -4 lines
Diff to previous 1.5 , to selected 1.18
Increased maximum number of files -- let system say otherwise
Tue Sep 12 13:04:22 1989 UTC (35 years, 8 months ago) by greg
Diff to previous 1.4 , to selected 1.18
Tue Jul 11 18:05:05 1989 UTC (35 years, 10 months ago) by greg
Changes since 1.3: +13 -8 lines
Diff to previous 1.3 , to selected 1.18
Changed variable evaluation to use pointer
Tue Jul 11 17:13:44 1989 UTC (35 years, 10 months ago) by greg
Changes since 1.2: +37 -11 lines
Diff to previous 1.2 , to selected 1.18
Added coefficient for faster combination
Tue May 9 10:07:04 1989 UTC (36 years ago) by greg
Changes since 1.1: +0 -1 lines
Diff to previous 1.1 , to selected 1.18
Changed default from average to sum
Thu Feb 2 10:49:22 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.18
