root/Development/ray/src/px/pcomb.c
Mon Aug 10 04:26:38 2009 UTC (16 years, 2 months ago) by greg
Diff to previous 2.43
Upped limit on open files to 1024
Mon Nov 10 19:08:19 2008 UTC (16 years, 11 months ago) by greg
Diff to previous 2.42
Wed Nov 7 05:40:06 2007 UTC (17 years, 11 months ago) by greg
Changes since 2.41: +39 -18 lines
Diff to previous 2.41
Fixed problem in last change -- pixel position should work, now
Mon Nov 5 23:40:26 2007 UTC (18 years ago) by greg
Diff to previous 2.40
Mon Oct 22 17:56:36 2007 UTC (18 years ago) by greg
Changes since 2.39: +3 -1 lines
Diff to previous 2.39
Fixed bug in -h option
Fri Sep 8 21:38:25 2006 UTC (19 years, 1 month ago) by greg
Changes since 2.38: +19 -10 lines
Diff to previous 2.38
Wed May 25 04:44:25 2005 UTC (20 years, 5 months ago) by greg
Diff to previous 2.37
Tue Mar 1 23:16:42 2005 UTC (20 years, 8 months ago) by greg
Changes since 2.36: +3 -6 lines
Diff to previous 2.36
Removed wasteful test for unit multiplier coefficient
Wed Feb 16 03:26:33 2005 UTC (20 years, 8 months ago) by greg
Diff to previous 2.35
Last minor change broke solid angle calculation -- fixed
Mon Jan 24 19:29:39 2005 UTC (20 years, 9 months ago) by greg
Changes since 2.34: +5 -5 lines
Diff to previous 2.34
Minor fixes to solid angle math
Tue Aug 31 18:52:27 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.33: +1 -3 lines
Diff to previous 2.33
Removed redundant function declarations
Tue Jun 8 19:48:30 2004 UTC (21 years, 4 months ago) by greg
Changes since 2.32: +2 -3 lines
Diff to previous 2.32
Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.31: +55 -29 lines
Diff to previous 2.31
Mon Mar 15 21:16:54 2004 UTC (21 years, 7 months ago) by greg
Changes since 2.30: +3 -2 lines
Diff to previous 2.30
Fri Jan 2 12:47:01 2004 UTC (21 years, 10 months ago) by schorsch
Changes since 2.29: +7 -3 lines
Diff to previous 2.29
Mon Oct 27 10:24:51 2003 UTC (22 years ago) by schorsch
Changes since 2.28: +9 -12 lines
Diff to previous 2.28
Various compatibility fixes.
Wed Oct 22 02:06:35 2003 UTC (22 years ago) by greg
Diff to previous 2.27
Mon Aug 4 22:37:53 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.26: +5 -4 lines
Diff to previous 2.26
Mon Jul 21 22:30:18 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.25
Thu Jun 26 00:58:10 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.24: +3 -3 lines
Diff to previous 2.24
Sun Jun 8 12:03:10 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.23: +2 -1 lines
Diff to previous 2.23
Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.22: +4 -10 lines
Diff to previous 2.22
Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.21: +20 -16 lines
Diff to previous 2.21
Tue Oct 27 09:08:25 1998 UTC (27 years ago) by gwlarson
Diff to previous 2.20
Thu Sep 19 12:10:46 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.19: +1 -0 lines
Diff to previous 2.19
added default value of -1 to T(n) for pictures w/o view parameters
Thu Sep 5 10:38:53 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.18: +1 -0 lines
Diff to previous 2.18
added definition of constant PI
Tue Sep 3 11:30:37 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.17: +58 -48 lines
Diff to previous 2.17
fixed S(n) function and added T(n) function and pa(n) and WE constants
Fri Aug 30 17:39:39 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.16: +57 -2 lines
Diff to previous 2.16
added computation of pixel solid angle ("S" variable)
Mon Oct 16 12:04:33 1995 UTC (30 years ago) by greg
Changes since 2.15: +33 -4 lines
Diff to previous 2.15
added compatibility with Radiance XYZE picture format
Fri Feb 17 18:37:20 1995 UTC (30 years, 8 months ago) by greg
Diff to previous 2.14
fixed potential bug in eclock tracking
Sun Feb 27 10:16:52 1994 UTC (31 years, 8 months ago) by greg
Diff to previous 2.13
Mon Jun 14 15:59:46 1993 UTC (32 years, 4 months ago) by greg
Diff to previous 2.12
increased default window to +/- 8 pixels instead of 4
Mon May 3 12:13:03 1993 UTC (32 years, 6 months ago) by greg
changed a range error to a domain error in l_ray()
Thu Apr 29 15:46:48 1993 UTC (32 years, 6 months ago) by greg
fixed bug in computation of image location in l_ray()
Thu Apr 29 14:32:07 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.9: +66 -16 lines
added origin and direction functions O[xyz](i), D[xyz](i)
Fri Apr 9 09:49:36 1993 UTC (32 years, 7 months ago) by greg
fixed Usage message (added -o)
Fri Oct 2 16:22:51 1992 UTC (33 years, 1 month ago) by greg
Mon Sep 21 12:13:48 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.6: +12 -0 lines
Changes for PC port
Tue Sep 8 10:35:05 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.5: +7 -20 lines
portability fixes
Fri Aug 28 21:41:49 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.4: +5 -8 lines
slight change to quit() routine
Thu Aug 13 10:49:08 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.3: +30 -8 lines
improved reaping of child processes
Mon Aug 10 12:10:26 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.2: +6 -0 lines
added wait call to reap child processes
Fri Mar 27 10:04:12 1992 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +7 -4 lines
changed header information for commands
Tue Nov 12 16:04:51 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.23: +0 -0 lines
Diff to previous 1.23
Mon Nov 11 14:01:24 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.22: +4 -2 lines
Diff to previous 1.22
Mon Aug 19 13:43:33 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.21
bug fix
Wed Aug 14 15:00:34 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.20: +5 -14 lines
Diff to previous 1.20
inconsequential changes
Thu May 30 10:14:39 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.19
fixed outdated usages message
Thu May 30 09:47:14 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.18: +6 -2 lines
Diff to previous 1.18
added ability to open commands as well as files
Mon May 27 09:01:05 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.17: +91 -68 lines
Diff to previous 1.17
changed code for output resolution to allow changes from input
Fri May 24 17:14:49 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.16: +36 -26 lines
Diff to previous 1.16
changed operation of -o option
Fri May 24 15:47:53 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.15: +47 -37 lines
Diff to previous 1.15
bug fixes after last change
Fri May 24 14:46:14 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.14: +141 -122 lines
Diff to previous 1.14
made it so constants are assigned before expressions are compiled
added rc, gc, bc, and lc functions for returning image coefficients
Thu May 23 13:46:05 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.13: +94 -35 lines
Diff to previous 1.13
added access to adjacent pixels for filtering, etc.
Wed May 22 14:56:51 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.12: +6 -6 lines
Diff to previous 1.12
changed assignment slightly for efficiency
Tue Apr 23 15:49:53 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.11: +4 -4 lines
Diff to previous 1.11
Tue Apr 23 13:03:31 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.10
arguments to varset() changed
Thu Apr 18 14:35:17 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.9: +20 -9 lines
Diff to previous 1.9
Thu Apr 18 10:19:48 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.8: +24 -2 lines
Diff to previous 1.8
added -o option for original values
Thu Apr 18 08:05:57 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.7: +67 -30 lines
Diff to previous 1.7
added variables for luminance in and out, xres, yres, nfiles
Fri Jul 20 14:38:06 1990 UTC (35 years, 3 months ago) by greg
Diff to previous 1.6
Thu Sep 14 09:20:38 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.5: +3 -4 lines
Diff to previous 1.5
Increased maximum number of files -- let system say otherwise
Tue Sep 12 13:04:22 1989 UTC (36 years, 1 month ago) by greg
Diff to previous 1.4
Tue Jul 11 18:05:05 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.3: +13 -8 lines
Diff to previous 1.3
Changed variable evaluation to use pointer
Tue Jul 11 17:13:44 1989 UTC (36 years, 3 months ago) by greg
Changes since 1.2: +37 -11 lines
Added coefficient for faster combination
Tue May 9 10:07:04 1989 UTC (36 years, 6 months ago) by greg
Changes since 1.1: +0 -1 lines
Changed default from average to sum
Thu Feb 2 10:49:22 1989 UTC (36 years, 9 months ago) by greg
