root/radiance/ray/src/px/pcomb.c
Revision: 2.5
Committed: Fri Aug 28 21:41:49 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.4: +5 -8 lines
slight change to quit() routine
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Combine picture files according to calcomp functions.
9 *
10 * 1/4/89
11 */
12
13 #include <stdio.h>
14
15 #include <errno.h>
16
17 #include "color.h"
18
19 #include "resolu.h"
20
21 #include "calcomp.h"
22
23 #define MAXINP 32 /* maximum number of input files */
24 #define WINSIZ 9 /* scanline window size */
25 #define MIDSCN 4 /* current scan position */
26
27 struct {
28 char *name; /* file or command name */
29 FILE *fp; /* stream pointer */
30 COLOR *scan[WINSIZ]; /* input scanline window */
31 COLOR coef; /* coefficient */
32 COLOR expos; /* recorded exposure */
33 } input[MAXINP]; /* input pictures */
34
35 int nfiles; /* number of input files */
36
37 char vcolin[3][4] = {"ri", "gi", "bi"};
38 char vcolout[3][4] = {"ro", "go", "bo"};
39 char vbrtin[] = "li";
40 char vbrtout[] = "lo";
41 char vcolexp[3][4] = {"re", "ge", "be"};
42 char vbrtexp[] = "le";
43
44 char vnfiles[] = "nfiles";
45 char vxmax[] = "xmax";
46 char vymax[] = "ymax";
47 char vxres[] = "xres";
48 char vyres[] = "yres";
49 char vxpos[] = "x";
50 char vypos[] = "y";
51
52 int nowarn = 0; /* no warning messages? */
53
54 int xmax = 0, ymax = 0; /* input resolution */
55
56 int xscan, yscan; /* input position */
57
58 int xres, yres; /* output resolution */
59
60 int xpos, ypos; /* output position */
61
62 int wrongformat = 0;
63
64 FILE *popen();
65
66
67 main(argc, argv)
68 int argc;
69 char *argv[];
70 {
71 int original;
72 double f;
73 int a, i;
74 /* scan options */
75 for (a = 1; a < argc; a++) {
76 if (argv[a][0] == '-')
77 switch (argv[a][1]) {
78 case 'x':
79 case 'y':
80 a++;
81 continue;
82 case 'w':
83 nowarn = !nowarn;
84 continue;
85 case 'f':
86 case 'e':
87 a++;
88 continue;
89 }
90 break;
91 }
92 /* process files */
93 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
94 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
95 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
96 }
97 nfiles = 0;
98 original = 0;
99 for ( ; a < argc; a++) {
100 if (nfiles >= MAXINP) {
101 eputs(argv[0]);
102 eputs(": too many picture files\n");
103 quit(1);
104 }
105 if (argv[a][0] == '-')
106 switch (argv[a][1]) {
107 case '\0':
108 input[nfiles].name = "<stdin>";
109 input[nfiles].fp = stdin;
110 break;
111 case 'o':
112 original++;
113 continue;
114 case 's':
115 f = atof(argv[++a]);
116 scalecolor(input[nfiles].coef, f);
117 continue;
118 case 'c':
119 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
120 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
121 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
122 continue;
123 default:
124 goto usage;
125 }
126 else {
127 if (argv[a][0] == '!') {
128 input[nfiles].name = "<Command>";
129 input[nfiles].fp = popen(argv[a]+1, "r");
130 } else {
131 input[nfiles].name = argv[a];
132 input[nfiles].fp = fopen(argv[a], "r");
133 }
134 if (input[nfiles].fp == NULL) {
135 perror(argv[a]);
136 quit(1);
137 }
138 }
139 checkfile();
140 if (original) {
141 colval(input[nfiles].coef,RED) /=
142 colval(input[nfiles].expos,RED);
143 colval(input[nfiles].coef,GRN) /=
144 colval(input[nfiles].expos,GRN);
145 colval(input[nfiles].coef,BLU) /=
146 colval(input[nfiles].expos,BLU);
147 }
148 nfiles++;
149 original = 0;
150 }
151 init(); /* set constants */
152 /* go back and get expressions */
153 for (a = 1; a < argc; a++) {
154 if (argv[a][0] == '-')
155 switch (argv[a][1]) {
156 case 'x':
157 varset(vxres, ':', eval(argv[++a]));
158 continue;
159 case 'y':
160 varset(vyres, ':', eval(argv[++a]));
161 continue;
162 case 'w':
163 continue;
164 case 'f':
165 fcompile(argv[++a]);
166 continue;
167 case 'e':
168 scompile(argv[++a], NULL, 0);
169 continue;
170 }
171 break;
172 }
173 /* set/get output resolution */
174 if (!vardefined(vxres))
175 varset(vxres, ':', (double)xmax);
176 if (!vardefined(vyres))
177 varset(vyres, ':', (double)ymax);
178 xres = varvalue(vxres) + .5;
179 yres = varvalue(vyres) + .5;
180 if (xres <= 0 || yres <= 0) {
181 eputs(argv[0]);
182 eputs(": illegal output resolution\n");
183 quit(1);
184 }
185 /* complete header */
186 printargs(argc, argv, stdout);
187 fputformat(COLRFMT, stdout);
188 putchar('\n');
189 fprtresolu(xres, yres, stdout);
190 /* combine pictures */
191 combine();
192 quit(0);
193 usage:
194 eputs("Usage: ");
195 eputs(argv[0]);
196 eputs(
197 " [-w][-x xr][-y yr][-e expr][-f file] [ [-s f][-c r g b] pic ..]\n");
198 quit(1);
199 }
200
201
202 tputs(s) /* put out string preceded by a tab */
203 char *s;
204 {
205 char fmt[32];
206 double d;
207 COLOR ctmp;
208
209 if (isformat(s)) { /* check format */
210 formatval(fmt, s);
211 wrongformat = strcmp(fmt, COLRFMT);
212 return; /* don't echo */
213 }
214 if (isexpos(s)) { /* exposure */
215 d = exposval(s);
216 scalecolor(input[nfiles].expos, d);
217 } else if (iscolcor(s)) { /* color correction */
218 colcorval(ctmp, s);
219 multcolor(input[nfiles].expos, ctmp);
220 }
221 /* echo line */
222 putchar('\t');
223 fputs(s, stdout);
224 }
225
226
227 checkfile() /* ready a file */
228 {
229 int xinp, yinp;
230 register int i;
231 /* process header */
232 fputs(input[nfiles].name, stdout);
233 fputs(":\n", stdout);
234 getheader(input[nfiles].fp, tputs, NULL);
235 if (wrongformat) {
236 eputs(input[nfiles].name);
237 eputs(": not in Radiance picture format\n");
238 quit(1);
239 }
240 if (fgetresolu(&xinp, &yinp, input[nfiles].fp) < 0) {
241 eputs(input[nfiles].name);
242 eputs(": bad picture size\n");
243 quit(1);
244 }
245 if (xmax == 0 && ymax == 0) {
246 xmax = xinp;
247 ymax = yinp;
248 } else if (xinp != xmax || yinp != ymax) {
249 eputs(input[nfiles].name);
250 eputs(": resolution mismatch\n");
251 quit(1);
252 }
253 /* allocate scanlines */
254 for (i = 0; i < WINSIZ; i++)
255 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
256 }
257
258
259 init() /* perform final setup */
260 {
261 double l_colin(), l_expos();
262 register int i;
263 /* define constants */
264 varset(vnfiles, ':', (double)nfiles);
265 varset(vxmax, ':', (double)xmax);
266 varset(vymax, ':', (double)ymax);
267 /* set functions */
268 for (i = 0; i < 3; i++) {
269 funset(vcolexp[i], 1, ':', l_expos);
270 funset(vcolin[i], 1, '=', l_colin);
271 }
272 funset(vbrtexp, 1, ':', l_expos);
273 funset(vbrtin, 1, '=', l_colin);
274 }
275
276
277 combine() /* combine pictures */
278 {
279 EPNODE *coldef[3], *brtdef;
280 COLOR *scanout;
281 double d;
282 register int i, j;
283 /* check defined variables */
284 for (j = 0; j < 3; j++) {
285 if (vardefined(vcolout[j]))
286 coldef[j] = eparse(vcolout[j]);
287 else
288 coldef[j] = NULL;
289 }
290 if (vardefined(vbrtout))
291 brtdef = eparse(vbrtout);
292 else
293 brtdef = NULL;
294 /* allocate scanline */
295 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
296 /* set input position */
297 yscan = ymax+MIDSCN;
298 /* combine files */
299 for (ypos = yres-1; ypos >= 0; ypos--) {
300 advance();
301 varset(vypos, '=', (double)ypos);
302 for (xpos = 0; xpos < xres; xpos++) {
303 xscan = (long)xpos*xmax/xres;
304 varset(vxpos, '=', (double)xpos);
305 eclock++;
306 if (brtdef != NULL) {
307 d = evalue(brtdef);
308 if (d < 0.0)
309 d = 0.0;
310 setcolor(scanout[xpos], d, d, d);
311 } else {
312 for (j = 0; j < 3; j++) {
313 if (coldef[j] != NULL) {
314 d = evalue(coldef[j]);
315 } else {
316 d = 0.0;
317 for (i = 0; i < nfiles; i++)
318 d += colval(input[i].scan[MIDSCN][xscan],j);
319 }
320 if (d < 0.0)
321 d = 0.0;
322 colval(scanout[xpos],j) = d;
323 }
324 }
325 }
326 if (fwritescan(scanout, xres, stdout) < 0) {
327 perror("write error");
328 quit(1);
329 }
330 }
331 efree(scanout);
332 }
333
334
335 advance() /* read in data for next scanline */
336 {
337 extern double fabs();
338 int ytarget;
339 register COLOR *st;
340 register int i, j;
341
342 for (ytarget = (long)ypos*ymax/yres; yscan > ytarget; yscan--)
343 for (i = 0; i < nfiles; i++) {
344 st = input[i].scan[WINSIZ-1];
345 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
346 input[i].scan[j] = input[i].scan[j-1];
347 input[i].scan[0] = st;
348 if (yscan <= MIDSCN) /* hit bottom? */
349 continue;
350 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
351 eputs(input[i].name);
352 eputs(": read error\n");
353 quit(1);
354 }
355 if (fabs(colval(input[i].coef,RED)-1.0) > 1e-3 ||
356 fabs(colval(input[i].coef,GRN)-1.0) > 1e-3 ||
357 fabs(colval(input[i].coef,BLU)-1.0) > 1e-3)
358 for (j = 0; j < xmax; j++) /* adjust color */
359 multcolor(st[j], input[i].coef);
360 }
361 }
362
363
364 double
365 l_expos(nam) /* return picture exposure */
366 register char *nam;
367 {
368 register int fn, n;
369
370 fn = argument(1) - .5;
371 if (fn < 0 || fn >= nfiles)
372 return(1.0);
373 if (nam == vbrtexp)
374 return(bright(input[fn].expos));
375 n = 3;
376 while (n--)
377 if (nam == vcolexp[n])
378 return(colval(input[fn].expos,n));
379 eputs("Bad call to l_expos()!\n");
380 quit(1);
381 }
382
383
384 double
385 l_colin(nam) /* return color value for picture */
386 register char *nam;
387 {
388 int fn;
389 register int n, xoff, yoff;
390 double d;
391
392 d = argument(1);
393 if (d > -.5 && d < .5)
394 return((double)nfiles);
395 fn = d - .5;
396 if (fn < 0 || fn >= nfiles) {
397 errno = EDOM;
398 return(0.0);
399 }
400 xoff = yoff = 0;
401 n = nargum();
402 if (n >= 2) {
403 d = argument(2);
404 if (d < 0.0) {
405 xoff = d-.5;
406 if (xscan+xoff < 0)
407 xoff = -xscan;
408 } else {
409 xoff = d+.5;
410 if (xscan+xoff >= xmax)
411 xoff = xmax-1-xscan;
412 }
413 }
414 if (n >= 3) {
415 d = argument(3);
416 if (d < 0.0) {
417 yoff = d-.5;
418 if (yoff+MIDSCN < 0)
419 yoff = -MIDSCN;
420 if (yscan+yoff < 0)
421 yoff = -yscan;
422 } else {
423 yoff = d+.5;
424 if (yoff+MIDSCN >= WINSIZ)
425 yoff = WINSIZ-1-MIDSCN;
426 if (yscan+yoff >= ymax)
427 yoff = ymax-1-yscan;
428 }
429 }
430 if (nam == vbrtin)
431 return(bright(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
432 n = 3;
433 while (n--)
434 if (nam == vcolin[n])
435 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
436 eputs("Bad call to l_colin()!\n");
437 quit(1);
438 }
439
440
441 wputs(msg)
442 char *msg;
443 {
444 if (!nowarn)
445 eputs(msg);
446 }
447
448
449 eputs(msg)
450 char *msg;
451 {
452 fputs(msg, stderr);
453 }
454
455
456 #ifdef NIX
457
458 quit(code)
459 int code;
460 {
461 exit(code);
462 }
463
464 #else
465
466 quit(code) /* exit gracefully */
467 int code;
468 {
469 int status;
470 register int i;
471 /* close input files */
472 for (i = 0; i < nfiles; i++)
473 fclose(input[i].fp);
474 /* reap children */
475 while (wait(&status) != -1)
476 if (code == 0)
477 code = status>>8 & 0xff;
478 exit(code);
479 }
480
481 #endif
